#41 | Link |
The incredible flexibility and range of settings and the profiling system allow me to fine-tune any content to my liking. So far, i have not tested anything better than madVR.
MPC-BE feature wishlist: 1) DiscID 2) Two independent volume control sliders in the UI when using directsound dual-audio-out. |
#42 | Link |
Betas are updated regularly, though. One can always hope for a paid for version, sooner or later.
LG 77C1 - Denon AVC-X3800H - Windows 10 Pro 22H2 - Kodi DSPlayer (LAV Filters, xySubFilter, madVR, Sanear) - RTX 4070 - Ryzen 5 3600 - 16GB RAM |
#44 | Link | |
I don't dispute the quality it can offer, I strongly dispute the amount of time needed to get there. Especially when comparing to madVR and a DirectShow based player.
#46 | Link | |
_
But the second time, I accepted to spent several hours on the manual: https://mpv.io/manual/master/ If you have lot of free time, it's doable in 1 day, but with limited time, you have to accept you'll need several days (weeks in my case). But now I use it for several years (thanks stax76 for motivating me) Ok, I don't know anything about HDR (i'm still a 1080p SDR user) and maybe it's less good than madVR, but in terms of ressources, mpv is better (you can use HwInfo64 to check CPU/GPU datas for both) But I'm sure a power user which created a nice guide could learn mpv easily ! ![]() |
#47 | Link | |
1. Download and extract into C:\Program Files\mpv 2. Navigate to the C:\Program Files\mpv\installer directory, right-click the mpv-install.bat and Run as administrator. 3. Go to the C:\Program Files\mpv folder and run the updater.bat as administrator (follow the prompts quickly - I recommend selecting the 64bit-v3 version and the daily builds). This simply updates to any new Shinchiro mpv build and installs/updates ffmpeg. 4. Navigate to C:\Users\[user]\AppData\Roaming\mpv and put your mpv.conf text file here. An example mpv.conf added below. FYI, there is an mpv player support thread now on AVS to help with the mpv.conf file and settings. The mpv manual also shows all the various options you can include. https://www.avsforum.com/threads/uno...hread.3274072/ Edit: Here's my current mpv.conf (Windows 10, nVidia RTX 2070S, Display is a JVC X790 projector). You can download shaders from the avs support thread above. Code:
msg-level=auto_profiles=warn,autocrop=warn,autoload=warn,cplayer=warn #no-osc #no-osd-bar no-border snap-window autofit-larger=100%x88% autofit-smaller=33%x66% no-input-default-bindings input-doubleclick-time=200 image-display-duration=inf screenshot-template="%{media-title}-%P-%n" screenshot-format=png sub-font-size=36 sub-border-size=0 sub-back-color=0.0/0.0/0.0/0.75 sub-shadow-offset=4 #Video #ontop fullscreen=yes vo=gpu-next hwdec=nvdec #or d3d11va video-output-levels=full #GPU Renderer fbo-format=rgba16hf #similar to MadVR gpu-api=d3d11 gpu-context=d3d11 d3d11-output-format=rgb10_a2 #Luma Upscaling glsl-shaders-clr glsl-shaders-append="C:\Users\tmitc\AppData\Roaming\mpv\shaders\FSRCNNX_x2_16-0-4-1.glsl" #update to match your location scale=ewa_lanczos scale-blur=0.981251 #Luma Downscaling glsl-shaders-append="C:\Users\tmitc\AppData\Roaming\mpv\shaders\SSimDownscaler.glsl" #update to match your location dscale=mitchell linear-downscaling=no #Chroma Upscaling / Downscaling glsl-shaders-append="C:\Users\tmitc\AppData\Roaming\mpv\shaders\KrigBilateral.glsl" #update to match your location cscale=mitchell #Upscaling / Downscaling Options correct-downscaling=yes sigmoid-upscaling=yes #Deringing scale-antiring=0.7 dscale-antiring=0.7 