#20861 | Link |
Profiles/Audio.txt
#20862 | Link |
Audio.txt 2.0 OPUS CODEC 64 kbps [abr] 2.0 OPUS CODEC 96 kbps [abr] 2.0 OPUS CODEC 128 kbps [abr] 5.1 OPUS CODEC 160 kbps [abr] 5.1 OPUS CODEC 240 kbps [abr] 5.1 OPUS CODEC 320 kbps [abr] 7.1 OPUS CODEC 224 kbps [abr] 7.1 OPUS CODEC 336 kbps [abr] 7.1 OPUS CODEC 448 kbps [abr] 2.0 FHG AAC-HE 64 kbps [abr] 2.0 FHG AAC-LC 96 kbps [abr] 2.0 FHG AAC-LC 128 kbps [abr] 2.0 FHG AAC-LC 256 kbps [abr] 5.1 FHG AAC-HE 192 kbps [abr] 5.1 FHG AAC-LC 256 kbps [abr] 5.1 FHG AAC-LC 320 kbps [abr] 7.1 FFMPEG AAC 384 kbps [abr] 7.1 FFMPEG AAC 448 kbps [abr] 7.1 FFMPEG AAC 640 kbps [abr] 2.0 FFMPEG AC3 192 kbps [cbr] 2.0 FFMPEG AC3 224 kbps [cbr] 2.0 FFMPEG AC3 256 kbps [cbr] 5.1 FFMPEG AC3 384 kbps [cbr] 5.1 FFMPEG AC3 448 kbps [cbr] 5.1 FFMPEG AC3 640 kbps [cbr] 2.0 FFMPEG FLAC ??? kbps [vbr] 5.1 FFMPEG FLAC ??? kbps [vbr] 7.1 FFMPEG FLAC ??? kbps [vbr] UPDATE:- I thought I'd try this, and it indeed add's it to the Profile options for the job, I guess the proof is in the pudding if it actually encodes it to that setting. Last edited by FTLOY; 27th August 2024 at 03:54. |
#20863 | Link |
I tested editing that text file. I managed to convert with that custom value. Thanks!
Another question if you don't mind... ![]() I wonder what would be sane values when denoising a specific grainy video? Sample pics: Original video: https://images2.imgbox.com/0d/ce/X8DX3n8B_o.png Used Degrain3, 400 : https://images2.imgbox.com/91/c9/EUoz0E3G_o.png Used Degrain3, 800 : https://images2.imgbox.com/08/e5/yKAB34TV_o.png Sample pics2: Original video: https://images2.imgbox.com/d5/50/loTDbpNr_o.png Used Degrain3, 400 : https://images2.imgbox.com/79/78/Pec7u2cb_o.png Used Degrain3, 800 : https://images2.imgbox.com/4d/6d/FlrBBok1_o.png What I'm asking is second a second opinion - do you think those values are reasonable / do those pictures look good? Personally I think both of them look good to me. I'm just worried that Degrain3 800 would be too much. Last edited by Juha; 28th August 2024 at 15:44. |
#20864 | Link | |
![]() SMDegrain would probably do better (but that's a whole different story).. It doesn't really matter what other ppl might say..if it looks good to you, that's all that matters. TBH, your source file is pretty bad, what resolution is that ?? Last edited by FTLOY; 29th August 2024 at 03:37. |
#20865 | Link | |
There is a point in my eyes where too much degraining can cause adverse picture quality. Where I would notice it in particular would be peoples foreheads when there is motion. I would notice the pores get washed out really bad and get "plastic" looking. then when stopped the pores would return. I also hate film grain so there is a fine balance between too little and too much degraining. I'm pretty much to the point now where I only use 3 different strengths. Very little grain , some grain , a lot of grain. I watch a couple scenes of a video and just pick the one I feel is the closest and go with it. You will never completely eliminate a heavy grained source and retain all the detail. Even something like Topaz AI is going to struggle with that. |
#20866 | Link | |
Believe it or not, but it's an uncompressed Full HD H264 video from a Blu-Ray disc... It's a 90's movie.
Thanks for replies. Last edited by Juha; 30th August 2024 at 22:51. |
#20867 | Link |
x265 has changed, and it will affect RipBot !!! (sooner or later)
I just wanted to post something about this again, as it will need to be addressed sometime soon.
