Old 7th November 2018, 23:11   #28021  |  Link
ocean
Thanks. What do you use to extract this information?
BDTools:
https://forum.doom9.org/showthread.php?t=174563
Extract from file *.clpi with Dolby Vision:
"stream_PID": 4117,
"stream_coding_type": "H.265",
"video_format": "1080p",
"frame_rate": "24",
"aspect_ratio": "16:9",
"reserved01": 0,
"cc_flag": 0,
"reserved02": 8704,
"ISRC": {
"country_code": "",
"copyright_holder": "",
"recording_year": "",
"recording_number": ""
"reserved03": 0
ocean is offline   Reply With Quote
Old 7th November 2018, 23:32   #28022  |  Link
gonca
You can also use Media Info
You can use
Text (or whichever view you like)
Debug > Advanced mode
Old 8th November 2018, 14:45   #28023  |  Link
Originally Posted by ocean View Post
Nice. I'd actually thought about writing a program to do essentially the same thing. Good to know someone else already did!
Old 8th November 2018, 22:09   #28024  |  Link
omegaman7
omegaman7's Avatar
JD, do you ever run backups to DVD-5 format? Because with the new version, it could be broken. I've attempted MKV to DVD, Blu-ray .iso to DVD, and the encoder crashes before it can even begin(I think the time stamp is relative to closing the encoder error window).
When it first occurred, I ran another movie to be sure I wasn't dealing with a corrupt stream. Same error occurred. But when I reverted to BD-Rebuilder version 5025 the job completed without a glitch.
The reason I still have that version, is I've been using it for quite some time without issue. But realized you have advanced the program substantially, and that I needed to update.
[11/08/18] BD Rebuilder v0.60.04
[12:36:04] Source:  ANT_MAN_AND_THE_WASP_00800
  - Input BD size: 34.69 GB
  - Approximate total content: [01:58:06.537]
  - Windows Version: 6.1 [7601]
  - Mode: DVD-5, 720x480/576, AC3 Audio
  - Quality: High Quality (Default)
  - Audio Settings: AC3=0 DTS=1 HD=0 Kbs=640
[12:36:08] PHASE ONE, Encoding
 - [12:36:08] Processing: VID_00801 (1 of 1)
 - [12:36:08] Extracting A/V streams [VID_00801]
 - [12:40:43] Reencoding video [VID_00801]
   - Rate/Length: 23.976fps, 169,907 frames
   - Bitrate: 4,617 Kbs
 - [12:40:43] Reencoding: VID_00801
[12:40:47] - Failed video encode, aborted
INF
[Status]
LABEL=ANT_MAN_AND_THE_WASP
VERSION=v0.60.04
SOURCE_SIZE=37243779072
SOURCE_VIDEO_SIZE=37243779072
TARGET_SIZE=49666850816
REDUCTION=1.33356098799705
RESIZE_1080=0
RESIZE_1440=0
AUDIO_TO_KEEP=eng;
KEEP_HD_AUDIO=0
SUBS_TO_KEEP=eng;
BACKUP_MODE=1
MOVIEONLY_TYPE=1
USE_LAVF=-1
INSTANCES=1
DGDECNV=0
DGDECIM=0
FRIMSOURCE=0
FFMS2=0
SSIF_MODE=0
QUICK=0
ENCODE_STEP=1.5
[00801]
AUDIO=100000
PGS=10000000000
APULLDOWN=0
S1440=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=49666850816
Rebuilders .ini
[Options]
VERSION=0.60.0.4
IMPORT_FOLDER=Z:\
FORCE_NOENCODE=
ENABLE_TEST=
BLANK_THRESHOLD=
MULTIPROCESS=
ENCODER=0
MODE=3
ENCODE_QUALITY=2
ONEPASS_ENCODING=0
AUTO_QUALITY=0
QUICK_EXTRAS=1
TARGET_SIZE=47366
AUDIO_TO_KEEP=eng;
SUBS_TO_KEEP=eng;
SD_CONVERT=0
OPEN_GOP=0
RESIZE_1080=0
RESIZE_1440=0
RESIZE_720=0
DEINTERLACE=1
SD_TO_1080=0
IGNORE_3D=1
CONVERT_WIDE=0
DTS_REENCODE=1
AC3_REENCODE=0
AC3_640=1
AC3_192=0
KEEP_HD_AUDIO=0
DECODER=2
AVCHD=0
REMOVE_WORKFILES=0
REMOVE_OUTPUT=0
