Old 7th August 2014, 12:45   #4241  |  Link
Zathor
Originally Posted by leon View Post
Can you please check sourceforge too?
Yes, I did it now as I read feature requests only once in a while. You mixed in your feature request also support request/bug report.
Warpsharph: LoadVirtualDubPlugin will not work with AviSynth+ by default. The VDubFilter.dll is not in an autoload directory. If you want to use it you have to load this dll first (or install AviSynth)
And you wrote
when vcomp.dll is in my Avisynth plugin dir MeGUI shows an error(there's a picture of it in doom 9's forum).
No clue as I cannot find it - a link would help here
Old 7th August 2014, 17:19   #4242  |  Link
leon
MeGUI still doesn't seem to be happy about doing things like adjusting the cropping too quickly in the script creator when ffms has been used for indexing.
It's a pretty easy issue to duplicate for me. Open an MKV, index it with ffms and enable cropping in the script creator. Click on one of the up arrows for adjusting the cropping and hold it. The cropping amount will automatically increase for a bit, then it'll stop. Upon releasing the up cropping arrow an error message window will appear. Click on "okay" and it'll appear again, and again, and again.....
The error message:
"MeGUI has encountered a fatal error and may not be able to proceed. Reason: Object reference not set to an instance of an object."
I can usually duplicate the same problem by clicking on, and holding down, one of the resize arrows. Mind you I rarely click and hold either the resize or cropping arrows (although it'd be nice if you could) but clicking on an arrow too quickly, lots of times in succession, will often result in the same error message.
From memory, if the "auto apply preview" option is checked, it makes it more likely the error will occur so I need to adjust the cropping/resizing more slowly, and from memory, the problem only occurs when FFVideoSource is used.
it happens for me too and because of this I change the settings slowly the same error occurs after saving Avisynth profile too.
and when I want to do AutoCrop and when "Apply auto preview" is checked it show me this error :
Original video window is open all the time.
leon is offline   Reply With Quote
Old 7th August 2014, 17:28   #4243  |  Link
leon
@Zathor
Thank you
http://www.mediafire.com/download/2c...1ge8/vcomp.dll
sorry for mixing subjects but I didn't want to post extra
topics.
what about my feature request ?(commandline)
Old 7th August 2014, 20:05   #4244  |  Link
Zathor
Please give me more details about this vcomp problem - if you have already posted it somwhere here please provide the forum link.
Your custom command line makes sense therefore I do not reject the request. But I cannot give you an ETA for the implemetation. There are hundreds of feature requests in the tracker and I do not have the time to implement them. Btw I do not implement feature requests in any specific order. Your request may be in the works tomorrow, next week, next year or never. So please do not push me. But if other people also like your request it is more likely that it will be implemented sooner - and especially if I need it for my use cases (not the case with this feature request - yet).
Old 7th August 2014, 20:09   #4245  |  Link
Zathor
This is a long open problem - sorry. As it indeed only happens when ffms is used it was never very high on my list. I tried to fix it several weeks ago but failed after hours of work. It crashs somewhere in the unmanaged code areas. Maybe someone more experienced can help with this problem.
https://sourceforge.net/p/megui/bugs/758/
But please try it with this build:
http://forum.doom9.org/showpost.php?...postcount=4289
The memory improvements may also help here.
Old 7th August 2014, 20:32   #4246  |  Link
leon
@Zathor
here you are :
http://forum.doom9.org/showthread.ph...95#post1685095
...So please do not push me...
don't need to say me that cause I'm patient
Old 8th August 2014, 09:15   #4247  |  Link
hello_hello
No different, unfortunately. At least not when it comes to clicking and holding a cropping arrow. The cropping value changes for a short period, then it stops changing, and when you release the cropping arrow the "fatal error" message appears, and appears again, and again...
Old 9th August 2014, 15:28   #4248  |  Link
leon
Hi
MeGUI shows this error (and some other errors too) when I want to open or apply that script(in the picture) :
I disabled "Improved AVS opening" but nothing changed.
Old 10th August 2014, 22:35   #4249  |  Link
That's interesting; it seems to treat the whole script content as a file name.
