#20921 | Link | |
So thank you for that, much appreciated! |
#20926 | Link |
ffx264/ffhevc author
20 was chosen at the beginning, when they added presets, and hasn't changed. At that time, x265 wasn't very good still so it needed more bitrate. Now, x265 is "good enough(tm)" and 23 is optimal CRF for me wrt quality/file size trade-off
#20929 | Link | |
Pig on the wing
When talking about CRF, it must be remembered that the "hdr10-opt" parameter that should be enabled with HDR encodes, shifts the scale a bit so you can use a 1-2 points lower value for the same average bitrate.
#20930 | Link | |
--profile main10 --output-depth 10 in it. It appears to me when encoding hdr, that even with the default setting, that the bt2020 parameters for hdr are being passed in the encode. |
#20931 | Link | |
Pig on the wing
You can use MediaInfo to see which parameters have been used on the video.
#20932 | Link |
Batch mode instructions?
Hey everyone. My Google Fu is failing me.
Is there a tutorial on Batch mode? My episode files have a DTS-HD track and I assumed with the defaults based on this pic, it would copy the stream over. Instead it's converting it to FLAC. How can I adjust that? In case the pic doesn't come through, it's the default batch window of Audio 1: DEFAULT English 1_audio 7.1|COPY STREAM 5.1|COPY STREAM 2.0|COPY STREAM 5.1|FFMPEG AC3|640 kpbs 2.0|FFMPEG AC3|256 kbps Last edited by valnar; 4th November 2024 at 14:45. Reason: clarification |
#20934 | Link |
How to retain Forced Subtitles flag
Before encoding a video I strip out any subs I don't want leaving just the English Subtitles, and English Forced Subtitles. I make sure that the forced subtitle has the Forced value set to YES
When the Forced Subtitles are de-muxed they end up in the corresponding Job folder with a file name like this (so far so good) 1_subtitles_English_DEFAULT_FORCED.srt But after encoding has been completed by Ripbot and the output is remuxed that subtitle still ends up with the Forced value set to NO, I need to open the output file in MKVToolnix change the flag to Yes and Remux it. When I look at Profile setting under preferred forced subtitles, it says FORCED and has examples of English|Forced.SSA as the filename to be used. But I don't control the filename that the subtitle is output as. Does that mean I should be entering this file name in that field for it to retain the forced flag? 1_subtitles_English_DEFAULT_FORCED.srt in that box? Or if that's not it, how do I retain the Forced value without having to remux after the encode? |
#20935 | Link |
Is 1_subtitles_English_DEFAULT_FORCED.srt automatically selected in SUBTITLES section after demuxing?
I think the problem is that 1_subtitles_English_DEFAULT_FORCED.srt was originally muxed with two flags DEFAULT and FORCED. In that case RipBot treats that file as DEFAULT.
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 8th November 2024 at 15:42. |
#20936 | Link | |
I did a test just now where I set Default to NO and Forced to YES, but Ripbot still did not set it to forced automatically in the job. I also tried adding both English_DEFAULT_FORCED and DEFAULT_FORCED to the preferred forced subtitle box and that didn't do anything either. It seems the only workarounds are to either Edit the job to manually select the subtitle I want forced. Or to edit the output with MKVToolnix, set the flag to YES and Remux. |
#20937 | Link |
Has anyone been able to get RipBot to work with Linux via WINE?
I know a Virtual Machine (VM) option exists but would take more resources... and I'm trying to de-windows my life, but it is soo hard ![]() I saw some interest from a few users (TDS, apol847, dv8r, BLKMGK, Ryushin, and mparade) Or is there something for Linux that does distributed encoding like RipBot? |
#20938 | Link | |
#20940 | Link | |
I did a couple quick tests and re-encoded some hdr material using hdr10-opt in the command (along with what I believe is correct from reading also adding --aq-mode 2). I can not tell any visual difference in the new encodes EXCEPT I am now getting anywhere from a 5 - 40 percent decrease in the final output size. So a win-win in my book. Since having --hdr10-opt in the profile will not ignore and blow up the encode on non-hdr material, I just now have an additional profile I use specifically for hdr material now which is no problem. Also, I posted back a bit that I was having issues with the latest encoding client .exe. Just recently I let ripbot auto update again which installed the latest version. I have done a bunch of encodes recently and have had no issues. Not sure if something was updated with ripbot, or something maybe with a windows update took care of the issue. Just wanted to get that out there.... |
