Old 25th January 2014, 23:41   #18941  |  Link
slvrsrfr
Avast flagged it too -screenshot attached:
slvrsrfr is offline   Reply With Quote
Old 26th January 2014, 00:08   #18942  |  Link
Ch3vr0n
@jdobbs: that's what I got from the site when I looked up what asprotect was. Read it was software to protect code so knew it was safe. Especially since that evo-gen is a generic message for suspected virus. First time it gets flagged, weird thing is with avast is that when you scan the zip file directly it does not trigger. The alert only triggers when extracting the zip, making it even more obvious it is a falls positive if the av suite can't give consecutive results
Verstuurd vanaf mijn Nexus 7 met Tapatalk
Old 26th January 2014, 03:18   #18943  |  Link
I finished my scan and AVG Antivirus tells me everything is clean. I really, really, really hate antivirus packages. The only thing worse than an antivirus package is a virus -- and I'm not sure it is that much worse (considering that both can prevent your computer from working properly).
False positive -- send a nasty e-mail to your A/V provider and tell them to get it together.
Old 26th January 2014, 03:32   #18944  |  Link
Ch3vr0n
already did, via the link they provide in the "popup" when they detect a "threat" and via support ticket. In the mean time added the executable to the exclusion list. I remember you changed the name from bdrebuilder.exe to BDRB.exe due to an AV doing just that. Generating false positive
Old 26th January 2014, 03:34   #18945  |  Link
RobertM
The only worse than an antivirus package is a virus
I think Oscar Wilde said that first
Old 26th January 2014, 05:24   #18946  |  Link
HWK
HWK's Avatar
I finished my scan and AVG Antivirus tells me everything is clean. I really, really, really hate antivirus packages. The only worse than an antivirus package is a virus -- and I'm not sure it is that much worse (considering that both can prevent your computer from working properly).
If that is not enough, here is post created by myce user who is not happy with avast, and shows how far companies will go to annoy end user.
http://club.myce.com/f186/virus-checkers-irritating-pop-up-ads-335156/
Old 26th January 2014, 13:28   #18947  |  Link
brunchto
I discovered that issue a couple of days ago. It has been corrected for the next release (later today or tomorrow).
Thanks. it works fine now.
I've noticed that when making movie only film, angle selection works fine if i do a backup, but not if i do a batch backup.
in the batch info, MAIN_MPLS_ANGLE=0 instead of 3 if i 've select angle 4 of the playlist. i've changed it manually in the BDBATCH.INI and it seems to be ok after that.
brunchto is offline   Reply With Quote
Old 26th January 2014, 15:39   #18948  |  Link
Thanks for letting me know. I'll check it out.
Old 26th January 2014, 16:50   #18949  |  Link
colinhunt
Angles reminded me of this: I did a full backup of Re-Animator special edition (German edition) which has a Multi-angle Storyboards special feature on it. For some reason 0.45.05 discarded angle 2 from it. Could it be because source is MPEG-2 720x576?
Old 26th January 2014, 16:59   #18950  |  Link
Originally Posted by colinhunt View Post
Angles reminded me of this: I did a full backup of Re-Animator special edition (German edition) which has a Multi-angle Storyboards special feature on it. For some reason 0.45.05 discarded angle 2 from it. Could it be because source is 720x576?
It sounds like PiP. Are you saying the secondary (PiP) video was 720x576?
Old 26th January 2014, 17:07   #18951  |  Link
colinhunt
Something else I recently noticed. A full backup came out slightly oversized so I decided to re-encode only one small m2ts, then replace m2ts and clipinf of the original backup with files from the re-encode.
Imported the m2ts into BD-RB (import > video files) but after it had collected a/v streams and built a pseudo-BD source, the Stream window listed only video. The source has 24bit 48kHz PCM audio. Log is of no help:
[17:43:05] Importing M2TS: 00004
- Preparing M2TS for processing...
- Collecting audio/video streams from source...
- Building pseudo-BD source structure...
[17:43:26] Video import completed successfully.
The 00000.m2ts file in the IMPORTS/00004/BDMV/STREAM directory contains a video stream only.
Old 26th January 2014, 17:09   #18952  |  Link
colinhunt
Sorry for being unclear. No, it's not a PiP feature. It's a multi-angle feature, a relic from DVD era, where you choose which "angle" you view by pressing the Angle button on the remote. It's like two full-screen video streams and you choose which one to view. Either/or, instead of one inside the other.
Source stream is MPEG-2 encoded 720x576 and includes two alternative video streams (angles). Oddly enough I can see no sign of it when examining the file in MediaInfo, but the Angle button works and switches between a storyboard and final scene.
update: figured out why MediaInfo claims there's only one video stream in the source. Because there is only 1 video stream in the source file! Multi-angle feature is done by having the "angles" in two separate files: 00408.m2ts and 00410.m2ts.
