26th October 2015, 21:54 | #4781 | Link | |
27th October 2015, 00:51 | #4782 | Link | ||
http://pastebin.com/h2B6DKXn https://github.com/stax76/staxrip/bl...nForm.vb#L2158 https://github.com/stax76/staxrip/bl...nForm.vb#L2176 Quote:
https://github.com/stax76/software-list https://www.youtube.com/@stax76/playlists Last edited by stax76; 27th October 2015 at 01:08. |
28th October 2015, 14:40 | #4783 | Link |
I seem to be having a strange issue since updating to the latest MeGUI, I haven't seen anyone else report about it so I am going to say its more than likely something my end, but just in case I will post about it.
It doesn't matter what program I use to index the files, be it L-Smash, DGIndexNV or DGIndex (external or internal versions), when I go to avs script creator and tell it to analyse the source it will indeed detect what type it is, but it will never finish analyzing, with interlaced content it seems to have an issue detecting the field type, it also does it on progressive, it just sits there saying it is still checking even though the green bar is full, I have even left it for 30 mins to see if it will finish, which it never does. I have tried this on many DVD's and a few Blurays and it will do it no matter what. They are all clean rips and I have re-ripped a few of the DVD's to make sure MeGUI 2610 was fine but with 2611 i get this issue. It is worth me cleaning out MeGUI and starting from scratch?
The Internet: where men are men, women are men, and children are FBI Agents |
28th October 2015, 18:44 | #4787 | Link | |
Edit: Working fine now - thanks Zathor
The Internet: where men are men, women are men, and children are FBI Agents Last edited by Carpo; 28th October 2015 at 20:32. |
29th October 2015, 08:00 | #4789 | Link |
Probably not a bug of MeGUI specifically, rather an issue with the used version of mkvmerge (MeGUI only provides the dialog to show you the progress, if any). So you should probably try to execute the mkvmerge call as reported in the log file, but directly in a command line interpreter window (cmd.exe), to check for unexpected warnings there.
By the way, HEVC in MKV is possible, yet in MP4 it's much more usual. MP4Box supported HEVC multiplexing already before mkvmerge. |
29th October 2015, 11:36 | #4792 | Link |
I think I can reproduce it. Will make a report with sample.
/nevermind, already fixed: https://github.com/mbunkus/mkvtoolnix/issues/1485 Last edited by sneaker_ger; 29th October 2015 at 11:41. |
29th October 2015, 11:47 | #4793 | Link |
It's already been fixed
https://github.com/mbunkus/mkvtoolnix/issues/1485 Last edited by Barough; 29th October 2015 at 12:15. |
29th October 2015, 13:57 | #4794 | Link |
Is there a certain number of times someone can request a new feature before it seems like they're being a bit pushy? It's just that today I found myself once again thinking how handy it'd be if MeGUI had a button you could click on to pause encoding......
29th October 2015, 15:54 | #4795 | Link |
Hi Zathor,
I have been having a problem that manifested recently when trying to OneClick .wmv files. It crashes at the index stage with the following error: Code:
[Error] [29-Oct-15 10:50:42 PM] p(Îcí¸g [Fatal]: Failed to avformat_open_input. Cheers mate! |
29th October 2015, 15:58 | #4796 | Link |
Hi
it seems new LSmash has a problem indexing MP4 files. I tried indexing several MKV and MP4 files. it worked fine with MKV files but kept showing an error with MP4 files. Here's an example: Code:
