Old 17th January 2020, 18:14   #7061  |  Link
Klaus1189
I found some inconsistencies according the tooltips of the language dll files in Windows explorer:
For example *eu* has still Media Player Classic - Home Cinema in it:
https://drive.google.com/file/d/1wFm...ew?usp=sharing
And some tooltips are not written in english, these are in their according language. I think it would look much better to use only english or each language.
Old 17th January 2020, 19:37   #7062  |  Link
v0lt
@Klaus1189
Thanks. I fixed it in r5013. These fields are not translated and will only be in English.
Old 19th January 2020, 05:26   #7063  |  Link
Anima123
There's a flicher when the first subtitle appears, using XySubFilter with MPC Video Renderer, and in DX11 mode, would it indicate a possible bug?
No flicker with DX9 mode.
Anima123 is offline   Reply With Quote
Old 19th January 2020, 18:25   #7064  |  Link
Klaus1189
Thank you v0lt
Old 19th January 2020, 21:46   #7065  |  Link
fried chicken
Hi. I joined some old xvid avi's and wound up re-encoding the file to hevc stored in mkv using VideoReDo. I tried to play the file with MPC-BE 1.5.4 portable and nothing happens. MPC-BE starts, sits for a couple seconds and then closes. The video never starts. I couldn't find anywhere to turn on a logfile so I have no further details. I found MPC-HC has been updated by Clsid so I tried that (MPC-HC 1.9.0) and it plays fine. I also tested the file in Kodi and it plays there as well. Out of curiosity I remuxed with mkvmerge and then MPC-BE played it fine. So, it seems that MPC-BE might have a bug in its mkv parser?
fried chicken is offline   Reply With Quote
Old 19th January 2020, 22:00   #7066  |  Link
Aleksoid1978
Aleksoid1978's Avatar
Upload short file for test.
I7 2600K@4.2 /Asrock P67 Extreme4 Gen 3 /Kingston HyperX 8Gb 1866 (4x2) Kit /OCZ Vertex 3 256Gb /Gigabyte GTX 960 /BenQ EW2430 /LG 47LM620T /Yamaha RX-V471 + NS-555 + NS-C444 + NS-333 + YST-SW215
Old 19th January 2020, 22:30   #7067  |  Link
fried chicken
Here's a 5MB sample I cut: https://mega.nz/#!Lr5iESKb!2drZDvChg...yG-aix4gkIClZM
Old 20th January 2020, 00:45   #7068  |  Link
Aleksoid1978
Thanks - fixed.
Old 20th January 2020, 02:13   #7069  |  Link
fried chicken
Thanks for such a fast fix Aleksoid1978! What was the problem?
Old 20th January 2020, 05:17   #7070  |  Link
R5022 - Fixed crash when opening files with HEVC tracks and an empty CodecPrivate block.
Old 20th January 2020, 14:15   #7071  |  Link
v0lt
Yes it is possible. But we do not know which versions of the components you are using.
In any case, I can advise you to change the "Swap effect" setting. If that doesn't work, then just use DX9 mode.
Old 21st January 2020, 00:47   #7072  |  Link
juanrugge
hi. so i have this problem back on MPC-HD (with madVR and lavfilters) where whenever i change subtitles or audio, i lost audio and video gets choppy (lower frame rate and frames missing).
after using MPC-BE with madVR and lavfilters, everything work fine for like 2 weeks, and then the same problem happen, didnt update anything. now way to recover from this, only restart player.
load ext subtitles works. i mostly play mkv files, and its the included audio and subs in the container that i cant change.
can someone please guide me as to what could be causing this? if you need any info just ask me. thanks.
juanrugge is offline   Reply With Quote
Old 24th January 2020, 06:56   #7073  |  Link
Aleksoid, Volt, would you consider an option to allow a small rewind in seconds after resuming when paused?
My Yamaha receiver takes a second for the audio to re-engage so I have to skip back a step each time I unpause so I don't miss audio.
A user defined setting of 1-3 seconds or so could be useful, anyone else in a similar situation or also like this idea?
Old 24th January 2020, 07:56   #7074  |  Link
Aleksoid1978
Use MPC Audio Renderer using Exclusive mode and release when idle ?
Old 25th January 2020, 07:12   #7075  |  Link
Yes, I've unticked release when idle now and it's better thanks. I would still make use of this feature if it was available though as there's still a small delay.
Old 25th January 2020, 21:21   #7076  |  Link
cmhrky
https://www.youtube.com/watch?v=FzI-KE_1Ayo
This video only opens 360p in r5046.
cmhrky is offline   Reply With Quote
Old 26th January 2020, 01:55   #7077  |  Link
Aleksoid1978
Other formats - fragments based and can't playback(only download).
Old 26th January 2020, 21:12   #7078  |  Link
Klaus1189
I tested latest MPCVideoRenderer-v0.4.0.1114_git2020.01.26-f040872 Nightly and if I enable D3D11 with MPC-BE and external LAV Filters I get a solid green video view. D3D9 is fine.
Going back to latest stable MPCVideoRenderer-v0.3.8.1060 solves the issue. I use Windows 10 Pro 64 bit with MPC-BE 1.5.5.5046 and latest LAVFilters-0.74.1-31 and AMD 20.1.3 driver for 5700XT.
Old 26th January 2020, 23:36   #7079  |  Link
Aleksoid1978
Show screenshot with statistics(Ctrl+J)
Old 26th January 2020, 23:44   #7080  |  Link
Klaus1189
https://drive.google.com/file/d/1CVx...ew?usp=sharing
I did some more tests, if I use DXVA2 it works, but if I use software decoding the issue appears. Same for internal filters of MPC-BE.
