3rd December 2018, 20:29 | #6581 | Link | |
-DGIndexNV.ini includes "Full_Path_In_Files=1" -During file indexing "Full_Path_In_Files=1" is removed from the file (resulting in relative file paths in the dgi file) -After the process ends "Full_Path_In_Files=0" gets written back to the ini file -<next run> -DGIndexNV.ini includes "Full_Path_In_Files=0" -During file indexing "Full_Path_In_Files=1" is set (resulting in absolute file paths in the dgi file) -After the process ends "Full_Path_In_Files=1" gets written back to the ini file -<repeat> So without manually editing the file, only every second run is fine. Last edited by pommesmatte; 3rd December 2018 at 20:32. |
3rd December 2018, 21:58 | #6583 | Link | |
First run (resulting in absolute paths) Code:
[Information] Log for job14 (idx, HANGMAN_F1_T2_Video - .mkv -> HANGMAN_F1_T2_Video - .dgi) -[Information] [03.12.2018 21:47:15] Started handling job -[Information] [03.12.2018 21:47:15] Preprocessing -[Information] [03.12.2018 21:47:15] Full_Path_In_Files=1 written to DGIndexNV.ini -[Information] [03.12.2018 21:47:15] Job command line: "C:\Multimedia\MeGUI-x64\tools\dgindexnv\dgindexnv.exe" -i "E:\_Eingang\hangman\HANGMAN_F1_T2_Video - .mkv" -o "E:\_Eingang\hangman\HANGMAN_F1_T2_Video - .dgi" -h -[Information] [03.12.2018 21:47:15] Process started -[Information] [03.12.2018 21:47:15] Standard output stream --[Information] [03.12.2018 21:47:16] Project -[Information] [03.12.2018 21:47:15] Standard error stream -[Information] [03.12.2018 21:50:06] MediaInfo --[Information] File: E:\_Eingang\hangman\HANGMAN_F1_T2_Video - .dgi --[Information] Indexed file: E:\_Eingang\hangman\HANGMAN_F1_T2_Video - .mkv --[Information] General ---[Information] Format: Matroska ---[Information] FileSize: 16226081661 ---[Information] PlayTime: 01:38:22.814 --[Information] Video ---[Information] ID: 1 ---[Information] StreamOrder: 0 ---[Information] CodecID: V_MPEG4/ISO/AVC ---[Information] Format: AVC ---[Information] FormatInfo: Advanced Video Codec ---[Information] Width: 1920 ---[Information] Height: 1080 ---[Information] FrameCount: 141526 ---[Information] FrameRate: 23.976 ---[Information] FrameRateMode: CFR ---[Information] FrameRateModeString: Constant ---[Information] Duration: 01:38:22.820 ---[Information] ScanType: Progressive ---[Information] Bits Depth: 8 ---[Information] AspectRatio: 1.778 ---[Information] AspectRatioString: 16:9 ---[Information] PixelAspectRatio: 1.000 ---[Information] Delay: 0 ---[Information] Default: No ---[Information] Forced: No -[Information] [03.12.2018 21:50:07] Postprocessing -[Information] [03.12.2018 21:50:10] Job completed Code:
Version=DGIndexNV 2053.0.0.161 Window_Position=197,125 Info_Window_Position=0,0 Process_Priority=2 Playback_Speed=3 AVS_Template_Folder= AVS_Template_File=template.avs AVS_Template_File_Index=0 AVS_Enable_Template=1 AVS_Overwrite=0 Full_Path_In_Files=1 MRUList[0]=E:\_Eingang\hangman\HANGMAN_F1_T2_Video - .mkv MRUList[1]=E:\_Eingang\overboard\OVERBOARD_F2_T1_Video - .mkv MRUList[2]= MRUList[3]= Enable_Info_Log=0 Loop_Playback=0 AVC_Extension=264 MPG_Extension=m2v VC1_Extension=vc1 HEVC_Extension=265 Deinterlace=0 UsePF=0 AlwaysCrop=1 UseD3D=0 Snapped=0 ResponseOnAudioMismatch=0 Enable_Audio_Demux=1 CUDA_Device=255 Decode_Modes=0,0,0,0 Full_Info=1 Bare_Demux=0 Disable_Encrypted_Audio_Warning=0 Fine_Cropping=0 Force_Zoom=0 StrictAVC=0 PGSForcedOnly=0 Code:
[Information] Log for job15 (idx, PETER_RABBIT_F1_T2_Video - .mkv -> PETER_RABBIT_F1_T2_Video - .dgi) -[Information] [03.12.2018 21:51:56] Started handling job -[Information] [03.12.2018 21:51:56] Preprocessing -[Information] [03.12.2018 21:51:56] Enable_Info_Log=1 written to DGIndexNV.ini -[Information] [03.12.2018 21:51:56] ResponseOnAudioMismatch=1 written to DGIndexNV.ini -[Information] [03.12.2018 21:51:56] Job command line: "C:\Multimedia\MeGUI-x64\tools\dgindexnv\dgindexnv.exe" -i "E:\_Eingang\peter hase\PETER_RABBIT_F1_T2_Video - .mkv" -o "E:\_Eingang\peter hase\PETER_RABBIT_F1_T2_Video - .dgi" -h -[Information] [03.12.2018 21:51:56] Process started -[Information] [03.12.2018 21:51:56] Standard output stream --[Information] [03.12.2018 21:51:56] Project -[Information] [03.12.2018 21:51:56] Standard error stream -[Information] [03.12.2018 21:55:17] MediaInfo --[Information] File: E:\_Eingang\peter hase\PETER_RABBIT_F1_T2_Video - .dgi --[Information] Indexed file: E:\_Eingang\peter hase\PETER_RABBIT_F1_T2_Video - .mkv --[Information] General ---[Information] Format: Matroska ---[Information] FileSize: 19074151615 ---[Information] PlayTime: 01:34:42.677 --[Information] Video ---[Information] ID: 1 ---[Information] StreamOrder: 0 ---[Information] CodecID: V_MPEG4/ISO/AVC ---[Information] Format: AVC ---[Information] FormatInfo: Advanced Video Codec ---[Information] Width: 1920 ---[Information] Height: 1080 ---[Information] FrameCount: 136248 ---[Information] FrameRate: 23.976 ---[Information] FrameRateMode: CFR ---[Information] FrameRateModeString: Constant ---[Information] Duration: 01:34:42.683 ---[Information] ScanType: Progressive ---[Information] Bits Depth: 8 ---[Information] AspectRatio: 1.778 ---[Information] AspectRatioString: 16:9 ---[Information] PixelAspectRatio: 1.000 ---[Information] Delay: 0 ---[Information] Default: No ---[Information] Forced: No -[Information] [03.12.2018 21:55:17] Postprocessing -[Information] [03.12.2018 21:55:23] Job completed Code:
Version=DGIndexNV 2053.0.0.161 Window_Position=197,125 Info_Window_Position=0,0 Process_Priority=2 Playback_Speed=3 AVS_Template_Folder= AVS_Template_File=template.avs AVS_Template_File_Index=0 AVS_Enable_Template=1 AVS_Overwrite=0 Full_Path_In_Files=0 MRUList[0]=E:\_Eingang\peter hase\PETER_RABBIT_F1_T2_Video - .mkv MRUList[1]=E:\_Eingang\hangman\HANGMAN_F1_T2_Video - .mkv MRUList[2]=E:\_Eingang\overboard\OVERBOARD_F2_T1_Video - .mkv MRUList[3]= Enable_Info_Log=1 Loop_Playback=0 AVC_Extension=264 MPG_Extension=m2v VC1_Extension=vc1 HEVC_Extension=265 Deinterlace=0 UsePF=0 AlwaysCrop=1 UseD3D=0 Snapped=0 ResponseOnAudioMismatch=1 Enable_Audio_Demux=1 CUDA_Device=255 Decode_Modes=0,0,0,0 Full_Info=1 Bare_Demux=0 Disable_Encrypted_Audio_Warning=0 Fine_Cropping=0 Force_Zoom=0 StrictAVC=0 PGSForcedOnly=0 Last edited by pommesmatte; 3rd December 2018 at 22:03. |
3rd December 2018, 22:14 | #6584 | Link |
Ok, thanks, with your ini files I am able to reproduce it. Question is why this is happening. Before DGIndexNV starts the value is correct, afterwards it gets removed.
