7th February 2017, 12:59 | #42341 | Link | |
previous my GTX 970 have coil-whine but now i upgraded to GTX 1070 no more coil whine anymore. |
7th February 2017, 15:20 | #42343 | Link | |
Kid for Today
7th February 2017, 17:22 | #42344 | Link |
Visual Novel Dev.
GTX 1080
I copied latest madVR then copied the test files for NGU Pixart over the install like you said. Those settings are for that situation...
7th February 2017, 18:44 | #42345 | Link |
but how many people are watching movies in this resolution, let alone care about good scaling then?
7th February 2017, 21:14 | #42347 | Link | |
SD/D-1 HD FHD are the most typical inputs these days only handling sub that is crazy somehow to even take into account anymore, no TV advertises with sub SD improvements and few only with good SD Handling Also if you think which codecs and/or analog sources have been used for those But still DVD (Mpeg-2) is a viable target they still exist and want to be upscaled to up to 4K now
all my compares are riddles so please try to decipher them yourselves :) It is about Time Join the Revolution NOW before it is to Late ! http://forum.doom9.org/showthread.php?t=168004 Last edited by CruNcher; 7th February 2017 at 21:35. |
7th February 2017, 21:25 | #42348 | Link |
Well, watching 360x288 on a 1080p screen is the same as watching 1440x1152 (i.e. >1080p) on an 8k screen, so it will become relevant eventually, probably. That said I don't think you can expect an image to look well when scaled more than 3x in each direction, eventually you just run out of detail. I am however somewhat optimistic that for smaller scaling factors you can make it hard to distinguish between a low quality high resolution image and a high quality low resolution image.
7th February 2017, 21:39 | #42349 | Link |
Most probably you first have to deartifacting before even thinking about the upscaling, every TV Hardware (MediaTek Based) these days has at least a simple MPEG improvement mode mostly even straight from the decoder part itself and Mali Txx onboard
And much faster as you can say A all the cheap Smart TVs will be Vulkan Render based
all my compares are riddles so please try to decipher them yourselves :) It is about Time Join the Revolution NOW before it is to Late ! http://forum.doom9.org/showthread.php?t=168004 Last edited by CruNcher; 7th February 2017 at 21:55. |
7th February 2017, 22:23 | #42350 | Link | |
I redid the comparison with zoom factor around 4x and found that NGU pix output is much closer to NNEDI3 with some presharpen (like LumaSharpen 0.3) added to NGU. NNEDI3 64+32 vs. NGU pix med+med NNEDI3 64+32 vs. NGU pix med+med (LumaSharpen 0.3) So I carefully assume people may prefer NNEDI3 due to its sharpness, not line thinning differences.
I'm infected with poor sources. |
8th February 2017, 14:55 | #42352 | Link |
Whichever one looks best to you. There isn't a universally recommended anti-bloating filter.
madVR options explained |
8th February 2017, 19:31 | #42354 | Link | |
2) No performance issues here. On my system with AMD GPU, for 720p23 to 1080p23 scaling, NGU Pixart Very High and NNEDI3 64n show about the same rendering times. 3) I would urge you to not drop NNEDI3. There are some other users too who want NNEDI3 to stay. 4) I haven’t been using super-sbr for some time and don’t feel the need for it either. So it does not matter to me whether super-xbr is replaced or not. |
8th February 2017, 21:40 | #42355 | Link | |
and just don't do it. i mean why even use high bit deep output if it isn't supported what a waste of time. |
8th February 2017, 22:03 | #42356 | Link | |
Visual Novel Dev.
3 . If you really want to - you could. 4. I think yes at this moment.
8th February 2017, 23:02 | #42357 | Link |
Hi, I had a few questions about what settings to use for playback, now that I have some hardware that can actually take advantage of more of the included settings. I apologize in advance if some of it comes off as very basic. Using the latest version of madVR 64, XySubFilter_3.1.0.746_x64_BETA3, display is an Asus pg279q, and GPU is an evga gtx 1080 ftw.
