Old 20th October 2016, 15:57   #25081  |  Link
MrVideo
MrVideo's Avatar
Bobbing instead of deinterlacing has its own cons, but QTGMC is an outstanding bobber in many respects.
Wow, I haven't heard that plugin name in a while. It is very slow, but indeed does a great job. I haven't used it in ages.
Old 20th October 2016, 16:24   #25082  |  Link
I actually prefer TIVTC to Telecide/Decimate for most sources (not all though). If I'm performing iVTC I usually try each and pick the one I think gives the clearer/stabler result. That's the reason I added both to BD-RB.
Old 20th October 2016, 16:30   #25083  |  Link
Sharc
Ahh...., that's why you set IVTC_METHOD=1 per default.
Old 21st October 2016, 06:28   #25084  |  Link
MrVideo
MrVideo's Avatar
I'm going to do a bunch of encodes using the following TFM settings:
tfm(order=1,mode=0,slow=2,display=false)
Yes, I know that the default for display is false. I have it there as a placeholder. If I spot some frames that do not look right, I can quickly change the false to true and rerun the job and look at the embedded info.
Jdobbs, What are the situations whereby you won't use TFM?
Old 21st October 2016, 21:54   #25085  |  Link
Lathe
Lathe's Avatar
Hard-telecined stuff:
The source which Lathe uploaded in his other thread was 2:3 hard-telecined (no pulldown flags). You can only say this by manually analyzing the stream; media info will always report such streams as interlaced which often misleads people (and tools) to blindly apply deinterlacers to hard telecined footage (why should they suspect something else....).
When you set IVTC_SELECTION=1 in the .ini, BD-RB lets you choose as dropdown menu (right click on the stream) to force IVTC on "interlaced" (in fact hard-telecined) streams. So when you are positive that the stream is in fact hard-telecined you can IVTC it; just don't apply IVTC to true interlaced content!
One still finds hard-telecined stuff as bonus material (extras) on BD's because the studios are sometimes lazy and take these from previous DVD releases, or compile hybrids of true interlaced video with telecined film .... lot from DVD-NTSC heritage.
True-interlaced:
A true interlaced 29.97i video can always be bobbed to 1280x720p@59.94fps in order to preserve the original time resolution and stay Blu-ray compliant. Bobbing instead of deinterlacing has its own cons, but QTGMC is an outstanding bobber in many respects (I prefer it over frame interpolation) -- and also use it sometimes to clean up IVTC-ed progressive material.
There is a lot to this... This is very vital information, because I'm pretty sure that on one of the very first ones I tried some script on, I had assumed that it was interlaced because MediaInfo said it was, so I used BDRB decomb/blend filter. It came out 'okay', but I'm pretty sure now that it likely was as you say, hard telecined. I did 2 like that. One didn't turn out too bad (colour 'AND HOPE TO DIE') One looks pretty rough (B&W 'I ACCUSE')
I THINK that pretty much all of the films I will be trying to 'improve' are from DVD captures; So, I'm guessing that most of them will likely fall into this same category. It there a way visually to 'step through' a file frame by frame to observe whether every frame is 'combed' or interlaced looking, or if it has (if I've read correctly about telecined stuff) 3 good looking frames, and then 2 that look interlaced (or the other way around ) Right...?
This is VERY good to know...
Old 22nd October 2016, 03:54   #25086  |  Link
Lathe
Lathe's Avatar
Just a quickie...
I tried putting a preset in as a Tweak, but it looks like BDRB ignored it. Are you not able to put an x264 preset as a Tweak?
Old 22nd October 2016, 05:00   #25087  |  Link
MrVideo
MrVideo's Avatar
You will need a program that will let you step through the file, a frame at a time and not de-interlace.. For that I use my video editing program. VLC will not let you do that. You can get it to slow down playback. But, I think VLC de-interlaces, so that doesn't help.
Old 22nd October 2016, 05:16   #25088  |  Link
Just a quickie...
There are some tweaks that BD-RB doesn't allow -- for example, anything that would change the framerate.
You can step through a video a frame at a time with Media Player Classic (MPC) -- it is included in the BD-RB tools folder (mplayerc.exe).
Old 22nd October 2016, 05:40   #25089  |  Link
Lathe
Lathe's Avatar
Ah, good to know, thanks!
Thanks too, Mr. Video. Yeah, VLC will allow you to set up whether interlace is active / automatic / off and which type. But, you are right, you cannot step through a file frame by frame. I'll use MPC then and give it a try.
Old 22nd October 2016, 05:45   #25090  |  Link
Lathe
Lathe's Avatar
Um... any other thought as to the 2 pass size fluctuation with BD25? Seems with LAVF it used to almost always come out to 22.95 or so. Now, it appears to be smaller a lot of the time, like around 21 Gigs.
Old 22nd October 2016, 09:07   #25091  |  Link
Sharc
..... It there a way visually to 'step through' a file frame by frame to observe whether every frame is 'combed' or interlaced looking, or if it has (if I've read correctly about telecined stuff) 3 good looking frames, and then 2 that look interlaced (or the other way around .......
I am normally using AvsPmod for this purpose. It's a very handy tool for trying out scripts and see the result immediately.
