7th February 2019, 09:08 | #6701 | Link |
So if there is a v3.0 release since 2 weeks, why do I still receive an RC version ... did I not update to the "tip"? Usually I do...
Ah, there was no back merge. Stable and default branch are still distinct. |
7th February 2019, 10:28 | #6702 | Link | |
Our plan is to continue to use 3.0_RC on the default branch and have completed tags only on the stable branch. So we don't intend to merge back.
AMD Ryzen 9 5950X, 32GB DDR4-3200 CL16, RTX 3060, 2TB NVMe PCIE4.0, NAS with 8x16TB HDD |
7th February 2019, 12:02 | #6703 | Link |
We are starting to use 3.0_Au (Gold) to signal that the default branch has moved to gold state. We are just trying to avoid merging back from stable to default as it is good practice to avoid merges. Hope this isn't too confusing!
7th February 2019, 19:38 | #6704 | Link | |
Using --crqpoffs -* would help red without spending more bits on blue. It makes a certain logical sense that, when decreasing chroma QP, it would make sense to reduce 2 red for every blue given the relatively higher sensitivity to red. However, red also accounts for a greater portion of luma than blue which likely would offset that some. Encoding in 10-bit instead of 8-bit should help as well. Sometimes these problems can be as much in the 10-bit Y'CbCr -> 8-bit RGB conversion on a device than in the encoding itself. Display controllers that just truncate the 8-bit instead of dithering can cause all kinds of issues even in SDR. Dithering should be done even when doing a 16-235 Y'CbCr to 0-255 RGB conversion. To humorously paraphrase Gen. Robert H. Barrow, USMC "Hobbyists talk about average bitrates and per-title metrics, but experts study color volume algorithms and rate control." |
7th February 2019, 19:42 | #6705 | Link | |
This can save some bits (only material at very low bitrates), and potentially some work by the tone mapper. Since display<>decode order, you'll get cases where the tone mapper could find out in advance that several frames in a row have identical color characteristics. |
7th February 2019, 21:43 | #6706 | Link | |
I'll continue sticking to zones then or live with rising the overall bitrate beyond general need if the pain becomes too much. |
12th February 2019, 20:50 | #6708 | Link |
--ctu --max-tu-size --qg-size tests
I've made some tests for 1080p with --tune-psnr, --tune-ssim, and no-tune for different variants --ctu --max-tu-size --qg-size
Does this mean that for 1080p encoding default settings (--ctu 64 --max-tu-size 32 --qg-size 32) is the best option? Results: Code:
no-tune === --ctu 64 --max-tu-size 32 --qg-size 32 Global PSNR: 55.009, SSIM Mean Y: 0.9965665 (24.643 dB) higher value --ctu 32 --max-tu-size 32 --qg-size 16 Global PSNR: 54.982, SSIM Mean Y: 0.9965609 (24.636 dB) --ctu 32 --max-tu-size 32 --qg-size 8 Global PSNR: 54.866, SSIM Mean Y: 0.9964265 (24.469 dB) --ctu 32 --max-tu-size 16 --qg-size 16 Global PSNR: 54.908, SSIM Mean Y: 0.9964738 (24.527 dB) --ctu 32 --max-tu-size 16 --qg-size 8 Global PSNR: 54.791, SSIM Mean Y: 0.9963344 (24.359 dB) === tune-psnr === --ctu 64 --max-tu-size 32 --qg-size 32 Global PSNR: 54.936 higher value --ctu 32 --max-tu-size 32 --qg-size 16 Global PSNR: 54.910 --ctu 32 --max-tu-size 32 --qg-size 8 Global PSNR: 54.806 --ctu 32 --max-tu-size 16 --qg-size 16 Global PSNR: 54.869 --ctu 32 --max-tu-size 16 --qg-size 8 Global PSNR: 54.765 === tune-ssim === --ctu 64 --max-tu-size 32 --qg-size 32 SSIM Mean Y: 0.9964914 (24.549 dB) higher value --ctu 32 --max-tu-size 32 --qg-size 16 SSIM Mean Y: 0.9964839 (24.539 dB) --ctu 32 --max-tu-size 32 --qg-size 8 SSIM Mean Y: 0.9963653 (24.395 dB) --ctu 32 --max-tu-size 16 --qg-size 16 SSIM Mean Y: 0.9964291 (24.472 dB) --ctu 32 --max-tu-size 16 --qg-size 8 SSIM Mean Y: 0.9963079 (24.327 dB) |
12th February 2019, 20:52 | #6709 | Link | |
12th February 2019, 21:05 | #6710 | Link |
The modern codec design process biases heavily for fixed QP maximizing mean PSNR, so adaptive quant and psychovisual optimizations are generally only helpful when targeting subjective quality. Which is all viewers care about. I’ve seen lots of beautiful PSNR plots turn into lousy looking video.
