31st July 2014, 06:04 | #21 | Link | |
ffx264/ffhevc author
31st July 2014, 07:30 | #24 | Link |
SuperVirus
Nope, because I am not a programmer since the days that the 96-column punch cards were still used ^.^;
All I wanted was just make the improvements created by Lord_Mulder (and now, by Alexei Andropov too) available to the *NIX users, so that their better builds of (ff)dcaenc don't depend on WINE anymore But if I just could, I certainly would fix the issues with the "uncommon" channel-layouts and would add the back-center channel to the mono inputs option =^_^= FWIW, these were the steps of the RE-Linuxization: 1) internal renaming from dcaenc to ffdcaenc 2) add _T(__GNUC_PATCHLEVEL__) to compiler_info.h 3) drop the Windows-specific Unicode support 4) replace all the occurrences of __int8 and __int32 with int8_t and int32_t , plus 5) replace "unsigned __int8" and "unsigned __int32" with "uint8_t" and "uint32_t" 6) remove the MSVC stuff from (ff)dcaenc.h 7) replace %d and %02d with %u and %02u in the file main.c, in order to eliminate the warning messages Last edited by filler56789; 1st August 2014 at 16:44. Reason: additional info |
7th August 2014, 05:24 | #25 | Link |
SuperVirus
Well, certainly not because of some good-intention ^.^; ,
but I have changed my mind https://github.com/filler56789/ffdcaenc-2 |
31st August 2014, 05:50 | #26 | Link |
47.952fps@71.928Hz
I managed to get one DVD going.
HCenc + AC3 + DTS (754.5 kbps for DVD authoring). It built propery with Muxman and managed to get it into an ISO with ImgBurn. I still have to test if it works on my devices though. That's another ballpark. For testing, I took a 24bit audio track and made 3 versions: 16bit (eac3to -down16), 24bit (original), s32 (ffmpeg) Ran them all though ffdcaenc and the file size was the same for all. I decoded all three to WAV with eac3to+arcsoft then eac3to+libav and ram them through Foobar2000's "bit comparator", only mild audio differnces were found between all of them. Not sure if upscaling 24->32 did anything, since there's no new data and I didn't apply any filtering. I do like it supports 24bit, since 16 & 24 are the common bit depths for blu-ray audio formats, so i don't needlessly have to upscale to s32. However, it seems no matter the source, it writes the DTS with 24bit, which is unusable in AVStoDVD (since AVS to accept only 16/20 bit DTS streams for maximum compatibility wtih Muxman). Using Muxman manually (without AVStoDVD), I was able to get the 24bit DTS stream to mux. This is still incredibly fun to play with.
Win10 (x64) build 19041 NVIDIA GeForce GTX 1060 3GB (GP106) 3071MB/GDDR5 | (r435_95-4) NTSC | DVD: R1 | BD: A AMD Ryzen 5 2600 @3.4GHz (6c/12th, I'm on AVX2 now!)
31st August 2014, 09:26 | #27 | Link |
@Sparktank
Please read the last pages in eac3to thread. - The standard dts don't have bitdepth, the size is always the same no matter the bitdepth of source wav because the bitrate is the same. - The 32 bits float have, more or less, the same precission than 24 bits int, because 32 float have 24 bits for mantissa (significand digits). It's usefull only when you need operate with the values to prevent int overflow. - If AVStoDVD don't accept a DTS marked with a source PCM of 24 bits is only a bug in the program. The DTS header field about Source PCM Resolution must be ignored.
31st August 2014, 16:23 | #28 | Link | ||||
47.952fps@71.928Hz
I did spend some time reading eac3to thread lately and had wondered if this was mostly just A2D concern about its bit-depth and DTS formats. Quote:
The documentation says there's a known bug about floating-point: Quote:
It would be nice to see something like this implemented into A2D, since I use most of what it uses. ---------- All this FF play, and I still haven't gotten around to actually trying Mulder's version (of which this is a fork of). I'll have to set up a day for all this.
13th September 2014, 20:21 | #29 | Link | |
AVStoDVD Dev
I have tried to search what is the real culprit to know if a DTS stream is DVD compliant (aka accepted by Muxman), without success. That's why I have implemented in AVStoDVD the 16/20 vs 24 bit approximate rationale. I would happily change the rationale, if anyone can suggest how to define in advance (i.e. thru Mediainfo) if a DTS stream is DVD compliant (accepted by Muxman). Thanks guys! Bye |
13th September 2014, 20:54 | #30 | Link |
Life's clearer in 4K UHD
The most likely culprit is that the DVD specification requires an elementary DTS stream to be encoded with 2012 primary (2013 bytes) per frame
13th September 2014, 21:55 | #31 | Link | |
AVStoDVD Dev
Bye P.S. If we are going OT, we can continue on the AVStoDVD thread. |
13th September 2014, 22:35 | #32 | Link | |
I discovered this issue only recently myself a few months, ago here...
