15th March 2016, 00:20 | #4982 | Link |
I'm having an issue with MeGUI.
I am using a tweaked for my needs variation of VideoFreds/John Meyers 8mm restoration script. Everytime I try to load it in MeGUI the program crashes before it even gets to the preview screen. I can however, get the exact same script to open in VDub, mpc-hc, etc. It's been pointed out that if the script opens in VDub, there is no reason why MeGUI shouldn't open it as well, which makes sense. But it doesnt. I have a much shorter script that does degraining, and MeGUI *will* open that one, as will VDub, mpc-hc, etc. So MeGUI works for me, but not on the script that I really need it to. I know it doesn't make sense, but that is where I am at. I'm hoping someone here might have an idea based on just the circumstances I posted. I can post the scripts if that is what would give better insight, (The one will take 3 posts to include it all) but I'm holding off on the small chance someone recognizes the issue I am having. I've deleted and reinstalled both Avisynth and MeGUI. I downloaded the previous version of MeGUI just to see what might happen, and it actually got to the preview screen, but when I hit "queue", it crashed as well. Really puzzling. |
15th March 2016, 02:11 | #4983 | Link | |
I suggest that you first determine how much memory your script uses. Run the script with AVSMeter with the "-log" switch and post the log here (or, if the log is too big, on pastebin or similar). If it crashes, report the error. Last edited by Groucho2004; 15th March 2016 at 02:46. |
15th March 2016, 03:27 | #4984 | Link |
The interface can make a difference and further the platform the client is built with can make a difference.
15th March 2016, 14:14 | #4985 | Link | |
I downloaded the program, but am having trouble running it. I haven't been able to convert the command line that you gave as an example to run my script. I have very little experience with cmd. But I saw where you can drop the script on the executable, so I tried that. A box popped up, doing work, then a few lines showed up at the bottom and the box closed itself and disappeared way before I could read it. If it left a log file, I don't know where it put it, I checked all of the folders that installed with the program. I apologize, but for something like what is posted in the instructions on how to use it, I need it spelled out for me. I'm not very intuitive at all with processes like this. I wish I was Last edited by Bruce/Fl; 15th March 2016 at 14:31. Reason: typos |
15th March 2016, 18:00 | #4986 | Link | |
Navigate to the directory to which you copied AVSMeter.exe and open "AVSMeter.ini" with a text editor (notepad). Change "CreateLog=0" to "CreateLog=1" and "PauseBeforeExit=0" to "PauseBeforeExit=1". Create a shortcut to AVSMeter.exe and drop the script on the icon. The log file will be created in the same directory as the script (scriptname.log). |
15th March 2016, 22:27 | #4987 | Link | ||
It didn't generate a log this time, but the window (which now stayed open for me!) said: Quote:
Edited to add: I also ran through my shorter script, just to see what it would look like, and do, as far as creating a log. It had moch more info in the window, as it should, and obviously no exceptions, but it didn't create a log file either. Was there some other value in the ini I was supposed to modify? Last edited by Bruce/Fl; 15th March 2016 at 22:35. Reason: Add extra info |