Why switching angles does not work in the full back-up, I don't have the foggiest.
Old 26th January 2014, 22:04   #18953  |  Link
gonca
- Fixed a problem with some multi-part sources
that could result in a "ERROR in attempt to
mux (MKVMERGE)" error when ALTERNATE output
has been selected.
[01/26/14] BD Rebuilder v0.46.05 (beta)
[14:49:53] Source: CHERNOBYL_DIARIES_00100
- Input BD size: 14.73 GB
- Approximate total content: [01:25:53.690]
- Windows Version: 6.1 [7601]
- Mode: MKV Container, 1920x1080, Intact Audio
- Decoding/Frame serving: DGDecNV [4-way]
[14:49:53] PHASE ONE, Encoding
- [14:49:53] Processing: VID_00083 (1 of 1)
- [14:49:53] Extracting A/V streams [VID_00083]
- [14:51:24] Reencoding video [VID_00083]
- Rate/Length: 23.976fps, 123,565 frames
- [14:51:24] Reencoding: VID_00083, Pass 1 of 1
- [15:52:21] Video Encode complete
- [15:52:21] Processing audio tracks
[15:52:21]PHASE ONE complete
[15:52:21]PHASE TWO - Rebuild Started
- [15:52:21] Building ALTERNATE OUTPUT Structure
- ERROR in attempt to mux (MKVMERGE)
[15:52:37] - Failed to REBUILD
[Status]
LABEL=CHERNOBYL_DIARIES
VERSION=v0.46.05 (beta)
SOURCE_SIZE=15812855808
SOURCE_VIDEO_SIZE=15812855808
TARGET_SIZE=34603008000
REDUCTION=2.18828328166338
RESIZE_1080=0
RESIZE_1440=0
AUDIO_TO_KEEP=eng;
KEEP_HD_AUDIO=-1
SUBS_TO_KEEP=
BACKUP_MODE=1
MOVIEONLY_TYPE=6
USE_LAVF=0
INSTANCES=4
DGDECNV=-1
SSIF_MODE=0
QUICK=0
ENCODE_STEP=0
COMPLETED=1
REBUILD_COMPLETE=0
[00083]
AUDIO=1000
PGS=00000
APULLDOWN=0
S1440=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=34603008000
SPLITS=4
NSIZE=0
FLINK=0
MLINK=0
Alternate output muxing issue popped up again
One file with a 4 way split for multi processing
Old 26th January 2014, 23:38   #18954  |  Link
That wouldn't be related. The issue I fixed had to do with multiple part sources and your report only has one.
What happens if you eliminate the 4-way processing?
Old 26th January 2014, 23:41   #18955  |  Link
gonca
Trying it now. Will know the results in about 20 minutes
Old 27th January 2014, 00:13   #18956  |  Link
gonca
Still fails
[17:03:01] Source: CHERNOBYL_DIARIES_00100
[17:03:01] PHASE ONE, Encoding
- [17:03:01] Processing: VID_00083 (1 of 1)
- [17:03:01] Extracting A/V streams [VID_00083]
- [17:04:32] Reencoding video [VID_00083]
- [17:04:32] Reencoding: VID_00083, Pass 1 of 1
- [17:57:47] Video Encode complete
- [17:57:47] Processing audio tracks
[17:57:47]PHASE ONE complete
[17:57:47]PHASE TWO - Rebuild Started
- [17:57:47] Building ALTERNATE OUTPUT Structure
[17:57:47] - Failed to REBUILD
Old 27th January 2014, 00:51   #18957  |  Link
Still fails
I guess I'll have to see if I can find that one (tomorrow) and see if I can repeat it.
Old 27th January 2014, 00:54   #18958  |  Link
gonca
Jdobbs
This error occurs on more movies with this version of BD_RB. Bridget Jones Diary also failed.
P.S.
Might be a good idea to try one of the movies you have first.
This isn't that good a movie, maybe not worth you spending your money if you don't have to.
Old 27th January 2014, 04:13   #18959  |  Link
Jdobbs
P.S.
Can you post your settings so I can be sure I'm duplicating them?
Old 27th January 2014, 08:33   #18960  |  Link
gzr
I know you won't think this is important but since you're using tsmuxer version 2.6.11 and now 2.6.12 the m2ts file in the blu ray structure is impossible to see with players like vlc and mpc-hc while befere the were no problems at all. Maybe this can show some hidden problem with tsmuxer.
gzr is offline   Reply With Quote