USE_FILTERS=0
BDMV_CERT_ONLY=0
IVTC_PULLDOWN=0
ASSUME_DVD_PAL=0
FRIMSOURCE=0
COMPLETION_BEEP=0
OUTPUT_SBS=0
NEROAAC=0
SUPTITLE=0
AUDIO_TRACK_LIMIT=1
SUBTITLE_TRACK_LIMIT=1
CUSTOM_TARGET_SIZE=23500
MOVIEONLY_TYPE=1
ALTCRF=18
ALT_TARGET=8000
ALTMETHOD=2
ALTAUTOCROP=0
AUDIO_DRC=0
ENABLE_BLANKING=0
PGSTOSRT=0
ALT_CRF_TARGET=1024
IMPORT_THRESHOLD=15
QUICK_PLAY_THRESHOLD=10
MENU_AUTO_BACKGROUND=0
MENU_AUTO_DVDAUDIO=1
MENU_PLAY_SEQUENTIAL=0
MENU_START_WITH_MENU=1
IMPORT_LIMIT_LANG=0
IMPORT_KEEP_PLAYALL=0
IMPORT_PREPARE_MKV=1
[Paths]
SOURCE_PATH=I:\
DGIndexNV=C:\Users\Kevin\Downloads\1BD-RBV06004\dgdecnv2041\DGIndexNV.exe
DGDecNV=C:\Users\Kevin\Downloads\1BD-RBV06004\dgdecnv2041\DGDecodeNV.dll
WORKING_PATH=W:\1_TEMP\
Old 8th November 2018, 23:06   #28025  |  Link
@omegaman7
I'll run a DVD-5 output test later today. The odd thing is that it appears HC Encoder is crashing. Both of the versions you mention are using the same version of HC Encoder.
Old 8th November 2018, 23:20   #28026  |  Link
@omegaman7
Hmmm... it looks like somehow the HCENCODER.EXE file in the tools folder has become corrupted. I just did a binary compare with an earlier release and it shows it has changed.
Copy HCENCODER.EXE from the tools folder of your previous version into the new one and it should be ok. Meanwhile I'm going to check other files as well to see if anything else was corrupted. I had a hard drive go bad a couple months back.... but when I recovered a backup to a new drive all seemed well. Maybe that wasn't the case for that file at least.
[Edit] I did a binary compare of all the other files in the tools folder -- it appears that one is the only one that doesn't match. I'm not sure how that could have happened -- but it obviously did.
Old 9th November 2018, 00:08   #28027  |  Link
omegaman7
omegaman7's Avatar
Sweet!
I've seen a few corrupted files myself recently. I think a "Lexar" flash drive is suspect lol
Old 9th November 2018, 20:11   #28028  |  Link
AmigaFuture
AmigaFuture's Avatar
I have the BDR-209D in the Win7 box. Go for the latest model in that series.
Yessir...that's what I have in my list. Checking at store today..
Originally Posted by omegaman7 View Post
Sweet!
This is also part of the reason I keep the last Beta of HCEncoder in an archive, and always rename the one that comes with BD-RB to disable it. The beta is a little nicer and quicker and support multitasking better. At least those where the tests from years ago...that I did. When I was using it a lot.
Old 10th November 2018, 00:00   #28029  |  Link
MrVideo
MrVideo's Avatar
Should be cheaper on line.
MrVideo is online now   Reply With Quote
Old 10th November 2018, 07:29   #28030  |  Link
AmigaFuture
Not only cheaper, but only found Online. Not a fan of Amazon only, or Online only... I still prefer face to face interactions..which is becoming dead. The day I almost only interact with Devices/Cell phone is when I really wonder WTF? That's becoming more and more..
Drive ordered.
Old 10th November 2018, 12:47   #28031  |  Link
frank
Banned
Please update FRIM to latest version v.1.29. Now it is stable in HW mode!
Edit MVENCODE.BAT
...FRIMDecode.exe -i::mvc "INPUT.m2ts"
to
...FRIMDecode.exe -i:mvc "INPUT.m2ts" One colon only.
