Old 11th April 2013, 15:26   #21  |  Link
LaTo
LaTo INV.
LaTo's Avatar
AutoGain beta7
Update Here: AutoGain-beta7
I consider the core robust and stable now, so for next release I will only fix bugs reported by users and some little things.
LaTo is offline   Reply With Quote
Old 12th April 2013, 14:37   #22  |  Link
Reel.Deel
Hi LaTo, I was wondering if you changed the defaults after Beta5 or something internally? By looking at the readme's I see that the defaults are still the same. But, beta5 compared to 6 and 7 behave differently.
Here's the comparison, I used all defaults and for beta 6 and 7 I used chroma_process=0. I like beta5 better.
Also, do you think it would be worthwhile to have U=xx, V=xx parameters instead of chroma_process=xx? I've come across footage where one of the chroma channels seems to be more "saturated" than the other.
Maybe independent parameters can aid those types of situations.
One last thing, AutoGain works fine with 8bit YV16/24 and with 16bit YV12 but with 16bit YV16/24 I get some weird artifacts which seems to only affect the MSB/top half. Here's an example after dithering to 8bit.
Kudos on the debug view. It looks very good!
Thanks again for all your awesome work!
Reel.Deel is offline   Reply With Quote
Old 12th April 2013, 20:50   #23  |  Link
LaTo
LaTo INV.
LaTo's Avatar
I made a mistake with dark_exclude/bright_exclude, default should be "0.5" and not "0.05"... I will change it in next version, for now use "dark_exclude=0.5,bright_exclude=0.5".
And for 16bits / YV24, this seems a chroma bug (maybe I forgot a shift somewhere... )
Old 14th April 2013, 09:52   #24  |  Link
steptoe
steptoe's Avatar
If I click that link, or any other to try and download autogain beta's I just get the '404 error' and had done in the past
Ignore that, must have been in the process of updating it while I was typing this. Just tried searching for another link came back to this one, beta 8 was available like 2 minutes later
steptoe is offline   Reply With Quote
Old 14th April 2013, 09:53   #25  |  Link
LaTo
LaTo INV.
LaTo's Avatar
AutoGain beta8
Update: AutoGain-beta8
Old 14th April 2013, 09:54   #26  |  Link
LaTo
LaTo INV.
LaTo's Avatar
Yeah, I was updating
Old 14th April 2013, 16:37   #27  |  Link
ganymede
Your plugins makes wonders on dark scenes with footage from my Canon DSLR. Thank you very much LaTo !
ganymede is offline   Reply With Quote
Old 15th April 2013, 12:33   #28  |  Link
PDyksma
LaTo:
Just want to say THANK YOU!
This is the first "autolevel" filter that works for me.
I had some difficult laser-scanned super8's which had varying levels and never succeeded in getting them right.
With your Autogain plugin the result is just amazingly good!
Thanks again!
PDyksma is offline   Reply With Quote
Old 15th April 2013, 14:27   #29  |  Link
Motenai Yoda
Motenai Yoda's Avatar
just a question, how dark_exclude/bright_exclude works?
by percentile of excluded pixel or percentile of dynamic range?
also can be added a parameter that control how heavy and light correctons weighs?
ie if i want that light corrections remains unthouched, and lighting heavy corrections, or viceversa, lighting light corrections and leave heavy corrections unthouched.
I think to an "S" function that, for positive values relieve light corrections and, for negative values relieve heavy corrections (or increase lights ones).
powered by Google Translator
Motenai Yoda is offline   Reply With Quote
Old 16th April 2013, 12:08   #30  |  Link
LaTo
LaTo INV.
LaTo's Avatar
By percentile of excluded pixel
You can do that in an avisynth script with lut/mask/merge, but for general purpose I don't see the point to remove small corrections and leave big corrections untouched.
A sort of color vibrance's effect but on luminance?
Old 17th April 2013, 09:39   #31  |  Link
LaTo
LaTo INV.
LaTo's Avatar
AutoGain beta9
Update: AutoGain-beta9
Old 17th April 2013, 18:53   #32  |  Link
Motenai Yoda
maybe I did not explain well,
I mean correction by frame, not by pixel.
