Old 11th August 2010, 14:44   #9141  |  Link
Originally Posted by AcePuppy View Post
JDobbs: The media can't be bad, after everything is ready to burn before even put on CD, I've tested to see if it locks at the same point as it does on the PS3 and standalone and it does on the computer.
If it helps even more, this is on a fully refresh Windows 7 machine, pretty bare. This occured on Windows XP as well. There is no freeze after a complete rip using AnyDVD only after rebuild is complete.
Run INSPECT.EXE and post the results.
Old 11th August 2010, 14:51   #9142  |  Link
AcePuppy
Will do when I get off work today.
AcePuppy is offline   Reply With Quote
Old 11th August 2010, 16:16   #9143  |  Link
deank
Programmer (or just 教务长)
deank's Avatar
Originally Posted by extravirgin View Post
If this isn't a bug and I'm just being dumb tell me and I'll leave you alone
I've been playing around with BD-Rebuilder for the last couple of days to create a full backup to BD-9. As far as I'm aware I've followed the instructions to the letter and get OK checks for Haali etc. I also allow BD RB to burn using ImgBurn. On completion it appears I've created a BD-9 but every disk I create will only show up as 'Data' on my PS3. I don't seem to get any errors in the log file either. Well, not that I'm aware.
So it's either a bug, the source is at fault or I'm doing something wrong. Any help would be appreciated.
When using Playstation 3 you have few options:
FULL BACKUP - use BD-R/RE media
MOVIE ONLY BACKUP - use BD-R/RE or DVD-R media
I believe this is your case:
FULL BACKUP with NO JAVA (BD-J) - use DVD media (BD5/BD9) but you'll have to patch the output (index.bdmv) with goBD tool or AVCHD patcher and PS3 will recognize it as AVCHD
FULL BACKUP with JAVA (BD-J) can't be used when written to DVD media.
Dean
Old 11th August 2010, 16:34   #9144  |  Link
DK
DK's Avatar
I have experienced some "strange" audio UPconversion with 34.06 (havent tried latest 07 yet):
Title "Breaking Up" has (according to tsMuxeR) these two audio streams I wanted to keep:
German DD 5.1 448kbps
English DD 2.0 192
Rebuilder output was:
German 640kbps
English 224kbps
Tried two times as I wanted to make sure I had no weird settings in the setup, which look like this:
Usually BD RB downconverts to 640 or 448 if selected but was has changed now?
Here are the logs:
[15:23:09] BD Rebuilder v0.34.06 (beta)
  - Source:  BREAKING_UP
  - Input BD size: 14,28 GB
  - Approximate total content: [01:25:55.000]
  - Target BD size: 7,84 GB
  - Windows Version: 6.1 [7600]
  - MOVIE-ONLY mode enabled
  - Quality: Good (Very Fast), CRF
[15:23:09] PHASE ONE, Encoding
 - [15:23:09] Extracting A/V streams [VID_00002]
 - [15:27:53] Reencoding: VID_00002 (1 of 1)
 - [15:27:53] Collecting video information
   - Source Video: MPEG-2, 1920x1080
   - Rate/Length: 25,000fps, 128.875 frames
 - [15:27:54] Performing CRF Prediction...
   - Analyzing 23,94 16,97 20,24 [19,94]
 - [15:31:31] Encoding using constant rate factor.
 - [17:03:11] Video Encode complete
 - [17:03:11] Reencoding audio tracks (if req'd)
 - [17:05:10] Multiplexing M2TS
[17:09:05]PHASE ONE complete
[17:09:05]PHASE TWO - Rebuild Started
 - [17:09:05] Rebuilding AVCHD file Structure
[17:13:23] - Encode and Rebuild complete
 - WORKFILES folder removed.
[17:13:24]JOB: BREAKING_UP finished.
