7th May 2020, 03:29 | #944 | Link |
A couple bugs. 'I' wants to be |
When using the latest version, both the original Tesseract 3x and 5x on certain parts of the PGS subtitle file is zoomed in to far for me or the program to read what it is. Other then those problems the newer version seems to perform better. |
7th May 2020, 07:52 | #947 | Link | |
Thanks! Edit: Also adding the OCR corrected words in this format fixed the I issue. -| to I Sent from my Pixel 3a using Tapatalk Last edited by jlw_4049; 7th May 2020 at 07:58. |
7th May 2020, 11:47 | #948 | Link |
Nikse555
Regarding Ditto again. The issue seems to be worse that I thought: it is enough to just call the Ditto list on the screen (Win+W) having SE active to get the lock error. But it is only the main screen text box that gets locked - text boxes in Options and 'Import/OCR' window are immune to this.
Windows 8.1 x64 Magically yours Raistlin |
7th May 2020, 15:28 | #949 | Link | |
https://github.com/SubtitleEdit/subt...leEditBeta.zip |
7th May 2020, 22:38 | #951 | Link | |
It was zoomed in about 50% to much and focused on the left side. Here is the .sup I was able to reproduce it with. http://www.mediafire.com/file/r69v2z...kmk/sample.sup |
8th May 2020, 10:06 | #952 | Link | |
The OCR window back-from-minimized should be fixed in latest beta: https://github.com/SubtitleEdit/subt...leEditBeta.zip |
8th May 2020, 11:52 | #953 | Link |
Acid fr0g
@Nikse555,
please of the feature list I posted, at least put Italic on the right side of the character to input during binary compare. You don't know how many times I forget to enable/disable italic and delete part of the OCR database...
@turment on Telegram |
8th May 2020, 14:43 | #954 | Link |
Bug:
8th May 2020, 17:48 | #955 | Link |
Feature request: apply undo/redo to blocks of similar actions rather than to separate actions. For example, I adjust the boundaries of a subtitle using the waveform - by moving a boundary with the mouse. I perform one moving but SE considers it as a chain of small boundary shiftings. Hence, these actions replace the older ones in Undo stack. This is pointless as makes it harder to undo the whole action and makes it unable to undo the older actions.
I suggest to introduce a new setting: "Consider similar actions as separate if there are at least x seconds between them". Then, if x is set to 3, adjusts (e. g. by clicking on small arrows in 'Start time' or 'Duration' fields) if there were less than 3 secs between any two of them are considered as one action for Undo/Redo.
9th May 2020, 04:37 | #958 | Link | |
Wanted to post back and say the issue with it zooming in to far on the 'subtitle image' window has not been solved with the latest Beta. https://i.imgur.com/hX6gCfh.png It is still doing this here when you minimize and come back. Although it seems like the program is reading them just fine. EDIT: Maximizing the window seems to allow you to read it, however, staying in the smaller window it looks like the picture that I posted above. |
9th May 2020, 11:52 | #959 | Link | |
I checked at home. The latest version 3.5.15 NEXT, beta 51 scales this window correctly. For me, only the first stable version 3.5.15 had a problem with this. It looked exactly like u jlw_4049.
Sorry for my mistakes - I'm using a translator. |
