Old 5th December 2013, 02:56   #18521  |  Link
wakko709
no nothing unique about the insistent
wakko709 is offline   Reply With Quote
Old 5th December 2013, 05:10   #18522  |  Link
wakko709
[12/04/13] BD Rebuilder v0.45.05 (beta)
[18:22:58] Source: UNDER_THE_DOME_SEASON_1_DISC_3
- Input BD size: 23.48 GB
- Approximate total content: [02:08:53.642]
- Target BD size: 22.95 GB
- Windows Version: 6.1 [7601]
[18:23:02] PHASE ONE, Encoding
- [18:23:02] Processing: VID_00000 (1 of 4)
- [18:23:02] Extracting A/V streams [VID_00000]
- [18:27:07] Reencoding video [VID_00000]
- Rate/Length: 23.976fps, 60,262 frames
- Bitrate: 19,899 Kbs
- [18:27:07] Reencoding: VID_00000, Pass 1 of 1
- [19:06:51] Video Encode complete
- [19:06:51] Processing audio tracks
- [19:06:51] Multiplexing M2TS
- [19:10:42] Processing: VID_00001 (2 of 4)
- [19:10:42] Extracting A/V streams [VID_00001]
- [19:14:42] Reencoding video [VID_00001]
- Rate/Length: 23.976fps, 59,353 frames
- Bitrate: 21,235 Kbs
- [19:14:42] Reencoding: VID_00001, Pass 1 of 1
- [19:52:55] Video Encode complete
- [19:52:55] Processing audio tracks
- [19:52:55] Multiplexing M2TS
- [19:57:41] Processing: VID_00002 (3 of 4)
- [19:57:41] Extracting A/V streams [VID_00002]
- [20:02:52] Reencoding video [VID_00002]
- [20:02:52] Keeping original video (no reencode)
- [20:02:52] Processing audio tracks
- [20:02:52] Multiplexing M2TS
- Error in attempt to multiplex: MUX_00002.meta
- Can't open file: E:\WORKFILES\VID_00002.AVS.264
[20:02:55] - Failed to build structure, aborted
- FFDSHOW: [4504], Ok
- AnyDVD settings check: Ok.
- BD Rebuilder v0.45.0.5, Ok
- X264: Ok
- AFTEN: Ok
- FAAC: Ok
- MP4BOX: Ok
- WAVI: Ok
- TSMUXER: Ok
okay I have reinstalled every the jdobbs has listed.
Old 5th December 2013, 14:00   #18523  |  Link
That doesn't make sense. I am getting no other reports of this... and it seems to be happening a lot with your setup.
Old 5th December 2013, 20:33   #18524  |  Link
omegaman7
omegaman7's Avatar
I believe I've seen that error, with a bad rip. Usually it happens after some time, not immediately. But bad rips can cause some strange behavior. Sort of like bad memory sticks can cause weird behavior.
Ahh! No video encode. It usually is an audio problem too! I'm even more likely to believe a bad rip
Old 8th December 2013, 18:13   #18525  |  Link
rysktkr
Microsoft Installer Error
I am trying to run BD Rebuilder. Each time I try and run it I get a dialog box that pops up saying "System Error Microsoft Installer Error was encountered" I am running Windows 7 and also ran the inspect script and everything seems to be installed correctly. I also ran as admin and same error.
- FFDSHOW MPEG2 set to "libmpeg2": Ok
- X264: Ok
- AFTEN: Ok
- FAAC: Ok
- MP4BOX: Ok
- WAVI: Ok
- TSMUXER: Ok
rysktkr is offline   Reply With Quote
Old 8th December 2013, 18:33   #18526  |  Link
gonca
rysktr
Does this error mention any applications. How about event viewer?
This error is not a BR_RB error, it is most likely an installation gone awry on your system.
Old 8th December 2013, 20:37   #18527  |  Link
@rysktr
That error isn't coming from BD-RB, Microsoft Installer isn't referenced in any way... I'd suggest you go to the first page of this thread and re-install everything.
Old 8th December 2013, 21:34   #18528  |  Link
wakko709
Ive tried re-installing.
Old 8th December 2013, 22:26   #18529  |  Link
wakko709
Ive tried re-installing \.
every thing except bd rebuider!