15th March 2016, 22:44 | #4988 | Link | |
As for the access violation message - that could be a lot of things, you have to debug the script line by line. |
15th March 2016, 23:59 | #4989 | Link | ||
Thank you again |
16th March 2016, 10:14 | #4991 | Link | |
My wild guess would be that one or more plugins are misbehaving. You should check your Avisynth installation and available plugins. Run this tool and save the logs/reports ("File" -> "Save info" and "Tools" -> "Plugin info" -> "Save plugin info report") and post them here (or off-site if they are too big). |
16th March 2016, 14:26 | #4992 | Link | |
Has anybody else had this issue or has the upload site been compromised? EDIT: I tried on my laptop, and was able to download with no issues (Different antivirus) Looking into it now Last edited by Bruce/Fl; 16th March 2016 at 14:43. |
16th March 2016, 15:05 | #4994 | Link | ||
The AVISynth info looks normal, I would guess. The plud=g in info is probably kind of sparse. The reason for that is, I was doing some trouble shooting on this problem, and came across this post: Quote:
Let me know if I need to drop them back in the plugin folder and run the AVSInfo again. Here are the files: Code:
[General Info - Avisynth.dll] Version String: AviSynth 2.60, build:Mar 31 2015 [16:38:54] File Version: 2.6.0.6 Directory: C:\Windows\SysWOW64 Timestamp: 2015-03-31, 01:40:58 MT Support: No [Plugin Directories] PluginDir2_5 (HKLM) C:\Users\Bruce\Videos\Tools\AVISynth\plugins [Supported Color Spaces] YUY2, Y8, YV12, YV16, YV24, YV411, RGB24, RGB32 [Internal Functions (357)] abs acos AddBorders AlignedSplice Amplify AmplifydB Animate Apply ApplyRange asin Assert AssumeBFF AssumeFieldBased AssumeFPS AssumeFrameBased AssumeSampleRate AssumeScaledFPS AssumeTFF atan atan2 audiobits audiochannels AudioDub AudioDubEx audioduration audiolength audiolengthf audiolengthhi audiolengthlo audiolengths audiorate AudioTrim AverageChromaU AverageChromaV AverageLuma AVIFileSource AVISource BicubicResize BilinearResize bitand bitchange bitchg bitclear bitclr bitlrotate bitlshift bitlshifta bitlshiftl bitlshifts bitlshiftu bitnot bitor bitrol bitror bitrrotate bitrshifta bitrshiftl bitrshifts bitrshiftu bitsal bitsar bitset bitshl bitshr bittest bittst bitxor BlackmanResize Blackness BlankClip Blur Bob Cache ceil ChangeFPS Chr ChromaUDifference ChromaVDifference ColorBars ColorBarsHD ColorKeyMask ColorYUV Compare ComplementParity ConditionalFilter ConditionalReader ConditionalSelect ContinuedDenominator ContinuedNumerator ConvertAudio ConvertAudioTo16bit ConvertAudioTo24bit ConvertAudioTo32bit ConvertAudioTo8bit ConvertAudioToFloat ConvertBackToYUY2 ConvertFPS ConvertToMono ConvertToRGB ConvertToRGB24 ConvertToRGB32 ConvertToY8 ConvertToYUY2 ConvertToYV12 ConvertToYV16 ConvertToYV24 ConvertToYV411 cos cosh Crop CropBottom Default Defined DelayAudio DeleteFrame DirectShowSource Dissolve DoubleWeave DuplicateFrame Echo EnsureVBRMP3Sync Eval Exist exp FadeIn FadeIn0 FadeIn2 FadeIO FadeIO0 FadeIO2 FadeOut FadeOut0 FadeOut2 fillstr findstr FixBrokenChromaUpsampling