11th February 2018, 16:22 | #48921 | Link | ||
King of the Jungle
The framerate of the movie is 23.976 |
11th February 2018, 16:36 | #48923 | Link |
King of the Jungle
Oh right, I think I understand. So is this just an issue for frame sizes that aren't clear divisions of the display size?
EDIT: scratch that, I'm really not sure I do understand this at all. Is there a good resource for getting my head around scaling in MadVR? I thought I had my head around it but these couple of films seem to behave differently to everything else Last edited by Clown shoes; 11th February 2018 at 16:58. Reason: Confused.com |
11th February 2018, 17:43 | #48924 | Link |
Yea, your rendering times are off the chart as huhn said likely because of the scaling. That's an odd source resolution.
11th February 2018, 17:54 | #48925 | Link | |
https://abload.de/img/herewegoagaintzuuk.png for reasons beyond me. |
11th February 2018, 18:08 | #48927 | Link | |
King of the Jungle
I had NGU sharp set as my luma upscaler with high on the doubler. Everything else is set to let MadVR decide. Is that really so stressful for a 1060? The only way I can prevent dropped frames is by setting it to NGU sharp low Last edited by Clown shoes; 11th February 2018 at 18:11. |
11th February 2018, 18:21 | #48929 | Link |
set this to "only if scaling factor is 4.0 (or bigger)" and see if it still happens. |
11th February 2018, 18:31 | #48930 | Link | |
King of the Jungle
Thanks huhn. So does that mean that MadVR was trying to quadruple the frame size as it was slightly less than 1080p and then downscale it again? |
11th February 2018, 19:15 | #48933 | Link |
I agree, quadrupling for less than a 3.0x upscale is total overkill, and even a negative at times. However, I thought "let madVR decide" for quadrupling was 2.4x so quadrupling should not have activated.
madVR options explained |
12th February 2018, 00:55 | #48935 | Link | |
Surface Pro
12th February 2018, 02:34 | #48937 | Link |
X Cinema Projectionist NZ
I have a small problem and not sure how to describe it.
Im not sure if its an issue with my JVC X9900 that I resently changed to from a JVC X9500. I had never seen this artifact on the X9500. I have all processing turned off on the X9900. The issue comes about only accasionally when the screen is black and the next image fades in. The look of the fade in kind of goes into double ghosting, or the look of water/waves moving across the screen. I just tried to video it to show you guys but it doesnt show up clear on the video. The artifact appears for a few seconds after the text "The Mountain Between Us", however you will not really see it on this video. https://youtu.be/TmhsoMWAVs0 I use the 1080Ti card and upscale BDs to 4K using NGU sharp. I have tried NGU soft, NGU AA and many others, the artifact is still there. I have tried dont render frames during fade in and out, doesnt help. Ive spent hours playing this scene over and over when turning almost evrything off on madvr and on the proj, it doesnt help. My rendering times are very very low, round 17ms, I have no dropped frames... It might just be the projector, as I say this never used to happen with the X9500. I dont think I ever see this during a film, maybe only at the start... Thoughts please? |
