Old 30th May 2024, 23:25   #20701  |  Link
Originally Posted by FTLOY View Post
Maybe back then, FFMS2 was faulty, but the latest build, and BS appear to be "fine" (in your words).
Couple Years too late.
Old 31st May 2024, 01:47   #20702  |  Link
Never too late, and you're the only one that do anything about it...
Old 31st May 2024, 01:53   #20703  |  Link
Problems with v1.27.3...
Just got this update, and sure enough, as others have mentioned, there is a virus type problem with both RipBot264.exe, and EncodingServer.exe, they were both quarantined, and you have to go in & restore them, so hopefully we'll only have to do that once.
So despite that, here's the changelog:-
v1.27.3
Added: Encoding error logging in EncodingServer
Added: EncodingClient can run custom script (EncodingClient.cmd) if EncodingServer detects an error during encoding process
Added: Errors can be also viewed in EncodingClient by clicking on red server label
Fixed: Randomly resetting progress in EncodingClient after restart
Can you please explain this new feature, and how to use it ??
Yes, the "virus" issue seems to be a little persistent, and even adding an exclusion for the whole RipBot264 folder does not remedy the problem.
Maybe being compiled on a W7 PC, with a totally different AV app to W10 & W11 PC's.....just thinking out loud.
I hope this doesn't break too may RipBot installs, out there
Old 31st May 2024, 06:27   #20704  |  Link
Originally Posted by rlev11 View Post
Yep, picks up Trojan:Win32/Phonzy.B!ml on ribbot264.exe and Trojan.Win32/Wacatac.B!ml on encodingclient and encodingserver exe's
Malwarebytes did not pick them up, only microsoft AV realtime protection
Downloaded the latest Microsoft Safety Scanner and ran that against it and it came back clean as well
I grabbed that app too, and it detected 1 infected file during the scan, but when it completed, it stated there were no issues.
Strange thing, I copied the updates onto the 7950X, and had no warnings, as I did on the W11 laptop, earlier.
https://learn.microsoft.com/en-us/de...o365-worldwide 148Mb download.
UPDATE:-
Well after all that, I loaded a job into 1.27.3, and started the encode, and got all sorts of warnings, and RipBot264.exe, and EncodingServer.exe were being quarantined, so for me, this new build is unusable
Old 31st May 2024, 10:04   #20705  |  Link
Nothing new. Almost everytime I do an update some antivirus goes crazy. I do not care at this point. Probably after some weeks they will white list those updated files.
Old 31st May 2024, 12:36   #20706  |  Link
1) Enable this option
2) open EncodingClient.cmd in notepad
3) Add your program you want to launch. For example you can use some program to send you a notification on your phone via email or push notifications.
@REM *****************************************************
@REM *                                                   *
@REM * %ERRORMESSAGE%     -> encoding error message      *
@REM *                                                   *
@REM               <INSERT YOUR SCRIPT HERE>
MyProgram.exe "%ERRORMESSAGE%"
%ERRORMESSAGE% text will be automatically replaced by proper error message.
For example:
192.168.0.1:1000 [2024-05-30 15:09:00] JOB1/CHUNK1: encoding stalled: [13.1%] 187/1426 frames. Process automatically killed.
Old 1st June 2024, 02:21   #20707  |  Link
@REM *                                                   *
@REM *                                                   *
For example:
OK, thanks for that....one thing I just thought of, how to play an audio file if there's an error ??
What would be the command line for that ?? (Example please, with the audio file being in the main RipBot folder)
Old 1st June 2024, 10:24   #20708  |  Link
You might use a command line media player, like mplayer / ffplay / a system media call in a PowerShell script ...
Old 1st June 2024, 11:17   #20709  |  Link
C:\RipBot264\Tools\ffmpeg\bin\ffplay.exe "C:\Windows\Media\Windows Error.wav" -autoexit -showmode 0 -loglevel 0
Old 1st June 2024, 11:40   #20710  |  Link
Thankyou, Atak, that's all I needed, to point me in the right direction.
