Old 10th March 2009, 09:07   #41  |  Link
puffpio
update : nevermind
even though the process was listed using 50%, the total cpu usage was 100%..i think the task manager was not reporting it correctly
puffpio is offline   Reply With Quote
Old 10th March 2009, 16:11   #42  |  Link
puffpio
Source: D:\temp\090306212759.avs
Params: --crf 22 --ref 5 --mixed-refs --bframes 3 --b-adapt 2 --b-pyramid --weightb --deblock -1:-1 --subme 8 --trellis 2 --partitions all --8x8dct --me umh --thread-input --no-psnr --no-ssim
[Type: 32-Bit, Pipe Buffer Size: 0 MByte]
encoded 1784 frames, 1.95 fps, 4160.33 kb/s
encoded 1784 frames, 2.18 fps, 4160.11 kb/s
encoded 1784 frames, 1.98 fps, 4160.33 kb/s
[Type: 64-Bit, Pipe Buffer Size: 0 MByte]
encoded 1784 frames, 2.37 fps, 4160.11 kb/s
encoded 1784 frames, 2.32 fps, 4160.11 kb/s
[Type: 64-Bit, Pipe Buffer Size: 1 MByte]
encoded 1784 frames, 2.43 fps, 4160.11 kb/s
encoded 1784 frames, 2.35 fps, 4160.11 kb/s
encoded 1784 frames, 2.16 fps, 4160.11 kb/s
[Type: 64-Bit, Pipe Buffer Size: 2 MByte]
encoded 1784 frames, 2.41 fps, 4160.11 kb/s
encoded 1784 frames, 2.42 fps, 4160.11 kb/s
encoded 1784 frames, 2.17 fps, 4160.11 kb/s
[Type: 64-Bit, Pipe Buffer Size: 4 MByte]
encoded 1784 frames, 2.39 fps, 4160.11 kb/s
encoded 1784 frames, 2.22 fps, 4160.11 kb/s
[Type: 64-Bit, Pipe Buffer Size: 8 MByte]
encoded 1784 frames, 2.48 fps, 4160.11 kb/s
encoded 1784 frames, 2.20 fps, 4160.11 kb/s
Old 10th March 2009, 16:17   #43  |  Link
LoRd_MuldeR
Software Developer
LoRd_MuldeR's Avatar
Originally Posted by puffpio View Post
when doing the benchmark, i notice that the first benchmark (the 32 bit one) only uses 1 of my cpu's
while just hitting start calls the 64 bit version and it uses both cpu's...
thoughts? running windows 7 and your latest version w/ x264 1125
I'm passing "--threads auto" to x264, so the problem (if there is one) shouldn't be on my side.
Anyway, if you are using a CPU with "Hyperthreading" (2 virtual cores per physical core), then 50% total load means that all physical cores are at 100% load, as Windows Taskmanager will only see virtual cores.
Of course it may also happen that your are bottlenecked by the input (decoder throughput, avisynth script) ...
Old 11th March 2009, 09:27   #44  |  Link
HymnToLife
Ubuntu French Roast
HymnToLife's Avatar
Not a tremendous speed boost here either.
Source is 1080p anime (creditless opening of Michiko e Hatchin), settings are the ones I use for my real-world encodes (except for the CRF 18, I normally use 2 pass bitrate mode and the final RF is usually something between 19-20).
CPU is Phenom II 940 @ 3.2 GHz, running Vista 64. I also updated x264 to r1127 from x264.nl.
I'm going to run another test with standard definition (DVD) anime soon-ish.
Source: C:\software\x264_x64.2009-03-08\michiko_op.avs
Params: --crf 18 --ref 8 --mixed-refs --no-fast-pskip --bframes 4 --b-adapt 2 --b-pyramid --weightb --direct auto --deblock -1:-1 --subme 7 --trellis 1 --partitions p8x8,b8x8,i4x4,i8x8 --8x8dct --me umh --merange 22 --psy-rd 0.8:0 --thread-input --no-dct-decimate --no-psnr --no-ssim
encoded 1944 frames, 5.02 fps, 7196.12 kb/s
encoded 1944 frames, 5.03 fps, 7196.12 kb/s
encoded 1944 frames, 5.13 fps, 7197.35 kb/s
encoded 1944 frames, 5.16 fps, 7197.35 kb/s
encoded 1944 frames, 5.17 fps, 7197.35 kb/s
encoded 1944 frames, 5.19 fps, 7197.35 kb/s
encoded 1944 frames, 5.21 fps, 7197.35 kb/s
encoded 1944 frames, 5.18 fps, 7197.35 kb/s
encoded 1944 frames, 5.15 fps, 7197.35 kb/s
Copy Protection:  A clever method of preventing incompetent pirates from
		   stealing software and legitimate customers from using it.