[Error] Log -[Information] Versions --[Information] [10/29/2015 6:00:17 PM] MeGUI: 2612 --[Information] [10/29/2015 6:00:17 PM] Operating System: Windows 7 Ultimate Edition x64 SP1 (6.1.65536.7601) --[Information] [10/29/2015 6:00:17 PM] .NET Framework: 4.0 (4.0.0.0) --[Information] [10/29/2015 6:00:17 PM] .NET Framework: 4.5.x (4.5.50938) --[Information] [10/29/2015 6:00:17 PM] AviSynth portable: 2.6.0.6 (21-09-2015) --[Information] [10/29/2015 6:00:17 PM] AvisynthWrapper: (02-01-2009) --[Information] [10/29/2015 6:00:17 PM] Haali Matroska Splitter: 1.13.138.14 (14-04-2013) --[Information] [10/29/2015 6:00:17 PM] Haali DSS2: (14-04-2013) --[Information] [10/29/2015 6:00:17 PM] ICSharpCode.SharpZipLib: 0.85.5.452 (07-08-2008) --[Information] [10/29/2015 6:00:17 PM] MediaInfo: 0.7.78.0 (02-10-2015) --[Information] [10/29/2015 6:00:17 PM] MediaInfoWrapper: 0.7.61.0 (06-01-2013) --[Information] [10/29/2015 6:00:17 PM] MessageBoxExLib: 1.0.2218.28317 (19-12-2008) --[Information] [10/29/2015 6:00:17 PM] SevenZipSharp: 0.64.3890.29348 (02-01-2011) --[Information] [10/29/2015 6:00:17 PM] 7z: 9.20 (18-11-2010) -[Information] Update detection --[Information] [10/29/2015 6:00:17 PM] Automatic update is disabled --[Information] [10/29/2015 6:00:17 PM] Using cached update config and server: http://megui.org/auto/ --[Information] [10/29/2015 6:00:17 PM] There is 1 package which can be updated: mkvmerge -[Information] FileIndexer --[Information] [10/29/2015 6:02:21 PM] MediaInfo ---[Information] [10/29/2015 6:02:21 PM] File: F:\1.mp4 ---[Information] General ----[Information] Format: MPEG-4 ----[Information] FormatString: MPEG-4 ----[Information] FileSize: 16826179 ----[Information] PlayTime: 00:05:07.265 ---[Information] Video ----[Information] ID: 1 ----[Information] StreamOrder: 0 ----[Information] Width: 352 ----[Information] Height: 288 ----[Information] FrameCount: 9218 ----[Information] FrameRate: 30.000 ----[Information] FrameRateOriginal: ----[Information] FrameRateMode: VFR ----[Information] ScanType: Progressive ----[Information] Codec: AVC ----[Information] CodecString: AVC ----[Information] Bits Depth: 8 ----[Information] Format: AVC ----[Information] AspectRatio: 1.222 ----[Information] AspectRatioString: 1.222 ----[Information] Delay: ----[Information] Title: ----[Information] Language: ----[Information] LanguageString: ----[Information] Default: ----[Information] DefaultString: ----[Information] Forced: ----[Information] ForcedString: ---[Information] Audio ----[Information] ID: 2 ----[Information] StreamOrder: 1 ----[Information] Format: AAC ----[Information] FormatProfile: LC ----[Information] FormatSettingsSBR: ----[Information] FormatSettingsPS: ----[Information] SamplingRate: 44100 ----[Information] SamplingRateString: 44.1 KHz ----[Information] Channels: 2 ----[Information] ChannelsString: 2 channels ----[Information] ChannelPositionsString2: 2/0/0 ----[Information] BitRateMode: VBR ----[Information] Delay: ----[Information] Language: ----[Information] LanguageString: ----[Information] Default: ----[Information] DefaultString: ----[Information] Forced: ----[Information] ForcedString: ----[Information] [10/29/2015 6:02:21 PM] The language information is not available for this track. The default MeGUI language has been selected. -[Error] Log for job1 (idx, 1.mp4 -> 1.mp4.lwi) --[Information] [10/29/2015 6:02:35 PM] Started handling job --[Information] [10/29/2015 6:02:35 PM] Preprocessing --[Information] [10/29/2015 6:02:35 PM] Job command line: "C:\Windows\system32\ping.exe" 127.0.0.1 -t --[Information] [10/29/2015 6:02:35 PM] Process started --[Information] [10/29/2015 6:02:35 PM] Standard output stream ---[Information] [10/29/2015 6:02:35 PM] Creating LSMASH index... ---[Information] [10/29/2015 6:02:35 PM] AviSynth script ----[NoImage] LoadPlugin("C:\Program Files\MeGUI\tools\lsmash\LSMASHSource.dll") ----[NoImage] LSMASHVideoSource("F:\1.mp4") --[Error] [10/29/2015 6:02:35 PM] Standard error stream ---[Error] [10/29/2015 6:02:35 PM] F:\1.mp4.lwi.lwi not moved to C:\Users\Admin\Desktop\New folder\1.mp4.lwi. error: Could not find file 'F:\1.mp4.lwi'. --[Information] [10/29/2015 6:02:35 PM] Job completed Last edited by leon; 29th October 2015 at 16:05. |
2nd November 2015, 23:07 | #4799 | Link | ||
No clue :-( Quote:
2614 [L-SMASH Indexer] do not expect a cache file for LSMASH*Source() 2613 [Update] do not delete NeroAacEnc during eac3to update |
