Old 25th February 2020, 02:18   #7221  |  Link
stax76
Perfect playback. Test in MPC-BE using EVR-CP/MPC-VR(DX9) + internal filter(DXVA2 Native), MPC-VR DX11 + LAV DX11 Native.
Tried all that, nothing works.
https://postimg.cc/G9hzy0fN
edit:
Please also show screenshot.
Old 25th February 2020, 02:24   #7222  |  Link
Aleksoid1978
Aleksoid1978's Avatar
edit:
Something wrong at you system. Monitor GPU load/memory using GPU-Z or TaskManager in Windows 10.
I7 2600K@4.2 /Asrock P67 Extreme4 Gen 3 /Kingston HyperX 8Gb 1866 (4x2) Kit /OCZ Vertex 3 256Gb /Gigabyte GTX 960 /BenQ EW2430 /LG 47LM620T /Yamaha RX-V471 + NS-555 + NS-C444 + NS-333 + YST-SW215
Old 25th February 2020, 02:39   #7223  |  Link
stax76
https://postimg.cc/YhB6zJDM
edit:
Why do the stats have tiny font? Please post screenshot.
Old 25th February 2020, 02:52   #7224  |  Link
did you try changing the nvidia power setting to adaptive?
it doesn't look like it but is this a laptop with an intel iGPU so maybe even optimus?
Old 25th February 2020, 03:00   #7225  |  Link
stax76
Where do I find this?
It's a 6 core desktop system.
HP Pavilion 590-p0599ng Desktop PC i5-8400 8GB 256GB SSD Silver
Old 25th February 2020, 03:08   #7226  |  Link
manage 3D settings -> power management mode
Old 25th February 2020, 22:57   #7227  |  Link
stax76
I was able to find out that in mpv it works if there is no color/transfer metadata in files.
mpc don't work with or without such metadata.
https://postimg.cc/qgG3QPQ8
https://github.com/mpv-player/mpv/issues/7478
Old 26th February 2020, 00:08   #7228  |  Link
Aleksoid1978
Very high GPU/Video decode load.
I repeat - 1030 is good for 4K 10-bit 60fps playback.
https://i.imgur.com/cbTxlfL.png
Old 26th February 2020, 06:16   #7229  |  Link
stax76
Video decode is indeed much higher.
Old 26th February 2020, 06:26   #7230  |  Link
your problem should be the hdr->SDR conversation which your card simply can't do that would explain why it works without meta data because there is no conversation without meta data.
the next part that doesn't make sense is the high video engine load it doesn't matter if the video can be shown or not the video engine shouldn't care but your load is still high.
Old 26th February 2020, 12:18   #7231  |  Link
aufkrawall
It should be no issue for a 1030 with mpv if peak detection is turned off and bilinear scaling is used since I had smooth playback of streamed 4k 60fps VP9 HDR on Gemini Lake and Linux. Not on Windows though, but a 1030 is much more "powerful" anyway.
Old 26th February 2020, 15:44   #7232  |  Link
stax76
Maybe there is problem with my card (MSI GeForce GT 1030 2GHD4 LP OC 2GB GDDR) or my PC (HP Pavilion 590-p0599ng Desktop PC i5-8400 8GB 256GB SSD). I've updated the NVIDIA driver, might I need a driver or new bios for the motherboard?
Kodi can play my file fluently however, including color manipulation but that color manipulation is broken, I can file a bug report.
Or I could ignore the issue since I rarely have such video files or buy a new PC or start rendering development.
My scaling setting is bilinear, I tried hdr-compute-peak=no and dropped frames went down from 550 to 220 so some improvement, any further ideas? Maybe try the Intel IGP?
Old 26th February 2020, 15:46   #7233  |  Link
v0lt
@stax76
Which GT 1030 graphics card are we talking about?
What kind of memory is GDDR5 or SDDR4?
https://www.geforce.com/hardware/des...specifications
GDDR5 - 48 GB/sec
SDDR4 - 16.8 GB/sec
Old 26th February 2020, 15:50   #7234  |  Link
stax76
Apparently I found the solution.
hdr-compute-peak = no
d3d11va-zero-copy = yes
Zero dropped frames!
mpc still unusable
Old 4th March 2020, 12:46   #7235  |  Link
s0meone_new
Hello!
Hungarian translation update! (little fix in it)
https://www109.zippyshare.com/v/oyl1jNZe/file.html
s0meone_new is offline   Reply With Quote
Old 4th March 2020, 14:04   #7236  |  Link
v0lt
@s0meone_new
Thanks. Updated in r5110.
Old 5th March 2020, 02:57   #7237  |  Link
s0meone_new
Ok thank, update again. (just a small fix)
https://www40.zippyshare.com/v/cfY68dJz/file.html
Completed.
Old 5th March 2020, 18:48   #7238  |  Link
v0lt
@s0meone_new
Thanks. Updated in r5112.
Old 6th March 2020, 12:36   #7239  |  Link
hajj_3
dav1d v0.6.0 decoder is out now, hope that this can be added to a new build of mpc-be.
Old 7th March 2020, 11:14   #7240  |  Link
koupa
Is there a possibility to add multi site support for subs like mpc-hc?
Sent from my MI MAX 3 using Tapatalk
koupa is offline   Reply With Quote
