Old 10th November 2019, 13:49   #7181  |  Link
redbtn
redbtn's Avatar
Thank you HolyWu
Can I find somewhere information how to build x265 with gcc or clang? I tried google it, but I fail.
redbtn is offline   Reply With Quote
Old 10th November 2019, 15:53   #7182  |  Link
agressiv
Registered Loser
agressiv's Avatar
Yes, thanks HolyWu for the lavf-enabled new build! Any chance you can upload a non-upx packed EXE? Or maybe even your source and compile script?
agressiv is offline   Reply With Quote
Old 11th November 2019, 02:03   #7183  |  Link
fauxreaper
HME is nondeterministic? Using --hme hex, I got slightly different file sizes on multiple encodes with same input file and x265 config.
fauxreaper is offline   Reply With Quote
Old 11th November 2019, 05:38   #7184  |  Link
microchip8
ffx264/ffhevc author
microchip8's Avatar
--hme does not accept any parameters
--hme-search does (where you set the motion estimation algo, such as hex)
Old 13th November 2019, 16:20   #7185  |  Link
nghiabeo20
I encode my clip in 5 parts, using -ss and -t to seek to cut position. Now mkvmerge refuses to merge the file, warning that "codec private data doesn't match". After checking the encoding settings, I found that only the --numa-pool change in the first 2 file. How can I edit SPS/PPS data to fool mkvmerge into merging my files? Thanks!
nghiabeo20 is offline   Reply With Quote
Old 13th November 2019, 16:57   #7186  |  Link
MeteorRain
結城有紀
If you don't mind, join files using MP4Box on MP4s.
Other option is to strip the SEI/VPS/SPS/PPS data for part 2-5 and simply join the raw bitstream. (Stripping is optional.)
If you really want to join using mkvmerge, try using a binary editor to change the text inside SEI, however to be honest I don't think that text should make a difference.
Projects
x265 - Yuuki-Asuna-mod Download / GitHub
TS - ADTS AAC Splitter | LATM AAC Splitter | BS4K-ASS
Neo AviSynth+ filters - F3KDB | FFT3D | DFTTest | MiniDeen | Temporal Median
MeteorRain is offline   Reply With Quote
Old 13th November 2019, 21:19   #7187  |  Link
stax76
stax76's Avatar
Is the estimated file size feature an official feature or a patch? It gets requested frequently, somebody needs to make an official feature request.
Old 13th November 2019, 22:45   #7188  |  Link
sneaker_ger
I don't think mkvmerge actually refuses to append the files. It is merely displaying a warning message, saying "there may (or may not) be problems".
Old 14th November 2019, 02:53   #7189  |  Link
foxyshadis
Angel of Night
foxyshadis's Avatar
Originally Posted by K.i.N.G View Post
The danger of that is that many people/companies will use that as an excuse to apply exagerated loss of detail information and 'mask' it with some added synthetic film grain applied to give the false illusion of detail retention (while the information that 'makes sense' is gone). If you know what i mean...
Lets hope they use a good implementation that prevents this as good as possible.
How is that any different from physical film grain on actual film stock? That x264 and x265 completely neglected it because it was hard to test doesn't mean a little noise generation isn't valuable.
Old 14th November 2019, 12:46   #7190  |  Link
Barough
Barough's Avatar
x265 v3.2+15-04db2bfee5d6 (32 & 64-bit 8/10/12bit Multilib Windows Binaries) (GCC 9.2.0)
Old 14th November 2019, 13:26   #7191  |  Link
Forteen88
Herr
Is this version newer than x265-3.2.1+1?
Forteen88 is offline   Reply With Quote
Old 14th November 2019, 13:28   #7192  |  Link
Barough
Barough's Avatar
Yes it is, this is compiled from the default branch and not the stable one.
Skickat från min SM-G975F via Tapatalk
Do NOT re-post any of my Mediafire links. Download & re-host the content(s) if you want to share it somewhere else.
Old 15th November 2019, 20:51   #7193  |  Link
benwaggoner
The grain generation is often done in wrong ways that make it much harder to encode than real world grain. I especially see this in 4K and HDR, where grain gets rendered at the pixel level with SDR code values and so comes out way too bright and too fine-grained. I've seen synthetic film grain that made content impossible to encode at even vaguely acceptable quality at 40 Mbps.
We're also seeing silly amounts of film grain in restored rescans of movies. It isn't creative intent to preserve all kinds of noise that wouldn't have been visible on the perf screens and foot lamberts that the creatives actually approved the content on.
Ben Waggoner
My Compression Book
Old 15th November 2019, 20:55   #7194  |  Link
Blue_MiSfit
Derek Prestegard IRL
Blue_MiSfit's Avatar
I hear you on the remastering, Ben.
Home Alone is an astounding example of this.
Old 15th November 2019, 20:57   #7195  |  Link
benwaggoner
Also maybe try --hrd-concat if you are using HRD?
Ben Waggoner
My Compression Book
Old 15th November 2019, 22:56   #7196  |  Link
Stereodude
Watch the 4k77 UHD release of Star Wars if you want to see overdone grain. MCTD is calling its name when I build my new Zen 2 system in the next month or two.
Old 17th November 2019, 15:59   #7197  |  Link
markiemarcus
Something definitely looked off with Home Alone. The pitch of the grain was both far too fine and too bright; it didn't gel at all with the image.
I must say though, I like the way the UHD release of Predator looks and it's pretty damn grainy. It looks right to me. Was shaky film stock from the outset IIRC.
markiemarcus is offline   Reply With Quote
Old 18th November 2019, 04:07   #7198  |  Link
RanmaCanada
The original Predator, in my view, is the PERFECT example of what a transfer and remaster should look like. I'm old enough to have seen it in the cinema, and watching that 4k copy was everything I remembered. And we all know how we view the past with rose coloured glasses.
RanmaCanada is offline   Reply With Quote
Old 18th November 2019, 08:28   #7199  |  Link
Film grain ... I witnessed an attempt to preserve a sensible amount of it while trying to remove the majority that only distracts the MPEG-2 encoder of a "Kinowelt" DVD production. Source: Die Feuerzangenbowle (1944) – too much denoising, and the trees on the schoolyard look like forged of concrete.
Old 19th November 2019, 14:45   #7200  |  Link
markiemarcus
Was quite a treat to watch it again I must say. I wonder what the difference in process was, because it obviously wasn't an easy source to work with.
It's a nice encode too. I've noticed that a number of grainy UHD Blu-rays have issues from time-to-time in that regard. There are a handful of scenes in both Blade Runner and The Fog that completely fall apart. Seems inexcusable given how much space there is to play with. In the case of The Fog, the bit rate actually plummets in the affected scenes.
