Old 3rd January 2020, 13:28   #29121  |  Link
Dofin
Hello, I've been using BD Rebuilder for years but recently it has started to completely freeze my PC. At first, I had thought about a heat issue but it is not as "Core temp" indicated. I've checked used software and everything looked working properly. Any suggestions ? Running Windows 10 PRO on eight core AMD processor. Many thanks.
Note: can not get a log as once PC's frozen, I do not have access to my mouse, programs or whatever was running, including Tasks Management. Only a hard reboot, depressing reset button on PC, works.
R M
Dofin is offline   Reply With Quote
Old 3rd January 2020, 13:57   #29122  |  Link
Michi
@jdobbs
Is there a GUI version of the tsmuxer you are using? And if so, where can one get it?
The latest nightly build with gui:
https://www.videohelp.com/software/tsMuxeR
Michi is offline   Reply With Quote
Old 3rd January 2020, 14:09   #29123  |  Link
MrVideo
MrVideo's Avatar
Thanks, I already have it. You gotta be quicker on the draw.
Old 3rd January 2020, 15:04   #29124  |  Link
MrVideo
MrVideo's Avatar
The rebuild of a UHD blu-ray to BD-50 has completed w/o any errors. Nothing to test it on though. It will be a while before I do.
Old 3rd January 2020, 16:50   #29125  |  Link
cartman0208
Only one pass was done.
Noticed that, too ...
If set to "Automatic Quality Settings", there's only one pass
You might want to uncheck that and then go to encoder settings again and uncheck any "one pass...", then you get two passes ... which will take even longer
@jdobbs: is there a reason for the strange sorting in the encoder quality menu? (Good is below Highest, but it seems to belong to the top?)
Old 3rd January 2020, 23:50   #29126  |  Link
MrVideo
MrVideo's Avatar
It took so long with one pass, setting it up for two will be like Rip Van Winkle.
Old 4th January 2020, 14:04   #29127  |  Link
Lowpro
Originally Posted by Lowpro View Post
I'd love to be able to take a movie that includes shifting aspect ratios and run it through BD Rebuilder having it reencode the video, so that the end result is a fixed aspect ratio.
An example would be a movie in the 2.40:1 aspect ratio where in just a couple scenes the aspect ratio opens up to 1.78:1. Would love to be able to reencode the video so that the entire film is in 2.40:1 instead, the IMAX portions above and below the 2.40:1 portion being replaced with black bars as is the case with the rest of the film.
I watch movies using a front projector and 150" 1.78:1 projector screen. For aspect ratios north or south of 1.78:1 I mask down to the projected image area with black velvet masking. I'm not interested in leaving unused portions of my projector screen unmasked for the entire length of a scope film because for a couple minutes during the film the aspect ratio jumps to 1.78:1.
Curious to learn how feasible such an option might be for BD Rebuilder or if anyone knows, how I might go about accomplishing the same with other tools out there.
@lowpro
BDRB has the possibility to add avisynth scripts. Assuming your source is 1920x1080, try
crop(0,120,-0,-120) #1.78 to 2.40
addborders(0,120,0,120) #letterbox (mask) for for blu-ray compliance
(It works in avisynth, I didn't try to include it in BDRB)
Thanks. I'll give that a try and yes, I own several movies on Blu-ray (1920x1080) that contain multiple aspect ratios. I'd like to create versions of each where the aspect ratio doesn't change. For example, if the main aspect ratio is 2.39:1 I'd like to mask everything above and below that visible area of the frame during times when the aspect ratio has changed. I don't care what content I lose as a result.
This worked beautifully by the way. The first film I tried this on was Mission: Impossible - Fallout. Added the script you provided via "Settings > Setup > Use AVS Filters during encoding", then creating a fresh movie-only backup. Worked like a charm. Was wonderful to be able to watch the film (...my projector screen physically masked down to 2.40:1) without those aerial sequences (1.78:1) being projected on the black velvet masking above and below the 2.40:1 screen area. The IMAX sequences do look great, but it's not worth the trade-off for me.