Tested on Dell 9560, Kaby Lake.
frank is offline   Reply With Quote
Old 10th November 2018, 18:46   #28032  |  Link
Ch3vr0n
You can do that yourself in the meantime. Just download it and replace the existing ones. It's only if you encounter issues, jdobbs will say no-no cause they're not the recommended versions yet.
Verstuurd vanaf mijn Nexus 6P met Tapatalk
Old 10th November 2018, 19:56   #28033  |  Link
MrVideo
MrVideo's Avatar
I normally do Ebay.
Old 10th November 2018, 21:22   #28034  |  Link
AmigaFuture
I normally do Ebay.
I rarely use eBay. Prices are usually high, and bidding goes a lot higher than it should for many items. For rare or "older" items I times use it....at times. The on-the-way drive should be good. If it is, I'll check eBay to see if it's lower priced because it's always good to have a backup that's also in great shape. But I also don't want used. Again, appreciate the help, all. Yay!
Old 11th November 2018, 18:48   #28035  |  Link
@Anyone who knows X265 better than me
Can someone tell me why when I set --level-idc 5.1 and try to set --high-tier in X265 it doesn't work (the encoder tells me it is "5.1 Main Tier")??? I can set the level to 5.0 and it accepts high tier but not 5.1...
The UHD spec (at least the UHD White Paper) requires Level 5.1 and High Tier.
Old 11th November 2018, 19:00   #28036  |  Link
sneaker_ger
Do you have --uhd-bd set? Are you using --bitrate in range allowed in main tier (<=40,000)? Do you have --no-high-tier set as well (accidentally)?
Old 11th November 2018, 19:19   #28037  |  Link
No. I don't have --uhd-bd set. I've found that I cannot create a working UHD structure if I have it set. It forces --no-open-gop on when it is set (even though the White Paper says UHD accepts open GOPs)... and if I run a UHD encode through TSMUXER without open GOPs the audio sync goes way out. I have no idea why. So I manually set all the other options enabled by "--uhd-bd"
In this particular encode I was using a CRF setting rather than bitrate. The VBV-MAXRATE happens to be below the maximum bitrate for Level 5.1/High-Tier -- does that make it adjust down?
No. I don't have --no-high-tier set.
Old 11th November 2018, 19:24   #28038  |  Link
Yeah... if I set the vbv maximum bitrate higher than 40Mbs, X265 does enable high tier. So that was it. Too bad... I was hoping that might be a source of some issues I was experiencing. Ok... back to banging my head against the wall.
Thanks, sneaker_ger, I appreciate your help.
Old 11th November 2018, 19:26   #28039  |  Link
sneaker_ger
You mean below maximum for main tier? Yes, that seems to be the case.
I guess it's not possible without --uhd-bd.
About open-gop: I wouldn't just assume x265's open-gop is allowed on Blu-Ray. There are different styles of doing it and my guess is the x265 devs deactivated it for --uhd-bd because their way is not compatible with the Blu-Ray specs. x264 changes its open-gop style somehow when you activate --bluray-compat IIRC.
(I have never read any actual explanation by the x265 devs so this is simply my guess.)
Old 11th November 2018, 19:34   #28040  |  Link
I've been using HEVCBrowser to look at original HEVC streams and comparing them to those created by X265 to try and put my finger on what is different. TSMUXER can mux the originals with no issues... but those I've created with X265 always have some type of issue. The latest is stuttering when you get later into a film.
Unfortunately setting --uhd-bd isn't an option right now -- because TSMUXER just won't mux it without huge audio desync (it gets way out of sync withing a few minutes of the start of a film) when --no-open-gop is set. I even dumped out all the PTS values for the audio and the video and compared them to the original... all were fine. Color me confused.
Interestingly, I can fix the stutter by encoding the movie in 15 minute segments and using TSMUXER to combine them. But then it seems to have issues at the joins and the audio goes out of sync again. The same happens if I manually join the segments together and run that through TSMUXER. If I join the segments together with MKVMERGE into an MKV -- the sync is fine, so it isn't frame counts or anything like that.
I also found I could make the stutter delay further into the film by setting --slices 4 -- but it still starts well within an hour or so. Again... the original HEVC files have no issues at all -- some of them have up to 8 slices and others only 1 and it seems to mux and play back fine.
It's frustrating as hell. Every time I try to fix something a new issue shows up.