Old 22nd October 2016, 10:05   #25092  |  Link
Sharc
@jdobbs
A question in the context of the IVTC discussion:
When incuding AVS scripts (Setup menu: "Use AVS filters during encoding") AND forcing IVTC, the custom filters are inserted before the IVTC in the final script, means the custom filters are applied to the telecined material.
Is there a way in BD-RB to swap the order, i.e. IVTC before the custom AVS filters? Or should the order be swapped automatically when forcing IVTC?
Edit:
I found the solution. One has to set the prefix r: in front of the custom filter. This puts the custom filter after the IVTC in the sequence.
(Question is perhaps still whether this swapping could/should be done automatically in this case).
Old 22nd October 2016, 15:26   #25093  |  Link
It really shouldn't matter. The specified bitrate is that same whether you use LAVF or any of the other frame-serving methods.
Old 23rd October 2016, 01:34   #25094  |  Link
gonca
I am seeing references to prefixes for the AVS Editor
I knew they existed but I an seeing different prefixes mentioned that I am not familiar with; i.e. r:
I have used search and cannot find a list of all the allowed prefixes.
Is there such a list?
Old 23rd October 2016, 01:47   #25095  |  Link
July 8th, 2010
- Added an AVS filter editor to the SETUP dialog.  This
  will allow you to add AVS filters to files.  Note that
  bug reports WILL NOT BE ACCEPTED when filters are in
  use (as errors are almost always caused by the filter
  usage).  You can add "E:", "F:", "I:", or "P:" as a
  prefix to a line added in the filter editor.  The
  prefixes represent "Extras", "Feature", "Interlaced",
  and "Progressive" respectively.  When specified, the
  prefix will limit that filter to usage only when the
  source to be encoded matches the prefix.  For example,
  if specifying "E:filter1()" the filter "filter1()"
  would only be applied to segments that are determined
  to be extras.  Setting "e:i:filter2()" limits use of
  "filter2()" to segments that are extras -- and are
  also interlaced.
November 28th, 2011
- Added a new prefix for filter editing.  By adding
  the "r:" prefix, BD-RB will add the specified
  filter after the resizing stage (rather than the
  default of before).  Note: If using more than one
  prefix, the "r:" must be the last in the series.
Also:
"a:" filter applies to the audio AVS
"m:" filter applies only to menus
Notes:
1. You can use either Upper or Lower case in the filter prefixes, it doesn't matter...
2. On a series disc, where there are multiple episodes -- don't use "F:" because it will only apply to the largest episode
Old 23rd October 2016, 01:58   #25096  |  Link
gonca
Thank you
Old 25th October 2016, 13:00   #25097  |  Link
Sharc
Script error?
@jdobbs
When I select "Use Deinterlacer on interlaced sources" (for an imported source), and set in the .ini
DEINTERLACER_TYPE=1
DB-RB aborts.
I assume it's due a script syntax error:
#Created by BD Rebuilder - v0.50.18
LoadPlugin("C:\Program Files Video\DGdecNV\DGDecodeNV.dll")
DGSource("C:\TEMP\BD REBUILDER\WORKFILES\VID_00000.DGI", fieldop=0)
ConvertToYV12()
LoadPlugin("C:\Program Files Video\BD_Rebuilder\tools\decomb521.dll")
FieldDeinterlace(blend=false,+blend=false)
ConvertToYV12().AssumeFPS(30000,1001)
The script is ok for the other DEINTERLACER_TYPE=n
Old 25th October 2016, 13:07   #25098  |  Link
@jdobbs
DEINTERLACE_TYPE=1
DB-RB aborts.
ConvertToYV12()
The script is ok for the other DEINTERLACE_TYPE=n
That sure doesn't look right, does it? I'll look at it later today.
[Edit] Yep. I screwed the pooch on that one when I made the change. It has been fixed for the next release.
Old 25th October 2016, 18:59   #25099  |  Link
geheim
Any news about 3D subtitle depth??
I still loose all depth in my 3D subtitles after encoding with FRIM...
@jdobbs Could you take a look at MVCEnc from BDtoAVCHD?? Because this tool keeps 3D offsets intact after encoding. However, it cannot keep any menus, therefore I prefer using BDRebuilder.
But without 3d subtitle depth many movies don't give a pleasant view with subtitles "cutting" across picture elements...
I'd really appreciate it if you could figure out why BDtoAVCHD keeps offsets intact and BDRebuilder doesn't. I'd be very pleased if you could add an option to select a fixed offset value, no need for the original depth offsets to be kept if that is too diffcult to implement. But any depth at all would be really good for a loads of movies.
Thanks so much!!
geheim is offline   Reply With Quote
Old 26th October 2016, 07:07   #25100  |  Link
Lathe
Lathe's Avatar
Yes, thanks, I do have that but I've not tried it out yet.
BTW, I'm glad you mentioned about AVS script running BEFORE the IVTC! I did not know this because sometimes I want to add filters, but I want to do it AFTER the IVTC is done. Hmmm...
So what is with the 'r'? Where exactly do you put it. Say I wanted to use Sharpen(.3), where would I put the 'r'? Would I enter the text in the Avisynth code area of BDRB like this: 'r Sharpen(.3)'...?
Oh, also, would I need to add an 'r' before each line of script?