First off, in the devices tab, for hdr, is it possible/recommended to use the 3dlut used for calibration? Or are they 2 completely separate things, that each need to be generated on their own? In the scaling algorithms section, for image upscaling, if you choose ngu, what is the difference between the chroma here, and the actual chroma upscaling tab? Does one take precedence, or are they doing entirely different things? And is it sufficient to leave the chroma option in image upscaling, along with the algorithms to use after doubling to "let madvr decide"? Also, I think I read that you don't really have to bother with any of the upscaling refinements if using ngu, since many of them are already applied? Also, is ngu high/very high "better" than using nnedi with a high neuron count? Another question I had was, does bumping the gpu queue size up past 8 do anything? I ask, because on a different machine + prior version of madvr, maybe 2 years ago, increasing that option to 16 from 8 helped me avoid frame drops for the settings I had then. Finally, what combination of settings should I use, in terms of v-sync, g-sync, and smooth motion? The monitor I have is a g-sync monitor, can go up 165hz. Normally leave it at that, with g-sync enabled, and v-sync enabled through the nvidia console as well. But for viewing content that I guess is 23.976fps, at least going by what madvr says, should I turn of g-sync? Turn off v-sync? Drop the refresh rate to 144hz? Does doing any of that even matter/change anything And which setting under smooth motion would I choose, in combination with the above? Also had what I suppose is a bug report, though it seems to have been from nvidia's side. Thought I would mention it, in case anybody else has the same issue. Using drivers from about a month ago, I was not able to get stable playback using any of the "demanding" algorithms. Had to drop settings down to NNEDI with 16 neurons just to get sub 30 ms render times, anything above had massive frame drops, render times at 70+. I noticed however that there would be periods of time where it would drop back down to normal levels, and the gpu queue would fill up, only for the queue to empty almost immediately, and times to shoot back up again. Looking at the gpu stats, using evga's tool, noticed that the gpu looked like it wasn't being utilized properly during the time when plaback was having an issue, ie. the clock speed would drop drastically, memory speed close to zero, along with power usage. Manually forcing max speeds on both clock and memory fixed the problem, was able to use ngu very high for 720p content, high for 1080p, but obviously something was wrong there. Decided to upgrade drivers today in the hopes it would fix it, and it actually seems to have done the trick, not noticing the problem anymore. Again, just an fyi. |
8th February 2017, 23:38 | #42358 | Link | |
question, how does the latest IGP perform on the current MadVR scalers?
e.g. AMD's Kaveri / Godavari APUs, or Intel's Skylake / Kabylake CPUs. is NGU too "heavy" for these IGP? Quote:
its like the gap detail between 16x16, 32x32, 64x64 and 128x128 pixel art or sprites. Last edited by kitame; 9th February 2017 at 00:00. |
9th February 2017, 00:14 | #42359 | Link |
Depends on what you're viewing. The lines that NGU pixart creates are excellent but the overall look is bland, it's also sometimes not smart enough and removes detail which I've stated as it being a bit "too aggressive"
At this point if that were to happen there would definitely be some unhappy people, me being one of them. Here's NNEDI3 64 neurons vs NGU very high on a source I use a lot when evaluating upscalers and my own Anime Avisynth profies for low res content. http://screenshotcomparison.com/comparison/199986 There is reasonably strong ringing and aliasing and quite soft lines, NNEDI3 enhances more of the image creating lines stronger and true to the source. Here the eyes are sharper and the image is more defined, although the lines are not as well enhanced as NGU pix very high. This is NGU's best quality and it bests even NNEDI3 256 neurons at creating these beautiful non aliased lines, notice the top shirt lines just below the neck for a good example of this. Unfortunately like I've said it also removes some things it doesn't consider to be lines, the wedge of hair just above the left eyebrow loses it's blurry left line for example. Looking at the above you can see NGU pix's somewhat dull, processed appearance, for NGU pix to replace NNEDI3 it needs to do a better job in all areas and it's simply not doing this right now. Last edited by ryrynz; 9th February 2017 at 00:16. |
9th February 2017, 01:56 | #42360 | Link |
i'm seeing minor aliasing on NGU, but i can see errors on NNEDI3.
aliasing on NGU = top hair is most evident. errors on NNEDI3 = sleeve cuff by the yellow ribbon has a broken line. i'm using 10x zoom comparison. Last edited by kitame; 9th February 2017 at 01:59. |
