23rd September 2014, 05:35 | #21261 | Link | |
23rd September 2014, 05:43 | #21262 | Link | |
23rd September 2014, 05:43 | #21263 | Link |
Special SeeD
Help, I trying to encode the 3D version of Maleficent, but the encoding process fails with a weird error:
C:\Users\Myself>"E:\Archivos de Programa\BD Rebuilder\tools\FRIMDecode .exe" -ts -i::mvc "I:\BDMV\STREAM\00300.m2ts" "I:\BDMV\STREAM\00331.m2ts" -o \\. \pipe\bdrb.yuv | "E:\Archivos de Programa\BD Rebuilder\tools\FRIMEncode.exe" mvc -i \\.\pipe\bdrb_L.yuv -i \\.\pipe\bdrb_R.yuv -viewoutput -o "E:\TEMP\MOVIE RI PPING\WORKFILES\VID_00300.AVS.264" -o "E:\TEMP\MOVIE RIPPING\WORKFILES\VID_00300 .AVS.mvc" -w 1920 -h 1080 -f 23.976 -u 3 -cpbsize 3750 -l 6 -profile high -level 4.1 -vbr 27153 45000 -gop 24 4 0 O -maxdpb 4 ERROR: unknown error (-1), src\pipeline_decode.cpp (1116) ERROR: the previous asynchrous operation is in execution (1), src\main_frim_de code.cpp (122) FRIM Encoder version 1.23 (build: Mar 19 2014) - based on Intel(R) Media SDK Media SDK impl HARDWARE - D3D9 (C:\Program Files\Intel\Media SDK\libmfx hw32.dll) Media SDK version 1.10 Memory type System Input format YUV420 Output video AVC Source picture: Resolution 1920x1088 Crop X,Y,W,H 0,0,1920,1080 Destination picture: Resolution 1920x1088 Crop X,Y,W,H 0,0,1920,1080 Frame rate 23.976 Bitrate control VBR avg,maximum 27153,45000 GOP structure: GOP length 24 I-/P-frame distance 4 IDR-frame interval 0 GOP type Opened Num of slices 6 Target usage 3 Processing started Frame number: 0 Processing finished in 0.00 seconds C:\Users\Myself> |
23rd September 2014, 08:31 | #21264 | Link | |
I'm noticing some other stuff..but doing more checks..
23rd September 2014, 09:05 | #21265 | Link |
Is your SSD Samsung type 840 or 840EVO? Apparently there is a bug which slows down reading. SAMSUNG are about to releasing a fix.
You may google for the news. Added: http://www.anandtech.com/show/8550/s...-is-on-the-way Last edited by Sharc; 23rd September 2014 at 09:20. |
23rd September 2014, 13:41 | #21267 | Link | |
Audio track is not extracted in preparation. If you want to test, this clip and others are available at this link. Source Code:
General ID : 1 (0x1) Complete name : E:\HD Trailers\Dolby Digital Plus\Beardyman.m2ts Format : MPEG-TS File size : 454 MiB Duration : 4mn 1s Overall bit rate mode : Variable Overall bit rate : 15.8 Mbps Maximum Overall bit rate : 35.5 Mbps Video ID : 4113 (0x1011) Menu ID : 1 (0x1) Format : MPEG Video Format version : Version 2 Format profile : Main@High Format settings, BVOP : Yes Format settings, Matrix : Custom Format settings, GOP : M=3, N=12 Codec ID : 2 Duration : 4mn 1s Bit rate mode : Variable Bit rate : 14.6 Mbps Maximum bit rate : 20.0 Mbps Width : 1 920 pixels Height : 1 080 pixels Display aspect ratio : 16:9 Frame rate : 23.976 fps Standard : Component Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Compression mode : Lossy Bits/(Pixel*Frame) : 0.293 Time code of first frame : 00:00:00:00 Time code source : Group of pictures header Stream size : 419 MiB (92%) Color primaries : BT.709 Transfer characteristics : BT.709 Matrix coefficients : BT.709 Audio ID : 4352 (0x1100) Menu ID : 1 (0x1) Format : E-AC-3 Format/Info : Audio Coding 3 Format settings, Endianness : Big Codec ID : 129 Duration : 4mn 1s Bit rate mode : Constant Bit rate : 448 Kbps Channel(s) : 6 channels Channel positions : Front: L C R, Side: L R, LFE Sampling rate : 48.0 KHz Compression mode : Lossy Stream size : 12.9 MiB (3%) AVCHD Code:
General ID : 1 (0x1) Complete name : E:\VIDEOS\BEARDYMAN\BDMV\STREAM\00000.m2ts Format : BDAV Format/Info : Blu-ray Video File size : 445 MiB Duration : 4mn 1s Overall bit rate mode : Variable Overall bit rate : 15.5 Mbps Maximum Overall bit rate : 35.5 Mbps Video ID : 4113 (0x1011) Menu ID : 1 (0x1) Format : AVC Format/Info : Advanced Video Codec Format profile : High@L4.0 Format settings, CABAC : Yes Format settings, ReFrames : 4 frames Codec ID : 27 Duration : 4mn 1s Bit rate mode : Variable Bit rate : 14.8 Mbps Maximum bit rate : 15.0 Mbps Width : 1 920 pixels Height : 1 080 pixels Display aspect ratio : 16:9 Frame rate : 23.976 fps Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Bits/(Pixel*Frame) : 0.299 Stream size : 427 MiB (96%) |