I notice you have added some limits, in a similar way, when gain of contrast is huge, or small, for some stuff, like night scenes or dark/light scenes (ie a corrected night scene maybe will look like a day scene), may don't require a heavy correction, so in other stuff can be preferable don't touch so much good scenes.
Old 18th April 2013, 10:01   #33  |  Link
Dogway
I get different results with high_bitdepth =true and without.
temporal_radius = -1 crashes on me
How to limit change to 235? is it a guesswork with bright_limit?
Old 18th April 2013, 10:32   #34  |  Link
LaTo
LaTo INV.
LaTo's Avatar
Or maybe I am tired, or maybe the italian->english->french translation is failing
Sorry but I still do not understand what you want more than dark/bright/gamma_limit... These will limit changes on low contrast scene (like night scene).
Please explain a bit more
Yes very small variations are possible, but that is just +/- 1-2 pixels differences.
Do you experience more changes?
No crash on my side...
But, with all due respect, you have 835 posts on doom9.org and your crash report is sooo small... Really, I can not do anything with that.
So as with the newbies:
- precise error message
- crash at startup or later or at the end
- avisynth version
- entire script used
- properties of the video
- a sample if possible
You can not because of the averaging system, you will always have values ​​above or below 16/235.
Add Limiter() after AutoGain if you do not want these.
Old 18th April 2013, 12:22   #35  |  Link
Dogway
I'm using Avisynth 2.6a3 MT.
It's more than 2 values, have a look.
Now I have 836 posts...
After giving it an unusual 10 seconds of settling it seems to be working... it seems..., can report further if you are not so annoyed.
Limiter() despite the name doesn't limit range, it actually kills it. So from your indirect take of the answer all I can read is "yes sir, guesswork". Thanks
Last edited by Dogway; 19th April 2013 at 07:59. Reason: There's no such as v2.6a4, MT is only for a3
Old 18th April 2013, 14:19   #36  |  Link
LaTo
LaTo INV.
LaTo's Avatar
I'm using Avisynth 2.6a4 MT.
Honestly there was no animosity from me in my answer, all reports are welcome... But how could I find a bug with so little information.
With all the time spent on the forum, you should be somewhat familiar with bug report.
Anyway, in the end you still do not give me all the information requested...
And for Limiter(), yes there is no solution unless you want to use "AutoGain(dark_exclude=0,bright_exclude=0,temporal_radius=0)" which is nearly as stupid as "ColorYUV(autogain=true)".
So the answer was the correct one, it's not my fault if you not like it...
Thank you anyway, there is effectively a bug with gamma processing in 16 bits... Just need to spot it.
Old 19th April 2013, 01:38   #37  |  Link
Dogway
with bright_limit as default, I went to the brightiest spot (many values compressed at 255) and lowered parameter up to 1.1 where (most) range was within 16-235.
I still don't know exactly how the filter works, but if there's no way to estimate lost range it's as useful as overdenoising. You are "gaining" partly, there's a range you are actually losing.
Old 19th April 2013, 19:12   #38  |  Link
LaTo
LaTo INV.
LaTo's Avatar
As I already said previously:
Set "dark_exclude=0, bright_exclude=0", to eliminate 99% of your problem.
But this will have some outside range values, use "temporal_radius=0" if you want but it will be jerky.
And I still do not have screenshot or sample or script or ..., so I talk without seeing anything...
Old 20th April 2013, 13:40   #39  |  Link
LaTo
LaTo INV.
LaTo's Avatar
Update 2013/04/20
v1.00:
first stable version
Finally
Old 20th April 2013, 14:38   #40  |  Link
Reel.Deel
Hi LaTo, congratulations on your advancement.
One odd thing though, the 2.6 version worked since beta8 but it does not with v1.00. I tried both MSVC and ICL, x86 only and the same error.
VirtualDub Error
Avisynth open failure:
Avisynth: access violation at 0x00000000 in C:\Documents and Settings\VirtualDub\VirtualDub.exe,
attempting to read from 0x00000000
(C:\AutoGain\Test.avs, line 6)
Here's the script:
LoadPlugin("AutoGain.dll")
# NTSC DVD Source
DGSource("X:\test.dgi")
AutoGain()
I'm using SEt's 2.6.0.3 MT 2012.05.16. I have not tried it with the official or MT 2.6.0.4. Unfortunately I have to go to work right now . When I get some time I will try it out and report back.
