Old 28th March 2020, 22:12   #1581  |  Link
Atlantis
Mzvasturbo, could you please give a step by step detail how to encode a HDR10+ file?
Atlantis is offline   Reply With Quote
Old 29th March 2020, 04:21   #1582  |  Link
Atlantis
Ok here is my unscientific speed tests. Same 4K HDR file. The first one is the x265 provided by staxrip 2.0.8.0
x265 3.3+2-gbe2d82093 GCC 9.2.0
2.40 fps
x265 3.3+10-g08d895bb6-gcc9.3.0
2.45 fps
x265 3.3+10-g08d895bb6-msvc-vs2019
2.34 fps
x265 M-3.3+10-g08d895bb6-gcc9.3.0
2.51 fps
x265 M-3.3+10-g08d895bb6-msvc-vs2019
2.30 fps
So gcc seems faster than msvc.
Old 29th March 2020, 09:37   #1583  |  Link
pintcat
Tried the latest StaxRip 2.0.8.0 and it doesn't recognize Visual C++ 2019. Runtimes are installed (both 32 & 64bit) and msvcp140.dll is in place. Still complaining. System is Windows 7 64bit.
pintcat is offline   Reply With Quote
Old 29th March 2020, 12:24   #1584  |  Link
Mzvasturbo
If you actualy have a mkv remux of video with HDR10+ metadata you must parse it with
HDR10+ parser https://github.com/quietvoid/hdr10plus_parser/releases
You can do it with ffmpeg https://video.stackexchange.com/ques...peg-in-windows
Command in cmd looks like this
ffmpeg -i "C:\video rip\Test.mkv" -c:v copy -vbsf hevc_mp4toannexb -f hevc - | "C:\hdr10plus_parser\hdr10plus_parser.exe" - -o "C:\video rip\Test.json"
ffmpeg -i "This is your video file path and name" -c:v copy -vbsf hevc_mp4toannexb -f hevc - | "this is your parser .exe location and name" - -o "This is your output file location and name"
Now next step is very simple.
I hope this helps. If you did all things correct you could see with https://mediaarea.net/en/MediaInfo something like this HDR format : SMPTE ST 2094 App 4, Version 1, HDR10+ Profile B compatible
Mzvasturbo is offline   Reply With Quote
Old 29th March 2020, 12:27   #1585  |  Link
stax76
@pintcat
You can try clicking the Version button and if that don't help you can try editing the versions.txt file in the apps folder, either edit the date of visual c or remove that line completely. You can try the same things with the latest beta, the current VC version I have is 14.25.28508.3 from 2020-01-08, it was necessary to block old VC versions because avisynth failed to load using an old version.
stax76 is online now   Reply With Quote
Old 29th March 2020, 14:08   #1586  |  Link
stax76
I've uploaded a new beta that addressed recent feedback and tool updates but has also a new feature.
### 2.1.0.2 Beta
- new: the MediaInfo folder view was replaced with a new powershell based
       dialog that supports caching for fast startup performance
- fix: install instructions for wrong versions in the Apps dialog were improved
- fix: UNC path issue fix (AMED)
- fix: x265 --hdr-opt renamed to --hdr10-opt
- update: x265 3.3+10-g08d895bb6-gcc9.3.0 Patman
- update: Python 3.8.2
- update: VapourSynth R49
- update: VC++ 2019 14.25.28508.3
https://staxrip.readthedocs.io/intro.html#download
Old 29th March 2020, 14:21   #1587  |  Link
Taurus
Taurus's Avatar
@Mzvasturbo
The picture in your post above is not showing....
Old 29th March 2020, 17:14   #1588  |  Link
Atlantis
Question about HDR10+. Is the metadata only that json file you mentioned? I thought it's a second video stream. There are video with a second video stream. What is that?
Old 29th March 2020, 17:48   #1589  |  Link
JKyle
HDR10+ is one of the HDR standards proposed by Samsung and Amazon and maintained by the HDR10+ Alliance. Although it's not as common as HDR10 (another de-facto standard of HDR), it's royalty-free. On the other hand, another HDR standard Dolby Vision charges businesses.
AFAIK, @Mzvasturbo has shown how to extract the SMPTE ST 2094-40 dynamic metadata embedded in an HDR10+ video file.
You can refer to this Wikipedia document about the detail on HDR and HDR standards.
JKyle is offline   Reply With Quote
Old 29th March 2020, 17:57   #1590  |  Link
Mzvasturbo
I can see it just fine in any browser ok here is the link
http://shrani.najdi.si/?J/7W/43pblryA/hdr10.jpg
Old 29th March 2020, 18:24   #1591  |  Link
Taurus
Taurus's Avatar
Thank you, maybe my security settings blocked the webhoster.
