Old 15th May 2019, 00:14   #6261  |  Link
Aleksoid1978
Aleksoid1978's Avatar
Originally Posted by SirMaster View Post
Does anyone know if it's somehow possible to use the dual audio output in MPC-BE to send Atmos/DTS:X bitstream out one output and a simple stereo downmix or just the L+R channels as a 2 channel PCM or even 2 channel analog out the other output?
Dual audio output possible only the same type - or Bitstream or PCM.
I7 2600K@4.2 /Asrock P67 Extreme4 Gen 3 /Kingston HyperX 8Gb 1866 (4x2) Kit /OCZ Vertex 3 256Gb /Gigabyte GTX 960 /BenQ EW2430 /LG 47LM620T /Yamaha RX-V471 + NS-555 + NS-C444 + NS-333 + YST-SW215
Aleksoid1978 is online now   Reply With Quote
Old 15th May 2019, 00:14   #6262  |  Link
Aleksoid1978
Originally Posted by jespermart View Post
Would it be possible to add support for BD Menu to Mpc-Be just like River are capeble of using libbluray??
If somebody implement it - possible
Old 16th May 2019, 13:11   #6263  |  Link
Grimsdyke
@devs. Since the volume is so low on my system's DirectSound-HDMI I recently switched to MPC audio renderer and the difference is really huge but unfortunately there are also now drop outs, especially on 4K files.
I am not sure if this is related to the recent fixes you applied based on peter0815x reports or maybe tuesday's Windows patches creates problems but this did not occured until Sunday !!
Old 16th May 2019, 13:18   #6264  |  Link
stax76
I've heard this drop out issue in mpc too in following clip:
http://tvdl.zdf.de/none/zdf/diverse/...k_p1112v12.mp4
Old 16th May 2019, 13:22   #6265  |  Link
Aleksoid1978
Test on old version
Old 16th May 2019, 13:26   #6266  |  Link
Aleksoid1978
If somebody have audio drop on latest SVN but don't have on oldest version - upload problem files. Also show timing where is drop.
Old 16th May 2019, 18:14   #6267  |  Link
peter0815x
i tested the file with svn (4545) and wasapi output.
plays without problems for me.
(interesting video)
peter0815x is offline   Reply With Quote
Old 16th May 2019, 18:48   #6268  |  Link
stax76
I get the first drop out at 00:00:07
Using default settings, so 'DirectSound System Default' audio renderer.
mpc version/built is 1.5.3 (build 4488)
My primary player is of course mpv...
Old 16th May 2019, 18:56   #6269  |  Link
stax76
same issue with b4545
Old 17th May 2019, 01:19   #6270  |  Link
Aleksoid1978
Test in MPC-HC ?
Old 17th May 2019, 01:40   #6271  |  Link
stax76
I tested 4488 and 4545 and both have dropouts, mpc-hc had the first dropout at 01:00
Old 17th May 2019, 02:04   #6272  |  Link
Aleksoid1978
stax76
I test with DS and WASAPI output - there is no drops. See CPU/GPU load when drops is happened.
Old 17th May 2019, 12:34   #6273  |  Link
Grimsdyke
I randomly picked 4540 and with this version the problem was even worse - dozens of drop outs/glitches per minute !! So something must have happened with Tuesday's patches. Something was changed that my setup can't handle
properly or maybe even broken.
The only way to at least bypass this issue (for now) that I found is to deactivate 'dual-audio-out' and use the switch within mpc audio renderer to use the analogue-outs when I need them.
Old 18th May 2019, 04:05   #6274  |  Link
Megalith
Is there a way to get ASIO output in MPC-BE?
Megalith is offline   Reply With Quote
Old 18th May 2019, 05:45   #6275  |  Link
peter0815x
here is a asio plugin
http://blog.familie-buchberger.at/20...asio-renderer/
(for videos mpc render with wasapi is the better choice)
Old 18th May 2019, 23:30   #6276  |  Link
Megalith
Thanks, it seems to be working well. But why is WASAPI the "better choice"?
Old 19th May 2019, 01:26   #6277  |  Link
The only reason to ever use ASIO is if your audio device supports nothing else properly (like some "pro" audio devices do), or has actual broken support for WASAPI. Ultimately bitexact audio is bitexact audio, and the API used doesn't make a huge difference.
There is a few other reasons, but none that apply to video playback.
Even more so, there is no reason to force usage of ASIO if the player has no first-class ASIO support in the first place, you just know its going to be worse then.
Old 19th May 2019, 02:22   #6278  |  Link
peter0815x
with the asio plugin you can get strange noises when you seek a video or when you go from dvd menu to the movie.
seems the asio plugin is playing some noises when the audio stream is interrupted.
may be a bug in asio plugin (or unoptimized plugin)
Old 20th May 2019, 16:25   #6279  |  Link
Manni
MPC-BE is giving me problems recently, I don't know if it's due to a recent windows update (I'm on Windows 10 Pro x64 build 1809).
It often hangs or exists when I start playing a UHD BD Folder.
When I play the same title with MPC-HC (I re-installed it to debug), I have no problem.
I tried to completely uninstall MPC-BE, delete the folder and registry and use all default settings (no madVR, nothing, just default internal filters), the issues are still there.
It seems to be worse when MyMovies calls MPC-BE from MCE, but I have issues even when I play the title standalone.
Some titles don't play or only play for a few seconds (The Meg). Other play fine.
Really weird. I never experienced anything like that. I tried to revert to earlier versions, same issues.
I tried different drivers for my 1080ti, 385.28 which usually works fine with everything up to the latest 430.64, still have issues.
Anyone has any idea?
I know that not everyone experiences this, but I've never had a situation like this before.
MPC-BE has always worked flawlessly on my rig, and it's been my player of choice for years.
Win10 Pro x64 b1909 MCE
i7 3770K@4.0Ghz 16Gb@2.18Ghz EVGA GTX 1080 Ti SC2 11Gb@2GHz 442.74 RGB Full 8bits
MPC-BE/LAV/MadVR/jRiver/MyMovies V5.25/CMC V3.2
Denon X8500H>HD Fury Maestro>JVC RS2000
Old 20th May 2019, 17:03   #6280  |  Link
chros
chros's Avatar
What does this mean exactly? How do you start it? Via File -> Open?
And which MPC-BE version? Latest stable?
Ryzen 5 2600,Asus Prime b450-Plus,16GB,MSI GTX 1060 Gaming X 6GB(v385.28),Win10 LTSB 1607,MPC-BEx64+LAV+MadVR,Yamaha RX-A870,LG OLED65B8(2160p@23/24/25/29/30/50/59/60Hz)
