8th December 2016, 18:22 | #2661 | Link |
Daily nightly build: r2337
http://www.mediafire.com/file/h6nlac...splus-r2337.7z 20161208 r2337dev
Could someone with AVX2 processor check please, whether there is a speed gain in the merge functions? I have only AVX, and using the intel sde emulator is 10 times slower, so I cannot profile. e.g. for weight=0.3 and 0.5 (this is special: averaging) a = MergeLuma(x,x2,weight=weight) b = MergeChroma(x,x2,weight=weight) c = Merge(x,x2,weight=weight) Thanks. |
9th December 2016, 00:41 | #2662 | Link |
I think a found another bug in Overlay. Try negative values for y -> y=-20. x is ok.
The mask is not moving in y direction!? I used the Test.png from above https://www.sendspace.com/file/ad7xdd Code:
logo = ImageSource("d:\Test.png",pixel_type="rgb32") overlay(x=60, y=-20, logo, mask=logo.showalpha(), pc_range=true)
AVSRepoGUI // VSRepoGUI - Package Manager for AviSynth // VapourSynth VapourSynth Portable FATPACK || VapourSynth Database Last edited by ChaosKing; 9th December 2016 at 00:44. |
9th December 2016, 10:55 | #2663 | Link |
I'm getting an "Access violation - System Exception" in VDub (on both x86/x64) using xy-vsfilter (3.0.0.306) and "MaskSub" function: Code:
MaskSub("Subtitle.ass", 1920, 1080, 23.976, 34000) |
9th December 2016, 11:52 | #2664 | Link |
Log created with: AVSMeter 2.4.4 (x64) Script file: F:\Pluggin_Tests\TestBench.avs Command line switches: -l [OS/Hardware info] Operating system: Windows 7 (x64) Service Pack 1 (Build 7601) CPU (brand string): Intel(R) Core(TM) i7-6950X CPU @ 3.00GHz CPU (code name): Broadwell-E (Core i7) CPU clock (measured): 4124 MHz CPU cores / Logical cores: 10 / 20 [Avisynth core info] VersionString: AviSynth+ 0.1 (r2331, MT, x86_64) VersionNumber: 2.60 File version: 0.1.0.0 Interface Version: 6 Multi-threading support: Yes Linker/compiler version: 14.0 Avisynth.dll location: C:\Windows\System32\AviSynth.dll Avisynth.dll time stamp: 2016-12-06, 14:42:15 (UTC) PluginDir+ (HKLM, x64): C:\Program Files (x86)\AviSynth+\plugins64+ PluginDir2_5 (HKLM, x64): C:\Program Files (x86)\AviSynth+\plugins64 [Clip info] Number of frames: 10000 Length (hh:mm:ss.ms): 00:06:40.000 Frame width: 3840 Frame height: 2160 Framerate: 25.000 (25/1) Colorspace: YV12 Audio channels: n/a Audio bits/sample: n/a Audio sample rate: n/a Audio samples: n/a [Runtime info] Frames processed: 10000 (0 - 9999) FPS (min | max | average): 519.1 | 646.0 | 633.5 Memory usage (phys | virt): 53 | 49 MiB Thread count: 41 CPU usage (average): 5% Time (elapsed): 00:00:15.785 [Script] a=Colorbars(width=1920*2,height=1080*2,pixel_type="yv12").killaudio().assumefps(25,1).trim(0,9999) Merge(a,a,0.5) Code:
Log created with: AVSMeter 2.4.4 (x64) Script file: F:\Pluggin_Tests\TestBench.avs Command line switches: -l [OS/Hardware info] Operating system: Windows 7 (x64) Service Pack 1 (Build 7601) CPU (brand string): Intel(R) Core(TM) i7-6950X CPU @ 3.00GHz CPU (code name): Broadwell-E (Core i7) CPU clock (measured): 4124 MHz CPU cores / Logical cores: 10 / 20 [Avisynth core info] VersionString: AviSynth+ 0.1 (r2337, MT, x86_64) VersionNumber: 2.60 File version: 0.1.0.0 Interface Version: 6 Multi-threading support: Yes Linker/compiler version: 14.0 Avisynth.dll location: C:\Windows\System32\AviSynth.dll Avisynth.dll time stamp: 2016-12-08, 14:45:04 (UTC) PluginDir+ (HKLM, x64): C:\Program Files (x86)\AviSynth+\plugins64+ PluginDir2_5 (HKLM, x64): C:\Program Files (x86)\AviSynth+\plugins64 [Clip info] Number of frames: 10000 Length (hh:mm:ss.ms): 00:06:40.000 Frame width: 3840 Frame height: 2160 Framerate: 25.000 (25/1) Colorspace: YV12 Audio channels: n/a Audio bits/sample: n/a Audio sample rate: n/a Audio samples: n/a [Runtime info] Frames processed: 10000 (0 - 9999) FPS (min | max | average): 505.4 | 662.4 | 648.3 Memory usage (phys | virt): 53 | 49 MiB Thread count: 41 CPU usage (average): 6% Time (elapsed): 00:00:15.424 [Script] a=Colorbars(width=1920*2,height=1080*2,pixel_type="yv12").killaudio().assumefps(25,1).trim(0,9999) Merge(a,a,0.5) |
9th December 2016, 11:55 | #2665 | Link | |
Mask is converted to greyscale (Y only, w/o U and V) unless the greymask parameter is set to false. Internally everything is YUV 4:4:4, and with greymask=true (default) the clip's U and V plane is faked from the Y plane. But only the frame pointers were faked, the pitch of U and V planes (which are zero for a greyscale clip) were still used for y shift calculation (mask_offsetU/V = original_mask_offset + x + y*pitchUV which obviously ignores y when pitchUV is zero) |
9th December 2016, 12:52 | #2666 | Link | |
Because 0.5 is a special case: read 2x32 bytes, average them (single command), write 1x32 bytes. It seems, that the memory access is the bottleneck, there is not much difference. For 0.3 it uses the 0.3 and 0.7 weights for clip1 and clip2 then sums it up, so multiplication and addition takes place. Regarding AVX, this instruction set has only float (single) 256 bit support. From AVX2 we have integer routines like in SSE2 with double (256 bit e.g. 32 bytes) data width. The original version used SSE2. |
9th December 2016, 16:32 | #2667 | Link |
Results are indeed more interesting.
Log created with: AVSMeter 2.4.4 (x64) Script file: F:\Pluggin_Tests\TestBench.avs Command line switches: -l [OS/Hardware info] Operating system: Windows 7 (x64) Service Pack 1 (Build 7601) CPU (brand string): Intel(R) Core(TM) i7-6950X CPU @ 3.00GHz CPU (code name): Broadwell-E (Core i7) CPU clock (measured): 4124 MHz CPU cores / Logical cores: 10 / 20 [Avisynth core info] VersionString: AviSynth+ 0.1 (r2331, MT, x86_64) VersionNumber: 2.60 File version: 0.1.0.0 Interface Version: 6 Multi-threading support: Yes Linker/compiler version: 14.0 Avisynth.dll location: C:\Windows\System32\AviSynth.dll Avisynth.dll time stamp: 2016-12-06, 14:42:15 (UTC) PluginDir+ (HKLM, x64): C:\Program Files (x86)\AviSynth+\plugins64+ PluginDir2_5 (HKLM, x64): C:\Program Files (x86)\AviSynth+\plugins64 [Clip info] Number of frames: 10000 Length (hh:mm:ss.ms): 