29th December 2008, 06:08 | #181 | Link | ||
29th December 2008, 13:05 | #182 | Link | |||
TEST TEST TEST TEST TEST TEST TEST TEST TEST TEST TEST TEST TEST TEST TEST TEST TEST TEST TEST TEST TEST TEST TEST TEST TEST TEST TEST TEST TEST TEST TEST TEST TEST TEST TEST TEST TEST TEST TEST TEST TEST TEST TEST TEST TEST TEST TEST TEST TEST TEST TEST TEST TEST TEST TEST TEST TEST TEST TEST TEST TEST TEST TEST TEST TEST TEST TEST TEST TEST TEST TEST TEST TEST TEST TEST TEST TEST TEST TEST TEST TEST TEST TEST TEST TEST TEST TEST TEST TEST TEST TEST TEST TEST TEST TEST TEST TEST TEST TEST TEST TEST TEST TEST TEST TEST TEST Test done on an old post rather than adding an off topic post to this thread. Last edited by BZeeme; 26th February 2009 at 11:25. Reason: Test of [code] 3 |
29th December 2008, 15:04 | #184 | Link | |
But the menu stuttering (and no Audio in menu) did not go away. I looks like this (only 3 MB) One additional thing about settings and audio: I set in setup Audio languages to keep: English and German. However, only English is kept automatically. I need to add german audio on every Title manually. Bye |
29th December 2008, 15:13 | #185 | Link |
Don't know if this might have anything to do with your problem, but which german choice are you selecting (e.g. "ger" or "deu")? It has to match the code in the source. I think "ger" is the more common one, but I'm really not sure.
29th December 2008, 18:40 | #186 | Link | |
I tried this one too, and yeah i've run into the same issue with the parsing of the playlist files. Is there an easy way to tell prior to starting a project if it branches like Wall-E does? Thoughts?
[SLiM] |
29th December 2008, 21:38 | #189 | Link |
actually jdobbs i'm not sure. I've only backed up Wall-E to this point, and when i put it into the PS3 nothing works, not menu, it sees the disc as a "Data Disc". When i use the same disc in my computer with the bd-rw it plays back fine, so i'm not sure where the issue is. I see others report this type of behaviour but no real answer at this point, off-topic to this thread but bound to come up again mind you....
[SLiM] |
29th December 2008, 21:46 | #190 | Link | |
http://forum.doom9.org/showthread.ph...11#post1229611 |
29th December 2008, 21:54 | #191 | Link |
Well I just finished backing up The Scorpion King, NTSC, Full backup, 4.09GB and burned to DVD+RW. Not having much success here and I am not sure what the problem is. Let me clarify - the audio for the main movie just does not play when burned to a DVD+RW, as with previous attempts. The main menu only plays for about 33 seconds before pausing, and when it continues, there is only audio while the video remains a still image at the pause point. I can select the menu buttons for the disc, so all is still functioning. However, after selecting play, the movie starts and the video looks great, just no audio is heard. Also, as with other backup tests reported, I cannot select subtitles from the remote, no pop up or available subtitles are displayed. Same with audio button, no pop up to display other available tracks.
So I burn the same files to a BD-RE disc, and now the audio and subtitles play fine, with the ability to change both audio and subtitle tracks from the remote during playback of the movie.( There is only the 1 eng. AC3 audio file that plays of course, but the button on the remote brings up the options as if there were other tracks available). The menu video still does its pause at the same time interval as the DVD+RW. However, this is not a big concern since I usually press play before the menu loop anyway, but I just wanted to report my findings. I only have the Sony BDP-BX1 to test with, so I don't know if it is player related or if it could be a BD-RB bug. I use only the default settings, and ImgBurn. I have made numerous movie only backups, not with BD-RB, and never had a problem.BDP-BX1 plays back movie only perfectly. I hope these tests I have reported can help track down if there is a bug, or if I need to do or change something, I am open to any and all suggestions. I would like to be able to keep the menus and burn to DVD-R or DVD+R DL just like all of those succesful reports I have read! |
29th December 2008, 23:38 | #193 | Link | |
- thx jdobbs for pointing me to the additional entry for german language (deu and ger). When checked both, the preselection is working fine. Previously I only had "ger" checked. - The menu stuttering disappeared, when I installed the latest update for PowerDVD 7.3 Ultra The Sound in menu is still missing, but thats maybe simple a Problem, that the menu sound is not eng or ger language and so not be added. Bye |
29th December 2008, 23:43 | #194 | Link |
@rendez2k
I tried what was mentioned in that thread and had the same issue where the menu would not play. It would just play all previews and all else was fine, but once it got to the menu, it would cut out.
[SLiM] |
30th December 2008, 00:10 | #195 | Link | |
30th December 2008, 05:52 | #196 | Link |
@Capsbackup
I believe he's talking about the disk itself, which makes sense. Rewritables are subject to a lot of the same things regular write-once disks are, with the added downfall that they get burned and erased multiple times. Many set tops also give issues with rewritables that don't appear with a finalized standard (write-once) blank. If you have Nero, go to the toolkit and choose Nero Diskspeed. There, you can run scans on your disk that can look for errors as well as bad sectors. If you don't have Nero, VSO software has a utility called VSO Inspector, which can do many of the same things. Or, if you have another rewriteable at your disposal, you can try burning another copy to rule out at least that particular disk... but if you still have problems, where do you go from there? It might be another faulty disk... picky players... hard to say. I'd start with the error scans first.
Isn't it a bit unnerving that doctors call what they do "practice?" --George Carlin |
30th December 2008, 07:48 | #197 | Link |
Damn it! My latest BD5 backup is too big for DVD+R - can anything be deleted from the files to free up around 10mb? I guess the sizing isn't quite right yet.... should I try putting the default size down a bit for future encodes?
30th December 2008, 09:59 | #198 | Link |
If you have a DVD-R at hand it would offer about 7 MB more space compared to a DVD+R. You may try.....
My few tests (full backup) with BD-RB ended up in the range of 96 ...98%. Added: Btw, when you experience problems with the playback of BD-RB backups, did you select anything like "skip intros / jump directly to the main menu" for the rips? Last edited by Sharc; 30th December 2008 at 10:09. |
30th December 2008, 21:08 | #200 | Link | |
One easy way to make it fit is to manually reencode the audio at a lower rate, or manually reencode one of the extras at a lower rate. Then just run it again, and it will say "resume?" -- when you resume it will rebuild using the new values. |