FixLuminance FlipHorizontal FlipVertical float floor fmod frac framecount FrameEvaluate framerate frameratedenominator frameratenumerator FreezeFrame GaussResize GeneralConvolution GetChannel GetChannels GetLeftChannel GetParity GetRightChannel Grayscale Greyscale HasAudio HasVideo height Hex hexvalue Histogram HorizontalReduceBy2 ImageReader ImageSource ImageSourceAnim ImageWriter Import Info int Interleave InternalCache Invert IsAudioFloat IsAudioInt IsBool IsClip IsFieldBased IsFloat IsFrameBased IsInt IsInterleaved IsPlanar IsRGB IsRGB24 IsRGB32 IsString IsY8 IsYUV IsYUY2 IsYV12 IsYV16 IsYV24 IsYV411 KillAudio KillVideo Lanczos4Resize LanczosResize Layer lcase leftstr Letterbox Levels Limiter Load_Stdcall_Plugin LoadCPlugin LoadPlugin LoadVFAPIPlugin LoadVirtualdubPlugin log log10 Loop LumaDifference Mask MaskHS Max Merge MergeARGB MergeChannels MergeChroma MergeLuma MergeRGB MessageClip midstr Min MixAudio MonoToStereo muldiv nop Normalize Null OpenDMLSource Ord Overlay PeculiarBlend pi PixelType PointResize pow Preroll Pulldown rand ReduceBy2 ResampleAudio ResetMask Reverse revstr RGBAdjust RGBDifference RGBDifferenceFromPrevious RGBDifferenceToNext rightstr round ScriptClip ScriptDir ScriptFile ScriptName SegmentedAVISource SegmentedDirectShowSource Select SelectEven SelectEvery SelectOdd SelectRangeEvery SeparateColumns SeparateFields SeparateRows SetMemoryMax SetPlanarLegacyAlignment SetWorkingDir Sharpen ShowAlpha ShowBlue ShowFiveVersions ShowFrameNumber ShowGreen ShowRed ShowSMPTE ShowTime sign sin SincResize sinh SkewRows SpatialSoften Spline Spline16Resize Spline36Resize Spline64Resize sqrt SSRC StackHorizontal StackVertical strcmp strcmpi String strlen Subtitle Subtract SuperEQ SwapFields SwapUV tan tanh TCPServer TCPSource TemporalSoften Time TimeStretch Tone Trim Turn180 TurnLeft TurnRight Tweak ucase UDifferenceFromPrevious UDifferenceToNext UnalignedSplice undefined UPlaneMax UPlaneMedian UPlaneMin UPlaneMinMaxDifference UToY UToY8 value VDifferenceFromPrevious VDifferenceToNext Version VersionNumber VersionString VerticalReduceBy2 VPlaneMax VPlaneMedian VPlaneMin VPlaneMinMaxDifference VToY VToY8 WAVSource Weave WeaveColumns WeaveRows width WriteFile WriteFileEnd WriteFileIf WriteFileStart YDifferenceFromPrevious YDifferenceToNext YPlaneMax YPlaneMedian YPlaneMin YPlaneMinMaxDifference YToUV [External Functions (38)] DirectShowSource DirectShowSource_DirectShowSource MAnalyse MBlockFps MCompensate MDegrain1 MDegrain2 MDegrain3 MDepan MFlow MFlowBlur MFlowFps MFlowInter MMask MRecalculate MSCDetection MShow MSuper mvtools2_MAnalyse mvtools2_MBlockFps mvtools2_MCompensate mvtools2_MDegrain1 mvtools2_MDegrain2 mvtools2_MDegrain3 mvtools2_MDepan mvtools2_MFlow mvtools2_MFlowBlur mvtools2_MFlowFps mvtools2_MFlowInter mvtools2_MMask mvtools2_MRecalculate mvtools2_MSCDetection mvtools2_MShow mvtools2_MSuper TCPDeliver_TCPServer TCPDeliver_TCPSource TCPServer TCPSource Code:
C:\Users\Bruce\Videos\Tools\AVISynth\plugins\DirectShowSource.dll Timestamp: 2015-04-18, 23:03:50 MD5 Hash: 329AC5DE00B2DBD479BA5C0D44E9E3FD DLL Dependencies: KERNEL32.DLL, MSVCRT.dll, ole32.dll, OLEAUT32.dll, QUARTZ.dll, USER32.dll, WINMM.dll Linker version: 6.0 Plugin version: AVS 2.6 Plugin FILEVERSION: 2.6.0.6 PRODUCTVERSION: 2.6.0.6 Language: Language Neutral Comments: Homepage: http://www.avisynth.org CompanyName: The Public FileDescription: Avisynth DirectShow Reader pluggin FileVersion: 2, 6, 0, 3 ProductVersion: 2, 6, 0, 6 InternalName: DirectShowSource 2.6.0 LegalCopyright: © 2000-2015 Ben Rudiak-Gould and others LegalTrademarks: OriginalFilename: DirectShowSource.dll PrivateBuild: ProductName: Avisynth 2.6 SpecialBuild: C:\Users\Bruce\Videos\Tools\AVISynth\plugins\mvtools2.dll Timestamp: 2011-09-19, 20:31:24 MD5 Hash: CD797449FC9ADF53A2E8BE856FEE96EF DLL Dependencies: KERNEL32.dll Linker version: 7.10 Plugin version: AVS 2.5 Plugin FILEVERSION: 2.5.0.0 PRODUCTVERSION: 2.5.0.0 Language: Process Default Language Comments: Motion estimation and compensation CompanyName: A.G.Balakhnin aka Fizick, fizick@avisynth.org.ru FileDescription: MVTools plugin for AviSynth FileVersion: 2.5.11.3 ProductVersion: 2, 5 InternalName: mvtools LegalCopyright: ©2004 Manao, ©2005 Fizick, ©2008 TSchniede under GNU GPL v2 LegalTrademarks: OriginalFilename: mvtools.dll PrivateBuild: ProductName: mvtools SpecialBuild: C:\Users\Bruce\Videos\Tools\AVISynth\plugins\TCPDeliver.dll Timestamp: 2015-04-18, 23:04:06 MD5 Hash: 089598CAF1180644C34A9E77AF0D28AF DLL Dependencies: KERNEL32.DLL, ADVAPI32.dll, COMCTL32.dll, comdlg32.dll, GDI32.dll, SHELL32.dll, USER32.dll, WINSPOOL.DRV, WS2_32.dll Linker version: 6.0 Plugin version: AVS 2.6 Plugin FILEVERSION: 2.6.0.6 PRODUCTVERSION: 2.6.0.6 Language: Language Neutral Comments: Homepage: http://www.avisynth.org CompanyName: avisynth.org FileDescription: Avisynth TCPDeliver pluggin FileVersion: 2, 6, 0, 7 ProductVersion: 2, 6, 0, 6 InternalName: TCPDeliver LegalCopyright: © 2004-2015, Klaus Post. LegalTrademarks: Released under GPL. OriginalFilename: TCPDeliver.dll PrivateBuild: ProductName: AviSynth 2.6 TCPDeliver SpecialBuild: |
16th March 2016, 16:49 | #4998 | Link |
With all the plugins back in the plugins folder.
C:\Users\Bruce\Videos\Tools\AVISynth\plugins\autolevels.dll Timestamp: 2016-03-01, 01:27:40 MD5 Hash: 46A7EE625C13A6F07E94CB611D0D00D9 DLL Dependencies: KERNEL32.dll Linker version: 10.0 Plugin version: AVS 2.5 Plugin No VersionInfo available C:\Users\Bruce\Videos\Tools\AVISynth\plugins\deflicker.dll Timestamp: 2016-03-01, 01:27:56 MD5 Hash: 806B0DB4249D125A98C44E9B276BA278 DLL Dependencies: KERNEL32.dll Linker version: 7.10 Plugin version: AVS 2.5 Plugin No VersionInfo available C:\Users\Bruce\Videos\Tools\AVISynth\plugins\DePan.dll Timestamp: 2016-03-01, 01:28:05 MD5 Hash: 4B439F3D5841CD3D0855CCB4A0B3CBD9 DLL Dependencies: KERNEL32.dll Linker version: 7.10 Plugin version: AVS 2.5 Plugin FILEVERSION: 1.10.0.0 PRODUCTVERSION: 1.10.0.0 Language: English (United States) Comments: Compensate and stabilize global motion (pan, zoom) CompanyName: A.G.Balakhnin aka Fizick, http://avisynth.org.ru FileDescription: Global motion compensation plugin for Avisynth 2.5 FileVersion: 1, 10, 0, 0 ProductVersion: 1, 10, 0, 0 InternalName: DePan LegalCopyright: Copyright © 2004-2007,A.G.Balakhnin aka Fizick, bag@hotmail.ru LegalTrademarks: OriginalFilename: DePan.dll PrivateBuild: ProductName: DePan SpecialBuild: C:\Users\Bruce\Videos\Tools\AVISynth\plugins\DePanEstimate.dll Timestamp: 