29th October 2012, 15:06 | #16022 | Link | ||
I guess those of us facing this problem will just have to determine which Blu-ray releases are worth copying with 50GB media... |
29th October 2012, 18:31 | #16023 | Link | |
I don't think it's too much to ask for improving software that is essentially free to anyone who can download it. |
29th October 2012, 20:51 | #16024 | Link | |
On the other hand, I share your belief that there's "somebody out there" who DOES have sufficient background to accomplish this. In reading through the posts to this thread, it seems obvious (to me, at least) that several of the posters here would be able to accomplish this. So I'll get on bended knee and outright beg of the community: Hopefully, if only as a "thank you" for your massive ongoing effort regarding this, the finest program of its type (free or for pay) , they'll step forward and volunteer to actively research the DTS Express anomaly and resolve the issue. You certainly deserve any and all possible assistance ;>} All qualified posters to this and creators and posters to other related sub-forums here (e.g. the "GUI" sub-forums), please come forward to help "jdobbs" and, therefore help ourselves and, at the same time, help the community! |
29th October 2012, 20:56 | #16025 | Link | |
29th October 2012, 21:50 | #16026 | Link |
@neuron2: that's exactly the problem, there are no fixed steps that guarantee you are able to reproduce the problem. It is just for some reason that certain players don't accept the dts-e stream remuxed by bdrb while others like my Panasonic dmp-bd85 do accept it and play it perfectly with insync audio and video. Jdobbs has been over everything multiple times with a finetoothed comb no doubt and can't fine anything that could cause that behavior. Some accept it, some others don't. Why they don't, well that's the 1million dollar question and solution to be found.
Verstuurd van mijn HTC Sensation XE with Beats Audio Z715e met Tapatalk |
29th October 2012, 22:00 | #16027 | Link |
Here's a summary of the issue.
1. Some discs have secondary audio that use DTS Express. Unfortunately when trying to back them up, there also isn't a way to demux them and remux them (TSMUXER doesn't support DTS Express). So for a long time there was no support for that audio codec and it was left out of backups. 2. So I decided I'd try extracting and reintegrating it myself. I just pulled the associated packets (headers and all) from the source M2TS stream, and after TSMUXER completed it's muxing, I updated the timing information of the extracted packet stream and reintegrated (merged) it into the TSMUXER created M2TS and CLPI. I also updated all the PMT and PAT entries, etc. in the M2TS. 3. That seemed to work fine. The audio is recognized correctly by packages like BDEdit, etc. and most players (like Samsung and others) recognized the audio and played it back fine. Others, however (like Sony), while indicating they recognized the existence of the audio, don't seem to be able to play it back. It's as if the stream doesn't exist. I have no idea what is wrong with the stream. I'm confident something is wrong with the way it is either integrated into the stream or in the updated CLPI entry -- but I just can't seem to find it. I'll admit that I'm a little out of my normal swimlane when it comes to multiplexing M2TS files (I've always depended on TSMUXER for that)... but I looked through the associated Blu-ray and M2TS specs and nothing stands out as an obvious flaw. It's gotten to the point where I've looked at it so much that I don't think I'd see it now even if it was obvious. Last edited by jdobbs; 29th October 2012 at 22:10. |
29th October 2012, 22:44 | #16028 | Link |
@neuron2
Hi! In addition to the information in jdobbs' post #16030, I'd just note that, from my experience the DTSExpress audio is almost always used on commercial discs in conjunction with "PIP" (Picture In Picture) - and after you use BD-RB to convert/compress such a disc (with no errors reported/indicated), on playback you'll SEE the "PIP" but hear silence. The most frequently noted culprit standalone player is the SONY BDP S360. I believe you'll find "Band of Brothers" to be an example that will produce the anomalous result we're discussing... I'd like to personally thank you for your interest ;>} Last edited by setarip_old; 29th October 2012 at 22:47. |
30th October 2012, 00:43 | #16029 | Link |
^^ If it helps, I used to have that problem on "The Pacific" until I changed my LG BD630 from "Primary Pass-Thru" to "DTS Re-encode" . Now it's fine. DTS-Express with BDRB and the hidden option
Win7x64...I had to... RIP WinXP Last edited by abbadon; 30th October 2012 at 23:45. |
30th October 2012, 23:44 | #16032 | Link |
When I asked jdobbs said with the way he programmed bdrb there was no speed improventment, and had tested as such. Though it can be a bit annoying for those with OCD or "secretarial" preference
Win7x64...I had to... RIP WinXP Last edited by abbadon; 31st October 2012 at 07:59. |
30th October 2012, 23:59 | #16033 | Link |
Perhaps not if u use only 1 drive but in my case i use 3-5 drives. All 1 or 2 TB. If there was an extra output folder possible i'd have the SOURCE on 1 drive, the workfiles on a 2nd, and the final output on a 3rd drive. That way not 1 drive has to do more than 1 thing at the same time. Any drive at any given time will either be READING from the source, RECODING the workfiles or WRITING the final output. How ever small the speed increase will be, i'll take it. That and it would also be a huge timesaver file moving wise. I'd no longer have to move my ISO's to a certain drive after BDRB finished creating it (currently in the workfiles on the 2nd drive). It would instantly be created on the Drive & folder i want the final output to be at.