From http://www.gnu.org/fun/jokes/software.terms.html
HymnToLife is offline   Reply With Quote
Old 11th March 2009, 10:16   #45  |  Link
HymnToLife
Ubuntu French Roast
HymnToLife's Avatar
Creditless first ending of Sky Girls (DVD, IVTC and resizing to 848x480 were done beforehand).
Once again, real-world settings, and once again, a very minimal speed increase.
In both this case and the one above, a buffer size of 2 MB seems to give the "best" results (if I may say so, given the very minimal difference).
Source: C:\software\x264_x64.2009-03-08\skygirls.avs
Params: --crf 18 --level 4.1 --ref 8 --mixed-refs --no-fast-pskip --bframes 4 --b-adapt 2 --b-pyramid --weightb --direct auto --deblock -1:-1 --subme 7 --trellis 1 --partitions p8x8,b8x8,i4x4,i8x8 --8x8dct --me umh --merange 18 --thread-input --no-dct-decimate --no-psnr --no-ssim
encoded 2196 frames, 23.58 fps, 2848.26 kb/s
encoded 2196 frames, 23.76 fps, 2848.26 kb/s
encoded 2196 frames, 23.46 fps, 2848.26 kb/s
encoded 2196 frames, 24.65 fps, 2848.26 kb/s
encoded 2196 frames, 24.71 fps, 2848.26 kb/s
encoded 2196 frames, 24.86 fps, 2848.26 kb/s
encoded 2196 frames, 24.82 fps, 2848.26 kb/s
encoded 2196 frames, 25.49 fps, 2848.26 kb/s
encoded 2196 frames, 24.69 fps, 2848.26 kb/s
encoded 2196 frames, 25.26 fps, 2848.26 kb/s
encoded 2196 frames, 25.60 fps, 2848.26 kb/s
encoded 2196 frames, 24.66 fps, 2848.26 kb/s
encoded 2196 frames, 25.46 fps, 2848.26 kb/s
encoded 2196 frames, 25.50 fps, 2848.26 kb/s
encoded 2196 frames, 25.63 fps, 2848.26 kb/s
encoded 2196 frames, 25.17 fps, 2848.26 kb/s
encoded 2196 frames, 25.58 fps, 2848.26 kb/s
Old 18th March 2009, 22:56   #46  |  Link
LoRd_MuldeR
Software Developer
Updated x264 binaries to r1128 (builds taken from x264.nl).
Old 19th March 2009, 18:10   #47  |  Link
Rodger
New Benchmarks from me > Q9400S @ 3300Mhz
Here is the new Result.