Old 28th August 2014, 07:04   #4250  |  Link
haruna
Hello, my meGUI suddenly stop worked though at first, it worked normally. I don't know what to do to fix it. This is my logfile. Hope you could help me with this problem. Thankyou.
Preliminary log file only. During closing of MeGUI the well formed log file will be written.
-[Information] Versions
--[Information] [26-Aug-14 8:16:30 PM] MeGUI: 2507
--[Information] [26-Aug-14 8:16:30 PM] Operating System: Windows 7 Ultimate Edition x64 SP1 (6.1.65536.7601)
--[Information] [26-Aug-14 8:16:31 PM] .Net Framework: 2.0.50727.5420
--[Information] [26-Aug-14 8:16:31 PM] .Net Framework: 4.0.30319
--[Information] [26-Aug-14 8:16:31 PM] AviSynth: 2.5.8.5 (21-12-2008)
--[Information] [26-Aug-14 8:16:31 PM] AvisynthWrapper:  (02-01-2009)
--[Information] [26-Aug-14 8:16:31 PM] Haali Matroska Splitter: 1.13.138.14 (14-04-2013)
--[Information] [26-Aug-14 8:16:31 PM] Haali DSS2:  (14-04-2013)
--[Information] [26-Aug-14 8:16:32 PM] ICSharpCode.SharpZipLib: 0.85.5.452 (07-08-2008)
--[Information] [26-Aug-14 8:16:32 PM] LinqBridge: 1.0.0.0 (28-05-2009)
--[Information] [26-Aug-14 8:16:32 PM] MediaInfo: 0.7.69.0 (24-04-2014)
--[Information] [26-Aug-14 8:16:32 PM] MediaInfoWrapper: 0.7.61.0 (06-01-2013)
--[Information] [26-Aug-14 8:16:32 PM] MessageBoxExLib: 1.0.2218.28317 (19-12-2008)
--[Information] [26-Aug-14 8:16:32 PM] SevenZipSharp: 0.64.3890.29348 (02-01-2011)
--[Information] [26-Aug-14 8:16:32 PM] 7z: 9.20 (18-11-2010)
-[Information] Update detection
--[Information] [26-Aug-14 8:16:41 PM] Using cached update config and server: http://megui.org/auto/stable/
--[Information] [26-Aug-14 8:16:41 PM] No package requires an update
-[Information] AutoEncode job generation log
--[Information] [26-Aug-14 8:19:37 PM] Desired Size : 90.00 MB
--[Information] [26-Aug-14 8:19:37 PM] Split Size : null
-[Information] [26-Aug-14 8:19:37 PM] Video output file: H:\Anime\07 Ghost\XIX_07_Ghost_EP15_animesave.264
-[Information] [26-Aug-14 8:19:37 PM] Muxed output file: H:\Anime\07 Ghost\XIX_07_Ghost_EP15_animesave-muxed.mkv
-[Information] [26-Aug-14 8:19:37 PM] Encodable audio stream 0: H:\Anime\07 Ghost\XIX_07_Ghost_EP15_animesave_new.m4a
--[Information] Eliminating duplicate filenames
-[Information] Log for job237 (audio, XIX_07_Ghost_EP15_animesave.mp4 -> XIX_07_Ghost_EP15_animesave_new.m4a)
--[Information] [26-Aug-14 8:19:40 PM] Started handling job
--[Information] [26-Aug-14 8:19:40 PM] Preprocessing
--[Information] [26-Aug-14 8:19:40 PM] MediaInfo
---[Information] [26-Aug-14 8:19:40 PM] File: H:\Anime\07 Ghost\XIX_07_Ghost_EP15_animesave.mp4
-[Information] Format: Matroska
-[Information] FormatString: Matroska
-[Information] FileSize: 296313248
-[Information] PlayTime: 00:23:50.400
---[Information] General
-[Information] ID: 2
-[Information] StreamOrder: 1
-[Information] Width: 1280
-[Information] Height: 720
-[Information] FrameCount: 34295
-[Information] FrameRate: 23.976
-[Information] FrameRateOriginal:
-[Information] FrameRateMode: CFR
-[Information] ScanType: Progressive
-[Information] Codec: V_MPEG4/ISO/AVC
-[Information] CodecString: AVC
-[Information] Bits Depth: 10
-[Information] Format: AVC
-[Information] AspectRatio: 1.778
-[Information] AspectRatioString: 16:9
-[Information] Delay: 0
-[Information] Title:
-[Information] Language: en
-[Information] LanguageString: English
-[Information] Default: Yes
-[Information] DefaultString: Yes