31st October 2012, 00:14 | #16034 | Link |
It won't make a difference and I've explained why about 30 times... but I'll add an alternate output folder as a hidden option -- just so I don't have to hear about it anymore. I'd appreciate it if people post there speed increases so I can say "I told you so".
The only real advantage would be if you are running batch jobs and space on the working drive is getting low. Last edited by jdobbs; 31st October 2012 at 00:17. |
31st October 2012, 00:34 | #16035 | Link |
<3, i'll do a couple speed tests if ya want, but for me as said it's mainly for file storage purposes. They'd be right on the drive & folder where i want them to be, and i wouldn't have to go arround moving them anymore the Temp folder (bdrb working folder) is currently approx 400GB here while my "iso storage" drive is a different one with over 1TB free and the working drive barely 1-200GB (& rapidly decreasing)
31st October 2012, 09:57 | #16036 | Link |
I get your perception for the data... I agree that it may not make a difference with an alternate output directory. I'm willing to test it. If it does show to be helpful, though, I won't gloat. I'm not into that..just like pride...no need for it. So, let's have some fun. It also depends on the speeds of HDDs.
31st October 2012, 14:18 | #16037 | Link |
the possibility of having a temporary folder and a folder ending is not to have an increase in speed of the process but to share folders on two different drives and not on the same disk, and thus have less risk of destroying the huge amount of work!
31st October 2012, 14:49 | #16038 | Link |
Re-encode crash
I know I have everything installed correctly but my encoding keeps crashing! Heres my log:
[10/31/12] BD Rebuilder v0.42.03 (beta) [09:26:17] Source: VOLUME_ID - Input BD size: 25.50 GB - Approximate total content: [03:26:52.308] - Target BD size: 23.30 GB - Windows Version: 6.1 [7601] - Auto Quality: Good (Very Fast), ABR - Decoding/Frame serving: DirectShow - Audio Settings: AC3=0 DTS=0 HD=1 Kbs=640 [09:26:18] PHASE ONE, Encoding - [09:26:18] Processing: VID_00003 (1 of 9) - [09:26:18] Extracting A/V streams [VID_00003] - [09:42:54] Reencoding video [VID_00003] - [09:42:54] Reencoding secondary video [TRK_02] - Encode failed. Aborting. - BD-Rebuilder v0.42.03 (beta) - Windows Version: 6.1 [7601] - AVISYNTH Version: 2.5.8.0, Ok - HAALI Splitter: 1.9.42.1, Ok - FFDSHOW: 3882, Ok - WIN7 preferred AVC CODEC: Ok - WIN7 preferred VC-1 CODEC: Ok - WIN7 preferred MPEG2 CODEC: Ok - FFDSHOW VC-1 set to "wmv9", Ok - FFDSHOW MPEG2 set to "libmpeg2": Ok - FFDSHOW AVC set to "ffmpeg-mt": Ok - AnyDVD settings check: Ok. - X264: Ok - AFTEN: Ok - FAAC: Ok - MP4BOX: Ok - WAVI: Ok - TSMUXER: Ok [09:43:04] - Failed video encode, aborted Any suggestions? |
31st October 2012, 15:07 | #16039 | Link |
This is not a bug report, quite the opposite in fact. Praise is surely allowed, right?
