Old 29th January 2016, 16:53   #3541  |  Link
Klaus1189
Originally Posted by FDisk80 View Post
I think he means to watch in true 10bit mode.
You got it.
Originally Posted by v0lt View Post
I think there may be information -> http://forum.doom9.org/showthread.php?t=172128
Thank you, v0lt. What do I need to use EVR-CP to get 10 bit per color playback?
- Windows 10 -> to get 10 bit per color without D3D-Fullscreen mode?
- Monitor or TV which does support 10 bit color depth?
- any special settings?
Old 29th January 2016, 17:30   #3542  |  Link
[QUOTE=Klaus1189;1755252]Thank you, v0lt. What do I need to use EVR-CP to get 10 bit per color playback?
you need FSE there is no way around to get 10 bit to the GPU.
you need one of those to display it the change isn't exclusive made for it.
depends on the GPU and the GPU driver settings.
Old 29th January 2016, 21:10   #3543  |  Link
Klaus1189
Sorry, I don't get that. Can you please explain me that a bit more precise?
Old 29th January 2016, 22:15   #3544  |  Link
Anima123
Windows mode doesn't support 10 bit playback, only FSE does.
Anima123 is offline   Reply With Quote
Old 30th January 2016, 00:13   #3545  |  Link
xiringu
Everytime I stream a youtube video, playback stops before the real ending of the video. Timers on the bottom right corner show the end of the video, but it's not. It ends like the video is corrupt or incomplete.
It's been happening for a few days/weeks, and I can't remember when it started. I tried build 1146 and it's not working properly.
xiringu is offline   Reply With Quote
Old 30th January 2016, 09:22   #3546  |  Link
Klaus1189
FSE is in madvr settings,right? So is it not possible to get 10 bit on Windows 10 with EVR CP? I thought it is possible ...
Old 30th January 2016, 10:21   #3547  |  Link
EVR has FSE too.
Old 30th January 2016, 10:24   #3548  |  Link
Klaus1189
OK. Do I need any special settings to use EVR-CP for true 10 bit playback?
Old 30th January 2016, 11:31   #3549  |  Link
yes FSE (d3d fullscreen)
don't forget the 10 bit display.
if you have an professional photo monitor you may have one.
and 10 bit output may not work properly too.
they added p010 INPUT support. the renderer could easily downsample to 8 bit at some point. this should easily happen with DXVA2 scaling.
Old 31st January 2016, 14:58   #3550  |  Link
Tiduz
Whenever i install MPC BE my quick access to pinned folders doesnt work, and sometimes it freezes my whole pc, anyone else expierence this at all? Never used to have any problems, im using a R9 390 with the latest amd drivers if that helps. as soon as i uninstall mpc be my quick access works again in pinned taskbar.
edit: and using Windows 10
edit2: It seems not enabling the custom icons during install helped, hopefully.
Tiduz is offline   Reply With Quote
Old 3rd February 2016, 12:49   #3551  |  Link
combucha
Hi
1) How to force MPC-BE to play video on start with window size matched to 100% video size? Every video I open is played in small window (dafault player size). I think tried all combinations from player menu, resetting mpc and nothing.
2) Some yt videos can't be rendered at all, for ex: https://www.youtube.com/watch?v=_A5OdIdLYJI
Why?
combucha is offline   Reply With Quote
Old 5th February 2016, 01:53   #3552  |  Link
hdboy
I did not understand what the problem is.
I have a sound bar with optical input. It can only handle Dolby and dts. So I use the internal mpc audio decoder, ac3 encoding option, and wasapi renderer to convert dts-hd and truehd audio into spdif bit stream for the sound bar. This works fine except with some truehd audio streams, where I get massive frame drops if I select sync video to audio or garbled sound if I select sync audio to video.
As far as I can tell, what the problematic audios have in common is a greater than 48khz sample rate. Is this a known limit? MPCBE's cpu usage is only 12%, so it's not overloading my cpu. It's not a huge deal since there's usually an alternative lo res audio stream, but I like to figure it out.
Win 7 x64, AMD Phenom II X6 1075T, nvidia 430GT, mpc-be x86
hdboy is offline   Reply With Quote
Old 5th February 2016, 04:35   #3553  |  Link
Aleksoid1978
Aleksoid1978's Avatar
Can you upload short sample file with TrueHD problematic stream, I check at my home A/V receiver.
Old 7th February 2016, 20:08   #3554  |  Link
arrgh
Hi
on the Shark007 Homepage one can see the following message for the "Shark Codecs" :
"Current releases introduce 3D MVC decoding within MKV Containers"
"When the 3D decoder is active, LAV Video will report, Active Decoder: msdk mvc"
...will this open the option to playback MVC coded MKVs in MPC-BE ?
thanks
arrgh is offline   Reply With Quote
Old 7th February 2016, 20:39   #3555  |  Link
Shark007
Shark007's Avatar
Originally Posted by arrgh View Post
Hi
thanks
On my Tools page, I release pre-configured versions of MPC-BE for use when installing my codec package. If you were to use a current version of my codec package and a player downloaded from my Tools page that includes madVR, it would work with 3D MVC MKV files without any further configuration.
Shark007 is offline   Reply With Quote
Old 8th February 2016, 05:16   #3556  |  Link
hdboy
Sorry, I've been sick with flu
I uploaded a clip (81M)
http://www.filedropper.com/truehd96
In MPC audio decoder, please disable TrueHD bitstreaming and enable AC3 encoding because that is what needs to be tested.
Old 8th February 2016, 16:56   #3557  |  Link
v0lt
Provide samples to see.
Old 9th February 2016, 11:03   #3558  |  Link
Aleksoid1978
Thanks - fixed.
Old 10th February 2016, 02:54   #3559  |  Link
RY
Bug
Found what the cause was can you fix this?
msacm.vorbis makes mpc-be x64 crash on launch
it's used by FL Studio 64-Bit to play Vorbis Ogg files
if I disable the codec using sysinternals autoruns mpc-be works fine hope you can fix this.
RY is offline   Reply With Quote
Old 10th February 2016, 03:02   #3560  |  Link
Time to release 1.4.6? Also could you update SVN repository link on OP please? It's no longer up to date.