Old 29th March 2020, 21:17   #1592  |  Link
JKyle
A Simple HDR10 Re-encoding Speed Test with Different x265 Builds by Patman
■ System Environment
StaxRip : 2.1.0.2
Windows : Windows 10 Home 2004
CPU : Intel(R) Core(TM) i5-7300HQ CPU @ 2.50GHz
■ Source video
LG: New York HDR
■ Remuxing of the original ts to mkv
ffmpeg -hide_banner -analyzeduration 100M -probesize 50M -i "LG New York HDR UHD 4K Demo.ts" -map 0 -c copy -bsf:a aac_adtstoasc -y "LG New York HDR UHD 4K Demo.mkv"
■ Resize
Spline64Resize (avs): 4K to FHD
■ Video encoding command line (avs2pipe, x265)
D:\Utilities\StaxRip\Apps\Support\avs2pipemod\avs2pipemod64.exe -y4mp "D:\Work\tmp\LG New York HDR UHD 4K Demo_temp\LG New York HDR UHD 4K Demo.avs" | D:\Utilities\StaxRip\Apps\Encoders\x265\x265.exe --crf 27 --output-depth 10 --aq-mode 3 --qg-size 8 --aq-strength 2 --me star --bframes 3 --rc-lookahead 30 --ref 5 --master-display "G(13250,34500)B(7500,3000)R(34000,16000)WP(15635,16450)L(12000000,500)" --colorprim bt2020 --colormatrix bt2020nc --transfer smpte2084 --repeat-headers --hrd --aud --psy-rd 3 --frames 1806 --y4m --output "D:\Work\tmp\LG New York HDR UHD 4K Demo_temp\LG New York HDR UHD 4K Demo_out.hevc" -
■ Result (from slowest to fastest)
x265M-3.3+10-g08d895bb6-gcc9.3.0
7.61 fps (237.29s)
x265M-3.3+10-g08d895bb6-msvc-vs2019
7.77 fps (232.41s)
x265M-3.3+10-g08d895bb6-gcc10.0.1
7.97 fps (226.74s)
x265-3.3+10-g08d895bb6-gcc10.0.1
8.02 fps (225.10s)
Old 29th March 2020, 22:18   #1593  |  Link
Patman
Patman's Avatar
7.61 fps (237.29s)
7.77 fps (232.41s)
7.97 fps (226.74s)
8.02 fps (225.10s)
THX for testing my builds. I'm very happy with the GCC 10.0.1 builds. Compiling with GCC 10 is a lot faster than compiling with GCC 9. I'll try to compile all my builds with GCC 10 in the future.
Patman is offline   Reply With Quote
Old 29th March 2020, 22:28   #1594  |  Link
JKyle
That's pretty good news.
Old 29th March 2020, 22:38   #1595  |  Link
creeve4
Originally Posted by Arbelisk View Post
Hey all! I'm currently using StaxRip 2.0.2.4 Beta and encoding a 4K movie using NVEnc. But for some reason, it will output two files after the encoding is finished. One has the original name that i set, and the other has _HDR10 at the end. Is there an option I'm missing to keep it from doing this? Thanks!
I am also looking for an answer about this. What are the differences between the file with _HDR and the one without?
creeve4 is offline   Reply With Quote
Old 29th March 2020, 23:11   #1596  |  Link
Atlantis
I also confirm that GCC 10 is a little faster. I'm using x265 3.3+10-g08d895bb6 GCC 10.0.1 Patman. And no M branch. I think the original looks better and cleaner. fps, Bitrate and ETA is enough.
Old 30th March 2020, 03:04   #1597  |  Link
pintcat
Thank you, works fine now. Wouldn't it be wise to accept every component version which is above the one mentioned in the versions.txt?
Old 30th March 2020, 16:17   #1598  |  Link
Mertiz88
Hi there,
Sorry if this is not the right thread to ask this question, also I've searched in the forums but didn't find the answer. I'm trying to use Staxrip 2.0.0.1 Beta just to apply a filter on an encoded video. What I did is taking that video and checked the filter box and made both video and audio settings on (copy/mux) but I found out that the filter didn't be applied. Basically, is that possible? If so, what's the right way to do that? thanks.
Mertiz88 is offline   Reply With Quote
Old 30th March 2020, 22:34   #1599  |  Link
Joekiwi
Hi I'm a newbie - but I think filters will not work unless you to a video encode . Definitely applies to crop - as I wanted to remove black borders and no can do - so had to do a complete re-encode from source.
I may be wrong -
Anyway you can run filters/scripts / command lines on base programs for avisynth & vapoursynth - I'm not going that far - so Staxrip just for me-( learning curve for payback for my needs too much ) Staxrip is just a nice frontend for a bunch of tools made easy for people like me
Joekiwi is offline   Reply With Quote
Old 30th March 2020, 22:36   #1600  |  Link
AMED
AMED's Avatar
@Mertiz88,
If you permanently want the filter on the video then you'll need to re encode it not copy/mux. are you able to just apply the filter on the software your using for playback?
A Man Eating Duck
AMED is offline   Reply With Quote
aac, hdr, hevc, staxrip, x265
