28th June 2013, 18:21 | #2241 | Link |
契約者
Hi Mosu. I have a problem with windows installer.
For some reason after starting mmg it only appears after 10-15 seconds and it appears behind the active window... Also fonts in some parts of the gui changed to something ugly... Edit: basically all text that is "gray", inactive now uses bigger and uglier font (no cleartype support?) Edit2: also I am talking about English version of the gui and I'm on Japanese locale. Japanese translation never was really beautiful to begin with. File->Options takes ages to appear too. But some other dialogs, like header editor, are fine. Last edited by Keiyakusha; 28th June 2013 at 18:35. |
28th June 2013, 18:34 | #2242 | Link |
MKVToolNix author
I build against a new version of wxWidgets (the current series, 2.9.x). Unfortunately it's a lot slower than the old one, but that's something you'll have to live with for the time being, I'm afraid. The current series is going to be the new stable series 3.0.x soon enough, and I'm not willing to stay on an old series (2.8.x) indefinitely.
Latest MKVToolNix is v83.0 If I ever ask you to upload something, please use my file server. |
28th June 2013, 18:39 | #2243 | Link |
MKVToolNix author
Note that the current 6.3.0 Windows builds were done against a slightly out-of-date version of wxWidgets 2.9.x. It also contains a bug that manifests when you drag & drop a file to the "attachments" tab causing mmg to show an error message and quit/crash. I've re-built against the latest 2.9.4 which works regarding the drag & drop issue, but I haven't uploaded it yet. Instead I will try to build another version against the latest from the 2.8 series, 2.8.12, and see if that works better.
In any way expect new Windows builds soon. They'll be identical to the 6.3.0 release but built against a different wxWidgets library version as said above -- meaning they'll also use 6.3.0 and their version number, likely postfixed with "-1" in the installer/portable archive file, but not in the programs themselves.
28th June 2013, 19:36 | #2244 | Link |
MKVToolNix author
The new build against wxWidgets 2.8.12 is available now as v6.3.0-1. Drag & drop works well with it as far as I can tell. I'll keep using that version for the time being.
29th June 2013, 20:49 | #2247 | Link |
MKVToolNix author
That element is called <ChapterProcess> in mmg's XML dialect. Here's the DTD for the XML files listing all know element names.
29th June 2013, 23:28 | #2248 | Link |
Anime addict
Hi Mosu, when you refer to "unframed" that meaning it. Excuse my ignorance. T_T
Intel i7-6700K + Noctua NH-D15 + Z170A XPower G. Titanium + Kingston HyperX Savage DDR4 2x8GB + Radeon RX580 8GB DDR5 + ADATA SX8200 Pro 1 TB + Antec EDG750 80 Plus Gold Mod + Corsair 780T Graphite |
30th June 2013, 07:27 | #2249 | Link |
MKVToolNix author
AVC/h.264 video bit streams consist of NALUs. Those NALUs can either be separated by certain start codes or they can be prefixed with the NALU's length. Which it is depends on what container they're stored in (see e.g. this description); e.g. raw AVC/h.264 elementary bit streams use start codes while length fields are used when they're stored inside MP4 or Matroska.
mkvmerge has different output modules for those two. "Framed" refers to the output module that accepts tracks that already contain those length fields. For these each memory slice that's handed over to the output module contains a full field or frame (depending on interlacing, of course), meaning those memory slices don't have to be post-processed anymore. The "unframed" output module accepts bits treams that use start codes. For those each memory slice can contain pretty much anything: less than a single frame, exactly one frame or even multiple frames at once. mkvmerge has to find those start codes itself and determine the length fields to add instead.
30th June 2013, 11:31 | #2250 | Link | |
Matroska find' ich toll
but 4 childelements of the segmentinfo are missing. ChapterTranslate 2 [69][24] - * - - m * * * * A tuple of corresponding ID used by chapter codecs to represent this segment. ChapterTranslateEditionUID 3 [69][FC] - * - - u * * * * Specify an edition UID on which this correspondance applies. When not specified, it means for all editions found in the segment. ChapterTranslateCodec 3 [69][BF] * - - - u * * * * The chapter codec using this ID (0: Matroska Script, 1: DVD-menu). ChapterTranslateID 3 [69][A5] * - - - b * * * * The binary value used to represent this segment in the chapter codec data. The format depends on the ChapProcessCodecID used. could you add this elements? |
30th June 2013, 11:46 | #2251 | Link |
MKVToolNix author
For segment info files there's a separate DTD (also for tags).
30th June 2013, 12:42 | #2252 | Link | |
theoretically are all features avalible to generate a "menu.xml". mmh i will try it. |
30th June 2013, 15:34 | #2253 | Link | |
Anime addict
30th June 2013, 15:44 | #2254 | Link |
MKVToolNix author
You cannot split where there are no key frames, no matter what codec/output module.
1st July 2013, 11:39 | #2256 | Link |
brontosaurusrex
Thanks, 'You can't stop me!' is working fine on wheezy.
mkvmerge GUI question: Is it possible to disable automagical append, when opening a vob ? (I solved it by modifying the generated cli)
certain other member |
1st July 2013, 11:42 | #2257 | Link |
MKVToolNix author
No, it isn't.
1st July 2013, 13:45 | #2258 | Link |
MKVToolNix author
To elaborate. When you add a file to mmg the additionally processed files will always be added as well. If you don't want to process them you don't have to resort to the command line, though: select the file you've just added and hit the "additional parts" button. There you can remove the parts you don't want processed.
If you're OK with the command line then by all means, chose that route I just wanted to point out an alternative.
3rd July 2013, 00:30 | #2260 | Link |
hi mosu
when you have time for watching this files would be nice. this are files from dvdmenuxtractor. in the *info.xml (segmentinfo) are elements of <chapterTranslate> but they will not shown in the mmg's Header Editor. mmg mux this file without issues. the *menu.xml (chapters) has a complex structure(DVD-structure) but mmg mux this file without issues. We may now assume that generates mkv has a dvd-strucure inside. but the videos dont play well. i have tested Haali, LAV, AV Splitter and MPC- internal splitter. im sure the problem are the splitters. but maybe mkvmerge is the problem. i hope you can say that with mkvmerge is all right. ( and then i hope LAV or void(AV Splitter) will add this feature to her splitter^^) in one of the zips you will find a *.btn file. can you explain me what it is? mmg mux it well too. hubble |