-[Information] Forced: No
-[Information] ForcedString: No
---[Information] Video
-[Information] ID: 3
-[Information] StreamOrder: 2
-[Information] Format: AAC
-[Information] FormatProfile: LC
-[Information] FormatSettingsSBR: No (Explicit)
-[Information] FormatSettingsPS:
-[Information] SamplingRate: 48000
-[Information] SamplingRateString: 48.0 KHz
-[Information] Channels: 2
-[Information] ChannelsString: 2 channels
-[Information] ChannelPositionsString2: 2/0/0
-[Information] BitRateMode:
---[Information] Audio
-[Information] ID: 1
-[Information] StreamOrder: 0
-[Information] Codec: S_TEXT/ASS
-[Information] CodecString: ASS
-[Information] Title: [XIX]Takarirnya
-[Information] Language: id
-[Information] LanguageString: Indonesian
---[Information] Text
--[Information] [26-Aug-14 8:19:41 PM] Trying to open the file with NicAudio
--[Information] [26-Aug-14 8:19:41 PM] Failed opening the file with NicAudio()
--[Information] [26-Aug-14 8:19:41 PM] Trying to open the file with BassAudioSource()
--[Information] [26-Aug-14 8:19:44 PM] Failed opening the file with BassAudioSource(). File could not be opened!
--[Information] [26-Aug-14 8:19:44 PM] Trying to open the file with FFAudioSource()
--[Information] [26-Aug-14 8:20:09 PM] Failed opening the file with FFAudioSource(). FFAudioSource: No audio track found
--[Information] [26-Aug-14 8:20:09 PM] Trying to open the file with LWLibavAudioSource()
haruna is offline   Reply With Quote
Old 28th August 2014, 08:43   #4251  |  Link
Just in case: Do not ask how to process pirated movies. See forum rules.
Your input file has the extension .mp4 but a Matroska container; better be certain what you have.
Old 13th September 2014, 09:50   #4252  |  Link
Carpo
Carpo's Avatar
Would it be possible to add the itags cover option to the MP4 muxer, I like to add film covers to my MP4s, yes I know its purely a cosmetic thing
The Internet: where men are men, women are men, and children are FBI Agents
Carpo is offline   Reply With Quote
Old 19th September 2014, 09:09   #4253  |  Link
yangshao
yangshao's Avatar
MeGUI video tasks to 99.9% error occurred!
Hello. Used a variety of versions of the MeGUI consists of 2508 current versions, a fatal error occurred when the task was always: video to 99.9% when occurs, the system prompts "encountered a problem, caused the program to stop working correctly". (windows7)
MeGui LOGO:
Supplement: music or video coding of MV is normal, but the video time length exceeds the above mentioned error occurred in the 60min will!!! Because of my code is complete movie file.
I write AVS are correct, AVS is the normal play! The use of other x264 tools (Hybrid, Simple x264 Launcher) code with a AVS file is not an error occurs, the task is completed properly! When video tasks why the use of MeGUI to 99.9% error will occur? What causes the encoder process exit? Please tell me how I should deal with, thank you!
yangshao is offline   Reply With Quote
Old 20th September 2014, 10:42   #4254  |  Link
Zathor
Please post the full log file.
What happens when you execute the command line directly?
Old 22nd September 2014, 20:18   #4255  |  Link
Capsbackup
When trying to mux a .264 file with a mp4 audio file using the mp4 muxer option, and split the file at 3.5GB, there is no split or completed output file at all!
If I do not select to split the file, I do get a completed muxed file.
So the splitting file option is not working anymore?