Old 9th December 2013, 00:37   #18530  |  Link
wakko709
[12/08/13] BD Rebuilder v0.45.05 (beta)
[12:36:20] Source: UNDER_THE_DOME_SEASON_1_DISC_3
[12:36:23] PHASE ONE, Encoding
- [12:36:23] Processing: VID_00000 (1 of 4)
- [12:36:23] Extracting A/V streams [VID_00000]
- [12:40:15] Reencoding video [VID_00000]
- [12:40:15] Reencoding: VID_00000, Pass 1 of 1
- [13:20:38] Video Encode complete
- [13:20:38] Processing audio tracks
- [13:20:38] Multiplexing M2TS
- [13:25:06] Processing: VID_00001 (2 of 4)
- [13:25:06] Extracting A/V streams [VID_00001]
- [13:28:50] Reencoding video [VID_00001]
- [13:28:50] Reencoding: VID_00001, Pass 1 of 1
- [14:13:29] Video Encode complete
- [14:13:29] Processing audio tracks
- [14:13:29] Multiplexing M2TS
- [14:17:15] Processing: VID_00002 (3 of 4)
- [14:17:15] Extracting A/V streams [VID_00002]
- [14:22:13] Reencoding video [VID_00002]
- [14:22:13] Keeping original video (no reencode)
- [14:22:13] Processing audio tracks
- [14:22:13] Multiplexing M2TS
[14:22:17] - Failed to build structure, aborted
- X264: Ok
- AFTEN: Ok
- FAAC: Ok
- MP4BOX: Ok
- WAVI: Ok
- TSMUXER: Ok
what now? btw i re-installed bd-rebuilder
Old 9th December 2013, 17:02   #18531  |  Link
HWK
HWK's Avatar
@wakko709 is this only disc generating this error or is it system wide.
Old 9th December 2013, 17:15   #18532  |  Link
He's reported it on at least a couple of discs (this one and TERMINATOR), but no one else is reporting it. That's what is confusing.
Old 9th December 2013, 18:28   #18533  |  Link
rysktkr
I uninstalled and reinstalled everything but I am still getting the BD Rebuilder pop-up. "System Error (with some hex number) A Microsoft Software Install error was encountered"
- X264: Ok
- AFTEN: Ok
- FAAC: Ok
- WAVI: Ok
- TSMUXER: Ok
Old 9th December 2013, 18:33   #18534  |  Link
- X264: Ok
- AFTEN: Ok
- FAAC: Ok
- WAVI: Ok
- TSMUXER: Ok
Sorry, I have no idea what is causing that, but I don't see how it could possibly a bug in BD-RB. Capture the popup box and post what it says. I have doubts that it is a "BD Rebuilder pop-up" -- more likely it is coming from the O/S.
I wouldn't be surprised if this wasn't related to antivirus software. They can cause some ridiculously hard-to-find errors.
Old 9th December 2013, 18:48   #18535  |  Link
rysktkr
Enclosed is picture of pop-up. Note I disabled my virus protection, I still see this pop-up.
Old 9th December 2013, 18:55   #18536  |  Link
Yep. That is coming from you O/S. BD-RB does not create a popup with that error message. I have no idea how/why it is being generated -- but it has nothing to do with BD-RB itself. It's possible I guess (but not probable) that is may be coming from one of the apps called by BD-RB, but I can't imagine how or which one.
Old 9th December 2013, 18:57   #18537  |  Link
rysktkr
Any ideas on how to fix this? None of my other programs are seeing this issue.
Old 9th December 2013, 19:03   #18538  |  Link
Sorry but no idea. Something is wrong with your system or setup. Does it get far enough that you have a log to post? At least then we could see if it is one specific helper app that is kicking something for the system to handle.
Old 9th December 2013, 19:24   #18539  |  Link
HWK
HWK's Avatar
Hmm, quite strange. Only way to find out what is happening is to monitor all system calls being made at kernel level. Especially for files, since they can't just delete themselves. I have Microsoft tool which can be used and then one of us or more experienced user can have look to see what is happening under the hood.
Old 9th December 2013, 19:24   #18540  |  Link
varekai
Google this
System Error &H80004023 (-2147467229).
http://forum.doom9.org/showthread.ph...44#post1623244
Maybe related?