Source: D:\Temp\MTV - h264_576p.avs
Params: --crf 22
encoded 6820 frames, 101.04 fps, 1831.60 kb/s
encoded 6820 frames, 100.87 fps, 1831.60 kb/s
encoded 6820 frames, 100.73 fps, 1831.60 kb/s
encoded 6820 frames, 102.31 fps, 1831.59 kb/s
encoded 6820 frames, 101.27 fps, 1831.59 kb/s
encoded 6820 frames, 101.46 fps, 1831.59 kb/s
encoded 6820 frames, 104.79 fps, 1831.59 kb/s
encoded 6820 frames, 104.92 fps, 1831.59 kb/s
encoded 6820 frames, 104.49 fps, 1831.59 kb/s
encoded 6820 frames, 104.76 fps, 1831.59 kb/s
encoded 6820 frames, 104.12 fps, 1831.59 kb/s
encoded 6820 frames, 104.14 fps, 1831.59 kb/s
encoded 6820 frames, 104.31 fps, 1831.59 kb/s
encoded 6820 frames, 103.21 fps, 1831.59 kb/s
encoded 6820 frames, 102.05 fps, 1831.59 kb/s
encoded 6820 frames, 101.81 fps, 1831.59 kb/s
encoded 6820 frames, 101.84 fps, 1831.59 kb/s
Rodger is offline   Reply With Quote
Old 27th March 2009, 22:42   #48  |  Link
Amefurashi
Amefurashi's Avatar
Some heavy testing on a 720p enc from Blu-Ray source:
Source: C:\LITTLE_MISS_SUNSHINE\little_miss_sunshine.avs
Params: --crf 18 --level 4.1 --keyint 240 --min-keyint 24 --ref 4 --mixed-refs
--bframes 5 --b-adapt 2 --b-pyramid --weightb --direct auto --deblock -2:-1
--subme 9 --trellis 2 --psy-rd 1.0:0 --partitions all --8x8dct --vbv-bufsize 40000
--vbv-maxrate 40000 --me umh --merange 24 --thread-input --aq-strength 1.0
encoded 501 frames, 1.43 fps, 10160.85 kb/s
encoded 501 frames, 1.44 fps, 10160.85 kb/s
encoded 501 frames, 1.74 fps, 10160.85 kb/s
encoded 501 frames, 1.70 fps, 10160.85 kb/s
encoded 501 frames, 1.65 fps, 10160.85 kb/s
encoded 501 frames, 1.69 fps, 10160.85 kb/s
encoded 501 frames, 1.58 fps, 10160.85 kb/s
encoded 501 frames, 1.66 fps, 10160.85 kb/s
encoded 501 frames, 1.64 fps, 10160.85 kb/s
encoded 501 frames, 1.62 fps, 10160.85 kb/s
encoded 501 frames, 1.72 fps, 10160.85 kb/s
encoded 501 frames, 1.59 fps, 10160.85 kb/s
encoded 501 frames, 1.68 fps, 10160.85 kb/s
encoded 501 frames, 1.61 fps, 10160.85 kb/s
Amefurashi is offline   Reply With Quote
Old 7th April 2009, 19:17   #49  |  Link
LoRd_MuldeR
Software Developer
Updated x264 binaries to r1137 (Skystrife builds).
Old 8th May 2009, 08:15   #50  |  Link
wiak
this gui is epic simple one little thing am missing is some defoult high profiles and a bitrate calculator and it will be the best GUI for me =)
Old 13th May 2009, 04:13   #51  |  Link
HaraldBluetooth
My PC spec.:
Q8200@2,33GHz
4 GB ram
Windows 7 Ultimate 64-bit
AviSynth script:
DirectShowSource("V:\Temp\Temp2\_Apocalypto.2006.720p.BluRay.x264-ESiR\Apocalypto.2006.720p.BluRay.x264-ESiR.mkv", fps=23.976, audio=false)
SelectRangeEvery
HQDN3D(1.9)
VagueDenoiser(threshold=1.7, method=3, nsteps=6, chromaT=0)
FFT3DGPU(bt=-1, sharpen=0.7)
Commandline:
Params: --crf 24.0 --ref 4 --mixed-refs --bframes 3 --b-adapt 2 --b-pyramid --weightb --deblock -3:-3 --subme 7 --trellis 2 --partitions p8x8,b8x8,i4x4,i8x8
LoRd_MuldeR - I just wan't to give you big thanks for this marvelous GUI.
With your default settings I got a FPS at 7,60. With two encodes at the same time I got a total FPS at 9,94.
I did a normal encode with MeGui in my 32 bit Windows XP SP3 with a FPS 6,92.
So compared to this it's an increase at 9,83% with one encode and with two encodes at the same time an increase at 43,64%.
I don't think I could do two encodes at the same time in 32 bit XP with these filters and x264 settings.
