9th April 2017, 22:37 | #14781 | Link | |
Demuxed dtsma tracks no longer appear in audio choices
10th April 2017, 03:28 | #14782 | Link |
OK, I know that's how you retain DTS streams, but I have a question for you:-
I have a few 2160p x265 10 bit 7.1 encoded movies, that I want to re encode down to x264 1080p. When I load the movie into Ripbot, it display's that there is only 2 tracks. But clearly they have 7.1 (8), as detected by MediaInfo, and VLC. Just seems a little misleading. I am yet to process one to see what the end result is..... |
10th April 2017, 05:38 | #14783 | Link | |
If you have a 7.1 track that is not listed, it could be a .dtsma issue as described by my ignored post above. |
10th April 2017, 05:46 | #14784 | Link | |
Possibly. |
10th April 2017, 10:27 | #14788 | Link |
I use MKVToolnix to extract the video and then use Ripbot264 to process that, then MKVTOOLNIX to mux back the chapters, subtitles and audio. That way I know it's exactly how I want it as Ripbot264 had a habit of processing the sound to a different format.
10th April 2017, 13:50 | #14790 | Link | ||
encoder will get lossless part of the source audio instead of lossy DTS-core. NicAudio only sees lossy part in DTS-MA.
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 10th April 2017 at 13:59. |
10th April 2017, 15:22 | #14792 | Link | |
Does my posted workaround of changing the .dtsma extension to .dts prevent encoding from the lossless part? |
10th April 2017, 16:36 | #14793 | Link | |
10th April 2017, 17:43 | #14794 | Link |
Wish list: higher bitrate choices for AAC
I'm aware many would offer that AAC 2.0 @128 and 5.1 @320 is more or less transparent, yet I'd like to have additional choices of 160, 192, 224, 256 and 320 for 2.0, 448, 512 and perhaps 576 for 5.1 and vbr 5 and 6 for both 2.0 and 5.1. Until this happens, I will continue to manually modify the jobx_EncodeAudio1 file inside the jobx folder.
Also, if you, (Atak), could implement AAC 7.1 with correct channel assignment, I'd "love you long time". Last edited by FuzzyNutz; 10th April 2017 at 19:57. |
10th April 2017, 20:35 | #14795 | Link | ||
10th April 2017, 21:11 | #14796 | Link | |
I'm aware that before v1.19.6, some of my jobs loaded from .mkv files had lossless audio tracks that underwent automatic FLAC conversion, but I did not see this conversion when loading jobs from M2TS files in Blu-ray structured folders; not as a message within the GUI or the resulting FLAC files in the jobx folders. When I encoded to AC3 or AAC from the M2TS scenario, was the FLAC conversion happening?...Behind the scenes? And if it did not happen, does that mean my AC3 or AAC encodes were from lossy cores? Last edited by FuzzyNutz; 11th April 2017 at 15:51. |
10th April 2017, 21:25 | #14797 | Link |
Atak, I made the update from Flac to version 1.3.2 and it works correctly with RipBot.
Did you get tested? http://www.rarewares.org/files/lossless/ |
10th April 2017, 22:47 | #14800 | Link |
Error demuxing TrueHD
Ripbot264 v1.19.6 failed to load an M2TS file from a BD folder structure, with a TrueHD track, set to "demux".
This error message appeared: FFAudioSource: No audio track found (E:\Temp\RipBot264temp\job3\getinfo.avs, line 4) Update: I suspect the TrueHD stream has issues. Last edited by FuzzyNutz; 11th April 2017 at 01:27. |