[Status]
LABEL=BREAKING_UP
VERSION=v0.34.06 (beta)
SOURCE_SIZE=15328978944
SOURCE_VIDEO_SIZE=15328978944
TARGET_SIZE=8422162432
REDUCTION=.549427490426332
RESIZE_1080=0
AUDIO_TO_KEEP=deu;eng;
SUBS_TO_KEEP=deu;eng;
BACKUP_MODE=1
MOVIEONLY_TYPE=0
QUICK=0
ENCODE_STEP=0
COMPLETED=1
REBUILD_COMPLETE=1
[00002]
AUDIO=110
PGS=1
M2TS_TARGET=8422162432
NSIZE=7286132736
FLINK=0
MLINK=0
Old 11th August 2010, 16:44   #9145  |  Link
English DD 2.0 192
German 640kbps
English 224kbps
Here are the logs:
[Status]
LABEL=BREAKING_UP
RESIZE_1080=0
BACKUP_MODE=1
MOVIEONLY_TYPE=0
QUICK=0
ENCODE_STEP=0
COMPLETED=1
REBUILD_COMPLETE=1
[00002]
AUDIO=110
PGS=1
NSIZE=7286132736
FLINK=0
MLINK=0
That's normal. BD-RB uses 224Kbs for stereo audio because (due to muxing) it uses exactly the same amount of space as a 192Kbs encode. I think you may be mistaken about the original German stream being 448Kbs. Blu-ray normally uses 640Kbs, and in HD the core is 640Kbs (unless it has been preprocessed in some way).
Old 11th August 2010, 16:54   #9146  |  Link
extravirgin
Dean
Dean you're a star. I'll give it a go.
extravirgin is offline   Reply With Quote
Old 11th August 2010, 17:14   #9147  |  Link
DK
DK's Avatar
Thanks for the quick reply.
First let me say the material has not been preprocessed - AnyDVD was used and that's all.
The bigger of the two DD streams is 448 according to tsmuxer and TMT3 also states this bitrate during playback:
Dont be confused by the fact that tsMuxeR declares stream #2 as GERMAN, which in fact is wrong - it's English.
I DEselected the LPCM stream so normally it cannot be the source for a downconversion to 640kbps which leaves me to assuming that the 448kbps stream was changed.
The BD output looks like this:
Old 11th August 2010, 17:20   #9148  |  Link
Hmmm... I want believe that TSMUXER is confused about the bitrate. 448Kbs is a perfectly legal rate for blu-ray, but I've never seen one -- but, as the master says, there are more things on heaven and earth than are dreamt of in my philosophy.
Old 11th August 2010, 17:41   #9149  |  Link
DK
DK's Avatar
TDK for example has a 448kbps GERMAN DD 5.1 stream.
And it was not only tsMuxeR but as I said before: TMT3 said so as well and here is a screenshot of what MediaInfo says about the orignal m2ts:
Old 11th August 2010, 18:05   #9150  |  Link
bluerip
H.264 stream does not contain fps field. Muxing fps=23.976
Who can help me with this error?
I have tried the fullbackup without any error.
It doesn't matter which target size I choose on movie only, the error occurs.
[06:53:55] BD Rebuilder v0.34.07 (beta)
  - Source:  ANGELS_AND_DEMONS_ORIGINAL
  - Input BD size: 33,59 GB
  - Approximate total content: [02:18:37.308]
  - Target BD size: 4,36 GB
  - Windows Version: 5.1 [2600]
  - SHUTDOWN at completion enabled
  - Auto Quality: High Quality (Default), Two Pass
  - Audio Settings: AC3=1 DTS=1 HD=0 Kbs=448
[06:53:56] PHASE ONE, Encoding
 - [06:53:56] Extracting A/V streams [VID_00505]
   - Extracting A/V to M2TS [VID_00505]
   - Extracting A/V from M2TS [VID_00505]
 - Error in attempt to extract audio/subs.