00:06:40.000 Frame width: 3840 Frame height: 2160 Framerate: 25.000 (25/1) Colorspace: YV12 Audio channels: n/a Audio bits/sample: n/a Audio sample rate: n/a Audio samples: n/a [Runtime info] Frames processed: 10000 (0 - 9999) FPS (min | max | average): 252.5 | 390.1 | 384.1 Memory usage (phys | virt): 53 | 50 MiB Thread count: 41 CPU usage (average): 5% Time (elapsed): 00:00:26.033 [Script] a=Colorbars(width=1920*2,height=1080*2,pixel_type="yv12").killaudio().assumefps(25,1).trim(0,9999) Merge(a,a,0.3) Code:
Log created with: AVSMeter 2.4.4 (x64) Script file: F:\Pluggin_Tests\TestBench.avs Command line switches: -l [OS/Hardware info] Operating system: Windows 7 (x64) Service Pack 1 (Build 7601) CPU (brand string): Intel(R) Core(TM) i7-6950X CPU @ 3.00GHz CPU (code name): Broadwell-E (Core i7) CPU clock (measured): 4124 MHz CPU cores / Logical cores: 10 / 20 [Avisynth core info] VersionString: AviSynth+ 0.1 (r2337, MT, x86_64) VersionNumber: 2.60 File version: 0.1.0.0 Interface Version: 6 Multi-threading support: Yes Linker/compiler version: 14.0 Avisynth.dll location: C:\Windows\System32\AviSynth.dll Avisynth.dll time stamp: 2016-12-08, 14:45:04 (UTC) PluginDir+ (HKLM, x64): C:\Program Files (x86)\AviSynth+\plugins64+ PluginDir2_5 (HKLM, x64): C:\Program Files (x86)\AviSynth+\plugins64 [Clip info] Number of frames: 10000 Length (hh:mm:ss.ms): 00:06:40.000 Frame width: 3840 Frame height: 2160 Framerate: 25.000 (25/1) Colorspace: YV12 Audio channels: n/a Audio bits/sample: n/a Audio sample rate: n/a Audio samples: n/a [Runtime info] Frames processed: 10000 (0 - 9999) FPS (min | max | average): 420.9 | 546.9 | 536.8 Memory usage (phys | virt): 53 | 49 MiB Thread count: 41 CPU usage (average): 6% Time (elapsed): 00:00:18.630 [Script] a=Colorbars(width=1920*2,height=1080*2,pixel_type="yv12").killaudio().assumefps(25,1).trim(0,9999) Merge(a,a,0.3) |
10th December 2016, 00:56 | #2668 | Link |
hi pinterf
I check to see if this bug http://forum.doom9.org/showpost.php?...3&postcount=55 still in avs+ after all this work on avs+ then I see it's still not fixed beside the Dither_convert_rgb_to_yuv(cplace ="dv",interlaced=true) I made this for YV16 to test Code:
Function do_PAL_dv (c) { c assert(isyv16(), "only yv16 is allowed.") SeparateFields() y=last B=UToY8() R=VToY8() YToUV(b.BicubicResize(b.Width(), Height()/2, src_top= 0.5),r.BicubicResize(r.Width(), Height()/2, src_top=-0.5),y) Weave() }
See My Avisynth Stuff |
10th December 2016, 09:22 | #2669 | Link | |
11th December 2016, 07:42 | #2670 | Link |
Chroma placement things and interlaced parameter are not valid for yv16 now. Interlaced is silently set to false if source is not 4:2:0. This may be too strict.
For yv12 test in the link: how do you know which is the correct one? |
11th December 2016, 16:24 | #2673 | Link | |
edit: found it Last edited by pinterf; 11th December 2016 at 18:25. |
11th December 2016, 16:45 | #2674 | Link |
Sorry if it's not the right place to talk about that. Dunno if the source of my issue is avisynth+.
