Old 12th October 2019, 11:04   #17481  |  Link
mparade
thx!!
Old 12th October 2019, 11:09   #17482  |  Link
Maybe you have activated PBO on 2990wx and hence too high power consumption for your power supply. 0.5kW is just insane.
Old 12th October 2019, 11:12   #17483  |  Link
mparade
If I set 8 servers for job 1 in the queue, will the following jobs be using the same servers and threads I assigned to them in job1 automatically for encoding?
Old 12th October 2019, 11:14   #17484  |  Link
mparade
Yes, I do (am).
Old 12th October 2019, 11:15   #17485  |  Link
All jobs will use the same server configuration.
Yes, I do.
So now you know what to do BTW. Overclocking AMD cpus do not make sense these days.
Old 12th October 2019, 11:20   #17486  |  Link
mparade
Super-good! Thank you very much!
Old 12th October 2019, 11:26   #17487  |  Link
mparade
Does chunk size affect encoding quality more than negligibly? Maybe it is not required at all to set chunk size according to duration of each source.
I would like to saturate my cores using 8 servers almost always that would give very fast encodes.
Old 12th October 2019, 11:32   #17488  |  Link
In CRF mode there is zero quality degradation. In 2-pass degradation is negligible. Also each chunk starts at key-frame.
Use default 1 minute if you are going to use 1950x and 2990wx at the same time.
Old 12th October 2019, 11:38   #17489  |  Link
mparade
WOW! I am in CRF mode. Thank you! I am, one from home, the other from workplace…
Old 12th October 2019, 11:43   #17490  |  Link
With decent internet connection (10Mbps+ upload) and VPN you can use other PC as well.
Old 12th October 2019, 11:45   #17491  |  Link
mparade
What is required to use both machines at the same time for the same job? Do you have a tutorial? At the moment I am using them separately with locally set servers.
Please help. Internet connection shouldn't be a problem. Both have Ripbot installed. I can set them up separately now. There is 2 km distance between them.
Old 12th October 2019, 11:50   #17492  |  Link
Please help.
You will have to create VPN network on work PC and then connect to that network from home PC. This way shared folder will be visible like on normal LAN. Some users already are using this method to distribute encoding work across internet. It is definitely possible with good internet connection.
https://www.pcworld.com/article/2105...n-windows.html
Old 12th October 2019, 11:59   #17493  |  Link
mparade
Source material should be only on home PC, right?
Work PC with VPN network just need to be on with Ripbot installed right? Or should I set somthing more on work pc? Sorry for being noob in this thema.
Old 12th October 2019, 12:03   #17494  |  Link
1) Source files are on your home PC.
2) Work PC just needs EncodingServer.exe running!
3) The idea is that you connect via VPN to work PC and then Work PC sees shared folder (for example \\HOME-PC\RipBot264temp) on Home PC.
Old 12th October 2019, 12:10   #17495  |  Link
mparade
I have to accomplish this! I will let you know if get stuck with something (I am sure I will )
Old 12th October 2019, 15:48   #17496  |  Link
mparade
how is the exact number of --seek parameter is specified on x264 command line, may I ask?
thank you for for the help in advance
Old 12th October 2019, 16:28   #17497  |  Link
seek = StartKeyFrameIndex - PreviousKeyFrameIndex
Old 12th October 2019, 17:10   #17498  |  Link
mparade
both work and home pc should be connected via VPN, right?
work pc at the moment cannot because refering to closed port
I have to ask local admin at company
Old 12th October 2019, 17:11   #17499  |  Link
mparade
thx!!
Old 12th October 2019, 17:39   #17500  |  Link
Your admin should know what to do.
https://www.youtube.com/watch?v=Mk_XYuzQ8jA
Ports to open
https://social.technet.microsoft.com...m=winservergen