 - H.264 stream does not contain fps field. Muxing fps=23.976
[18:47:35] - Failed to retrieve audio, aborted
[Options]
MODE=1
ENCODE_QUALITY=2
ONEPASS_ENCODING=0
AUTO_QUALITY=1
TARGET_SIZE=4469
AUDIO_TO_KEEP=deu;
SUBS_TO_KEEP=deu;
SD_CONVERT=0
OPEN_GOP=0
RESIZE_1080=0
DEINTERLACE=0
DTS_REENCODE=1
AC3_REENCODE=1
AC3_640=0
AC3_192=0
KEEP_HD_AUDIO=0
AVCHD=1
REMOVE_WORKFILES=0
MOVIE_ONLY_LOOP=1
REMOVE_OUTPUT=0
USE_FILTERS=0
AUDIO_TRACK_LIMIT=0
SUBTITLE_TRACK_LIMIT=0
CUSTOM_TARGET_SIZE=23450
[Paths]
SOURCE_PATH=D:\FILME\ANGELS_AND_DEMONS_ORIGINAL\
WORKING_PATH=F:\FILME\GESCHRINKTE FILME\ANGELS AND DEMONS_5GB_03407_FORCED\
Inspect.exe shows all things ok.
- AVISYNTH Version: 2.5.7.0, Ok
- HAALI Splitter:  Ok
- FFDSHOW: 3326, Ok
- FFDSHOW VC-1 set "disabled", WMP11, Ok
- FFDSHOW MPEG2 set to "libavcodec":  Ok
- FFDSHOW AVC set to "libavcodec":  Ok
- BD Rebuilder v0.34.0.7, Ok
- X264:  Ok
- AFTEN:  Ok
- FAAC:  Ok
- MP4BOX:  Ok
- WAVI:  Ok
- TSMUXER:  Ok
bluerip is offline   Reply With Quote
Old 11th August 2010, 18:53   #9151  |  Link
DK
DK's Avatar
Could you try with a working path that has NO spaces?
Old 11th August 2010, 19:20   #9152  |  Link
MilesAhead
MilesAhead's Avatar
This reminds me. On my Vista64 SP1 machine, inspect.exe always crashes with error 13 "Type Mismatch" even if BDRB works perfectly. inspect.exe works as expected on Windows Seven 32 bit.
It's never given any report other than the error 13 dialog on the 64 bit PC.
"I don't want to belong to any club that would have me as a member."
- Groucho Marx
MilesAhead is offline   Reply With Quote
Old 11th August 2010, 19:43   #9153  |  Link
bluerip
Nope.
Same error message.
[20:13:14] BD Rebuilder v0.34.07 (beta)
[20:13:18] PHASE ONE, Encoding
 - [20:13:18] Extracting A/V streams [VID_00505]
[20:37:46] - Failed to retrieve audio, aborted
[Options]
MODE=1
ENCODE_QUALITY=2
ONEPASS_ENCODING=0
AUTO_QUALITY=1
TARGET_SIZE=4469
AUDIO_TO_KEEP=deu;
SUBS_TO_KEEP=deu;
SD_CONVERT=0
OPEN_GOP=0
RESIZE_1080=0
DEINTERLACE=0
DTS_REENCODE=1
AC3_REENCODE=1
AC3_640=0
AC3_192=0
KEEP_HD_AUDIO=0
AVCHD=1
REMOVE_WORKFILES=0
MOVIE_ONLY_LOOP=1
REMOVE_OUTPUT=0
USE_FILTERS=0
AUDIO_TRACK_LIMIT=0
[Paths]
WORKING_PATH=F:\FILME\SHRINKED_MOVIES\ANGELS_AND_DEMONS_5GB_03407_FORCED\
Old 11th August 2010, 20:46   #9154  |  Link
DK
DK's Avatar
Which tool did you use for extracting the content?
Normally Angels & Demons should be more than just [VID_00505] so I wonder if some sort of preprocessing took place.