Lowpro is offline   Reply With Quote
Old 4th January 2020, 16:25   #29128  |  Link
Devilman1
This happened to me in the past when I had a faulty emory stick or a faulty capacitor on the Motherboard or on the Graphic card, but normally it happens also when using other stressing software
Devilman1 is offline   Reply With Quote
Old 4th January 2020, 17:36   #29129  |  Link
The last couple of encode options got added after the fact... so they are out of sequence. I just didn't feel like having to go back through the code and change the numbering for every reference. Normally "Good" doesn't even show as an option (until you use it by manually setting it in the INI). There's also an "Ultra-High (Extremely Slow)" setting that you can use by manually setting your INI value to 4.
Old 7th January 2020, 23:10   #29130  |  Link
Here's a piece of information I discovered that I think is interesting. The HEVC codec, according to UHD-BD spec is meant to be used only with 2160p and 1080p sources and those two resolutions are all that is supposed to be supported. But... the settings in the MPLS and CLPI files include other formats. So I did some experimenting... and low and behold, I can create a disc that uses the HEVC codec on 480/576 and 720p sources -- and my Sony UHD-BD Player accepts it and plays it back just as if it were meant to do so.
That's a big deal if you are trying to backup some old DVDs (like series discs) onto BD, as HEVC is much more efficient (especially at low bitrates) and you can fit a LOT of old episodes on a 50GB disc when using it.
Just thought I'd mention it. If someone else would like to try it... I'd be interested to know if other players accept it as well. You can do it with the new TSMUXER using the --blu-ray-v3 setting. The only thing I noticed that is a little odd is that it seems to always assume a 16:9 aspect ratio (which can be fixed with a little patching).
If it appears to be universal among players, I may add it as an option in BD-RB (with a warning that it isn't actually within spec).
Old 8th January 2020, 00:33   #29131  |  Link
Emulgator
Big Bit Savings Now !
Emulgator's Avatar
Good find ! I shall try this on a UDP-205.
As soon as you have a BD-RB test version ready, please let me know.
Edit:
Now I see, I shall try using tsMuxeR 2.6.15 first so that you can implement it in BD-RB if sucess can be reported.
"Data reduction ? Yep, Sir. We're working on that issue. Synce invntoin uf lingöage..."
Old 11th January 2020, 15:08   #29132  |  Link
BD Rebuilder v0.61.03
I have updated the first post of this thread with a link to the most recent version of BD-RB (v0.61.03). Changes for this release:
- Updated the included TSMUXER4K version to the
  most current release that supports UHD. This
  should fix dolbyvision problems experienced
  in 61.01.  If you added UHD_TSMUXER=0 to your
  your INI -- it should be removed in order to
  enable the new TSMUXER version.
- Corrected an issue in which performing a
  build with UHD_TSMUXER=0 could result in a
  "Error in attempt to create UHD CLPI" error
- Fixed a rare issue associated with importing
  an MPEG-2 source with telecined video.
- Modified alternate build routine so that SRT
  files that are kept are limited to those
  selected in the SETUP dialog.
Old 11th January 2020, 20:41   #29133  |  Link
Michi
Nothing has changed with the new version. My Sony X800M2 plays DV Rebuilds only in HDR , when DV is off. When I turn DV on the Sony on, the main film is black.
DV remuxes of the main film with the last tsmuxer plays my Sony without problems.
