Go Back   Doom9's Forum > (HD) DVD, Blu-ray & (S)VCD > Advanced authoring
Old 16th February 2020, 21:19   #301  |  Link
zeropc
6 hours later and after two tries I give up.
It stands at 99% for hours and getting there took about 90 minutes each try.
I can only force quit the app
also the files created are right from the start very big... see screenshot below
zeropc is offline   Reply With Quote
Old 16th February 2020, 21:53   #302  |  Link
videoh
Useful n00b
Please give me a link to purchase the disk so I can try it.
Also, please try checking the 'No preallocation' checkbox before demuxing. Preallocation requires a lot of free disk space but the resulting files are less fragmented.
Old 16th February 2020, 22:28   #303  |  Link
zeropc
https://www.amazon.com/Hellboy-Blu-ray/dp/B07GW46DV7
Old 16th February 2020, 22:53   #304  |  Link
videoh
Useful n00b
Did you try with no preallocation?
Old 17th February 2020, 19:48   #305  |  Link
videoh
Useful n00b
Any chance of a reply, zeropc?
Old 17th February 2020, 20:51   #306  |  Link
zeropc
Still running the test
Old 17th February 2020, 21:32   #307  |  Link
zeropc
After almost 3 hours it finished with no preallocation turned on
i used Alien 4K however. There was no log file created
Old 17th February 2020, 23:10   #308  |  Link
videoh
Useful n00b
I just demuxed Hobbes and Shaw UHD in 10 minutes. You'll need to demux to an SSD drive for best performance.
Don't point me to a disk to purchase and then give results for a different disk!
Old 18th February 2020, 19:40   #309  |  Link
zeropc
I tried it again with no preallocation on Hellboy. It gets stuck at 41% and I can only do a hard turn off of the PC
What does no preallocation actually do?
I also used a SSD. Still very slow though
Old 18th February 2020, 21:03   #310  |  Link
videoh
Useful n00b
I have Hellboy on order and will report my results when it arrives. How much free space do you have on the SSD and how is it connected to your system? What is your OS, etc.?
Read the user manual for an explanation of preallocation. It's also discussed at my forum.
Old 18th February 2020, 21:31   #311  |  Link
zeropc
Windows 10 through Parallels Desktop to macOS Mojave
Like I said before, other applications have no speed issues. That's why it's very odd.
Free space on the SSD is 250GB
Where can I get the manual?
Old 18th February 2020, 22:06   #312  |  Link
videoh
Useful n00b
Re-download, as the manual was missing from the zip file for some time.
A quick google search shows many reports of very poor performance for Win10 under Parallel Desktop. Do you have a native windows machine to try? My Hellboy is ripping right now. I don't anticipate any performance issues.
Old 18th February 2020, 22:09   #313  |  Link
zeropc
I did, no manual inside the rar file
Old 19th February 2020, 00:09   #314  |  Link
videoh
Useful n00b
http://rationalqm.us/dgdemux/binaries/
The 1.0.0.19 RAR contains DGDemux.txt.
I just fully demuxed Hellboy 00292.mpls in 8 minutes on my native Win10 system. In perfect sync throughout, of course.
Old 19th February 2020, 15:21   #315  |  Link
zeropc
I used 00291.mpls. Can you please check this one too
I'll create BootCamp partition. Maybe this will fix the issues I've
Old 19th February 2020, 20:23   #316  |  Link
videoh
Useful n00b
7 minutes 54 seconds.
Old 19th February 2020, 21:29   #317  |  Link
zeropc
So defiantly a problem on my sight. Thanks for testing, videoh
But besides the slow remuxing on my side, why does the app create such huge files from the start?
Old 19th February 2020, 23:06   #318  |  Link
videoh
Useful n00b
That is the preallocation. It's discussed extensively at my forum. When the files are closed they are truncated to their actual sizes.
Old 20th February 2020, 18:25   #319  |  Link
zeropc
Ah!!!!!
Old 3rd March 2020, 06:38   #320  |  Link
infamousfunk
created an account here to say i can't wait to try your software. seems like the only one capable of properly decoding seamless branched uhd's.
infamousfunk is offline   Reply With Quote