This is what my log looked like:
[01:37:06] PROCESSING BATCH FILE [1]
[04:49:23] BD Rebuilder v0.30.04 (beta)
  - Target BD size: 7,72 GB
  - One Pass ABR Mode enabled
  - Audio Settings: AC3=0 DTS=1 HD=1 Kbs=448
[04:49:23] PHASE ONE, Encoding
 - [04:49:23] Extracting A/V streams [VID_00505]
 - [04:59:52] Reencoding: VID_00505 (1 of 34)
 - [05:35:13] Extracting A/V streams [VID_00506]
 - [05:35:23] Reencoding: VID_00506 (2 of 34)
 - [05:39:06] Extracting A/V streams [VID_00509]
 - [05:39:12] Reencoding: VID_00509 (3 of 34)
 - [05:41:30] Extracting A/V streams [VID_00511]
 - [05:41:41] Reencoding: VID_00511 (4 of 34)
 - [05:46:30] Extracting A/V streams [VID_00512]
 - [05:46:37] Reencoding: VID_00512 (5 of 34)
 - [05:49:16] Extracting A/V streams [VID_00514]
 - [05:50:22] Reencoding: VID_00514 (6 of 34)
 - [06:19:35] Extracting A/V streams [VID_00515]
 - [06:19:40] Reencoding: VID_00515 (7 of 34)
 - [06:21:53] Extracting A/V streams [VID_00517]
 - [06:21:56] Reencoding: VID_00517 (8 of 34)
 - [06:22:47] Extracting A/V streams [VID_00518]
 - [06:22:50] Reencoding: VID_00518 (9 of 34)
 - [06:23:58] Extracting A/V streams [VID_00520]
 - [06:24:50] Reencoding: VID_00520 (10 of 34)
 - [06:46:19] Extracting A/V streams [VID_00521]
 - [06:46:24] Reencoding: VID_00521 (11 of 34)
 - [06:48:17] Extracting A/V streams [VID_00523]
 - [06:48:25] Reencoding: VID_00523 (12 of 34)
 - [06:51:29] Extracting A/V streams [VID_00524]
 - [06:51:33] Reencoding: VID_00524 (13 of 34)
 - [06:52:46] Extracting A/V streams [VID_00526]
 - [06:53:52] Reencoding: VID_00526 (14 of 34)
 - [07:21:30] Extracting A/V streams [VID_00527]
 - [07:21:31] Reencoding: VID_00527 (15 of 34)
 - [07:22:06] Extracting A/V streams [VID_05032]
 - [07:22:49] Reencoding: VID_05032 (16 of 34)
 - [07:39:47] Extracting A/V streams [VID_00530]
 - [07:39:49] Reencoding: VID_00530 (17 of 34)
 - [07:40:24] Extracting A/V streams [VID_00532]
 - [07:40:30] Reencoding: VID_00532 (18 of 34)
 - [07:43:11] Extracting A/V streams [VID_00533]
 - [07:43:15] Reencoding: VID_00533 (19 of 34)
 - [07:44:28] Extracting A/V streams [VID_00535]
 - [07:44:37] Reencoding: VID_00535 (20 of 34)
 - [07:48:22] Extracting A/V streams [VID_00536]
 - [07:48:27] Reencoding: VID_00536 (21 of 34)
 - [07:50:19] Extracting A/V streams [VID_00538]
 - [07:50:26] Reencoding: VID_00538 (22 of 34)
 - [07:52:59] Extracting A/V streams [VID_00539]
 - [07:53:04] Reencoding: VID_00539 (23 of 34)
 - [07:55:16] Extracting A/V streams [VID_00542]
 - [07:55:19] Reencoding: VID_00542 (24 of 34)
 - [07:56:49] Extracting A/V streams [VID_00545]
 - [07:57:06] Reencoding: VID_00545 (25 of 34)
 - [08:04:20] Extracting A/V streams [VID_05033]
 - [08:04:22] Reencoding: VID_05033 (26 of 34)
 - [08:04:53] Extracting A/V streams [VID_00548]
 - [08:05:14] Reencoding: VID_00548 (27 of 34)
 - [08:13:34] Extracting A/V streams [VID_00550]
 - [08:14:28] Reencoding: VID_00550 (28 of 34)
 - [08:35:36] Extracting A/V streams [VID_00551]
 - [08:35:38] Reencoding: VID_00551 (29 of 34)
 - [08:36:22] Extracting A/V streams [VID_00553]
 - [08:36:44] Reencoding: VID_00553 (30 of 34)
 - [08:45:09] Extracting A/V streams [VID_00554]
 - [08:45:13] Reencoding: VID_00554 (31 of 34)