EDIT: Sorry, no clue. I made a line by line comparison and changed everything to the default one, however it still reverts to 0. Could you please delete your dgindexnv.ini and try it again? Last edited by Zathor; 3rd December 2018 at 22:25. |
4th December 2018, 19:22 | #6588 | Link | |
Potentially I can do the same either in the way that - the file is renamed during the whole process - or the file is copied to the working path with a new file name I tend to go the second way as this works every time (rename is only possible if the source can be modified). Any thoughts? |
4th December 2018, 22:44 | #6589 | Link | |
However I could reproduce the buggy behaviour again, by disabling full paths in DGIndexNV GUI (it seems that also was the culprit before). After that the behaviour is as described. It can be repaired by deleting ini file OR by enabling the option IN THE GUI again, manually editing the option in the DGIndexNV.ini does not work however. |
5th December 2018, 08:01 | #6591 | Link | |
6th December 2018, 15:48 | #6593 | Link | |
So far so good. I assume it's not possible to completely fix the DGIndexNV problem with mod2 video. I made another sample, 602x362 this time. DGIndexNV adds "CLIP 0 6 0 6" to the index file, but it seems only the mod4 part of the padding is cropped. The rest is resized. There's probably nothing MeGUI could do to work around that. There also seems to be some frame rate oddness. When I opened the original vob file I used to create the mod2 test MKV with DGIndexNV, it showed the frame rate as 29.970030 and the index file said FPS 30000 / 1001 However for the MKV encode I made from the vob file, DGIndexNV itself showed 29.970031, but the index file said FPS 299700 / 10000 As well as the mod2 problem videoh said doesn't need fixing because it's not a problem, you can see the LWLibavVideoSource vs DGDecode frame rate difference in the screenshots. Maybe MeGUI should automatically add AssumeFPS to a DGSource script? LWLibavVideoSource("D:\test.mkv.lwi") DGSource("D:\test.dgi") The rest of the GUI unfriendliness seems to have been worked around, although given there's mod2 issues preventing MeGUI from correctly calculating any aspect error, I'd consider blocking DGIndexNV for mod2 sources. Thanks for the hard work! Last edited by hello_hello; 6th December 2018 at 15:55. |
6th December 2018, 15:54 | #6594 | Link | |
6th December 2018, 16:57 | #6595 | Link | |
Useful n00b
If you provide the stream I can look at your FPS matter. However, the difference appears practically insignificant. It might be resolved already with a change I did for Zathor (not yet slipstreamed): prefer the container frame rate over the ES frame rate. With your stream I can confirm or disconfirm that. Last edited by videoh; 6th December 2018 at 21:40. |
6th December 2018, 20:40 | #6598 | Link | |
Useful n00b
The first sample that I politely requested and that you declined to supply was for your cropping issue. I was aware of the NVDec issue but needed to confirm that this was the root issue for you and not something else. Be aware that issues with the same or similar symptoms can sometimes be caused by different root causes. This second sample that I have politely requested is to confirm or disconfirm that your FPS issue is resolved by my recent change not yet slipstreamed. The file that Zathor has kindly supplied cannot help me to confirm that your file is or is not now handled properly regarding FPS detection. Can you please provide this sample that shows your FPS issue? Thank you. Last edited by videoh; 6th December 2018 at 21:26. |
8th December 2018, 11:15 | #6600 | Link |
Try replacing "Dither_out()" by "ConvertFromStacked()".
If it still doesn't work show complete MeGUI log and Avisynth script. |