I got it to work with the .wav I want to play (of course it was a very different path)
Old 1st June 2024, 12:24   #20711  |  Link
Is there a way to test in from the EncodingClient.cmd ??
During encoding kill ffmpeg.exe
You may use this command
taskkill /IM ffmpeg.exe
Old 1st June 2024, 12:37   #20712  |  Link
Thanks again.
However, when I got the command line in the correct place in the .cmd, simply double clicking on the .cmd, it played.
And if it's left as is, (as shown below) the error message will be displayed as well as the sound.
Old 2nd June 2024, 07:18   #20713  |  Link
dipais
What sort of a "watermark" do you want to insert ?? (sample maybe, but don't attach it with your reply !!!)
You need to figure out how to write your own custom scripts !!!
FTLOY,
I really didn't have time to look at what I had asked a long time ago. Please forgive me. So what I mean is using Ripbot to insert a watermark in the top right position like in this Netflix video.
Would you mind telling me the steps. What scripts are supported by Ripbot. I'm a newbie in this matter so I don't really understand how to use scripts in Ripbot.
Cheers,
D
dipais is offline   Reply With Quote
Old 2nd June 2024, 08:22   #20714  |  Link
Originally Posted by dipais View Post
FTLOY,
Cheers,
D
Hi, I've never tried to ADD a watermark, so I will have to have a bit of a play.
In the meantime, someone else may suggest something.
Old 2nd June 2024, 14:06   #20715  |  Link
FTLOY,
Cheers,
D
Just replace this with proper path to your PNG file.
Image=ImageSource("ripbot264-ico.png",pixel_type="RGB32")
#Custom
ImageScalingFactor=32 #larger value = smaller image
ImageTransparencyFactor=0.5 #1.0 = 0% transparency , 0.0 = 100% transparency
ImageMixingMode="Blend" #Blend , Add , Subtract , Multiply , Chroma , Luma , Lighten , Darken , SoftLight , HardLight , Difference , Exclusion
ImagePosition="TopRight" #TopLeft , TopRight , BottomRight , BottomLeft
MarginSizeFactor=0.01 #larger value = larger shift from edges of the frame
ImageAlpha=ShowAlpha(Image)
ImageAR=Image.width/Image.height
ImageTargetWidth=Int(video.width/ImageScalingFactor)
ImageTargetHeight=Int(ImageTargetWidth/ImageAR)
Image=Spline36Resize(Image,ImageTargetWidth,ImageTargetHeight)
ImageAlpha=Spline36Resize(ImageAlpha,ImageTargetWidth,ImageTargetHeight)
MarginSize=Int(video.width*MarginSizeFactor)
cond = (LCase(ImagePosition)=="topleft") ? Eval("""
	ImagePosX=0+MarginSize
	ImagePosy=0+MarginSize
""") : Eval("""""")
cond = (LCase(ImagePosition)=="topright") ? Eval("""
	ImagePosX=video.width-image.width-MarginSize
""") : Eval("""""")
cond = (LCase(ImagePosition)=="bottomright") ? Eval("""
	ImagePosy=video.height-image.height-MarginSize
""") : Eval("""""")
cond = (LCase(ImagePosition)=="bottomleft") ? Eval("""
""") : Eval("""""")
video=Overlay(video,Image,mask=ImageAlpha,x=ImagePosX,y=ImagePosY,opacity=ImageTransparencyFactor,mode=ImageMixingMode)
Old 2nd June 2024, 14:43   #20716  |  Link
I thought I'd try this, and I even got a Netflix.png and I reduced it's size a LOT, and it doesn't show when previewing the clip.
Old 2nd June 2024, 14:53   #20717  |  Link
Problem?
Old 2nd June 2024, 15:09   #20718  |  Link
Problem?
OK, so what are the dimensions / properties of your Netflix ?
Old 2nd June 2024, 15:10   #20719  |  Link
2226 x 678 pixels
Old 2nd June 2024, 15:20   #20720  |  Link
2226 x 678 pixels
Hmmmm, my .png was a lot smaller than that.
