12th May 2020, 21:57 | #1902 | Link | |
Software Developer
The "Tuning" combobox is disabled for NVEncC, because NVEncC doesn't have anything like that. You can still set "Preset" and "Profile" for NVEncC. Anything else, as always, needs to be set via "Custom Encoder Parameters" edit box...
16th May 2020, 14:11 | #1903 | Link | ||
Software Developer
Simple x264/x265 Launcher v2.97
https://github.com/lordmulder/Simple...ases/tag/v2.97 Quote:
25th June 2020, 21:11 | #1905 | Link | |
Software Developer
Simple x264/x265 Launcher v2.98
https://github.com/lordmulder/Simple...ases/tag/v2.98 Quote:
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 25th June 2020 at 21:34. |
26th June 2020, 22:20 | #1908 | Link |
Software Developer
Not at this time. It's just a crude integration of QDarkStylesheet, which works fairly well, but also produces quite a few glitches.
I will see if further improvements are possible when I have more time... It's exactly 42.3141 percent worse (Really, this depends on a whole lot of factors, including the kind of material you are encoding, the selected bit rate and the selected quality preset. So you are best off doing you own tests with settings that fit your workflow!)
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 26th June 2020 at 22:25. |
27th June 2020, 00:15 | #1909 | Link |
I had no doubts, why then is it used here?
I tried something but the results are not satisfactory even at the same bitrate. I did a bluray rip of the alien film, even using the preset faster the results are much better with x265 (I have an i7 4790k). Using nvenc CQP 20 or in vbr mode, it does not improve the quality via gpu |
27th June 2020, 12:36 | #1910 | Link | |
Software Developer
Anyway, it's all about giving users options to choose from. If your goal is to get the maximum quality at a medium to low bitrate, and if you are willing the spend a whole lot of encoding time for that, then using one of the software encoders probably still is your best choice. But, if your goal is to finish the encode as quickly as possible while still getting a "reasonable" quality, then probably nothing will beat a hardware encoder, such as NVEncC.
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 27th June 2020 at 12:55. |
27th June 2020, 16:43 | #1911 | Link | |
I really wouldn't recommend encoding 4k on a quad core. Although like Lord said, hardware is an option if you dont mind the quality loss. Sent from my SM-G986U1 using Tapatalk |
11th November 2020, 20:48 | #1913 | Link |
Hi
The latest included x264 version is r3009 from june, however official one is newer: x264 r3027 from october. Is it still get update? Regards szabi |
19th November 2020, 02:32 | #1914 | Link | |
Software Developer
19th November 2020, 02:33 | #1915 | Link | |
Software Developer
Simple x264/x265 Launcher v2.99
https://github.com/lordmulder/Simple...ases/tag/v2.99 Quote:
19th November 2020, 20:38 | #1916 | Link | |
EDIT: Regarding the lots of changes I use x264 with this settings since years. Should I change my preferred settings or I can stay on my oldies one? What do u suggest? Last edited by szabi; 19th November 2020 at 20:49. |
20th November 2020, 00:42 | #1917 | Link |
Big Bit Savings Now !
It depends what resolution you feed to encoder, how much grain you want to encode,
how much picture deterioration you can stand and which playback device you intend to target. x264 has not changed much in that regard. If you aim at 1080p25/29,97 blu-ray for instance and want to have transparency through grain and keep all details, bufsize and maxrate are too high, while 13Mbps would be too misery. If you aim at a hardware player or mobile phone and supply denoised, degrained stuff 720p@24/25/29fps, 13Mbps are good to go, while the bufsize and maxrate are still unnecessary high.
"To bypass shortcuts and find suffering...is called QUALity" (Die toten Augen von Friedrichshain) "Data reduction ? Yep, Sir. We're that issue working on. Synce invntoin uf lingöage..." Last edited by Emulgator; 20th November 2020 at 00:44. |
20th November 2020, 22:13 | #1918 | Link |
Hi
You are right I did not go into details. I use for 1080p output and all limits are kept due to hardware decoder I have expect nofastpskip which in use to increase quality. I still use 2 pass encode that is why bitrate is calculated for the size of output however quality is still around 1 pass 17mbps bitrate. At least I hope. :-) Thanks for your help. Regards. szabi Last edited by szabi; 20th November 2020 at 22:15. |
11th May 2021, 19:57 | #1919 | Link | |
JFYI, from long time ago, [2018, I just noticed your reply]
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 11th May 2021 at 20:00. |
12th May 2021, 13:01 | #1920 | Link | |
Grumpy Old Man.
I just happen to find this app today, and I have had a bit of a fiddle with it, and I think it's pretty easy to update x264 & x265, and I notice that it seems to use L Smash as a decoder (is that correct?), anyway, can this be updated by the user ?? Would there be a chance that you could "point" the app to where the sources paths could be chosen, instead of integrated with in the app ? (I'm not really sure what I'm talking about). I also installed Vapoursynth & Python, but it also ask's for Visual Studio, which looks like it's a fairly large download..is that really required ?? One thing I noticed when I updated x264 from https://artifacts.videolan.org/x264/release-win64/, and renamed it, when I tested a new job, the encoding info window at the bottom of the app, did NOT show all the info that the built in version x264 did (if you know what I'm trying to say) I could send screenshots if you like.