23rd September 2014, 16:33 | #21268 | Link | |
I'll look at it again to make sure it's right. [Edit] Yep... forgot to take a reporting delay into account. Fixed it Last edited by jdobbs; 23rd September 2014 at 16:58. |
23rd September 2014, 17:58 | #21269 | Link | |
"Double" (or even more) was observed at the beginning of the encode, gradually getting lower. Your explanation makes it clear as to why this happened. Thanks. |
23rd September 2014, 21:57 | #21270 | Link | |
23rd September 2014, 22:00 | #21271 | Link | |
23rd September 2014, 22:01 | #21272 | Link | |
I hunted down the cause and can report the following: The error only happens if you are using the latest Intel drivers 15.36.3.64.3907 and HW mode is used for FRIMDecode (FRIM_SW_DECODE=0) - using HW mode for FRIMEncode doesn't cause the error (it just isn't usable for me due to the mentioned corruptions). Going back to older drivers (e.g. 15.33.22.64.3621) resolves this issue. So there is either an issue in the Media SDK shipped with the newest driver itself or FRIMDecode needs to be updated for the new SDK version (1.10). |
23rd September 2014, 23:51 | #21273 | Link | |||||
Hello Jdobbs, I am working on CAPT_AMERICA_WINTER_SOLDIER_3D and have alternate output enabled with HEVC and aac audio. I f I use neroaacencoder I get failure and if faac is used then it works fine.
I am attaching info here to help troubleshoot issue, when neroaac encoder fails. Quote:
[update] Even if audio process is success, mkvmerge fails. Upon further investigation I know the cause of failure. Contents of mux_movie_only_meta Quote:
Also there is cosmetic issue when processing audio it goes above 100 percent in this case at least. another issue is if you abort on second pass encoding and restart from beginning it does not update overall progress.
If you fail to plan; you plan to fail, would you not agree? Think about it. Last edited by HWK; 24th September 2014 at 00:19. |
24th September 2014, 00:18 | #21274 | Link |
The only difference I see between my setup and yours is that I'm using NeroAACEn v1.5.4 to your v1.5.1. But I did a lot of AAC encodes using Nero during testing.
There should never be a .264 extension when using MOVIEONLY_TYPE=33. I'll have to go back and see how that is possible. I did at least 20-30 encodes in testing and it never happened. Maybe there some's kind of flag confusion from a 3D source (I don't think I tested any 3D sources), I'll have to try one and see. Last edited by jdobbs; 24th September 2014 at 02:34. |
24th September 2014, 01:28 | #21276 | Link | |
Special SeeD
24th September 2014, 03:52 | #21277 | Link | ||
@ Jdobbs, I decided to do same movie in crf mode and video encode aborted. Upon examination of bat file of x265 I discovered argument weren't pass correctly. Quote:
I am gone try 2D source next and see what is outcome.
If you fail to plan; you plan to fail, would you not agree? Think about it. Last edited by HWK; 24th September 2014 at 04:04. |
24th September 2014, 05:23 | #21278 | Link |
I have a Blu-ray that with the movie only comes to 24.34 Gigs. I tried changing the 'Custom Size' for BD-25 higher than the default 22.9 (only in these rare cases would I do this) But, when I went to run the encode, BDRB still shows the target size as 22.9. I tried changing it in the 'Setup' menu where it LOOKS like you can input another value. Will I be able to squeak this one in? What is the maximum size I can get? Why didn't it change; did I input too large of a size (I tried 24.5)
Thanks! *** EDIT Sorry, never tried this before, but I figured it out (Duh...) I have to SELECT the custom output size as opposed to BD-25. I'll play around with the sizes and figure it out. Geez... Last edited by Lathe; 24th September 2014 at 05:37. |
24th September 2014, 07:56 | #21279 | Link | |
I think however --pass 1 needs to be added in the commandline in order to really produce the stats file. |