 - [08:46:43] Extracting A/V streams [VID_00556]
 - [08:48:16] Reencoding: VID_00556 (32 of 34)
 - [09:26:20] Extracting A/V streams [VID_00557]
 - [09:26:24] Reencoding: VID_00557 (33 of 34)
 - [09:27:28] Extracting A/V streams [VID_00559]
 - [09:28:13] Reencoding: VID_00559 (34 of 34)
[09:41:58]PHASE ONE complete
[09:41:58]PHASE TWO - Rebuild Started
 - [09:41:58] Rebuilding BD file Structure
[09:53:26] - Encode and Rebuild complete
[09:53:26]JOB: ANGELS_AND_DEMONS finished.
Old 11th August 2010, 20:58   #9155  |  Link
bluerip
AnyDVD
In my BD stream window, i can see also the files as you have.
With fullbackup mode there were no issues, only with movie-only mode.
I have started now again with choosing the play list 00001. But I guess this will used automaticly, right?
Old 11th August 2010, 21:21   #9156  |  Link
DK
DK's Avatar
I'm not sure which playlist to pick but the movie length seemed to be correct compared to what my version looked like and I also did a movie-only back up as you can see.
Old 11th August 2010, 21:32   #9157  |  Link
bluerip
I meant this, see the screenshot.
How I can fix this?
Old 11th August 2010, 21:36   #9158  |  Link
KarstenS
Ok. Cars is now ready. It did rebuild completely. But I had to confirm many oversize messages ang got round about 9,2GB oversize (target size 14,5GB, size in real 23,7GB).
Playback run with following issues:
- Main movie has activated english subtitles (with original disk no sub is active without user activity)
- playback completely hang up at the movie parts, that are more than one time on the disk but with different in movie text translations (ok, the first part at beginning with happy birthday 20 years pixar not)
I have to skip them to continue playback.
In the short movie "One man band" this works correctly.
The other things seems to work.
Log and INF I put into attachment.
Will do Madagascar 2 now again to see how much the other fix solves problems (same issue as in Monster vs. Aliens)
PS: Is there some problem with the forum software? I can't see since today screenshots anymore in Iron (is a "spyware" free version of the Chrome brwoser).
KarstenS is offline   Reply With Quote
Old 11th August 2010, 21:46   #9159  |  Link
DK
DK's Avatar
How I can fix this?
Stupid me.
I didnt realise that of couse your conversion stopped after trying to (unsuccessfully) extract [VID_00505].
Can't judge your screenshot yet so we'll wait for approval.
Maybe you could have a look at my posts concerning Angels & Demons in the meantime: CLICK
Old 11th August 2010, 22:22   #9160  |  Link
bluerip
Stupid me.
I have tried the same movie with language english.
It's not finished, but you can see it further than with German.
[22:40:06] BD Rebuilder v0.34.07 (beta)
[22:40:07] PHASE ONE, Encoding
- [22:40:07] Extracting A/V streams [VID_00505]
- [23:06:59] Reencoding: VID_00505 (1 of 34)
- [23:06:59] Collecting video information
- Rate/Length: 23,976fps, 13.107 frames
- Bitrate: 3.779 Kbs
- [23:06:59] Reencoding: VID_00505, Pass 1 of 2
What's wrong on German?
I need the German language with forced subs.
In the setting I have marked only the German on the audio and subtitle languages.
Limit to one track for each language is not marked.
I am confused....