14th September 2014, 00:01 | #33 | Link |
The tool I use in the post linked by SeeMoreDigital is LeeAudbi
Maybe you can use the LeeDtsBi.exe, out of the GUI, than output the file AudioBi.log: Code:
========================================================== File ........: D:\tmp\test 4\321.dts Size ........: 1886250 bytes ----------------------------------------- First Frame Info CRC present .................: 0 (Not) Number of PCM Sample Blocks .: 15 ( 512 samples/frame) Primary Frame Byte Size .....: 1005 ( 1006 bytes/frame) Audio Channel Arrangement ...: 9 (5 C + L + R + SL + SR) Core Audio Samp. Frequency ..: 13 (48 kHz) Transmission Bit Rate .......: 15 (768 Kb/s) Embedded Down Mix Enabled ...: 0 (Not) Embedded Dynamic Range Flag .: 0 (Not) Embedded Time Stamp Flag ....: 0 (Not) Auxiliary Data Flag .........: 0 (Not) Mastered in HDCD format .....: 0 (Not) Extension Audio Descr. Flag .: 0 (Channel Extension XCh) Extended Coding Flag ........: 0 (Not) Audio Sync Word Insert. Flag : 1 (Sub-sub-frame) Low Frequency Effects Flag ..: 2 (Present, interpolation factor 64) Predictor History Flag Switch: 1 (Yes) Multirate Interpolator Switch: 0 (Non-perfect Reconstruction) Encoder Software Revision ...: 7 (Current) Copy History ................: 1 (Definition deliberately omitted) Source PCM Resolution .......: 6 (24 bits) Front Sum/Difference Flag ...: 0 (Not) Surrounds Sum/Difference Flag: 0 (Not) Dialog Normalization Param. .: - 0 dB ------------------------------------------- Estimated Info Total Frames ......: 1875 Duration ..........: 20 seconds. ( 0 h. 0 m. 20 s.) ------------------------------------------------- End Info I don't know the Muxman requirements, but I don't think is related with the value of the field Source PCM Resolution that can be changed without modify the audio itself.
BeHappy, AviSynth audio transcoder. Last edited by tebasuna51; 14th September 2014 at 00:07. |
14th September 2014, 17:58 | #34 | Link |
AVStoDVD Dev
@tebasuna51
thanks for the info about LeeDtsBi, nice tool Actually some years ago I had already contacted mpucoder who pointed me to this page for DTS compliance to DVD: http://mpucoder.com/DVD/dtshdr.html At that time it was quite obscure to me. Now it should be more clear thank to your explanations and achievable with LeeDtsBi. Requirements (other than bitrate and samplerate): Number of PCM Sample Blocks = 15 Primary Frame Byte Size = 1005 for 768 Kbps streams or 2012 for 1536 Kbps streams Bye Last edited by MrC; 14th September 2014 at 18:19. Reason: Deepening more |
14th September 2014, 18:50 | #35 | Link |
SuperVirus
I think I've found one of those "problematic 24-bit files" mentioned by MrC
http://forum.videohelp.com/threads/3...=1#post2345872 |
15th September 2014, 20:30 | #36 | Link |
AVStoDVD Dev
@tebasuna51
I have seen that LeeDtsbi accepts only DTS files as input (well, it is designed for that, I assume .... ). Would it be possible to expand the scope by feeding also containers of DTS tracks, such as avi, vob, mkv? Thanks in advance Bye Last edited by MrC; 15th September 2014 at 20:33. |
15th September 2014, 23:57 | #38 | Link |
SuperVirus
^ MrC, I presume you can use a recent build of MediaInfo for that purpose. My copy is version 0.7.67, and until now, it deals fine (bitrate-wise) with all the "generic DTSs" that I have created with dcaenc Example: Code:
General Unique ID : 253922954119774177664030532708049754484 (0xBF07C83717D52580B6BF63AA47561974) Complete name : D:\SomeDirectory\filename.mkv Format : Matroska Format version : Version 2 File size : 171 MiB Duration : 10mn 13s Overall bit rate : 2 333 Kbps Encoded date : UTC 2010-02-22 21:41:31 Writing application : mkvmerge v5.8.0 ('No Sleep / Pillow') built on Sep 30 2012 10:57:14 Writing library : libebml v1.3.0 + libmatroska v1.4.0 Video ID : 1 Format : VC-1 Codec ID : V_MS/VFW/FOURCC / WMV3 Codec ID/Info : Windows Media Video 9 Codec ID/Hint : WMV3 Duration : 10mn 13s Bit rate : 1 994 Kbps Width : 1 280 pixels Height : 720 pixels Display aspect ratio : 16:9 Frame rate mode : Constant Frame rate : 25.000 fps Bit depth : 8 bits Compression mode : Lossy Bits/(Pixel*Frame) : 0.087 Stream size : 146 MiB (85%) Default : Yes Forced : No Audio ID : 2 Format : DTS Format/Info : Digital Theater Systems Mode : 16 Format settings, Endianness : Big Codec ID : A_DTS Duration : 10mn 13s Bit rate mode : Constant Bit rate : 292 Kbps Channel(s) : 2 channels Channel positions : Front: L R Sampling rate : 44.1 KHz Bit depth : 16 bits Compression mode : Lossy Stream size : 21.4 MiB (13%) Language : English Default : Yes Forced : No Last edited by filler56789; 16th September 2014 at 00:02. |
16th September 2014, 10:00 | #39 | Link |
AVStoDVD Dev
@filler56789
thanks for looking into this. Actually I already use MediaInfo to scan video and audio properties. Unfortunately samplerate and bitrate are not sufficient to define if a DTS stream is DVD compliant. There are streams having 768/1536 Kbps and 48 KHz but are not DVD compliant. As mentioned before we need to check also: Number of PCM Sample Blocks = 15 Primary Frame Byte Size = 1005 for 768 Kbps streams or 2012 for 1536 Kbps streams as LeeDtsBi from tebasuna51 does. I have already sent a feat request to Zenitram (MediaInfo author) to include the above properties. Let's wait for his reply. Bye |
16th September 2014, 14:46 | #40 | Link | |
SuperVirus
1006 bytes per frame = 754.500kbps 1024 bytes per frame = 768.000kbps 2013 bytes per frame = 1509.750kbps 2048 bytes per frame = 1536.000kbps Last edited by filler56789; 16th September 2014 at 14:49. Reason: clarity |
