31st May 2019, 14:43 | #41 | Link |
I can't check if it is a real dependency. Only that it is not a VS plugin.
AVSRepoGUI // VSRepoGUI - Package Manager for AviSynth // VapourSynth VapourSynth Portable FATPACK || VapourSynth Database Last edited by ChaosKing; 31st May 2019 at 15:05. |
31st May 2019, 15:06 | #42 | Link |
Professional Code Monkey
If you're really insane you could parse the package json and see which files belong to a plugin and simply exclude them. I don't recommend that you do this.
31st May 2019, 15:12 | #43 | Link |
Hmm this would at least work for files that are in that package. The file is parsed and read anyway :P
31st May 2019, 21:45 | #44 | Link |
Better? Comparison is at filename level, maybe I will add hash compare someday so what w2xc-abc.dll would be also recognized.
🤨 Notice - Probably a Plugin dependency (not a VS Plugin): ------------------------------------------------------------ libfftw3-3.dll [belongs to FFTW3 Library] libfftw3f-3.dll [belongs to FFTW3 Library] libmfxsw64.dll [belongs to DGMVCSourceVS] libRandom.dll svml_dispmd.dll [belongs to Waifu2x] w2xc.dll [belongs to Waifu2x] w2xc-abc.dll
AVSRepoGUI // VSRepoGUI - Package Manager for AviSynth // VapourSynth VapourSynth Portable FATPACK || VapourSynth Database Last edited by ChaosKing; 31st May 2019 at 21:47. |
31st May 2019, 22:46 | #45 | Link | |
dependency files: ------------------------------------------------------------ libfftw3-3.dll [belongs to FFTW3 Library] libfftw3f-3.dll [belongs to FFTW3 Library] unidentify files: ------------------------------------------------------------ libRandom.dll w2xc-abc.dll |
31st May 2019, 23:37 | #46 | Link |
Checked Plugins: 118, Notices: 2, Errors: 1 . . . 🙂 Identified non-VapourSynth Plugins: ------------------------------------------------------------ libfftw3-3.dll [belongs to FFTW3 Library] libfftw3f-3.dll [belongs to FFTW3 Library] libmfxsw64.dll [belongs to DGMVCSourceVS] svml_dispmd.dll [belongs to Waifu2x] w2xc.dll [belongs to Waifu2x] 🤨 Unidentified DLLs (maybe also Plugin dependencies?): ------------------------------------------------------------ libRandom.dll w2xc-abc.dll
AVSRepoGUI // VSRepoGUI - Package Manager for AviSynth // VapourSynth VapourSynth Portable FATPACK || VapourSynth Database Last edited by ChaosKing; 31st May 2019 at 23:43. |
1st June 2019, 00:05 | #47 | Link |
I don't know about that, because the VMAF filter has a model folder that has like 90 files inside, that's going to be a long list.
The diagnostic test is use to check when something goes wrong, and I don't think those files are going to matter. |
6th June 2019, 16:24 | #48 | Link |
I worked a bit on the dependency stuff.
Question: I know that for example that "MSVCP140.dll" is a "Visual C++ Redistributable" Runtime dll, but can I know from which Runtime it is? from 2015, 2017? Or replaces the 2017 dll the 2015 version? Code:
🔥 Error 126 - A DLL dependency is probably missing: ------------------------------------------------------------ bilateralGPU.dll requires following dependencies (one of these should be missing): - opencv_core320.dll - opencv_cudaimgproc320.dll - VCRUNTIME140.dll - api-ms-win-crt-heap-l1-1-0.dll - api-ms-win-crt-runtime-l1-1-0.dll - api-ms-win-crt-math-l1-1-0.dll opencv_core320.dll requires following dependencies (one of these should be missing): - cudart64_80.dll - MSVCP140.dll - CONCRT140.dll - VCRUNTIME140.dll - api-ms-win-crt-heap-l1-1-0.dll - api-ms-win-crt-stdio-l1-1-0.dll - api-ms-win-crt-string-l1-1-0.dll - api-ms-win-crt-runtime-l1-1-0.dll - api-ms-win-crt-math-l1-1-0.dll - api-ms-win-crt-convert-l1-1-0.dll - api-ms-win-crt-environment-l1-1-0.dll - api-ms-win-crt-time-l1-1-0.dll - api-ms-win-crt-filesystem-l1-1-0.dll
AVSRepoGUI // VSRepoGUI - Package Manager for AviSynth // VapourSynth VapourSynth Portable FATPACK || VapourSynth Database Last edited by ChaosKing; 6th June 2019 at 16:29. |
6th June 2019, 16:53 | #49 | Link |
2019 replaces both 2017 and 2015.
8th June 2019, 18:52 | #51 | Link |
It supports portable version currently only via a "vsrepogui.json" file. (You can set relative paths, but still need python in path)
AVSRepoGUI // VSRepoGUI - Package Manager for AviSynth // VapourSynth VapourSynth Portable FATPACK || VapourSynth Database Last edited by ChaosKing; 8th June 2019 at 18:54. |
9th June 2019, 09:21 | #53 | Link |
Nothing wrong with it. I needed a custom path for Scripts, so I quickly implement it via a file. This way it's more universal and easier to test around for me. I will add autodetect maybe in the future.
12th June 2019, 12:27 | #54 | Link |
New release https://github.com/theChaosCoder/VSR...leases/tag/0.7
(You need listpedeps if you also want to see the dependencies https://github.com/brechtsanders/pedeps)
13th June 2019, 15:44 | #56 | Link |
I have it from here https://flyclipart.com/art-pusheen-c...een-png-204717
CC BY-NC 4.0 Licence ✓ Free for personal use ✓ Attribution not required ✓ Unlimited download
14th June 2019, 15:23 | #57 | Link | |
Some real feedback, I'm pretty new to VS and this was really helpful when trying to find dependencies without having to go look on github (didn't try the normal VSRepo). Some things that were a bit strange to me in the UI: 1. The height of each row is not fixed so it looks pretty ugly when scrolling with the text jumping around. Would probably look better to have all of them the same (maximum I guess) height. 2. The namespaces are links (or at least blue and underlined) but don't really do anything when clicked on. 3. There's a description when you click on a row but I would prefer if this was visible by default, that way you don't need to click on everything to see what it is. Anyway these are nitpicky suggestions, I didn't have any real problems when using it. |
14th June 2019, 15:39 | #58 | Link |
1. Ok will change it
2. Yeah I forgot about it. I wanted to link them to the vsrepo json files on github, but I'm open for other suggestions. 3. I will look into it. It seems if you click on any row and then mark everything with STRG+A you can open every hidden row.
9th July 2019, 01:34 | #59 | Link |
New release (see first page)
- Should start faster now (async plugin read on start) - Should detect all possible VS installations now (for all and per user) - Add some additional diagnostic information - All rows have the same height now (better scrolling experience) - Namespace links now opens its meta package on github
9th July 2019, 08:59 | #60 | Link | |
Hi, ChaosKing I suggest you use it with caution. I specifically contacted the platform, they said that this is a user-uploaded image, they can not guarantee copyright issues. Just like this, https://www.netclipart.com/isee/ibiJ...heen-birthday/, it is possible to complain directly. |