[01.11.20] BD Rebuilder v0.61.03
[15:17:05] Source:  COLD_PURSUIT
  - Input BD size: 78,62 GB
  - Approximate total content: [02:04:46.291]
  - Target BD size: 46,26 GB
  - Windows Version: 6.2 [9200]
  - Quality: Good (Fastest, BD-25+), ABR
  - Decoding/Frame serving: FFMPEG
  - Audio Settings: AC3=0 DTS=0 HD=1 Kbs=448
[15:17:07] PHASE ONE, Encoding
 - [15:17:07] Processing: VID_00000 (1 of 14)
 - [15:17:07] Extracting A/V streams [VID_00000]
 - [15:17:11] Reencoding video [VID_00000]
   - Source Video: HEVC, 3840x2160
   - Rate/Length: 24,000fps, 1.046 frames
   - Bitrate: 24.020 Kbs
 - [15:17:11] Reencoding: VID_00000, Pass 1 of 1
 - [15:19:04] Video Encode complete
 - [15:19:04] Processing audio tracks
   - Track 4356 (deu): Keeping original audio
 - [15:19:04] Multiplexing M2TS
 - [15:19:08] Processing: VID_00001 (2 of 14)
 - [15:19:08] Extracting A/V streams [VID_00001]
 - [15:19:12] Reencoding video [VID_00001]
   - Rate/Length: 24,000fps, 631 frames
   - Bitrate: 9.355 Kbs
 - [15:19:12] Reencoding: VID_00001, Pass 1 of 1
 - [15:20:04] Video Encode complete
 - [15:20:04] Processing audio tracks
 - [15:20:04] Multiplexing M2TS
 - [15:20:08] Processing: VID_00002 (3 of 14)
 - [15:20:08] Extracting A/V streams [VID_00002]
 - [15:20:31] Reencoding video [VID_00002]
   - Rate/Length: 24,000fps, 8.582 frames
   - Bitrate: 35.000 Kbs
 - [15:20:31] Reencoding: VID_00002, Pass 1 of 1
 - [15:34:37] Video Encode complete
 - [15:34:37] Processing audio tracks
 - [15:34:37] Multiplexing M2TS
 - [15:34:45] Processing: VID_00003 (4 of 14)
 - [15:34:45] Extracting A/V streams [VID_00003]
 - [15:34:49] Reencoding video [VID_00003]
   - Rate/Length: 24,000fps, 211 frames
 - [15:34:49] Reencoding: VID_00003, Pass 1 of 1
 - [15:35:16] Video Encode complete
 - [15:35:16] Processing audio tracks
 - [15:35:16] Multiplexing M2TS
 - [15:35:20] Processing: VID_00008 (5 of 14)
 - [15:35:20] Extracting A/V streams [VID_00008]
   - Extracting video streams [VID_00008]
   - Extracting secondary video [VID_00008]
   - Extracting audio/subtitle streams [VID_00008]
 - [15:54:17] Reencoding video [VID_00008]
   - Rate/Length: 24,000fps, 160.215 frames
 - [15:54:17] Reencoding: VID_00008, Pass 1 of 1
 - [18:57:39] Video Encode complete
 - [18:57:39] Processing audio tracks
 - [18:57:39] Multiplexing M2TS
[18:57:44]PHASE ONE aborted by user request
[19:01:31] Source:  COLD_PURSUIT
- Resuming from previously started job.
[19:01:32] PHASE ONE, Encoding
 - [19:01:32] Processing: VID_00008 (5 of 14)
 - [19:02:01] Multiplexing M2TS
 - [19:03:17] Processing: VID_00020 (6 of 14)
 - [19:03:17] Extracting A/V streams [VID_00020]
 - [19:03:21] Reencoding video [VID_00020]
   - Rate/Length: 24,000fps, 240 frames
   - Bitrate: 1.489 Kbs
 - [19:03:21] Reencoding: VID_00020, Pass 1 of 1
 - [19:03:35] Video Encode complete
 - [19:03:36] Processing audio tracks
 - [19:03:36] Multiplexing M2TS
 - [19:03:39] Processing: VID_00021 (7 of 14)
 - [19:03:39] Extracting A/V streams [VID_00021]
 - [19:03:42] Reencoding video [VID_00021]
   - Rate/Length: 24,000fps, 167 frames
   - Bitrate: 1.244 Kbs
 - [19:03:43] Reencoding: VID_00021, Pass 1 of 1
