24th August 2019, 02:21 | #17241 | Link |
ByteShare
Core 2019.08.23 You have to look in the Settings > Tools > Installed Tools > Core
The RipBot version in the main window doesn't change with updates always, so it will still read 1.25.0 Personally the Window name should just be RipBotx264 and the version should be pulled from something else and shown in the main GUI, so that when updates are pushed out only changing the updater version or an .ini file would be required rather than recompiling GUI or something like that so even when filters are updated we'd see a version change. Last edited by byteshare; 24th August 2019 at 02:24. |
24th August 2019, 02:46 | #17242 | Link | |
I'll chime in once I know if the frame flickering seems resolved. |
24th August 2019, 06:41 | #17244 | Link |
ByteShare
Huh...I'm not, but you can switch back to FFMS2 if you weren't having an issue with that one.
Since 8.20 I wasn't having the issues since the Encoding Servers stopped trying to recreate the index files...at least on the 6 files that I had flickering between the 2-4 encodes for each with versions since the LSmash addition but before 8.20. Last edited by byteshare; 24th August 2019 at 06:44. |
24th August 2019, 07:10 | #17245 | Link | |
24th August 2019, 07:14 | #17246 | Link |
ByteShare
Using DE mode doesn't matter, since 8.20 the way indexing works is different. I confirmed the flickering in DE and non-DE and then it working in both.
FFMS2 is the way before LSmash. You can change the default decoder in the settings from LSmash to FFMS2 for all codecs or just the ones you want. Even though LSmash is working I switched back to FFMS2 now that we have the option since creating jobs is faster and I wasn't having issues before LSmash. |
24th August 2019, 08:18 | #17247 | Link | |
24th August 2019, 16:28 | #17248 | Link | |
ByteShare
I confirmed it by going through both the parts I had marked as consistently having issues and skipping through 5s at a time on 6 files that had issues on every encode I did on them (2-4 times depending on the file). |
24th August 2019, 16:30 | #17249 | Link | |
24th August 2019, 18:01 | #17250 | Link | |
What is the "fast"? What is the "it" in "I confirmed it"? |
24th August 2019, 18:06 | #17251 | Link |
update log error
An error appears in every activation cycle in my update log:
2019-08-24 12:55:57 : =========================[UPDATER ACTIVATED]========================= 2019-08-24 12:55:57 : Looking for correct UUID link in 2019-08-24 12:55:57 : [ERROR] NO CONNECTION with 2019-08-24 12:55:57 : Searching for UUID link with DuckDuckGo... 2019-08-24 12:55:57 : Search results... 2019-08-24 12:55:57 : http://pastebin.com/FC9zCf0D 2019-08-24 12:55:57 : Looking for correct UUID link in http://pastebin.com/FC9zCf0D 2019-08-24 12:55:58 : [SUCCESS] http://pastebin.com/FC9zCf0D has correct UUID link 6c966b28-e0dd-48f6-b1c7-a56e8a275ec0 2019-08-24 12:55:58 : No results. My Windows 10 (Pro) firewall includes exceptions for RipBot264 and it's updater, that I added. |
24th August 2019, 19:40 | #17253 | Link | |
https://www.mediafire.com/file/0744w...dater.exe/file
24th August 2019, 19:42 | #17254 | Link |
FFMS2 is not perfect either
https://forum.doom9.org/showthread.p...99#post1881599 I would at least use LSMASH for MPEG-2. I have few sample where FFMS2 mpeg-2 decoder acts weird.
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 24th August 2019 at 19:48. |
24th August 2019, 20:21 | #17255 | Link | |
24th August 2019, 20:59 | #17256 | Link | |
E5 2697 v2 @ 3.0GHz on P9X79 Deluxe 24GB Xeon E5-2680 v2 @ 3.1GHz 16GB Sony Vaio VPC-F13Z1E/B |
24th August 2019, 21:05 | #17257 | Link | ||
ByteShare
"fast"...*fact (typo) "it" confirming the issue wasn't happening |
24th August 2019, 21:28 | #17258 | Link |
Do not use lsmash for vc1!!! IT is totally broken!!!
24th August 2019, 22:07 | #17260 | Link |
@Atak
I wanted to ask something regarding which server runs the CombineAllChunks.cmd Is it the one who finishes the last chunk?