I'm loving some of the recent new features, Import especially. I'm in the habit of encoding most interesting extras into MKV and doing a movie-only backup of the main feature. Previously I was out of luck if the extra feature did not have a playlist of its own - but now I can use the Import feature! No more messing about with MeGUI, for example. Lovely. Earlier today Import saved my bacon another way. I had done a Full Backup of a title with lots of extras but the output was 100MB too large. That was solely my fault because I'm always aiming to use the entire BD25 by setting a Custom output size (24400 works pretty well with DGD). Now, instead of re-encoding the entire title I used Import to re-encode a single (original) m2ts and setting the Custom output size so that the resulting m2ts was 100MB smaller than the previously encoded one. I used Alternate Movie-Only Output but set it to "Output BD or AVCHD Compliant Structure" so the result was like a very small BD. After that it was simply a question of renaming the file from 00000.m2ts to 00006.m2ts and copying it over the other, 100MB larger 00006.m2ts. Worked like a charm! |
31st October 2012, 15:56 | #16040 | Link |
That wasn't a bug report, but this is. And it's the weirdest thing. I'm trying to do a movie-only backup of a French title which consists of:
* VID_00001 MPEG-4 (AVC), 1080p, 24fps, 61.58MB * VID_00000 MPEG-4 (AVC), 1080p, 24fps, 26584.42MB - Audio 1 DTS-HD XLL, Multi-Ch, French - Audio 2 DTS-HD XLL, Multi-Ch, English - Audio 3 DTS-HD XLL, Stereo, French I disabled both French tracks. BD-RB re-encodes VID_00001 but calculates VID_00000 fits without re-encoding. As PHASE TWO Rebuild starts, this happens: - [16:40:18] Rebuilding BD file Structure - Failed in attempt to multiplex: MUX_MOVIE_ONLY.meta - Can't open file: U:\BDRB\WORKFILES\00001.track_4113.264 [16:40:21] - Failed to REBUILD Here's the content of MUX_MOVIE_ONLY.meta: MUXOPT --no-pcr-on-video-pid --new-audio-pes --blu-ray --vbr --custom-chapters=00:00:00.000;00:05:55.916;00:13:24.166;00:20:59.000;00:29:11.500;00:35:52.375;00:44:52.541;00:49:30.083;00:56:28.750;01:01:14.041;01:07:30.291;01:17:24.458;01:49:05.125 --vbv-len=500 V_MPEG4/ISO/AVC, "U:\BDRB\WORKFILES\00001.track_4113.264"+"U:\BDRB\WORKFILES\00000.track_4113.264", fps=24, track=1, insertSEI, contSPS A_DTS, "U:\BDRB\WORKFILES\00001.track_4353.DTS", timeshift=14125ms, lang=eng The reason rebuild fails is simple: there is no "00001.track_4113.264" in the WORKFILES directory. The directory does have "00000.track_4113.264" (19.7GB) and "00001.track_4353.dts" (1.54GB), but "00001.track_4113.264" is missing. VID_00001 is re-encoded without problems, as the log shows: [16:19:51] PHASE ONE, Encoding - [16:19:51] Processing: VID_00001 (1 of 2) - [16:19:51] Extracting A/V streams [VID_00001] - [16:29:36] Reencoding video [VID_00001] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 24,000fps, 339 frames - Bitrate: 28*708 Kbs - [16:29:36] Reencoding: VID_00001, Pass 1 of 2 - [16:29:48] Reencoding: VID_00001, Pass 2 of 2 - [16:30:11] Video Encode complete Update: I guess I found the culprit. Even though it's encoding VID_00001, BD-RB names the output file "00000.track_4113.264". And when the next file, VID_00000, is being processed, that too is named "00000.track_4113.264", thus deleting the earlier file. Last edited by colinhunt; 31st October 2012 at 16:16. |