For the users that like to update RB manually, any recent x265 builds, will produce an error like this :- Code:
""\\RYZEN-9-7950X\Ripbot264temp\Tools\ffmpeg\bin\ffmpeg.exe" -loglevel panic -i "\\RYZEN-9-7950X\RipBot264temp\job3\Chunks\1.avs" -strict -1 -f yuv4mpegpipe - | "\\RYZEN-9-7950X\Ripbot264temp\tools\x265\x265_x64.exe" --seek 0 --colorprim bt2020 --transfer smpte2084 --colormatrix bt2020nc --master-display "G(13250,34500)B(7500,3000)R(34000,16000)WP(15635,16450)L(40000000,50)" --crf 16 --fps 24000/1001 --min-keyint 24 --keyint 240 --frames 3610 --sar 1:1 --level 5.2 --profile main10 --output-depth 10 --ctu 64 --high-tier --vbv-bufsize 240000 --vbv-maxrate 240000 --y4m --pools "32" --output "\\RYZEN-9-7950X\RipBot264temp\job3\Chunks\1.265" -" x265 [WARN]: extra unused command arguments given <-> |
#20868 | Link |
I ripped my first 4K movie. For testing purposes, I made two rips of it:
- 4K resolution rip - Full HD resolution rip (resized original 4K to Full HD) I used the setting to crop black bars but Ripbot only cropped black bars from 4K rip. 4K -> Full HD rip didn't get black bars cropped. I suspect it's because I didn't choose "custom" as the output resolution, but if I crop something, shouldn't it always be taken into account even if I choose a predefined resize option? 4K rip: https://images2.imgbox.com/07/ad/hd6GSBcs_o.png Full HD rip: https://images2.imgbox.com/b9/ca/j4n4wjg7_o.png (Screenshots were taken by using MPC's native "save image" function.) Cropping / resize settings in Ripbot I used for the Full HD rip: https://images2.imgbox.com/da/a4/vBf2sUmF_o.png Resolution of the output 4K rip is 3840 x 1600. Full HD rip is 1920 x 1080. Last edited by Juha; 4th September 2024 at 12:06. |
#20869 | Link | |
#20871 | Link | |
This way you will get what you are trying to do is downsize the encode without encoding the black bars. Doing the 1920x1080 [2.40:1] will encode it at the resolution specified which would be 1920x1080, but will just put the flag into the stream that it is a 2.4:1 aspect ratio. This way only works if the aspect ratio is one of the presets built into ripbot. I think what is in now is 1.78,1.85,2.0,2.35, and 2.4. If the pixels are just a few off just choose the preset that it shows, So if the autocrop shows 2.394:1 just choose the 2.40 and go. you will not notice those couple of pixels added or missing. If it is not really close to one of the presets for something oddball, just get out the calculator and figure out what the 1920 x height number is (round up or down if not a full pixel) by using the SAR number from the autocrop if you have black bars on top and bottom. Vertical bars you would do the same except take 1080 times the SAR number. So a SAR of 1.5 would be 1620x1080. This is where you would use the bottom custom resize setting that lets you choose both width and height. Bottom line is for horizontal bars use 1920 as the width and calculate the height, and for vertical bars use a height of 1080 and calculate the width. Last edited by rlev11; 4th September 2024 at 23:58. Reason: added some extra text |
#20872 | Link | |
And after rlev11's excellent explanation, it might take you longer to "set it up" than how much longer those black bars take to process, and from what I understand, if you don't get it right, then you'll have to do it all over again....just sayin'. |
#20873 | Link | |
#20874 | Link | |
1920x1080 + MDegrain2 400 ![]() 1920x800 + MDegrain2 400 ![]() You basically get ~16% faster script processing for free. Add x265 encoder and it may go up to ~20% total. Here We call this optimization...
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 5th September 2024 at 12:04. |
#20875 | Link |
Ha, not everything needs to be cropped, and some it's a little complicated.
Autocrop can sometimes not do the job properly, and I'm not going to get the calculator out. If it looks OK on the TV, WGAF !!, I did a crop test a week or so ago, and it looked the same.... |
#20876 | Link | |
#20878 | Link |
Pig on the wing
There's no reason not to crop. The borders are not always totally black and also may contain (invisible) compression artifacts which affect the bitrate needed.
Cropping has been a strong recommendation since I started working with video stuff over 20 years ago.
#20879 | Link | |
And I've been encoding for 20+ years too.... |
#20880 | Link |
Going back to my test video of ST Strange new worlds in 4k. Original pixels is 3840x2160, but in a 2.4:1 aspect ratio so there are 560 horizontal lines of black space. If I encode it without an autocrop (x265 and using Smdegrain...), my test chunk on my 7950x shows 14.06 fps. That same chunk with an autocrop so encoding 3840x1600 comes out at 19.83 fps. That like a 29% increase in speed at the expense of 2 extra clicks. Resizing that down to 1080p takes 3 more clicks and typing in 1920. And "getting the calculator out" would be very rare if only downsizing an oddball aspect ratio.
To each his own, but I will keep cropping useless data and enjoy the speed increase for the time of a few extra clicks.... |
