Old 6th March 2018, 14:51   #15621  |  Link
gabbett1
Here's the screenshot. In that shot, server 3 was online when I started to get the screenshot but went offline. Server 1 goes offline all the time as well which is the host PC.
gabbett1 is offline   Reply With Quote
Old 6th March 2018, 16:37   #15622  |  Link
byteshare
ByteShare
byteshare's Avatar
Please try this:
Originally Posted by GZZ View Post
Post you image to a image service and post the link. Attachment will never be approved.
Have you tried manually starting the encoding servers from the encoding clients a few times?
Old 6th March 2018, 18:42   #15623  |  Link
gabbett1
Please try this:
No, I haven't.
Old 6th March 2018, 21:23   #15624  |  Link
MaistroX
Fist and foremost to Atak_Snajpera regardning Windows 10 and RipBot264, but IF anyone else can help, Iīm MORE then glad!
I have had RipBot264 and it has worked fine for several years now on Windows 7, but had a crash here and was forced by HW and so on to install Windows 10 Pro.
After installation I tryed RipBot264 and it ALLWAYS crash somewere in the middle of Pass 2 so the next screen I see it that H.264 or H.265 has crashed (see attached Picture).
After I Close that popup screen, RipBot264 remuxes the Movie and it usualy is around 40~ mins, NOT the hole Movie.
(https://imgur.com/a/Tpnjr)[QUOTE]
Please help!!!
MaistroX is offline   Reply With Quote
Old 6th March 2018, 22:46   #15625  |  Link
byteshare
ByteShare
byteshare's Avatar
[QUOTE=MaistroX;1835669]Fist and foremost to Atak_Snajpera regardning Windows 10 and RipBot264, but IF anyone else can help, Iīm MORE then glad!
Please help!!!
Does it do the same thing in DE mode? I have issues with FFMPEG crashing but just need to start the server if it fails to many times.
Old 6th March 2018, 23:51   #15626  |  Link
MaistroX
DE Mode?
I just use it and has Always done it localy.
Old 7th March 2018, 11:59   #15627  |  Link
MerolaC
Man, thank you so much for this!
The HDR to SDR tone mapping is God sent!
My question is, how you accomplish this? Can you do some insight?
Thank you again!
MerolaC is offline   Reply With Quote
Old 7th March 2018, 12:31   #15628  |  Link
@MaistroX
x264/x265 crashing may suggest that your CPU or/and memory are not stable!
@MerolaC
https://forum.doom9.org/showthread.p...36#post1827936
Old 7th March 2018, 16:42   #15629  |  Link
MerolaC
Amazing stuff!
Thank you.
Old 7th March 2018, 17:51   #15630  |  Link
MaistroX
Thx, I will look into IF itīs stable @normal Clock!
Is there a way to get RipBot264 to use all (or be able to set) CPU Power on ex a Ryzen 1800X, as Itīs now it uses not more then 40%->65% max?
See attached Pictures
Regards MaistroX
@MaistroX
@MerolaC
Old 7th March 2018, 18:26   #15631  |  Link
DE mode. In your case 2 servers will be enough.
https://forum.doom9.org/showthread.p...50#post1831550
Old 7th March 2018, 18:54   #15632  |  Link
MaistroX
Was that info a answer to my question? 😉
I only use one PC here so is DE mode still an option?
Regards MaistroX
Old 7th March 2018, 20:05   #15633  |  Link
https://forum.doom9.org/showthread.p...99#post1831599
Old 7th March 2018, 21:49   #15634  |  Link
GZZ
When doing batch job and setting it to autocrop and the movie is without black bars to crop, then it output this in the avs script: video=Crop(video,0,0,-0,-0), not sure if it hurts performance in anyway, just look a bit odd to even write the line.
GZZ is offline   Reply With Quote
Old 8th March 2018, 02:52   #15635  |  Link
Viper714
Posting Images
For those of you trying to post images on this site, it will not or ever get approval. You need to place the image on a online image repository and then paste the link in your post so it will show.
I use photobucket. You can create a FREE account and then upload your images to this repository. After uploading you can copy the "Direct Link" and paste that "link" in your post or you can copy the IMG code and paste directly. So to help explain this a little better, here is a YouTube LINK for a quick tutorial. It is a little bit old, but you should be able to find the same functionality in the latest version.
Hope that helps those of you trying to display your images / screenshots.
Viper714 is offline   Reply With Quote
Old 8th March 2018, 20:59   #15636  |  Link
MaistroX
Just Tryed DE Mode , and it direct getīs me this error ->
"FFVideoSource: Failed to open '\\RWDA-2018\TBOEM_2017-Test-1-005.mkv'
(C:\Temp\RipBot264temp\job4\Chunks\getinfo.avs, line 7)
getinfo.avs file here -> http://s000.tinyupload.com/?file_id=...94132656792224
How to fix this?
Regards
Old 9th March 2018, 12:14   #15637  |  Link
How to fix this?
Regards
Something went wrong because It should be
\\RWDA-2018\RipBot264temp\job4\video.mkv
You will have to show me step by step what you do exactly (video would be very helpful!)
Old 9th March 2018, 16:28   #15638  |  Link
byteshare
ByteShare
byteshare's Avatar
x265_x64.exe error
Trying to help a friend but not sure what is causing this since I've never had this issue, just FFMPEG issues:
https://cdn.discordapp.com/attachmen...00/unknown.png
These are the settings used:
--preset slow --profile main10 --multi-pass-opt-analysis --multi-pass-opt-distortion --output-depth 10 --aq-mode 3 --aq-strength 0.55 --me 3 --subme 3 --rc-lookahead 50 --no-strong-intra-smoothing --no-constrained-intra --deblock -1:-1 --psy-rd 2.0 --no-sao --bitrate 1125
What else needs to be known?
Old 9th March 2018, 18:58   #15639  |  Link
Check CPU and memory stability. You must be 100% sure that it is not an OC issue.
Old 9th March 2018, 19:52   #15640  |  Link
byteshare
ByteShare
byteshare's Avatar
Thank you, will have him do some RAM and CPU checks. No OC (Over Clock).
