28th August 2011, 17:35 | #10001 | Link |
yeah, I never watch movies in anything other than the original track either
might be a nice feature to add for those who want to add multiple tracks though (the multiple track could even be for something else, like commentary) |
29th August 2011, 03:03 | #10002 | Link |
For any Anime lovers, how are you all doing your subtitles? For instance all my Funimation BD's each contain two sup files. One is usually the opening/closing audio track for the music and the other is the feature.
My output container is mp4 so I just embed the main feature subtitle track but was curious if there is a way to build both subtitle tracks onto the output video. Hope that makes sense. Thanks. |
29th August 2011, 20:02 | #10003 | Link |
RipBot264 is amazing! Does anyone know if there is a way to get it to demux the audio later in the process? So it doesn't do it right when you select a file. It would make encoding multiple files so much easier as you wouldn't have to wait for each file to demux before you start encoding. Thanks.
29th August 2011, 20:11 | #10004 | Link | |
30th August 2011, 09:41 | #10005 | Link |
@rc71
I see, but since it is possible to include "all subtitles" with Ripbot264, why isn't it possible to include *all* audiotracks as well?? This just doesn't make sense to me. And besides: It would be very, very useful to a lot of people. Well.. maybe in a future version... |
30th August 2011, 13:42 | #10006 | Link |
So you also have to encode all of them. The you also have to have the option set Standard-Flags for 1 Audio-Track.
A force-tag for Subtitles would be great so i don't have to build them into the movie itself. |
31st August 2011, 04:39 | #10007 | Link | |
just because you include an audio track doesn't mean you have to encode it
also the stuff you guys want can be done via remuxing with mkvmerge. I know that's an extra step but that's what you'll need to do until ripbot can do the operations (if they get added) Quote:
I'd never use it |
31st August 2011, 18:10 | #10008 | Link |
Converting DTS to AC3... with quality, quick and easy.
For anyone who needs include dual audio... though the RipBot also converts. Use my version... Here Just follow the two steps below: 1. Rename your DTS file to INPUT.dts audio and drag it for inside of the DTS2AC3 folder. 2. Run one of the "DTS2AC3.bat": DTS2AC3-384kbit DTS2AC3-448kbit DTS2AC3-640kbit The AC3 audio will be created and saved as you chose in the same folder, but with the name OUTPUT.ac3. |
1st September 2011, 02:48 | #10009 | Link |
HI Jandor,
Ripbot doesnt calculate the conversion to fit under the DVD5 and DVD9 AVCHD format. Either if you convert it to .AC3, you need to calculate it manually. I does like that (convert DTS to AC3 with EAC3toGUI that i copy into tools folder, and calculate manually: Ex: 4475 - (ac3 size track 2) = ex. 4183, set 4175. This example is for Multi AC3 Only, or audio I is DTS converted with ripbot. For Multi DTS; ex: 8125 - (dts audio track #2) = ex. 7293mb, set it to 7175 (take out 100mb for conversion space, containers, etc.) and make an estimate to under 25mb range (ex. 4025mb, 4050mb, 4075mb). In that way, i remux the output conversion with ripbot, add the second audio track, remux everything in AVCHD and everything fit under the DVD5/9 format with dual language. That's the only one way i've found to add an second language. If you had a more easy or faster way to do it, im open!
PC; 7.5 on 7.9 (Windows Experience Rating) on the lower rating. |
1st September 2011, 02:56 | #10010 | Link | |
I understand but for a people like me that my primary language is something different that english (me is french) i prefer to listen first in my favorites language, and after listen in english. It's help to more understand after if i listen first in french. Also, my wife listen up in english, me in french. It's usefull to add the second language. Same for people how is primary language is French, Spanish, Portuguese. Many people request that features. If you can took suggestions and on future think that it can be possible if many poeple is interested, we can wait the time you need to do it, sure we can wait. Personnally, more than two years i've read over your thread and about 10 peoples ask that feature. I'Ve test HDConvertToX software that they are suppose to do it, but i experiencing many bugs so i prefer your software much stable and easy to use. I not like it, I LOVE IT! lol
1st September 2011, 03:25 | #10011 | Link |
@8ternity
Use 2-pass RipBot and control the size of the file containing an audio stream, in ways that make room for the "remux" of the second audio. Just need to know the size of the second audio stream. I never liked 2-pass, but it is the way to enjoy the encoding of RipBot. Really, RipBot264 and AVStoDVD, are my favorites. Last edited by jandor; 1st September 2011 at 03:44. |
1st September 2011, 07:46 | #10012 | Link |
@ jandor:
Your DTS2AC3 uses Aften as AC3 encoder. Because Aften has no really complex psycho-acoustic model yet, its efficiency is rather limited. High bitrates are recommended to preserve quality (with the limitation that "DVD Video" only supports AC3 up to 448 kbps; but current at-least-slightly Blu-ray compatible allround players and A/V Receivers should handle 640 kbps AC3). |
1st September 2011, 13:33 | #10013 | Link |
Hi, @LigH
I see no difference to Aften conversion of the DTS2AC3 compared to other converters. It may be strange, but I encode DVD-9 with AC3 640 kbps. Which the best encoder AC3? Which of them does better quality print? I already know the eac3to. Thanks! |
1st September 2011, 14:39 | #10015 | Link |
I don't know any really free AC3 encoder with any halfway complex psycho-acoustic model (similar to e.g. the one the LAME MP3 encoder uses). All the more complex AC3 encoders I know are commercial. So regarding freeware, Aften is still the best we have. And I did not say it is bad; it just could be better, and you may hear the limits when the bitrate gets sparse - like only 384 kbps for 5.1 audio, or even less.
640 kbps is not part of the DVD Video specs; there may be DVD authoring tools which reject such streams, there may be DVD players which contain AC3 decoders which are limited to at most 448 kbps. |