2016-03-01, 01:28:11 MD5 Hash: 2D29FE256E23204EF7E6BFCF1B48C9EB DLL Dependencies: KERNEL32.dll Linker version: 7.10 Plugin version: AVS 2.5 Plugin FILEVERSION: 1.9.2.0 PRODUCTVERSION: 1.9.2.0 Language: English (United States) Comments: Estimate global motion (pan, zoom) CompanyName: A.G.Balakhnin aka Fizick, http://avisynth.org.ru FileDescription: Global motion estimation plugin for Avisynth 2.5 FileVersion: 1, 9, 2, 0 ProductVersion: 1, 9, 2, 0 InternalName: DePanEstimate LegalCopyright: Copyright © 2004-2007,A.G.Balakhnin aka Fizick, bag@hotmail.ru LegalTrademarks: OriginalFilename: DePanEstimate.dll PrivateBuild: ProductName: DePanEstimate SpecialBuild: C:\Users\Bruce\Videos\Tools\AVISynth\plugins\DirectShowSource.dll Timestamp: 2015-04-18, 23:03:50 MD5 Hash: 329AC5DE00B2DBD479BA5C0D44E9E3FD DLL Dependencies: KERNEL32.DLL, MSVCRT.dll, ole32.dll, OLEAUT32.dll, QUARTZ.dll, USER32.dll, WINMM.dll Linker version: 6.0 Plugin version: AVS 2.6 Plugin FILEVERSION: 2.6.0.6 PRODUCTVERSION: 2.6.0.6 Language: Language Neutral Comments: Homepage: http://www.avisynth.org CompanyName: The Public FileDescription: Avisynth DirectShow Reader pluggin FileVersion: 2, 6, 0, 3 ProductVersion: 2, 6, 0, 6 InternalName: DirectShowSource 2.6.0 LegalCopyright: © 2000-2015 Ben Rudiak-Gould and others LegalTrademarks: OriginalFilename: DirectShowSource.dll PrivateBuild: ProductName: Avisynth 2.6 SpecialBuild: C:\Users\Bruce\Videos\Tools\AVISynth\plugins\fft3dfilter.dll Timestamp: 2016-03-01, 01:28:18 MD5 Hash: 2DDD22752BBAF5943A4B208AEFCD9E93 DLL Dependencies: USER32.dll, KERNEL32.dll Linker version: 7.10 Plugin version: AVS 2.5 Plugin FILEVERSION: 2.1.1.0 PRODUCTVERSION: 2.1.1.0 Language: Language Neutral Comments: Frequency Domain filter. Uses external FFTW3.DLL library. CompanyName: A.G.Balakhnin aka Fizick, bag@hotmail.ru, http://avisynth.org.ru FileDescription: FFT3DFilter plugin for Avisynth 2.5 FileVersion: 2, 1, 1, 0 ProductVersion: 2, 1, 1, 0 InternalName: FFT3DFilter LegalCopyright: Copyright © 2004-2006 A.G.Balakhnin LegalTrademarks: OriginalFilename: FFT3DFilter.dll PrivateBuild: ProductName: FFT3DFilter SpecialBuild: C:\Users\Bruce\Videos\Tools\AVISynth\plugins\mt_masktools.dll Timestamp: 2016-03-01, 01:28:26 MD5 Hash: B1964202E3B2DC22541F27C642AE7619 DLL Dependencies: KERNEL32.dll Linker version: 7.10 Plugin version: AVS 2.5 Plugin FILEVERSION: 2.0.23.0 PRODUCTVERSION: 2.0.23.0 Language: English (United States) Comments: CompanyName: FileDescription: Masktools Dynamic Link Library FileVersion: ProductVersion: InternalName: Masktools 2.0 LegalCopyright: Copyright (C) 2005 LegalTrademarks: OriginalFilename: mt_masktools.dll PrivateBuild: ProductName: Masktools Dynamic Link Library SpecialBuild: C:\Users\Bruce\Videos\Tools\AVISynth\plugins\mvtools2.dll Timestamp: 2012-07-17, 20:37:34 MD5 Hash: 9AFD5E0AC0E329761DFCC6F98FF04566 DLL Dependencies: KERNEL32.dll Linker version: 8.0 Plugin version: AVS 2.5 Plugin FILEVERSION: 2.6.0.5 PRODUCTVERSION: 2.6.0.5 Language: Process Default Language Comments: Motion estimation and compensation CompanyName: A.G.Balakhnin aka Fizick, fizick@avisynth.org.ru FileDescription: MVTools plugin for AviSynth FileVersion: 2.6.0.5 ProductVersion: 2, 6, 0, 5 InternalName: mvtools LegalCopyright: ©2004 Manao, ©2005 Fizick, ©2008 TSchniede under GNU GPL v2 LegalTrademarks: OriginalFilename: mvtools.dll PrivateBuild: ProductName: mvtools SpecialBuild: C:\Users\Bruce\Videos\Tools\AVISynth\plugins\RemoveDirtSSE2.dll Timestamp: 2016-03-01, 01:28:41 MD5 Hash: 5BD6940938EA67A827F81560443EB3A1 DLL Dependencies: KERNEL32.dll, MSVCR71.dll Linker version: 7.10 Plugin version: AVS 2.5 Plugin No VersionInfo available C:\Users\Bruce\Videos\Tools\AVISynth\plugins\RemoveGrain.dll Timestamp: 2016-03-01, 01:28:48 MD5 Hash: 2C552F4F77186A0C0F65E862AD57E135 DLL Dependencies: MSVCR71.dll, KERNEL32.dll Linker version: 7.10 Plugin version: AVS 2.5 Plugin No VersionInfo available C:\Users\Bruce\Videos\Tools\AVISynth\plugins\RemoveGrainSSE2.dll Timestamp: 2016-03-01, 01:28:55 MD5 Hash: 97A216CE30ED7F9E4965BD41C0BAFC33 DLL Dependencies: KERNEL32.dll, MSVCR71.dll Linker version: 7.10 Plugin version: AVS 2.5 Plugin No VersionInfo available C:\Users\Bruce\Videos\Tools\AVISynth\plugins\TCPDeliver.dll Timestamp: 2015-04-18, 23:04:06 MD5 Hash: 089598CAF1180644C34A9E77AF0D28AF DLL Dependencies: KERNEL32.DLL, ADVAPI32.dll, COMCTL32.dll, comdlg32.dll, GDI32.dll, SHELL32.dll, USER32.dll, WINSPOOL.DRV, WS2_32.dll Linker version: 6.0 Plugin version: AVS 2.6 Plugin FILEVERSION: 2.6.0.6 PRODUCTVERSION: 2.6.0.6 Language: Language Neutral Comments: Homepage: http://www.avisynth.org CompanyName: avisynth.org FileDescription: Avisynth TCPDeliver pluggin FileVersion: 2, 6, 0, 7 ProductVersion: 2, 6, 0, 6 InternalName: TCPDeliver LegalCopyright: © 2004-2015, Klaus Post. LegalTrademarks: Released under GPL. OriginalFilename: TCPDeliver.dll PrivateBuild: ProductName: AviSynth 2.6 TCPDeliver SpecialBuild: C:\Users\Bruce\Videos\Tools\AVISynth\plugins\warpsharp.dll Timestamp: 2016-03-01, 01:29:16 MD5 Hash: 0844858CB65C9AB88C6705AF14306D9E DLL Dependencies: USER32.dll, MSVCP71.dll, MSVCR71.dll, ole32.dll, OLEAUT32.dll, KERNEL32.dll Linker version: 7.10 Plugin version: AVS 2.5 Plugin No VersionInfo available |
16th March 2016, 17:10 | #4999 | Link |
Let's see, maybe worth a try:
Delete these: mt_masktools.dll RemoveDirtSSE2.dll RemoveGrain.dll RemoveGrainSSE2.dll mvtools2.dll Download these: https://github.com/tp7/masktools/rel...tools2-x86.zip http://ldesoras.free.fr/src/avs/mvtools-2.6.0.5.zip https://github.com/tp7/RgTools/relea...gTools-x86.zip and put them in your autoload directory. All the plugins and .avsi files you use should be in that directory and you should therefore not need any "Loadplugin" or "Import" in your script. There are other ways to organise this but let's stick with this for now. At least you know from where plugins are loaded. Your problems are not related to megui and this is going way off topic. Maybe a moderator could move these posts starting with #5063 to a new thread. Last edited by Groucho2004; 16th March 2016 at 17:12. |
16th March 2016, 17:12 | #5000 | Link |
Another one is mt_masktools.dll , that's an older one . There used to be mt_masktools-26.dll and mt_masktools-25.dll (for avisynth 2.6.x and 2.5.x , respectively, for masktools2 a48), but those are older too. The newest one is masktools2.dll (masktools 2 beta 1) for avisynth 2.6 , I would try updating that too
http://avisynth.nl/index.php/MaskTools2 |