[Information] Log
--[Information] [9/22/2014 11:46:21 AM] MeGUI: 2508
--[Information] [9/22/2014 11:46:21 AM] Operating System: Windows 7 x64 SP1 (6.1.65536.7601)
--[Information] [9/22/2014 11:46:21 AM] .Net Framework: 2.0.50727.5420
--[Information] [9/22/2014 11:46:21 AM] .Net Framework: 4.0.0.0
--[Information] [9/22/2014 11:46:21 AM] AviSynth: 2.5.8.5 (21-12-2008)
--[Information] [9/22/2014 11:46:21 AM] AvisynthWrapper: (06-01-2013)
--[Information] [9/22/2014 11:46:21 AM] Haali Matroska Splitter: 1.9.42.1 (10-01-2009)
--[Information] [9/22/2014 11:46:21 AM] Haali DSS2: (10-01-2009)
--[Information] [9/22/2014 11:46:21 AM] ICSharpCode.SharpZipLib: 0.85.5.452 (06-01-2013)
--[Information] [9/22/2014 11:46:21 AM] LinqBridge: 1.0.0.0 (06-01-2013)
--[Information] [9/22/2014 11:46:21 AM] MediaInfo: 0.7.70.0 (03-09-2014)
--[Information] [9/22/2014 11:46:21 AM] MediaInfoWrapper: 0.7.61.0 (06-01-2013)
--[Information] [9/22/2014 11:46:21 AM] MessageBoxExLib: 1.0.2218.28317 (06-01-2013)
--[Information] [9/22/2014 11:46:21 AM] SevenZipSharp: 0.64.3890.29348 (06-01-2013)
--[Information] [9/22/2014 11:46:21 AM] 7z: 9.20 (06-01-2013)
--[Information] [9/22/2014 11:46:23 AM] Connected to server: http://megui.xvidvideo.ru/auto/
--[Information] [9/22/2014 11:46:23 AM] No package requires an update
-[Information] Log for job1 (mux, Transformers Age Of Extinction.264 -> Transformers Age Of Extinction-muxed.mp4)
--[Information] [9/22/2014 11:47:31 AM] Started handling job
--[Information] [9/22/2014 11:47:31 AM] Preprocessing
--[Information] [9/22/2014 11:47:31 AM] MediaInfo
---[Information] [9/22/2014 11:47:31 AM] File: G:\BD RIPS\Transformers Age Of Extinction\Transformers Age Of Extinction.264
----[Information] Format: AVC
----[Information] FormatString: AVC
----[Information] FileSize: 9756563984
----[Information] PlayTime:
----[Information] ID:
----[Information] StreamOrder:
----[Information] Width: 1920
----[Information] Height: 800
----[Information] FrameCount:
----[Information] FrameRate: 23.976
----[Information] FrameRateOriginal:
----[Information] FrameRateMode:
----[Information] ScanType: Progressive
----[Information] Codec: AVC
----[Information] CodecString: AVC
----[Information] Bits Depth: 8
----[Information] AspectRatio: 2.400
----[Information] AspectRatioString: 2.40:1
----[Information] Delay:
----[Information] Title:
----[Information] Language:
----[Information] LanguageString:
----[Information] Default:
----[Information] DefaultString:
----[Information] Forced:
----[Information] ForcedString:
---[Information] [9/22/2014 11:47:31 AM] File: G:\BD RIPS\Transformers Age Of Extinction\Transformers Age Of Extinction.track_2.mp4
----[Information] Format: MPEG-4
----[Information] FormatString: MPEG-4
----[Information] FileSize: 546358893
----[Information] PlayTime: 02:45:07.392
----[Information] ID: 1
----[Information] StreamOrder: 0
----[Information] Format: AAC
----[Information] FormatProfile: LC
----[Information] FormatSettingsSBR: No (Explicit)
----[Information] FormatSettingsPS:
----[Information] SamplingRate: 48000
----[Information] SamplingRateString: 48.0 KHz
----[Information] Channels: 6
----[Information] ChannelsString: 6 channels
----[Information] ChannelPositionsString2: 3/2/0.1
----[Information] BitRateMode: VBR
--[Information] [9/22/2014 11:47:32 AM] Job commandline: "C:\Tools\MeGUI\tools\mp4box\mp4box.exe" -add "G:\BD RIPS\Transformers Age Of Extinction\Transformers Age Of Extinction.264#trackID=1:fps=23.976:name=" -add "G:\BD RIPS\Transformers Age Of Extinction\Transformers Age Of Extinction.track_2.mp4#trackID=1:lang=en:name=" -splits 3670016 -tmp "G:\\BD RIPS\\Transformers Age Of Extinction" -new "G:\BD RIPS\Transformers Age Of Extinction\Transformers Age Of Extinction-muxed.mp4"
