#10901 | Link |
This is great, I like that you shrunk the size of the chunks this should greatly improve efficiency as I have 1 slower machine on my network that was bogging down encoding jobs, especially when it was the last to finish up.
Thanks for directing me to the update, and keep up the good work. |
#10902 | Link |
Requests:
1) In New Job, Properties dialog where you can change deinterlacing, cropping, etc, if no changes were made, then exiting the dialog should be instant, no gathering of information 2) As part of job control, after audio is encoded once, note the time stamp. If the job is re-run and the audio settings, track, audio rip, etc haven't change, then don't encode audio again. 3) In "Encoding Settings" add quickie field to encode 10 second segment. An enable button & beginning time would be required. Thanks Atak as always. |
#10903 | Link |
Are there plans for GPU accelerated x264?
I understand that the folks on this forum are not responsible for the x264 project directly, but was wondering if anybody knew if the x264 project had plans to take advantage of GPU based hardware for their encoding application?
#10904 | Link |
no plans. too much work.
#10907 | Link |
Silent Reader
For distributed encoding computing clients need to have access to source material (e.g. Bluray-rips).
So for example, if you have a 40GB Source, and a local computing client and a remote computing client with nearly same performance, you would have to transfer 20GB to your remote client. Do you really want that?! Additional remote client has to transfer computed result (smalller than that 20GB) back to source for muxing. Maybe you have a synchron 100MBit Internet access, then it is possible (short transfer time), but if you have an asynchron DSL connection (16.000/1000 kbit/sek).... good luck.... upload sucks... in both ways... upload from source to client and upload results from clients back to source. Last edited by Wishbringer; 13th March 2012 at 09:55. |
#10909 | Link | |
This is the latest update. |
#10911 | Link | |
#10912 | Link |
@Atak_Snajpera: got a question regarding fhg aac encoder: Did you check if WinAmps license allows the redistribution of the .dlls ?
(I was wondering since I added support for fhgaacenc but I'm not sure if it's okay to bundle the dlls with the Hybrid installer,..) |
#10913 | Link | |
second then you have to make sure your firewall allows the server app access. I have successfully used the distributed encoding over a routed network without issue |
#10914 | Link | |
#10915 | Link | |
Each encoding server PC has the a: drive mapped to \\server\a$. That drive has the following folders a:\source (all source material goes there) a:\temp\ripbot264temp (temporary space for ripbot264) a:\ripbotoutput (all output from ripbot is directed there On each machine ripbot is run on, I placed the ripbot files in c:\program files (x86)\RipBot, and made shortcuts in the startmenu. in each encoding server, I started up the server and verified that it created an exception in the firewall. on the client, I fired up the encoding client by itself and verified that I can connect to the encoding servers. once that was done, I started some testing with various source files... I actually found that on some files the encodign cliend did not copy the file to the shared folder, but instead referred it to it's location on the server (a:\source\folder\file) so mapping the drive to the same letter on the encoding server solved that problem |
#10916 | Link | ||
#10917 | Link |
after it happened on a .mpg file I mapped the drive and have not had any more issues. I have planned to unmap it and test with other file types to get a list but have not had time to do it yet. to be clear on what happened there, Ripbot created a job#.d2v file that points to the .mpg in the drive source. I can zip up the job file and attach if you want to see it...
I should also add that it does not seem to want to start the distributed encoding for .TS or .VOB files either. is this expected as I found that if I go in and trick ripbot it will distribute the encoding for these file types... Last edited by Shrekage; 15th March 2012 at 16:13. |
#10918 | Link | |
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 15th March 2012 at 16:53. |
#10919 | Link | |
as for the .TS files... I have had these for a very long time. and I dont have that many so it's not a big proglem... Thanks! Last edited by Shrekage; 15th March 2012 at 16:59. |
#10920 | Link |
for .mpg you can trick ripbot by remuxing all your mpg collection to .mkv