cscale-antiring=0.7 #Optional Shaders glsl-shader=~~/shaders/adaptive-sharpen.glsl #Dithering temporal-dither=yes dither=fruit dither-depth=auto #Deband (Uncomment options below to enable) #deband #deband-iterations=4 #deband-threshold=48 #deband-range=16 #deband-grain=48 #Audio Bitstreaming #audio-spdif=ac3,dts,dts-hd,eac3,truehd #Uncomment this to enable HDMI bitstreaming (Atmos may currently have issues on some systems) audio-channels=7.1,5.1,stereo #update to match your setup #OSD input-default-bindings = yes input-ar-delay = 500 input-ar-rate = 20 keep-open = yes keep-open-pause = no osd-duration = 2000 #osd-playing-msg = '${filename}' script-opts = osc-scalewindowed=1.5,osc-hidetimeout=2000,console-scale=1 screenshot-directory = '~~desktop/' [protocol.https] #osd-playing-msg = '${media-title}' ############ # Profiles # ############ [bt.2100-pq] profile-cond=get("video-params/primaries") == "bt.2020" and get("video-params/gamma") == "pq" profile-restore=copy target-trc=bt.1886 target-prim=dci-p3 #options are bt.2020, dci-p3, bt.709 tone-mapping=auto #use "vo=gpu-next" to allow the default spline tone mapping (the best) tone-mapping-mode=auto hdr-compute-peak=yes target-peak=100 # change to auto if using an SDR display (defaults to 203 nits) gamut-mapping-mode=auto #uses perceptual by default [bt.2020] profile-cond=get("video-params/primaries") == "bt.2020" and get("video-params/gamma") == "bt.1886" profile-restore=copy target-trc=bt.1886 target-prim=dci-p3 [bt.709] profile-cond=get("video-params/primaries") == "bt.709" profile-restore=copy target-trc=bt.1886 target-prim=bt.709 [interlaced] profile-cond=deinterlace or (get("video-frame-info/interlaced") and not deinterlace) profile-restore=copy deinterlace [end] profile-cond=eof_reached profile-restore=copy-equal
My HT: JVC X790R | 120" CineWhite | madVR HTPC RTX 2070S | mpv | UB420 | Denon X3600H @ 5.2.4 | Totem Tribe LCR | 4 x ADX Maximus & Dayton Audio SA230 | 40" TV / MeLE N5105 / MoviePosterApp Last edited by *MidnightWatcher*; 9th July 2023 at 16:31. |
#52 | Link | |
https://www.avsforum.com/threads/uno...#post-62560932
My HT: JVC X790R | 120" CineWhite | madVR HTPC RTX 2070S | mpv | UB420 | Denon X3600H @ 5.2.4 | Totem Tribe LCR | 4 x ADX Maximus & Dayton Audio SA230 | 40" TV / MeLE N5105 / MoviePosterApp |
#54 | Link |
It works yes, but not perfect. The pause must be before playback starts, not start playback for a split of a second, change refresh rate, pause for the set seconds and continue.
But thank you very much. Finally I got it working, but I stick with MPC-BE with MPC-VR, madVR and LAV Filters and Kodi. |
#56 | Link |
No, not that I'm aware of. You'll need a PC.
#57 | Link | |
Minneapolis
https://yabb.jriver.com/interact/ind...,135621.0.html Support for custom shaders was recently added. Requires MC 31.0.50 or higher.
JRiver Last edited by JimH; 2nd September 2023 at 08:16. |
#58 | Link | |
https://github.com/stax76/awesome-mpv
https://github.com/stax76/software-list https://www.youtube.com/@stax76/playlists Last edited by stax76; 9th September 2023 at 16:38. |
#59 | Link | |
#60 | Link |
Hi, couple of quick questions please :
- Does the JRiver Renderer (JRVR) have RTX Super Resolution support now? Is it planned? - Conversely, since MPC Video Renderer does have RTX Super Resolution support, are you able to use MPC Video Renderer with JRiver Media Player? Thanks, I am hunting for a new video player since ZoomPlayer is only 32bit Last edited by andybkma; 24th October 2023 at 14:48. |
direct3d, enhanced, video renderer |
