3rd May 2020, 07:45 | #2141 | Link | |
https://bugs.chromium.org/p/aomedia/...detail?id=2545 |
3rd May 2020, 12:57 | #2142 | Link | |
3rd May 2020, 15:20 | #2143 | Link |
AVIF (AV1 Image File Format): experimental support
https://bugzilla.mozilla.org/show_bug.cgi?id=1625363 Firefox 77.0a1 (2020-05-03) https://i.imgur.com/uonsh58.png https://i.imgur.com/5awSd0t.png |
4th May 2020, 13:54 | #2145 | Link | |
Yes.
5th May 2020, 01:34 | #2147 | Link |
Can I get FFmpeg with all AV1 encoders?
It seems like media autobuilds is something like that, but it also looks like a worthless POS. Spams me with a hundred questions (with stuff I don't care for maybe don't even know what they are) only to fail at the first step of trying to do anything. What I mainly want is ffmpeg with all AV1, HEVC encoders. (and maybe other non-free good codecs) Last edited by mzso; 5th May 2020 at 01:49. |
5th May 2020, 03:46 | #2148 | Link | |
5th May 2020, 07:59 | #2149 | Link |
MABS allows you to configure the set of linked codec libraries with a file build/ffmpeg_options.txt where all known supported options are listed, grouped and partially disabled due to known issues or your choice to disable codecs during your configuration of MABS as a whole (stored in build/media-autobuild_suite.ini).
5th May 2020, 10:11 | #2150 | Link | |
- Download and install msys2 basic system ------------------------------------------------------------------------------- ------------------------------------------------------------------------------- - Downloading and unpacking msys2 basic system ------------------------------------------------------------------------------- The Win32 internal error "Egy rendszerhez csatlakoztatott eszköz nem működik" 0x1F occurred while writing to the console output buffer at the current cursor position. Contact Microsoft Customer Support Services. '7za' is not recognized as an internal or external command, operable program or batch file. At the very fist step it actually tries to do something, after wasting me a quarter hour asking questions for nothing. |
5th May 2020, 23:03 | #2152 | Link | |
6th May 2020, 16:25 | #2154 | Link |
Then that might be the problem. Nowadays Powershell blocks scripts by default. And the bat file calls a .ps1 script.
You can test it by calling Code:
Get-ExecutionPolicy If it says restricted you have to change it. You have to open a Powershell window as Administrator and set the policy to unrestricted with Code:
Set-ExecutionPolicy Unrestricted You can set the setting back to restricted in an admin shell by Code:
Set-ExecutionPolicy Restricted PS: If you only build for yourself you can try replacing "-mtune=generic" with "-march=native" in media-autobuild_suite.bat to optimize for your CPU. |
10th May 2020, 23:46 | #2157 | Link | |
If you don't want to compile your self ffmpeg and all you have already here a docker image with that: https://hub.docker.com/r/singhkays/ffmpeg-av1-libaom (updated every day)
11th May 2020, 14:37 | #2158 | Link | |
PS E:\autobuild\media-autobuild_suite-master_2020-05-02> .\media-autobuild_suite.bat ------------------------------------------------------------------------------- - Download and install msys2 basic system ------------------------------------------------------------------------------- ------------------------------------------------------------------------------- - Downloading and unpacking msys2 basic system ------------------------------------------------------------------------------- The Win32 internal error "Egy rendszerhez csatlakoztatott eszköz nem működik" 0x1F occurred while writing to the cons ole output buffer at the current cursor position. Contact Microsoft Customer Support Services. '7za' is not recognized as an internal or external command, operable program or batch file. PS E:\autobuild\media-autobuild_suite-master_2020-05-02> |
13th May 2020, 16:22 | #2160 | Link | |
If that does not help just open a github issue with the required log files. They help pretty fast. |