 - [19:03:53] Video Encode complete
 - [19:03:53] Processing audio tracks
 - [19:03:53] Multiplexing M2TS
 - [19:03:56] Processing: VID_00022 (8 of 14)
 - [19:03:56] Extracting A/V streams [VID_00022]
 - [19:04:00] Reencoding video [VID_00022]
   - Rate/Length: 24,000fps, 168 frames
   - Bitrate: 1.339 Kbs
 - [19:04:00] Reencoding: VID_00022, Pass 1 of 1
 - [19:04:10] Video Encode complete
 - [19:04:10] Processing audio tracks
 - [19:04:10] Multiplexing M2TS
 - [19:04:13] Processing: VID_00025 (9 of 14)
 - [19:04:13] Extracting A/V streams [VID_00025]
 - [19:04:17] Reencoding video [VID_00025]
   - Rate/Length: 24,000fps, 120 frames
   - Bitrate: 791 Kbs
 - [19:04:17] Reencoding: VID_00025, Pass 1 of 1
 - [19:04:25] Video Encode complete
 - [19:04:25] Processing audio tracks
 - [19:04:25] Multiplexing M2TS
 - [19:04:30] Processing: VID_00026 (10 of 14)
 - [19:04:30] Extracting A/V streams [VID_00026]
 - [19:04:33] Reencoding video [VID_00026]
   - Rate/Length: 24,000fps, 192 frames
   - Bitrate: 2.790 Kbs
 - [19:04:33] Reencoding: VID_00026, Pass 1 of 1
 - [19:04:45] Video Encode complete
 - [19:04:45] Processing audio tracks
 - [19:04:45] Multiplexing M2TS
 - [19:04:48] Processing: VID_00027 (11 of 14)
 - [19:04:48] Extracting A/V streams [VID_00027]
 - [19:04:52] Reencoding video [VID_00027]
   - Bitrate: 1.400 Kbs
 - [19:04:52] Reencoding: VID_00027, Pass 1 of 1
 - [19:05:03] Video Encode complete
 - [19:05:03] Processing audio tracks
 - [19:05:03] Multiplexing M2TS
 - [19:05:07] Processing: VID_00028 (12 of 14)
 - [19:05:07] Extracting A/V streams [VID_00028]
 - [19:05:10] Reencoding video [VID_00028]
   - Bitrate: 500 Kbs
 - [19:05:10] Reencoding: VID_00028, Pass 1 of 1
 - [19:05:18] Video Encode complete
 - [19:05:18] Processing audio tracks
 - [19:05:18] Multiplexing M2TS
 - [19:05:21] Processing: VID_00029 (13 of 14)
 - [19:05:21] Extracting A/V streams [VID_00029]
 - [19:05:26] Reencoding video [VID_00029]
   - Rate/Length: 24,000fps, 480 frames
   - Bitrate: 29.360 Kbs
 - [19:05:26] Reencoding: VID_00029, Pass 1 of 1
 - [19:06:12] Video Encode complete
 - [19:06:12] Processing audio tracks
 - [19:06:12] Multiplexing M2TS
 - [19:06:16] Processing: VID_00031 (14 of 14)
 - [19:06:16] Extracting A/V streams [VID_00031]
 - [19:06:20] Reencoding video [VID_00031]
   - Bitrate: 16.925 Kbs
 - [19:06:20] Reencoding: VID_00031, Pass 1 of 1
 - [19:06:32] Video Encode complete
 - [19:06:32] Processing audio tracks
 - [19:06:32] Multiplexing M2TS
[19:06:35]PHASE ONE complete
[19:06:35]PHASE TWO - Rebuild Started
 - [19:06:35] Rebuilding BD file Structure
[19:06:44] - Encode and Rebuild complete
[19:06:44] Writing BD structure to ISO file
 - ImgBurn completed successfully
 - COLD_PURSUIT folder removed.
 - WORKFILES folder removed.
[19:07:36] JOB: COLD_PURSUIT finished.
Old 12th January 2020, 13:23   #29134  |  Link
BD-Rebuilder is using the last TSMUXER... (current as of yesterday), so that isn't the problem. Too bad you deleted the work folder, I'd like to see a couple of the files to see what is up. Can you post your settings so I can look at those?
