19th April 2010, 01:05 | #7781 | Link | |
third: Not all players support all full backups on DVD-5/9. The one you backed up probably had Java-base menus. Either that or the disc was questionable. What did you use to burn it? For playback my recommendation is to get you hands on a Sony BDP-S360. It's very inexpensive and will play all formats. |
19th April 2010, 01:08 | #7783 | Link | |
19th April 2010, 01:10 | #7784 | Link | |
19th April 2010, 06:09 | #7786 | Link |
how did i know if it Java-base menus ?
and how i can make it work ? i use LG bluray player, to burn i use pioneer & LG , and burn with imgburn with Verbatim disc i have success using this verbatim blank and can play it smoothly in rom or player with first title can you suggest what should i do now to make it play ? Last edited by tandi; 19th April 2010 at 06:37. |
19th April 2010, 08:11 | #7787 | Link | |
@tandi
Hi! Quote:
19th April 2010, 13:19 | #7788 | Link | |
Will test it again if you say it should have been possible. ++++++++++ Retried batch mode with two conversions added. Started batch mode and I am definitely NOT able to do anything with a rightclick to the second process, which is not running yet! v 33.04 / XP Pro 32 Last edited by DK; 19th April 2010 at 13:29. |
19th April 2010, 13:43 | #7789 | Link |
If you see blocky parts, I would do a two-pass encode. But can you give me more details? What bitrate were you seeing for the subject video? I want to make sure I tweak "Automatic" so you never see a difference. "Automatic" should only select one-pass when the size/bitrate of the source is at a point where you doesn't visibly affect the encode.
19th April 2010, 13:48 | #7790 | Link | |
Just to be careful, though, I'm only assuming that this is the issue... There's also a chance it could be the format in which it was burned, the disc, or other things. I'm doing remote analysis here -- which is always dangerous. Did you burn manually, or did BD-RB send the burn directly to ImgBurn? The reason I ask is that there are some specific configuration parameters that have to be set in ImgBurn in order to make the disc work. Last edited by jdobbs; 19th April 2010 at 13:51. |
19th April 2010, 13:52 | #7791 | Link | |
19th April 2010, 18:34 | #7792 | Link | |
19th April 2010, 18:42 | #7793 | Link |
yeah it have BDMV\JAR folder
and you said ' I'm doing remote analysis here ' not understand what you mean and i burn it manually and for the first title, i use same blank disc, same burning rom and same player, but it work can you suggest what should i do ? cause i really need to make backup to BD-9 |
19th April 2010, 19:34 | #7794 | Link | |
Banned
- Source: THE_LORD_OF_THE_RINGS_THE_TWO_TOWERS - Input BD size: 37.87 GB - Approximate total content: [03:12:39.623] - Target BD size: 22.66 GB - Windows Version: 6.0 [6000] - One Pass ABR Mode enabled - Audio Settings: AC3=1 DTS=1 HD=1 Kbs=640 [06:34:44] PHASE ONE, Encoding - [06:34:44] Extracting A/V streams [VID_00022] - [06:35:01] Reencoding: VID_00022 (1 of 5) - [06:35:01] Collecting video information - Source Video: VC-1, 1920x1080 - Rate/Length: 29.970fps, 2,521 frames - [06:35:01] Reencoding: VID_00022, Pass 1 of 1 - [06:38:46] Video Encode complete - [06:38:46] Reencoding audio tracks (if req'd) - [06:38:46] Multiplexing M2TS - [06:38:54] Extracting A/V streams [VID_00040] - [06:39:16] Reencoding: VID_00040 (2 of 5) - [06:39:16] Collecting video information - Source Video: VC-1, 1920x1080 - Rate/Length: 23.976fps, 2,954 frames - [06:39:16] Reencoding: VID_00040, Pass 1 of 1 - [06:42:22] Video Encode complete - [06:42:22] Reencoding audio tracks (if req'd) - [06:42:22] Multiplexing M2TS - [06:42:29] Extracting A/V streams [VID_00009] - [06:43:03] Reencoding: VID_00009 (3 of 5) - [06:43:03] Collecting video information - Source Video: VC-1, 1920x1080 - Rate/Length: 23.976fps, 4,499 frames - [06:43:03] Reencoding: VID_00009, Pass 1 of 1 - [06:47:49] Video Encode complete - [06:47:49] Reencoding audio tracks (if req'd) - [06:47:49] Multiplexing M2TS - [06:48:00] Extracting A/V streams [VID_00021] - [06:49:14] Reencoding: VID_00021 (4 of 5) - [06:49:14] Collecting video information - Source Video: VC-1, 1920x1080 - Rate/Length: 23.976fps, 9,588 frames - [06:49:14] Reencoding: VID_00021, Pass 1 of 1 - [06:59:28] Video Encode complete - [06:59:28] Reencoding audio tracks (if req'd) - [06:59:28] Multiplexing M2TS - [06:59:56] Extracting A/V streams [VID_00005] - [08:23:21] Reencoding: VID_00005 (5 of 5) - [08:23:21] Collecting video information - Source Video: VC-1, 1920x1080 - Rate/Length: 23.976fps, 258,096 frames - Bitrate: 11,613 Kbs - [08:23:21] Reencoding: VID_00005, Pass 1 of 1 - [18:41:46] Video Encode complete - [18:41:46] Reencoding audio tracks (if req'd) - [18:41:46] Multiplexing M2TS [19:29:52]PHASE ONE complete [19:29:52]PHASE TWO - Rebuild Started - [19:29:52] Rebuilding BD file Structure [19:30:37] - Encode and Rebuild complete - WORKFILES folder removed. [19:30:37]JOB: THE_LORD_OF_THE_RINGS_THE_TWO_TOWERS finished. |
19th April 2010, 20:03 | #7797 | Link |
I don't know if this is already answered, but...
