Old 10th March 2025, 19:28   #21181  |  Link
Juha
Mobius is not perfect. Bt2446 is much better.
https://forum.doom9.org/showthread.p...74#post1893674
I assume Bt2446 is something that Ripbot is using?
With my movies that doesn't produce good looking results what it comes to brightness. It's just too dark to me.
This is from 1080p Blu-Ray disc:
https://images2.imgbox.com/8d/cd/Dp4nRzWH_o.png
4K disc, RipBot Tonemap enabled:
https://images2.imgbox.com/d2/76/iDHR6K0A_o.png
4D disc, no Tonemap:
https://images2.imgbox.com/30/03/IDkM3A6N_o.png
Is there a way for me to test what results I get in Ripbot if I try different methods? How do I apply those commands to a Ripbot job? (Mobius, Hable, Reinhard etc.). I'm happy to use any method/settings that produces results as if the source were a 1080p blu-ray disc.
Juha is offline   Reply With Quote
Old 11th March 2025, 01:44   #21182  |  Link
TR-7970X
TR-7970X's Avatar
The original certainly looks the best....
You should be able to make as many changes to the HDRtoSDR.avs as you like, until you get the desired result.
This might help:-
http://www.avisynth.nl/index.php/HDRTools
Other options would be creating your own custom script, or running FFMPEG after RipBot has completed the encode.
TR-7970X is offline   Reply With Quote
Old 12th March 2025, 14:38   #21183  |  Link
Normally difference between Tonemap OFF and Tonemap ON should be much bigger than in your example
TONEMAP OFF
TONEMAP ON (BT2446)
Old 15th March 2025, 07:13   #21184  |  Link
stretch009
v1.27.4 issues
I've been having issues using v1.27.4 and someone in other forum said rolling back to v1.27.3 fixed there issues. How do I roll back to v1.27.3?
stretch009 is offline   Reply With Quote
Old 15th March 2025, 07:58   #21185  |  Link
TR-7970X
TR-7970X's Avatar
What issues are you having ?
You can't really roll back, due to the way RB gets updated.
However, rlev11 posted some older versions here:-
https://forum.doom9.org/showthread.p...63#post2012363
Main Systems:-
Threadripper 7970X on Asus Pro WS TRX50-Sage WiFi
Ryzen 9 9950X3D on MSI Carbon X670E
Ryzen 9 7950X on Gigabyte Aorus Elite B650
Intel 13900KF on MSI Tomahawk B660
Old 15th March 2025, 08:26   #21186  |  Link
stretch009
I used to be able to use Luts but I'm getting errors now. (I believe it was fine before the update to 1.27.4):
Old 15th March 2025, 09:02   #21187  |  Link
TR-7970X
TR-7970X's Avatar
Did this work with 1.27.3 ?
Looks more like the input file has a problem.
Main Systems:-
Old 15th March 2025, 20:13   #21188  |  Link
stretch009
I definitely don't think it's the input file that has the problem since I tried several files. One thing I noticed is while I had two cube files in the Lut
folder from time to time I was able to preview one of them and the other one always errored out. I've had the same errors with 1.27.4 and now
1.27.3 but I think I might have fixed it. It appears it's as simple as only having one cube file in the Lut folder. I put the cube file that was erroring
out every single time by itself now in the Lut folder. It immediately worked.
Old 16th March 2025, 12:34   #21189  |  Link
Juha
TONEMAP OFF
TONEMAP ON (BT2446)
I've had bad experiences with more than one 4K film.
Any change to share that piece of the clip in it's original 4K HDR format where that scene is? I'd like to try tonemapping that scene on my end.
Old 16th March 2025, 13:06   #21190  |  Link
TR-7970X
TR-7970X's Avatar
You should modify the HDRtoSDR.avs until you get your desired result !
Main Systems:-
Old 16th March 2025, 13:37   #21191  |  Link
https://www.mediafire.com/file/g8u5c...16_4K.mkv/file
Old 19th March 2025, 20:33   #21192  |  Link
Juha
I'm having a issue that I have seen occasionally in the past but now it happened twice in a row.