12th February 2019, 21:15 | #6711 | Link | ||
Which option can you advise? And one more question. Can I somehow optimize the settings for quality improvement without significantly reducing speed? Or will these settings be enough? My traget bitrate 20-25mbs --preset placebo --crf 12 --profile main10 --output-depth 10 --level-idc 51 --sar 1:1 --colorprim 9 --colormatrix 9 --transfer 16 --range limited --master-display "G(13250,34500)B(7500,3000)R(34000,16000)WP(15635,16450)L(10000000,1)" --hdr --hdr-opt --chromaloc 2 --repeat-headers --hrd --max-cll "0,0" --min-luma 0 --max-luma 1023 --subme 7 --me star --merange 48 --limit-tu 4 --max-merge 4 --limit-modes --limit-refs 3 --rd 6 --rd-refine --no-tskip --rskip --no-cutree --no-sao --no-open-gop --no-b-pyramid --no-strong-intra-smoothing --vbv-bufsize 160000 --vbv-maxrate 160000 --cbqpoffs -2 --crqpoffs -2 --min-keyint 5 --keyint 240 --ipratio 1.30 --pbratio 1.20 --deblock -3:-3 --qcomp 0.65 --aq-mode 2 --aq-strength 0.8 --psy-rd 1.5 --psy-rdoq 5 Last edited by redbtn; 12th February 2019 at 21:32. |
13th February 2019, 16:08 | #6712 | Link | |
Lost my old account :(
Have you actually tried those settings? It wouldn't surprise me that placebeo crf12 could render a file bigger then the original 4k one, and you will be lucky if you do it above 1fps. I'm sure you have your reasons for this scenario, but if quality was that important to me, I would just go with the original. Last edited by excellentswordfight; 13th February 2019 at 16:22. |
13th February 2019, 16:54 | #6713 | Link | |
I view at 4K UHD TV, but it is connected to a computer as duplicated with a monitor with a resolution of 1080p because windows 10 cannot normally scale many applications in 4K (it's sadly). Therefore, I decided that there is no point in reducing the image via MadVR in real time. Although I have a GTX 1080 which does it without problems. And also save about 50 percent of the HDD space. |
13th February 2019, 18:30 | #6714 | Link |
Pig on the wing
You can safely use --rskip, it will speed up things a lot and you won't notice any difference. I'd also use something like --subme 3.
13th February 2019, 22:13 | #6715 | Link | |||
Boulder thank you!
And i should remove this? clip = core.resize.Bicubic(clip=clip, format=vs.YUV420P10, range_s="limited") Thank you! My VS scrypt: Quote:
14th February 2019, 01:33 | #6716 | Link |
advice
--crf 18 --profile main10 --level-idc 5.1 --output-depth 10 --rd 4 --ctu 32 --amp --aq-mode 2 --vbv-bufsize 160000 --vbv-maxrate 160000 --ipratio 1.3 --pbratio 1.2 --no-cutree --subme 7 --me star --merange 24 --max-merge 3 --bframes 12 --rc-lookahead 60 --lookahead-slices 4 --ref 6 --min-keyint 24 --keyint 240 --deblock -3:-3 --no-sao --no-strong-intra-smoothing --high-tier Someone told me, that there is no reason to use subme 7, I am use to from x264 use subme 10 so I thought that it could be usefull. Thank you for your advice and some explonation. Last edited by hevc_enocder; 14th February 2019 at 02:24. Reason: spelling |
14th February 2019, 09:09 | #6718 | Link | |
Subme and RD(O) level are separate settings in x265 and I personally don't think it's worth using anything higher than subme 5. Whenever I've tested, it's never actually been worth it to use anything higher than subme 3 really which is the lowest subme to include chroma residual cost. I'd definitely choose --rd 5 (or 6 since they're the same) plus --rd-refine over subme 7 everytime. Though that will half your encoding time so I rarely ever bother with that either |
14th February 2019, 10:35 | #6719 | Link | |
I just did a quick test on tears of steal with those settings and compared it an encode at native res with slow preset (+ --deblock -1:-1 --no-sao --no-strong-intra-smoothing)... the 1080p one ended up at 40Mbps (downscaled with spline), and the 2160 one at 25, the one at at native res was sharper and was about 3x faster to encode... Ofc, if you find the time/compression/quality to be a good tradeoff for you go ahead with that. But when you even have a 4k TV I would jut go with a 4k workflow cause you can get away with 4k re-encodes with that bitrate target. Not gonna tell you what to do, but I would at least play with different preset levels and crf values and look at the actually video to see if you can find a better "sweetspot". Cause it sounds awful to me o spend 2days for an encode, just to get a bloated file that still has a loss of detail/sharpness (cause of downscaling). Last edited by excellentswordfight; 14th February 2019 at 11:18. |