Old 12th January 2020, 16:32   #29135  |  Link
Michi
My bdrebuilder.ini:
[Options]
VERSION=0.61.0.3
MODE=0
ENCODER_MENU=1
ENCODE_QUALITY=5
ONEPASS_ENCODING=2
AUTO_QUALITY=0
AUDIO_TO_KEEP=deu;gem;ger;
SUBS_TO_KEEP=deu;gem;ger;gmh;goh;gsw;
SD_CONVERT=0
OPEN_GOP=1
RESIZE_1080=0
DEINTERLACE=0
SD_TO_1080=0
CONVERT_WIDE=0
DTS_REENCODE=0
AC3_REENCODE=0
AC3_640=0
AC3_192=0
KEEP_HD_AUDIO=1
AVCHD=0
REMOVE_WORKFILES=1
MOVIE_ONLY_LOOP=1
REMOVE_OUTPUT=1
USE_FILTERS=0
BDMV_CERT_ONLY=0
USE_LAVF=1
IVTC_PULLDOWN=0
ASSUME_DVD_PAL=0
UNMASK_CHAPTER=0
COMPLETION_BEEP=0
DGDECNV=0
AUDIO_TRACK_LIMIT=0
SUBTITLE_TRACK_LIMIT=0
CUSTOM_TARGET_SIZE=66000
TARGET_SIZE=47366
AUTO_BURN=2
MOVIEONLY_TYPE=40
ALTCRF=18
ARCHIVE_265=1
ARCHIVE_AUDIO=100
ARCHIVE_CRF=16
ARCHIVE_ENABLE=1
ARCHIVE_LIMIT=1
ALT_TARGET=7800
ALTMETHOD=0
ALTAUTOCROP=0
QUICK_EXTRAS=0
OUTPUT_3D=0
RESIZE_1440=0
RESIZE_720=0
NEROAAC=0
SUPTITLE=0
IGNORE_3D=0
OUTPUT_SBS=0
ENCODER_MENU=1
HC_PROFILE=BEST
IMPORT_HEVC_INTACT=1
MIN_M2TS_SIZE=20
NEW_CRF_PREDICTION=1
MULTIPROCESS=0
THREADS=auto
BD5_SIZE=4520
BD9_SIZE=8200
BD25_SIZE=23200
QUALITY_ULTRA=1
FRIMSOURCE=0
ENCODER=0
DGDECIM=1
FRIM_SW_DECODE=1
FRIM_SW_ENCODE=1
PRIORITY_CLASS=1
IMPORT_THRESHOLD=15
QUICK_PLAY_THRESHOLD=10
MENU_AUTO_BACKGROUND=1
MENU_PLAY_SEQUENTIAL=0
MENU_START_WITH_MENU=1
DECODER=0
AUDIO_DRC=0
MENU_AUTO_DVDAUDIO=1
IMPORT_LIMIT_LANG=0
IMPORT_KEEP_PLAYALL=0
ALT_CRF_TARGET=4000
PGSTOSRT=0
UHD_MAXRATE=60000
UHD_VBV_BUFFER=60000
TWEAK_X265=--no-open-gop --no-sao --no-slow-firstpass --no-rskip --subme 4 --weightb
[Paths]
SOURCE_PATH=Y:\
WORKING_PATH=Q:\4K\
Old 12th January 2020, 17:33   #29136  |  Link
thekiller
hello, i regularly meet with bdrebuilder problems with the automatically crop black bolders, on harry potter 5 instead of having 1920x800, i have 1516x796, how to fix the good value?
thank you
thekiller is offline   Reply With Quote
Old 12th January 2020, 22:50   #29137  |  Link
thank you
BD-RB should correct it on it's own when it reencodes.
Old 13th January 2020, 01:25   #29138  |  Link
LowDead
@jdobbs: Have you recently tried importing mkv's?
I just encountered an error just after the "Scanning for Variable Framerate" step. Something about missing number or filename. I went back to 0.60.29 and it worked again. I'll get you a log ASAP
//LD
EDIT:
Well There wasn't much in the log...
[01:49:08] Importing MKV: PURE_(2019)_S01E01_-_EPISODE_1
  - Preparing MKV for processing...
