#102 | Link |
If I created Guest or Standard User account I indeed got the same error. But If I switched to admin or set XP SP2 compatibility error did not show. Run as admin does not work in my case either. BTW Do you use UAC?
deets when you get that error try to open info.txt from: C:\Users\<your user name>\AppData\Local\Temp\RipBot264temp\job1\info.txt I need to know exactly what values are inside that file. (first is framecount ,below should be framerate...)
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 14th September 2007 at 00:41. |
#105 | Link | |
deets
It should be 189789 23.976044 not 189789;23.976044 in single line ?!?!?!?! What do you see in getinfo.avs? Quote:
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 14th September 2007 at 00:57. |
#107 | Link |
ok. well i have 2 machines, one with vista 64 and that works fine with 1.5.0
this laptop, which is XP, is the one that gives the floating point error though... using the same file to test, so its something about XP? how can i get you that info from XP? edit, nice clean post ![]() ok i found the file on XP and its only MKV that give me the floating point error, the info.txt has this: 64699 23.976044 0 0 0 from 2 mkv files avi and mpg work fine on xp, all work fine on vista Last edited by deets; 14th September 2007 at 01:08. Reason: cleaning up |
#108 | Link |
The Scientist
I think I found solution ![]() I had function CheckRequiredSoftware() in OnCreate event. If function is moved to OnShow event error does not show ![]() deets The easiest way is to search for info.txt
#110 | Link |
There is something wrong. Those zeros mean that audio wasn't detected by avisynth/decoder. (third row shows frequency, fourth is audio channels and the last one is length) Show me your getinfo.avs file.
see you tommorow....time to bed...ZzZZzzZzZzzzzz....
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 14th September 2007 at 01:32. |
#111 | Link |
DirectShowSource("C:\downloads\sample.mkv") WriteFile("C:\DOCUME~1\OWNER~1.YOU\LOCALS~1\Temp\RipBot264temp\job1\info.txt","Framecount") WriteFile("C:\DOCUME~1\OWNER~1.YOU\LOCALS~1\Temp\RipBot264temp\job1\info.txt","Framerate") WriteFile("C:\DOCUME~1\OWNER~1.YOU\LOCALS~1\Temp\RipBot264temp\job1\info.txt","AudioRate") WriteFile("C:\DOCUME~1\OWNER~1.YOU\LOCALS~1\Temp\RipBot264temp\job1\info.txt","AudioChannels") WriteFile("C:\DOCUME~1\OWNER~1.YOU\LOCALS~1\Temp\RipBot264temp\job1\info.txt","AudioLength") Trim(0,-1) 1472 23.976044 48000 2 2946946 I have no clue if this was causing the other issues for people with the same problem... thanks, would have not worked it out had it not been you pointing out the three zeros were the sound ![]() Last edited by deets; 14th September 2007 at 02:22. |
#113 | Link |
AppleTV profile (Right click and select Save link as)
http://yamf.republika.pl/RipBot264/[... ] AppleTV.ini Let me know if It's working or not.
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 17th September 2007 at 01:19. |
#114 | Link |
Has anyone any idea how to make any of the resulting files to play in Quicktime? I even used the iPod profile, but no matter what profile I use i get an error in Quicktime when trying to playback the file:
"Error -2041: an invalid sample description was found in the movie" |
#115 | Link |
One other small suggestion.
After I set a profile, I set autocrop, then I want to set the width. I either want 320 for an ipod or 640 for my computer; but I never know the height. On avi.net you just set the width and the height is calculated for you automatically. Can you do the same thing? The author of avi.net (the Scientist) is on this thread, maybe he can tell you how he did it. |
#116 | Link | |
![]() ![]() BTW You didn't answer my question about AppleTV profile. mrpijey I think it's time to start use real software. Quicktime is a peace of ...
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 17th September 2007 at 21:09. |
#117 | Link | |
![]() But if you guys got any good recommendations for me then please teach me ![]() - Playback on Mac (using iTunes and Frontrow) - Playback on PC (using Media Center and/or iTunes) - Playback on iPod Touch Getting stuff to work on Media Center is the easiest part, since Windows is so forgiving with it's options to accept codecs. Quicktime won't even do divx/xvid, and that's the only option for a decent media center front end on the Mac (Frontrow, which uses iTunes, which uses Quicktime). The alternative is to keep all DVD:s in their original format (4,7-9.4GB MPEG2), and that's a whole waste of space when there are much better codecs out there... and this still would make the Mac a very useless moviebox ![]() So if you got any ideas... |
#118 | Link | |
#119 | Link | |
#120 | Link |
