27th September 2019, 06:04 | #141 | Link | |
I'm Siri
u can turn off aero animation here Last edited by feisty2; 27th September 2019 at 06:10. |
27th September 2019, 09:25 | #142 | Link |
yeh, for that box I usually hit Adjust for best performance, and then tick these only.
Show Shadows under mouse Show Window contents when dragging Smooth edges of screen fonts Use drop shadows for icons on the desktop
27th September 2019, 10:26 | #143 | Link | |
I do use the Aero thingy w/transparency, firstly because it looks kinda cool (as opposed to the Win8/10 flat look) and secondly because my video adapter can handle it easily.
Groucho's Avisynth Stuff |
27th September 2019, 10:33 | #144 | Link |
Any GPU with Pixel shader 2.0 will handle without issues Aero. I remember using aero on Acer laptop with Radeon x700 128 MB. Super smooth.
27th September 2019, 10:54 | #145 | Link |
Good to know, thanks.
27th September 2019, 11:45 | #146 | Link | |
or do you have plenty of oomph to spare. [EDIT: Have you compared with/without - EDIT: or is it a stupid question] EDIT: I've always looked at that chrome or plasticky look with disdain, just like a naff game or some 80's/90's Amiga demo or something. Flat, squarish, 2D world for me : G2K4, you gained some + points for the first 4 ticks, but losts em all for that last one EDIT: @BetA13, Thanks for the info, it distracted me for a little bit, but then I decided that I'm happy to stick with CPU and no aero, me is just a luddite stick-in-the-mud. [maybe I just dont care that much].
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 27th September 2019 at 12:35. |
27th September 2019, 12:51 | #147 | Link | |
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 27th September 2019 at 12:54. |
27th September 2019, 13:16 | #148 | Link |
Oh, it is a stupid question then, sorry to waste your time
27th September 2019, 14:24 | #149 | Link | ||
Anyway, Quote:
27th September 2019, 15:56 | #150 | Link |
Points, well no not really, I woz just throwing you a bone, thats the kinda nice fella that I is.
27th September 2019, 18:40 | #151 | Link | |
cosmic entity
Sadly i cant answer that 100%, BUT if i do benchmarks and encoding stuff, it tends to be a bit better/faster when using my Perf. Theme. (wich is an greyish dark "classic" Theme without aero.. What i saw is that classic uses less VRAM, wich in return you have more to spare for the workload/bench/game. But these are amounts that other People would laugh at^^ you save around 100 - 180 MB VRam... SO, yes, in some heavy workloads or benches/application, a classic theme can give you a tiny little bit more Performance... At least that is what I experienced trough my years of testing... Just thought to point that out... Best Regards. |
27th September 2019, 19:05 | #152 | Link |
On my very ancient machine with these specs:
I had to be very creative to squeeze out the last little bit of performance. The tools which really helped were CacheMan and AppBooster. For some memory intensive software this made the difference between unusable and working pretty well. Of course using simple desktop themes (Aero not available under WinXP) may also help a little bit. A few ywars ago MS told me that the OS installation was not legit and switched the desktop background to black. I thought that this looked very cool, I liked it so much that I kept the black background for several months. Like Groucho said: Each to his own... Last edited by manolito; 27th September 2019 at 19:09. |
27th September 2019, 19:31 | #153 | Link |
576 MiB RAM is a lot for win XP.
27th September 2019, 20:37 | #154 | Link |
It's MB, not GB...
And no, it is by far too little for some software. Google Chrome is swapping all the time, but my old Opera12 which is much faster refuses to load more and more websites. I can tell the difference from comparing it to my NetBook Medion Akoya E1210 (the famous Aldi netbook) which also runs WinXP, but has 2 GB of RAM. This makes a major difference... |
27th September 2019, 23:14 | #155 | Link | |
28th September 2019, 00:07 | #156 | Link | |
From Wikipedia:
But you were missing my point completely. You said that 576 MiB RAM is a lot for win XP. This is totally wrong, maybe you were talking about Win95 or Win98. Last edited by manolito; 28th September 2019 at 02:38. |
28th September 2019, 01:44 | #157 | Link |
It all depends on what software you plan on running. XP itself will run quite nicely with 576 MiB. Back in the day when this amount of memory was common, most software used a fraction of what programs use nowadays.
Groucho's Avisynth Stuff Last edited by Groucho2004; 28th September 2019 at 11:22. Reason: typo (fickin' tiny phones) |
28th September 2019, 10:45 | #158 | Link | |
[and 50% brightness, 100% tends to be way too bright in darkish pub, nearly blinding] EDIT: BetA13, thanks for taking the time to respond, not a 100.0% stupid question then. By the way, I took one of my W10 laptops back to 1709, and froze Feature updates so that it will stay forever 1709, the other one (x64) is in pieces after replacing screen digitizer and did not work after re-assembly, gonena give it another go in a few days.
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 28th September 2019 at 10:55. |