About a week now that my x264 encoding process does crazy stuff. After hours of encoding in the middle of a process my cpu which reach most of the time the 100% falls about 20-30%. I tried to run my avs script directly into x264, using avs4x26x, or piping it using avs2yuv_x64. Same result. My logic would say it's due to a bad script which makes process to fail (I wonder why because it appears with no reason): Code:
SetMemoryMax(1600) DGSource("Test1.dgi",fieldop=0,deinterlace=0) QTGMC(preset="Medium", FPSDivisor=2, DftThreads = 1, EdiThreads = 1) #crop(2, 2, -2, -2) Spline36Resize(1280,720) prefetch(4) Code:
AVSMeter 2.3.8 (x86) - Copyright (c) 2012-2016, Groucho2004 [OS/Hardware info] Operating system: Windows 8.1 (x64) (Build 9600) CPU: Intel(R) Core(TM) i7-3770K CPU @ 3.50GHz Ivy Bridge (Core i7) CPU clock (measured): 4346 MHz CPU cores / Logical cores: 4 / 8 VersionString: AviSynth+ 0.1 (r2337, MT, i386) VersionNumber: 2.60 File version: 0.1.0.0 Interface Version: 6 Multi-threading support: Yes Linker/compiler version: 14.0 Avisynth.dll location: C:\Windows\SysWOW64\AviSynth.dll Avisynth.dll time stamp: 2016-12-08, 18:02:40 PluginDir+ (HKLM, x86): C:\Program Files (x86)\AviSynth+\plugins+ PluginDir2_5 (HKLM, x86): C:\Program Files (x86)\AviSynth+\plugins [Avisynth CPP 2.6 plugins] C:\Program Files (x86)\AviSynth+\plugins+\ConvertStacked.dll (n/a) C:\Program Files (x86)\AviSynth+\plugins+\DirectShowSource.dll (n/a) C:\Program Files (x86)\AviSynth+\plugins+\ImageSeq.dll (n/a) C:\Program Files (x86)\AviSynth+\plugins+\Shibatch.dll (n/a) C:\Program Files (x86)\AviSynth+\plugins+\TimeStretch.dll (n/a) C:\Program Files (x86)\AviSynth+\plugins+\VDubFilter.dll (n/a) C:\Program Files (x86)\AviSynth+\plugins+\yadifmod2.dll (n/a) C:\Program Files (x86)\AviSynth+\plugins+\yadifmod2_avx2.dll (n/a) C:\Program Files (x86)\AviSynth+\plugins\avss_26.dll (2.0.0.13) C:\Program Files (x86)\AviSynth+\plugins\DGDecodeNV.dll (0.0.0.2052) C:\Program Files (x86)\AviSynth+\plugins\DirectShowSource.dll (2.6.1.0) C:\Program Files (x86)\AviSynth+\plugins\ffms2.dll (n/a) C:\Program Files (x86)\AviSynth+\plugins\masktools2.dll (2.1.0.0) C:\Program Files (x86)\AviSynth+\plugins\MSharpen.dll (n/a) C:\Program Files (x86)\AviSynth+\plugins\mvtools2.dll (2.7.0.22) C:\Program Files (x86)\AviSynth+\plugins\nnedi3.dll (0.9.4.32) C:\Program Files (x86)\AviSynth+\plugins\RgTools.dll (n/a) C:\Program Files (x86)\AviSynth+\plugins\TCPDeliver.dll (2.6.1.0) [Avisynth CPP 2.5 plugins] C:\Program Files (x86)\AviSynth+\plugins+\flash3kyuu_deband.dll (n/a) C:\Program Files (x86)\AviSynth+\plugins\AddGrainC.dll (1.5.2.0) C:\Program Files (x86)\AviSynth+\plugins\AudioLimiter.dll (n/a) C:\Program Files (x86)\AviSynth+\plugins\avss.dll (2.0.0.13) C:\Program Files (x86)\AviSynth+\plugins\avstp.dll (1.0.3.0) C:\Program Files (x86)\AviSynth+\plugins\aWarpSharp.dll (n/a) C:\Program Files (x86)\AviSynth+\plugins\BassAudio.dll (n/a) C:\Program Files (x86)\AviSynth+\plugins\ColorMatrix.dll (2.5.0.0) C:\Program Files (x86)\AviSynth+\plugins\Convolution3DYV12.dll (1.0.0.5) C:\Program Files (x86)\AviSynth+\plugins\DctFilter.dll (0.0.1.4) C:\Program Files (x86)\AviSynth+\plugins\deblock.dll (1.2.0.0) C:\Program Files (x86)\AviSynth+\plugins\Decomb.dll (n/a) C:\Program Files (x86)\AviSynth+\plugins\dfttest.dll (1.9.4.0) C:\Program Files (x86)\AviSynth+\plugins\DGDecode.dll (1.5.8.0) C:\Program Files (x86)\AviSynth+\plugins\dither.dll (n/a) C:\Program Files (x86)\AviSynth+\plugins\EEDI2.dll (0.9.2.0) C:\Program Files (x86)\AviSynth+\plugins\EEDI2.dll_back (0.9.2.0) C:\Program Files (x86)\AviSynth+\plugins\eedi3.dll (0.9.1.0) C:\Program Files (x86)\AviSynth+\plugins\FFT3DFilter.dll (2.1.1.0) C:\Program Files (x86)\AviSynth+\plugins\FFT3dGPU.dll (0.8.2.0) C:\Program Files (x86)\AviSynth+\plugins\FillMargins.dll (1.0.2.0) C:\Program Files (x86)\AviSynth+\plugins\FluxSmooth.dll (n/a) C:\Program Files (x86)\AviSynth+\plugins\gradfun2db.dll (n/a) C:\Program Files (x86)\AviSynth+\plugins\GRunT.dll (n/a) C:\Program Files (x86)\AviSynth+\plugins\LeakKernelDeint.dll (1.5.4.0) C:\Program Files (x86)\AviSynth+\plugins\MDeblock.dll (n/a) C:\Program Files (x86)\AviSynth+\plugins\MDeblockS.dll (n/a) C:\Program Files (x86)\AviSynth+\plugins\NicAudio.dll (n/a) C:\Program Files (x86)\AviSynth+\plugins\nnedi.dll (1.3.0.0) C:\Program Files (x86)\AviSynth+\plugins\nnedi2.dll (1.6.0.0) C:\Program Files (x86)\AviSynth+\plugins\RemoveGrainSSE2.dll (n/a) C:\Program Files (x86)\AviSynth+\plugins\RemoveGrainSSE3.dll (n/a) C:\Program Files (x86)\AviSynth+\plugins\RemoveGrainSSE3.dll_back (n/a) C:\Program Files (x86)\AviSynth+\plugins\RepairSSE2.dll (n/a) C:\Program Files (x86)\AviSynth+\plugins\RepairSSE3.dll (n/a) C:\Program Files (x86)\AviSynth+\plugins\Rotate.dll (1.3.4.0) C:\Program Files (x86)\AviSynth+\plugins\SSE2Tools.dll (n/a) C:\Program Files (x86)\AviSynth+\plugins\TDeint.dll (1.1.0.0) C:\Program Files (x86)\AviSynth+\plugins\TDeint.dll_back (1.1.0.0) C:\Program Files (x86)\AviSynth+\plugins\TIVTC.dll (1.0.5.0) C:\Program Files (x86)\AviSynth+\plugins\TomsMoComp.dll (0.0.1.8) C:\Program Files (x86)\AviSynth+\plugins\TTempSmooth.dll (0.9.4.0) C:\Program Files (x86)\AviSynth+\plugins\UnDot.dll (0.0.1.1) C:\Program Files (x86)\AviSynth+\plugins\unsharpHQ_v05_x86.dll (n/a) C:\Program Files (x86)\AviSynth+\plugins\VariableBlur.dll (n/a) C:\Program Files (x86)\AviSynth+\plugins\VerticalCleanerSSE2.dll (n/a) C:\Program Files (x86)\AviSynth+\plugins\VSFilter.dll (3.0.0.306) C:\Program Files (x86)\AviSynth+\plugins\warpsharp.dll (n/a) [Avisynth C 2.5 plugins] C:\Program Files (x86)\AviSynth+\plugins\yadif.dll (1.7.0.0) C:\Program Files (x86)\AviSynth+\plugins\yadif.dll_bak (1.7.0.0) Code:
AVSMeter 2.3.8 (x64) - Copyright (c) 2012-2016, Groucho2004 [OS/Hardware info] Operating system: Windows 8.1 (x64) (Build 9600) CPU: Intel(R) Core(TM) i7-3770K CPU @ 3.50GHz Ivy Bridge (Core i7) CPU clock (measured): 4346 MHz CPU cores / Logical cores: 4 / 8 VersionString: AviSynth+ 0.1 (r2337, MT, x86_64) VersionNumber: 2.60 File version: 0.1.0.0 Interface Version: 6 Multi-threading support: Yes Linker/compiler version: 14.0 Avisynth.dll location: C:\Windows\System32\AviSynth.dll Avisynth.dll time stamp: 2016-12-08, 15:45:04 PluginDir+ (HKLM, x64): C:\Program Files (x86)\AviSynth+\plugins64+ PluginDir2_5 (HKLM, x64): C:\Program Files (x86)\AviSynth+\plugins64 [Avisynth CPP 2.6 plugins] C:\Program Files (x86)\AviSynth+\plugins64+\ConvertStacked.dll (n/a) C:\Program Files (x86)\AviSynth+\plugins64+\DirectShowSource.dll (n/a) C:\Program Files (x86)\AviSynth+\plugins64+\ImageSeq.dll (n/a) C:\Program Files (x86)\AviSynth+\plugins64+\Shibatch.dll (n/a) C:\Program Files (x86)\AviSynth+\plugins64+\TimeStretch.dll (n/a) C:\Program Files (x86)\AviSynth+\plugins64+\VDubFilter.dll (n/a) C:\Program Files (x86)\AviSynth+\plugins64+\yadifmod2.dll (n/a) C:\Program Files (x86)\AviSynth+\plugins64+\yadifmod2_avx2.dll (n/a) C:\Program Files (x86)\AviSynth+\plugins64\DGDecodeNV.dll (0.0.0.2052) C:\Program Files (x86)\AviSynth+\plugins64\masktools2.dll (2.1.0.0) C:\Program Files (x86)\AviSynth+\plugins64\msharpen.dll (n/a) C:\Program Files (x86)\AviSynth+\plugins64\mvtools2.dll (2.7.0.22) C:\Program Files (x86)\AviSynth+\plugins64\nnedi3.dll (0.9.4.32) C:\Program Files (x86)\AviSynth+\plugins64\RgTools.dll (n/a) [Avisynth CPP 2.5 plugins] C:\Program Files (x86)\AviSynth+\plugins64\TIVTC.dll (1.0.5.0) [Avisynth CPP 2.0 plugins] C:\Program Files (x86)\AviSynth+\plugins64\VSFilter.dll (3.0.0.306) [Plugin errors] --------------------------------------------------------------------------- Error loading "C:\Program Files (x86)\AviSynth+\plugins64\DGDecode.dll" Cannot load 32 bit DLL with 64 bit Avisynth --------------------------------------------------------------------------- "C:\Program Files (x86)\AviSynth+\plugins64\mvtools2.dll" Dependencies that couldn't be loaded: libfftw3f-3.dll Note: libfftw3f-3.dll can be downloaded here: http://www.fftw.org/install/windows.html I really need to understand for fixing it. I'd love to have your help. Last edited by Sm3n; 11th December 2016 at 16:46. Reason: layout |
11th December 2016, 16:53 | #2675 | Link | |
I'm not happy, now I have a deeper clue about the caveats of keeping the backward compatibility with that what is called "baked code". In its current form I am not able to keep the compatibility between avisynth 2.5 interface and my new AVSValue handling schema. The problem affects arrays (and such, the filter parameter passing). Although the array creation is transparent when 2.6 interface is used and automatically uses the new mechanism for creating and copying AVSValue types, but plugins using "baked code" avs 2.5 interface are not knowing about the feature and use the array creation codes hardcoded in the 2.5 interface. And since I simply not able to check, what kind of interface made a call to ScriptEnvironment::Invoke, I have to revert that array feature. O.K. having script arrays are only a nice addition to the language but there was quite a bit of work with this feature. So it seems that I have to revert my nice new array mechanism, even from the dev version of my builds. As there are still some plugins out there with the 2.5 interface, I cannot make avs+ incompatible with them and cause users inconveniance. Last edited by pinterf; 11th December 2016 at 17:03. |
11th December 2016, 17:00 | #2676 | Link | |
The solution was that the processor got too hot after a while, and an automatic thermal throttle was kicking in. Try monitoring the processor, and check the heatsink and fan. Last edited by pinterf; 11th December 2016 at 17:02. |
11th December 2016, 21:57 | #2678 | Link |
New week, new build, new adventures.
This time I had to remove the script array feature that has caused me and you headaches. http://www.mediafire.com/file/gbpdu5...splus-r2343.7z 20161211 r2343dev
Last edited by pinterf; 11th December 2016 at 22:05. Reason: Typo: r2343 is the right version |
11th December 2016, 22:02 | #2679 | Link | ||
11th December 2016, 22:04 | #2680 | Link | |
One last request: could you repeat this test with the r2343? |
