Old 13th April 2018, 18:06   #5261  |  Link
foxyshadis
ангел смерти
foxyshadis's Avatar
Premiere does it by reading the entire file start to finish and recording the seek points of each frame. That can take minutes before you can even start watching the movie, no one wants to put up with that just to get slightly faster seeking during a movie.
There are four boxes to be used in defense of liberty: soap, ballot, jury, and ammo. Please use in that order.
Old 13th April 2018, 21:29   #5262  |  Link
amayra
Quality Checker
amayra's Avatar
i think is about time to give assfiltermod another chance as experimental for advance user
I love Doom9
Old 13th April 2018, 22:17   #5263  |  Link
Aleksoid1978
Aleksoid1978's Avatar
No. It's don't support multiple pins.
I7 2600K@4.2 /Asrock P67 Extreme4 Gen 3 /Kingston HyperX 8Gb 1866 (4x2) Kit /OCZ Vertex 3 256Gb /Gigabyte GTX 960 /BenQ EW2430 /LG 47LM620T /Yamaha RX-V471 + NS-555 + NS-C444 + NS-333 + YST-SW215
Old 14th April 2018, 05:46   #5264  |  Link
v0lt
@amayra
In the MPC-BE code there is such a macro.
#define ENABLE_ASSFILTERMOD 0
Very advanced users can change it, rebuild MPC-BE and try this filter locally. But I immediately warn you, this is a bad idea. In the official builds this will not happen, of course.
Old 14th April 2018, 20:34   #5265  |  Link
Klaus1189
Do I still need DirectX 9.0c runtime for MPC-BE when I do a clean fresh install of Win 10 Pro?
Old 14th April 2018, 20:51   #5266  |  Link
v0lt
@Klaus1189
The player only needs d3dx9_43.dlll and d3dcompiler_47.dl, which are available in installers and archives.
Old 15th April 2018, 19:25   #5267  |  Link
Klaus1189
Thank you v0lt, I updated german translation based on r3531
I noticed that the checkboxes look much better now @200%, but the empty last line in formats list is still visible. Do you think it is fixable somehow?
Do you have plans for a new beta release and maybe also a stable release? I am just inquisitive, I use nightlies
Old 16th April 2018, 04:20   #5268  |  Link
v0lt
@Klaus1189
Thanks. Updated in r3533.
The empty space at 200% should decrease in r3534, but possibly increased at 150%.
Old 16th April 2018, 17:27   #5269  |  Link
Klaus1189
It looks better now at 100%, 150% and 200% (I tried these three). Thanks
Old 17th April 2018, 22:19   #5270  |  Link
tyrindor
Originally Posted by Aleksoid1978 View Post
tyrindor
Try this build - https://yadi.sk/d/CnPLkVxg3UMWj5
it's don't create log file. Just check for drops and A/V sync.
Seems to be working still.
tyrindor is offline   Reply With Quote
Old 17th April 2018, 23:14   #5271  |  Link
Aleksoid1978
I'm rewrite audio-renderer, you can use latest SVN version.
Old 18th April 2018, 07:32   #5272  |  Link
tyrindor
Do you have a link? The latest I am seeing is from 02/28.
https://sourceforge.net/projects/mpc...vn%20trunk%29/
Old 18th April 2018, 08:04   #5273  |  Link
Aleksoid1978
https://yadi.sk/d/hlf1lfC8mKU58/!_last
Old 18th April 2018, 11:32   #5274  |  Link
is a reclock like feature planned in your rewrite?
Old 18th April 2018, 12:47   #5275  |  Link
v0lt
Not planned.
Old 18th April 2018, 20:05   #5276  |  Link
JarrettH
I know it's supported, but is ace stream not functional? After I paste the acestream://dsfkjdsfkfs url, it tries to load and goes directly to "file not found."
Old 21st April 2018, 20:44   #5277  |  Link
mytbyte
Acestream works here but can anyone please advise why switching audio language (from rus to eng for example) while playing acestream links directly or from playlist, stops the playback or jumps to the next...how to circumvent this?...I hate to use VLC since deinterlacing (software) is choppy on my config, DXVA is smooth as silk always
EDIT: OK, false alarm, I reverted to internal splitter instead of LAV splitter and it works...as far as I can see...
mytbyte is offline   Reply With Quote
Old 23rd April 2018, 16:20   #5278  |  Link
Klaus1189
I beg to change a feature - Delay when Refresh rate change is done.
In MPC-HC 1.7.13.112 nightly, the first frame is already rendered but paused and after the delay is done, the playback starts.
In MPC-BE 1.5.2.3559 nightly the delay is runnig before the first frame is presented and causes some dropped frames in madVR.
This would help me to use this feature to get 0 dropped/repeated frames in madVR.
Probably it is "only" a change in source code of a place the delay code?
I searched for the commit of Alex Marsev back in 2013 who added it for me in MPC-HC
https://github.com/mpc-hc/mpc-hc/com...defae1c67b3c0d
Old 23rd April 2018, 16:30   #5279  |  Link
Klaus1189
I tried 1.7.2, which doesn't work like 1.7.13.112. I check the versions between these to see which commit(s) might be useful.
Old 23rd April 2018, 16:37   #5280  |  Link
Klaus1189
1.7.10 is not fine
1.7.11 is fine
now trying to find the nightly builds between those two.