--[Information] [9/22/2014 11:47:32 AM] Process started
--[Information] [9/22/2014 11:47:32 AM] Standard output stream
--[Information] [9/22/2014 11:47:32 AM] Standard error stream
---[Information] [9/22/2014 11:47:39 AM] AVC-H264 import - frame size 1920 x 800 at 23.976 FPS
---[Information] [9/22/2014 11:52:45 AM] AVC Import results: 237537 samples - Slices: 62044 I 585896 P 302208 B - 277663 SEI - 4 IDR
---[Information] [9/22/2014 11:52:45 AM] Stream uses forward prediction - stream CTS offset: 2 frames
---[Information] [9/22/2014 11:52:45 AM] OpenGOP detected - adjusting file brand
---[Information] [9/22/2014 11:52:45 AM] IsoMedia import Transformers Age Of Extinction.track_2.mp4 - track ID 1 - Audio (SR 48000 - 6 channels)
---[Information] [9/22/2014 11:53:29 AM] Not enough Random Access points in input file - cannot split
--[Information] [9/22/2014 11:53:29 AM] Postprocessing
---[Information] [9/22/2014 11:53:29 AM] Deleting intermediate files
--[Information] [9/22/2014 11:53:29 AM] Job completed
Old 22nd September 2014, 20:39   #4256  |  Link
AMED
AMED's Avatar
I don't think this is a fault with MeGUI.
Can you try using Mp4box to remux this file in to a new mp4 file (without splitting) and then try that new mp4 in MeGUI.
EDIT: According to the Mp4box documentation
Note 1 : The input file must have enough random access points in order to be splitted. This may not be the case with some video files where only the very first sample of the video track is a key frame (many 3GP files with H263 video are recorded that way). In order to split such files you will have to use a real video editor and re-encode the content.
A Man Eating Duck
AMED is offline   Reply With Quote
Old 22nd September 2014, 21:16   #4257  |  Link
Capsbackup
Thanks for your reply. I did notice that message in the log. I have used this method several times before, which is using MeGui to reencode the file to a given file size, then use that MeGui reencoded .264 as well as MeGui's reencoded dts or ac3 to mp4 audio file as the inputs.
Tried using the successful mux to one file as the video input, then used the mp4 audio file as the audio input, but same results as before with the same message
"Not enough Random Access points in input file - cannot split".
Old 22nd September 2014, 21:32   #4258  |  Link
sneaker_ger
Open gop left just 3 possible split points for the entire movie. (First IDR is very first frame of movie and doesn't count)
Use closed gop or make the planned split points IDR frames via qpfile next time.
Old 22nd September 2014, 23:19   #4259  |  Link
Capsbackup
Thanks for the suggestion. I have used qp file for chapters before, but not for splitting files.
I use the Bluray profile with a CRF 22 for encoding, with open gop. Several movies I have done this way have always worked. The only reason I split the files is when the finished file is greater than 4GB. Only then do I split them, since my WD MY Book Live NAS only allows less than 4 GB files for remote download access.
I thought I frames would work as well, but apparently not.
Old 26th September 2014, 10:27   #4260  |  Link
hello_hello
When you right click on a job in the job queue you're given a bunch of options. "Delete", "change status", "run in temporary worker" etc. Each of them only apply to the selected job(s). Except abort. That doesn't just abort the selected job, it aborts them all. Why?????
I know the conformation window asks if you want to abort all jobs but it seems to me it should apply just to the selected jobs just like all the other options. Then maybe I wouldn't have clicked through the confirmation window and accidentally aborted a job which had been running for hours. I've done that a few times in the past.