is there any way I can define a separate hard drive as "Destination Path", apart from Source Path and Working Path? This is from a 2 x 1TB 7200 RPM SATA2 Stripe 0 volume: - [10:46:58] Multiplexing M2TS - [11:11:15] Extracting A/V streams [VID_00002] About 23 minutes of multiplexing. Where as the same task is finished in about 6 minutes on a 2 x 146GB SAS 15K RPM Stipe 0 volume: TIA. |
19th April 2010, 23:22 | #7800 | Link |
Hello Jdobbs!
x264.exe crashed during conversion of this bluray: BAD_LIEUTENANT here the 1rst try: Code:
----------------------- [18:11:32] BD Rebuilder v0.33.04 (beta) - Source: FULLDISC - Input BD size: 23,28 GB - Approximate total content: [03:12:07.048] - Target BD size: 22,66 GB - Windows Version: 6.1 [7600] - One Pass ABR Mode enabled - Audio Settings: AC3=0 DTS=0 HD=1 Kbs=640 [18:11:32] PHASE ONE, Encoding - [18:11:32] Extracting A/V streams [VID_00006] - [18:11:33] Reencoding: VID_00006 (1 of 7) - [18:11:33] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 214 frames - Bitrate: 14*585 Kbs - [18:11:33] Reencoding: VID_00006, Pass 1 of 1 - Encode failed. Retrying. [18:11:58]PHASE ONE aborted by user request ----------------------- [18:15:18] BD Rebuilder v0.33.04 (beta) - Source: FULLDISC - Input BD size: 23,28 GB - Approximate total content: [03:12:07.048] - Target BD size: 22,66 GB - Windows Version: 6.1 [7600] - One Pass ABR Mode enabled - Audio Settings: AC3=0 DTS=0 HD=1 Kbs=640 [18:15:21] PHASE ONE, Encoding - [18:15:21] Extracting A/V streams [VID_00006] - [18:15:22] Reencoding: VID_00006 (1 of 7) - [18:15:22] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 214 frames - Bitrate: 14*585 Kbs - [18:15:22] Reencoding: VID_00006, Pass 1 of 1 - Encode failed. Retrying. - Encode failed. Retrying. Code:
[Status] LABEL=FULLDISC VERSION=v0.33.04 (beta) SOURCE_SIZE=24999965565 SOURCE_VIDEO_SIZE=24807383040 TARGET_SIZE=24326963200 REDUCTION=.972870884288164 RESIZE_1080=0 AUDIO_TO_KEEP=all SUBS_TO_KEEP=all BACKUP_MODE=0 MOVIEONLY_TYPE=0 QUICK=1 ENCODE_STEP=1 [00006] AUDIO=1111 PGS= M2TS_TARGET=19761016 RATE=14585 i've got this message in the inspector: Code:
----------------------- [18:19:42] BD Rebuilder v0.33.04 (beta) - Source: FULLDISC - Input BD size: 23,28 GB - Approximate total content: [03:12:07.048] - Target BD size: 22,66 GB - Windows Version: 6.1 [7600] - One Pass ABR Mode enabled - Audio Settings: AC3=0 DTS=0 HD=1 Kbs=640 [18:19:45] PHASE ONE, Encoding - [18:19:45] Extracting A/V streams [VID_00006] - [18:19:45] Reencoding: VID_00006 (1 of 7) - [18:19:45] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 214 frames - Bitrate: 14*585 Kbs - [18:19:45] Reencoding: VID_00006, Pass 1 of 1 - Encode failed. Retrying. - Encode failed. Retrying. - Reached retry limit. Aborting. - BD-Rebuilder v0.33.04 (beta) - Windows Version: 6.1 [7600] - AVISYNTH Version: 2.5.7.0, Ok - HAALI Splitter: Ok - FFDSHOW: 3326, Ok - WIN7 preferred AVC CODEC: Ok - WIN7 preferred VC-1 CODEC: Ok - WIN7 preferred MPEG2 CODEC: Ok - FFDSHOW VC-1 set to "wmv9", Ok - FFDSHOW MPEG2 set to "libavcodec": Ok - FFDSHOW AVC set to "ffmpeg-mt": Ok - X264: Wrong version found - AFTEN: Ok - FAAC: Ok - MP4BOX: Ok - WAVI: Ok - TSMUXER: Ok [18:20:54] - Failed video encode, aborted Edit: x264 --help version: x264 core:92 r1523 25ca5b0 test also x264 core: 93 r1538 bd72d46
PC; 7.5 on 7.9 (Windows Experience Rating) on the lower rating. Last edited by 8ternity; 19th April 2010 at 23:27. |