When using distributed encoding, the Encoding client gets stuck at 100 %. Ripbot window says "Please wait..." but waiting never finishes as the process doesn't complete - it's just stuck at 100 %.
https://images2.imgbox.com/b6/9c/cGtDXuLz_o.png
I can "resolve" this by ending the encoding client process in the task manager - after this, RB starts to mux the encoded file.
Old 19th March 2025, 22:13   #21193  |  Link
Juha
When using tonemap, the end result is quite similar on my end, compared to yours:
https://images2.imgbox.com/c3/72/b22ErA4X_o.png
Interestingly, that original clip looks quite different on my end, compared to you:
https://images2.imgbox.com/24/fa/P6d7NMo1_o.png
Maybe Media Player Classic / K-Lite codec pack does some tweaks to the 4K HDR video...
Anyway, as I have major share of my movies in 1080p SDR, I want to rip my 4K movies to look exactly like them because I have used to the brighter image
Though, that one particular scene does look fine, I admit. But I still don't like the overall look of BT2446 in other movies so I guess I'll need to do some setting tweaking.
Old 19th March 2025, 22:24   #21194  |  Link
Juha
Yes.
But I don't know exactly what these values: (Lhdr & Lsdr) do (other than affect brightness someway) and how changing them affects the end result. If I could get some advice how to use those values, I would appreciate. http://avisynth.nl/index.php/HDRTools doesn't explain much.
Open HDRtoSDR.avs in notepad and change that value in red.
Function HDRtoSDR(clip video,string "Transfer")
source=video
Transfer = Default(Transfer,"")
cond = (Transfer=="PQ") ? Eval("""
	video=ConvertYUVtoXYZ(video,Color=0,HDRMode=0,OOTF=false,OutputMode=2,threads=1)
	video=ConverXYZ_BT2446_C_HDRtoSDR(video,PQMode=true,Lhdr=50000.0,Lsdr=100.0,pColor=0,pct_ref=0.6,pct_ip=0.6,pct_wp=1.0,pct_sdr_skin=1.0,pct_hdr_skin=0.44,threads=1)
	video=ConvertXYZtoYUV(video,Color=2,pColor=0,OOTF=false,threads=1)
	video=ConvertBits(video,8)
""") : Eval("""""")
Old 19th March 2025, 22:49   #21195  |  Link
Can you upload unprocessed hdr sample which looks too dark after tonemap?. I would like to take a look...
Old 20th March 2025, 01:08   #21196  |  Link
TR-7970X
TR-7970X's Avatar
Yes.
Maybe you could have a look here:- https://forum.doom9.org/showthread.p...07#post1843107 (if you haven't already) it might be helpful.
You could still create your own Custom script, instead of changing HDRtoSDR.avs
Main Systems:-
Old 29th March 2025, 16:33   #21197  |  Link
stryker412
I just tried to run a few episodes through Ripbot. I am taking the HD remux to an hevc. As soon as I hit start encoding it finishes immediately. I'm still running v 126.0.0 but the last time I used it (last month?) it worked fine.
Edit: Tried on 1.27.1 and it went through fine. Why wouldn't the older version work?
stryker412 is offline   Reply With Quote
Old 31st March 2025, 21:57   #21198  |  Link
stretch009
Rendered Subtitles Issue
I'm burning/rendering the English subs for Italian dialogue for the Godfather trilogy using the latest 1080p BD's. Wherever you use them, media players et cetera they are gold(ish) colored. After using BDSup2Sub or rendering with Ripbot they are bright yellow. I saw that Ripbot converts the sup file to sub/idx. Is there anyway to edit those files to bring it back to gold(ish) again?
Old 1st April 2025, 13:57   #21199  |  Link
Ryushin
Ryushin's Avatar
There is an option in the settings to not convert to DVD subs. I always burned my subs in as well, but I had to change that once HDR came out as the subs would mess with the brightness of the whole picture. So I started adding subs to the files and letting the media player overlay the subs (Plex got a lot better handling for this). You may have to do the same thing.
SMDegrain Lite package for RipBot264: https://cloud.chrisdos.com/s/yiXwKbkMsQoNo6X
Old 1st April 2025, 14:26   #21200  |  Link
Do not use rendered subtitles. Just mux them as forced in subtitles section.