HaraldBluetooth is offline   Reply With Quote
Old 15th May 2009, 11:23   #52  |  Link
XadoX
XadoX's Avatar
Intel Xeon E5420
Temp.avs:
DGDecode_mpeg2source("D:\Temp.d2v", info=3)
ColorMatrix(hints=true, threads=0)
crop( 10, 76, -6, -68)
Trim(13767, 16062)
Source: D:\Temp.avs
Params: --crf 22
encoded 2296 frames, 78.79 fps, 1127.03 kb/s
encoded 2296 frames, 79.27 fps, 1127.03 kb/s
encoded 2296 frames, 79.60 fps, 1127.03 kb/s
encoded 2296 frames, 78.20 fps, 1126.99 kb/s
encoded 2296 frames, 77.46 fps, 1126.99 kb/s
encoded 2296 frames, 78.58 fps, 1126.99 kb/s
encoded 2296 frames, 81.86 fps, 1126.99 kb/s
encoded 2296 frames, 82.09 fps, 1126.99 kb/s
encoded 2296 frames, 81.63 fps, 1126.99 kb/s
encoded 2296 frames, 80.91 fps, 1126.99 kb/s
encoded 2296 frames, 84.73 fps, 1126.99 kb/s
encoded 2296 frames, 83.44 fps, 1126.99 kb/s
encoded 2296 frames, 83.34 fps, 1126.99 kb/s
encoded 2296 frames, 81.77 fps, 1126.99 kb/s
encoded 2296 frames, 83.81 fps, 1126.99 kb/s
encoded 2296 frames, 81.95 fps, 1126.99 kb/s
encoded 2296 frames, 80.56 fps, 1126.99 kb/s
XadoX is offline   Reply With Quote
Old 17th May 2009, 23:12   #53  |  Link
wiak
can someone with some better skills than me list the "encoding options" that is the closest to the MeGUI's DXVA-HD-HQ Profile and the DXVA-SD-HQ Profile? for this GUI please
btw you can also find latest x64 builds by techouse @ http://nwgat.net/x264/
Old 19th May 2009, 23:20   #54  |  Link
saint-francis
too much lurking
saint-francis's Avatar
@Lord
Any chance of batch encoding capabilities being incorporated into this fantastic tool?
saint-francis is offline   Reply With Quote
Old 19th May 2009, 23:36   #55  |  Link
LoRd_MuldeR
Software Developer
MeGUI does show you the complete commandline for each profile. So you can simply copy&paste
Anyway, if you want to use MeGUI profiles, why not simply use MeGUI?
Not planned. But I have included the sources, so feel free to hack that in
Old 20th May 2009, 00:03   #56  |  Link
saint-francis
too much lurking
Sure thing! As soon as I retire I'll go back to school and learn how.
I'll just figure out how to do it the old fashioned way.
Thanks for the useful tool. I think it's helping to bring 64 bit awareness to the community.
Old 11th June 2009, 14:16   #57  |  Link
Buggle
@Lord_Mulder
I was wondering whether you were planning on continuing support for this utility, or if this is only a proof-of-concept?
The reason I ask this is because to my knowledge, this tool is at this moment about the only option that has a high enough usability for moderately experienced users to allow x64 encodes.
The options we have are, as I understand it:
your pipebuf tool, avisynth64+MeGUI64 (not usable), avs2yuv
I would personally opt for the integration of piping (which one would you recommend; pipebuf or avs2yuv?) into MeGUI that would then also be able to run in x64 mode, but I guess your tool is as good as it gets till that moment arrives...
Old 11th June 2009, 14:25   #58  |  Link
LoRd_MuldeR
Software Developer
Originally Posted by Buggle View Post
@Lord_Mulder
You got it wrong. The "avs2yuv" tool reads an Avisynth script and writes the raw video data to STDOUT. This way the x264 process can read the data from STDIN. And this can happen from 32-Bit Avisynth/avs2yuv to 64-Bit x264, because they're running as two separate processes (just communicating through a pipe). Mixing 32-Bit and 64-Bit code within the same process is not possible! That's why we have to use the pipe method. The sole purpose of my "pipebuf" tool is to establish the pipe between avs2yuv and x264. The same could be done with cmd.exe, but cmd.exe doesn't allow to specify the pipe buffer size.
BTW: Yes, I will continue to give support for that tool. But I'm definitely not going to implement any new features. I don't want to maintain yet another x264 GUI...
Old 12th June 2009, 16:46   #59  |  Link
LoRd_MuldeR
Software Developer
Updated x264 binaries to r1165 (JEEB builds).
Old 13th July 2009, 08:26   #60  |  Link
komisar
komisar's Avatar
LoRd_MuldeR, can you update benchmark to support lattest version of x264? (--progress option trouble)
..::[I am live here]..::..[My x264 CLI/VFW builds and tools]::..
komisar is offline   Reply With Quote
