#11143 | Link |
Oh boy, now I'm jealous. I'm averaging between 12-14 hour encode times on my old clunker on 2 hour BD movies. Even when I get DE running on 3 machines the FPS is in the 4-5 range and it's still taking me 8-10 hours. I better start saving my $$$ for one of those i7 quad cores.
#11144 | Link |
One suggestion
Shouldn't the last chunk in each pass be smaller, at most 5000 frames, so that other servers are not idle for a lot of time? And, I got an error which appeared when I logged on the "server" (main machine) using Remote Desktop Connection. At first I thought it was a coincidence, can someone else verify this? (or not?) Last edited by slalom; 9th May 2012 at 10:57. |
#11146 | Link |
I mostly see a difference in the encoding size. A difference of 1-2 could be 500-1000MB difference in a 16x9 1080p movie. With a really grainy movie, it could be about 14GB in size with a CRF of 20 (Fargo comes to mind). With denoising around 4.5, I was able to get it to 8GB. Not a bad space savings and I find the picture quality looks much nicer then with all the grain.
#11147 | Link | ||
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 9th May 2012 at 12:12. |
#11149 | Link |
is this a joke? Download again with proper .ini
#11151 | Link |
correct ini looks like this
[settings] // TEMP=uses System temp ; C , D ... uses specific partition StoreTempFilesin=C KeepJobsQueue=1 --------------------- DefaultProfile=[HIGH 4.0] HD . Progressive DefaultEncodingMode=CQ DefaultModeValue=20 --------------------- //Directory must exists!!! D:\movies\ is correct but D:\movies is incorrect! DefaultOutputPath=desktop --------------------- // allowed values are mp4 , mkv , bluray , mkv-divxhd DefaultContainer=mp4 --------------------- // in GiB (1GiB=1024 MiB) , 0 = no splitting SplitM2TS=0 --------------------- FastFirstPassin2passMode=1 --------------------- //AnyDVD DVD/HD-DVD/Blu-Ray decryptor will be automatically activated with RipBot264 ExecuteAnyDVD=0 --------------------- //Blu-ray subtitles will be converted to SUB/IDX format for .mkv container. Smaller size and better compatibility with some players. ConvertSUPtoSUB=1 --------------------- x264LowPriority=1 --------------------- // it will use 64bit version of x264 on 64bit Windows. up to 10% faster encoding speed. Usex264x64=1 --------------------- // Supported input formats AVI / MP4 / MKV / DVD / HD-DVD / Blu-ray UseDistributedEncoding=1
#11153 | Link |
see previous page
#11154 | Link |
Drunken munky
I assume its all about the update from this link
http://forum.doom9.org/showthread.ph...38#post1573638 Replaced the files now im getting same error with message ending in 0000949A |
#11155 | Link |
I love this program and i have never had any issues with it. I had to learn a bit about interlaced and progressive stuff but since then, every conversion turned out great. I still would like to ask the author a question if i may. Atak - no pressure - but do you have second audio track on your to do list?
#11156 | Link |
DE impressions
I thought i would share my experience with using DE. First of i like to thank Atak for enabling distributed encoding. My setup consists of 5 machines, the first one is a dual CPU Xeon x5650 @ 2.67Ghz (12cores). This box serves as the host for the main ripbot control box. it has all the files stored on it and is where i create the jobs. the 4 other boxes i have vary a bit. each box comes with dual CPU Xeon L5520 @ 2.27ghz (8cores/16HT). 3 of the boxes have 24gb ram and the other has 16gb. all are running 10k scsi drives for storage and OS is 2008r2. The result is 4 encoders able to process bluray at 70-80fps. This is faster than realtime of the movie and generally i can finish a movie in about 90 minutes in 2-pass config using 10bit profile.
The interesting part is the encoder has very similar fps when doing 2-pass encoding. I dont seem to be able to break the 80fps on pass one for bluray content. My guess is that i could be running into a bottleneck on the headend server since it has to communicate all that traffic (130mbit) between all 4 encoders. I know that people have been asking for more encoders added and Atak mentioned 8. This would basically be what i'm running now if you were to use desktop quad cores. i think anything beyond that would be pointless as the overhead required to make them work would defeat the purpose. However, i suppose if you have a bunch of dual cores it might make more sense to have more than 8 but i could also argue you need to get better machines too. ![]() Hope this sheds some light on what it would be like to have 8 quad core desktops as a configuration. Again, great work Atak, thanks for all the hard work and dedication to bring such a great application to us. |
#11157 | Link |
do you really have to use 2-pass mode? constant quality will be faster (1-pass).
if you have 1gbps lan then bottleneck won't occur. 100mbps is indeed to slow for your very fast pcs. let's assume that single pc can encode at real time (24fps). bd movie bitrate is often around 30mbps. 30mbps * 4 pc = 120mbps ups bottleneck ...
#11159 | Link |
i don't use Remote desktop
Also 'error' means nothing to me. I'm not a fortune teller...
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 10th May 2012 at 10:45. |