From the TEMPIMPORT folder:
General
Unique ID                                : 183007012736287462016813617846879401966 (0x89ADDE5BA9BE000BA56959A4B42A37EE)
Complete name                            : W:\WORK\TEMPIMPORT\Pure (2019) S01E01 - Episode 1.MKV
Format                                   : Matroska
Format version                           : Version 2
File size                                : 2.06 GiB
Duration                                 : 33 min 16 s
Overall bit rate                         : 8 846 kb/s
Encoded date                             : UTC 2020-01-13 00:49:08
Writing application                      : mkvmerge v9.7.1 ('Pandemonium') 32bit
Writing library                          : libebml v1.3.4 + libmatroska v1.4.5
Video
Format                                   : AVC
Format profile                           : Main@L4
Format settings                          : CABAC / 4 Ref Frames
Format settings, CABAC                   : Yes
Format settings, ReFrames                : 4 frames
Codec ID                                 : V_MPEG4/ISO/AVC
Bit rate                                 : 8 458 kb/s
Width                                    : 1 920 pixels
Height                                   : 1 080 pixels
Frame rate mode                          : Variable
Frame rate                               : 50.000 FPS
Original frame rate                      : 25.000 FPS
Scan type                                : Interlaced
Scan type, store method                  : Separated fields
Scan order                               : Top Field First
Bits/(Pixel*Frame)                       : 0.082
Stream size                              : 1.97 GiB (96%)
Color range                              : Limited
Color primaries                          : BT.709
Transfer characteristics                 : BT.709
Matrix coefficients                      : BT.709
Audio
Format                                   : AC-3
Format/Info                              : Audio Coding 3
Codec ID                                 : A_AC3
Bit rate                                 : 384 kb/s
Channel(s)                               : 6 channels
Channel positions                        : Front: L C R, Side: L R, LFE
Sampling rate                            : 48.0 kHz
Frame rate                               : 31.250 FPS (1536 SPF)
Bit depth                                : 16 bits
Stream size                              : 91.4 MiB (4%)
Service kind                             : Complete Main
LASTCMD only had some command from old encode.
INI:
[Options]
VERSION=0.61.0.3
ENCODER=0
MODE=0
ENCODE_QUALITY=3
ONEPASS_ENCODING=0
AUTO_QUALITY=0
AUDIO_TO_KEEP=deu;eng;ger;swe;
SUBS_TO_KEEP=all
SD_CONVERT=0
OPEN_GOP=1
RESIZE_1080=0
RESIZE_1440=0
RESIZE_720=0
DEINTERLACE=1
SD_TO_1080=0
IGNORE_3D=0
CONVERT_WIDE=0
DTS_REENCODE=0
AC3_REENCODE=0
AC3_640=1
AC3_192=0
KEEP_HD_AUDIO=1
AUDIO_DRC=0
DECODER=3
AVCHD=1
REMOVE_WORKFILES=0
REMOVE_OUTPUT=0
USE_FILTERS=0
BDMV_CERT_ONLY=0
IVTC_PULLDOWN=1
ASSUME_DVD_PAL=0
FRIMSOURCE=0
COMPLETION_BEEP=0
OUTPUT_SBS=0
NEROAAC=0
SUPTITLE=0
PGSTOSRT=0
AUDIO_TRACK_LIMIT=1
CUSTOM_TARGET_SIZE=8250
AUTO_BIAS=3
B_PYRAMID=1
DGDECIM_SW_DECODE=0
ENCODER_MENU=1
FRIM_SW_DECODE=0
FRIM_SW_ENCODE=0
HC_PROFILE=BEST
KEEP_MBTREE=1
PASS_TWO_STATS_UPDATE=1
SHOW_ENCODER=1
DTSX_ENABLE=1
ENABLE_TEST=1
ENABLE_BLANKING=1
DEFAULT_LANG=eng
TARGET_SIZE=8250
MIN_M2TS_SIZE=1
SYS:
[01-13-20] Checking System Settings
  - BD-Rebuilder v0.61.03
  - Working Path Free Space: 64,45GB
  - AVISYNTH Version: 2.6.0.5, Ok
  - LAVFILTERS:  Ok
  - X264:  Ok
  - X265:  Ok
  - AFTEN:  Ok
  - FAAC:  Ok
  - MP4BOX:  Ok
  - WAVI:  Ok
  - TSMUXER:  Ok
  - FRIMEncode:  Ok
  - FRIMDecode:  Ok
[01-13-20] Systems Settings Check complete
//LD
Old 13th January 2020, 14:26   #29139  |  Link
thekiller
Hello, thank you for your reply, I went to see the extracted x264 file, it has the right resolution, so there is a problem with the re-encoding because the output file is incorrect ??
Thank
Old 13th January 2020, 15:38   #29140  |  Link
Thank
Please post the contents of AVS file from the working folder and the PINFO.INF file from the PSEUDO folder (in the imported folder). That way I can see how BD-RB attempted to correct the sizing of the file.
