23rd June 2020, 15:36 | #2001 | Link | |
This was a post by sneaker some time ago. Sent from my SM-G986U1 using Tapatalk |
23rd June 2020, 20:10 | #2005 | Link | |
23rd June 2020, 20:16 | #2006 | Link |
I don't understand, doesn't that encode the DTS HD track? I do not want that. DTS HD track can be 6.1 or 7.1. I want to encode the core which is 5.1. I want only 5.1.
UPDATE: If you say to it to convert the DTS HD 7.1 to 5.1. It is not the original mix. It is modifying and mixing the channels. God knows what happens in the final mix. But if you encode the original 5.1 mix, the channels and the mix will be the original untouched. What happens when it is downmixing 7.1 to 5.1? Last edited by Atlantis; 23rd June 2020 at 20:23. |
23rd June 2020, 20:30 | #2007 | Link | |
I want to encode a video in staxrip. I open it in staxrip. I want to encode the video and only the DTS core. Is there a step by step to do it all in staxrip GUI without leaving? |
23rd June 2020, 20:44 | #2008 | Link | |
As far as I know StaxRip doesn't support this on demux. Maybe stax76 can add it in. Im assuming you know that you can extract core with ffmpeg and ea3cto. EDIT: Upon some testing mkvextract CLI (That I'm 99% sure StaxRip uses to demux) doesn't support extracting DTS to core. It only extracts it to raw data that is the full DTS-HD file. I'll do some more digging and see if it's possible. Last edited by jlw_4049; 23rd June 2020 at 21:08. |
23rd June 2020, 21:07 | #2009 | Link |
The eac3to demuxing dialog is typically used for BD folder demuxing and for M2TS demuxing, it can also be used to demux other things like mkv, probably not a good idea to change the default mkv demuxer from mkvmerge to eac3to. There is however a decoupled demuxing feature under:
Tools > Advanced > Demux. eac3to does unlike mkvextract support Core only demuxing, maybe somebody should request it for mkvextract which extracts dtshd even when the dts file extension is used, I don't see how that makes sense. If you open a mkv file with default settings then you have either dtshd in mkv or you have it demuxed, in both cases the audio processing is a two-step process not directly supported by staxrip. You've two options: 1. Instead of using the GUI audio encoder you can use the CLI audio encoder, this is somehow advanced, ideally for people that like working with command line. 2. You can create an GUI audio profile that does nothing but extracting the core. Directly after you opened the source you can choose this audio profile, go into the audio dialog and choose the option Execute Command Line, while this is processing you can do other things like choosing video filters etc., when extracting completes, right-click the audio track in the main dialog and select the extracted DTS Core file as audio source, then choose your aac or opus profile.
23rd June 2020, 21:17 | #2010 | Link |
@Atlantis
I asked if it was possible in the proper thread for this. https://forum.doom9.org/showthread.p...04#post1916504 If the author adds the feature to the program then I'm sure Stax76 can easily add it to the Demuxer GUI. |
23rd June 2020, 22:52 | #2011 | Link | |
App Digger
1. Create a new audio profile based on Copy/Mux with Extract DTS Core feature. Or 2. Create a new command line audio profile that uses ffmpeg. A screenshot for this: The command line: Code:
"%app:ffmpeg%" -analyzeduration 100M -probesize 50M -i "%input%" -bsf:a dca_core -c:a copy -y -hide_banner "%output%" (I guess these two are basically the same though.) And the rest is as @stax76 explained: After the source file is opened, choose either of these two profiles in the corresponding DTS-HD audio track, right-click the track, and run "Execute". After the core is successfully extracted, right-click the audio track again and choose the extracted dts audio file for re-encoding. Last edited by JKyle; 23rd June 2020 at 23:02. |
24th June 2020, 07:45 | #2012 | Link |
JKyle, the following command is enough to extract DTS Core
"%app:ffmpeg%" -i "%input%" -bsf:a dca_core -c:a copy -y -hide_banner "%output%" Is there a specific reason you would need -analyzeduration and -probesize ? For the rest I think you gave the best solution possible ! |
24th June 2020, 08:10 | #2013 | Link | |
App Digger
Some containers, esp. MPEG-2 transport streams like ts, m2ts, and mts, have a very tiny packet size, and therefore are more prone to stream probe failure. In those cases, ffmpeg yields the following error message and comes up with the -analyzeduration and -probesize options. Code:
Could not find codec parameters for stream 0: unknown codec Consider increasing the value for the 'analyzeduration' and 'probesize' options Last edited by JKyle; 24th June 2020 at 08:13. |
24th June 2020, 12:20 | #2015 | Link | |
25th June 2020, 01:55 | #2017 | Link | |
App Digger
1) Click Win+r 2) Type cmd 3) Ctrl + Shift + Enter 4) cd to the folder where ffmpeg.exe is located. 5) Create a symbolic link to AviSynth.dll there like this (full path should be specified): Code:
mklink AviSynth.dll G:\...\StaxRip-x64-2.1.3.5-beta\Apps\FrameServer\AviSynth\AviSynth.dll ... But on second thought, do we even need to do this for StaxRip? I see similar reports of failure to create symlinks for AviSynth.dll here and there, but as for me, I'm not experiencing this problem as of now for both installed and portable AviSynth implementations in fresh start of StaxRip. Is it something that happens when ffmpeg is employed for preprocessing? AFAIK, Patman's ffmpeg is built with AviSynth support. Does ffmpeg require AviSynth.dll when it takes an avs input in this case? But wait. Patman's ffmpeg is static, which means it doesn't depend on external dlls. What am I missing here? Someone with knowledge please enlighten me. Last edited by JKyle; 25th June 2020 at 04:06. |
25th June 2020, 13:08 | #2018 | Link | |
Unable to create file because it already exists P.S. Why do I need a Command Prompt if I use software??? Last edited by hevron; 25th June 2020 at 13:31. |
25th June 2020, 13:43 | #2019 | Link |
@JKyle
On my system which is pretty much default Win 10, soft link creation does not require elevated privileges. If soft link creation of staxrip fails then maybe starting staxrip as admin once for soft link creation might help. Creating the links manually will not work however, staxrip uses absolute paths for soft link creation, it saves the location in the settings only if the creation succeeds and verifies that the staxrip location hasn't changed, if the creation did not succeed or the location has changed then staxrip will recreate the links. It's probably not working in Win 7, even with elevated privileges Win 7 might not allow creation without changing permissions. If avisynth 3.6.1 x64 is installed then users can go into the staxrip settings dialog and disable portable mode, after staxrip is restarted it will use the installed avisynth and don't create any soft links.
https://github.com/stax76/software-list https://www.youtube.com/@stax76/playlists Last edited by stax76; 25th June 2020 at 13:48. |
25th June 2020, 14:11 | #2020 | Link | |
Probably now you need to run only with administrator rights. Last edited by hevron; 25th June 2020 at 15:01. |
aac, hdr, hevc, nvenc, staxrip, x264, x265 |
