28th June 2019, 02:58 | #581 | Link | |
LoadPlugin("C:\Staxrip.2.0.2.4.x64\Apps\dgdecnv2053\DGDecodeNV.dll") DGSource("C:\The Matrix 2160p_temp\The Matrix 2160p.dgi") DGHDRtoSDR(impl="255",tm=1.0,fulldepth=true,light=300,gamma=0.42,r=1.0,g=1.0,b=1.15) https://imgur.com/a/tqpbMLS |
28th June 2019, 03:23 | #582 | Link |
@MrBrownCow
To copy the error to the clipboard you can click on the preview which shows an error message box that has a copy button. I think fulldepth is a parameter in DGSource.
28th June 2019, 03:34 | #583 | Link | |
DGHDRtoSDR: input must be CS_YUV420P16 (C:\Movies\The Matrix 2160p_temp\The Matrix 2160p.avs, line 4) |
28th June 2019, 03:42 | #584 | Link |
I think you have to move the fulldepth parameter.
DGSource("C:\The Matrix 2160p_temp\The Matrix 2160p.dgi", fulldepth=true) DGHDRtoSDR(impl="255",tm=1.0,fulldepth=true,light=300,gamma=0.42,r=1.0,g=1.0,b=1.15)
28th June 2019, 05:28 | #586 | Link | |
LoadPlugin("C:\Staxrip.2.0.2.4.x64\Apps\dgdecnv2053\DGDecodeNV.dll") DGSource("C:\Movies\The_Matrix_2160p_temp\The_Matrix_2160p.dgi", fulldepth=true) DGDenoise() DGHDRtoSDR(impl="255",tm=1.0,light=300,gamma=0.42,r=1.0,g=1.0,b=1.15) TY! |
28th June 2019, 13:29 | #587 | Link |
Useful n00b
Did you read the document?
If you want DGHDRtoSDR to output 8 bit (YV12) then omit fulldepth or include fulldepth=false. If you want YUV420P16 output then include fulldepth=true. DGSource must always have fulldepth=true when using DGHDRtoSDR after it. |
29th June 2019, 12:59 | #589 | Link |
Just try it and if it's not working or anything is unclear then post a full log file on pastebin.
29th June 2019, 21:31 | #590 | Link |
If @Videoh is reading this. There seems to be a small issue with DGIndexNV(Can't really Upload the Sample). I can Post the metadata if needed. It's not parse some mp4 formats. I believe it was mp42 format(id MediaiInfo Lists). The video was not mine, It was Encoded by HandBrake(aka ffmpeg). It would not open the file. My mp4 created files seem to fine.
1st July 2019, 00:27 | #592 | Link | |
Not sure you can do anything, I was more looking for if you knew if the tool has support for mp42?
If it helps I can pull out the Encoding Settings from the Metadata. Here: Quote:
AVC Form: avcC x264 Core 65. Framerate: VFR (This could where the issue is at. Not sure why VFR Exists in lower resolutions.) |
1st July 2019, 00:44 | #593 | Link |
I hope the speed increase you talked about is right. I just spent 30 hours for just one file.
So how to install 2.0.2.4? First I don't understand the two version framework 4.7 and 4.8. It's what framework? Should we extract the content of the 4.8 and put it in the root? It's with 4.8 that you see double speed increase? |
1st July 2019, 06:11 | #594 | Link | |
Install the version you want and then download the 2.0.2.4 version of staxrip. |
1st July 2019, 21:09 | #596 | Link |
I have Win10 1903 and Framework 4.8. I installed StaxRip 2.0.2.4 4.8 and here are my findings.
First it didn't work. The system cannot find the file specified File: ffmsindex.exe. In the log the command is ffmsindex.exe Z:\New\test.mkv Z:\New\test_temp\test.ffindex. It does not have the absolute path. After solving that I found these results. x265 1080p SDR encoding is faster. x265 2160p HDR encoding is slower. I give more details in a post below. |
1st July 2019, 21:19 | #597 | Link |
I used the same files for each resolution.
1920 x 1080 - SDR - CRF-22 StaxRip 2.0.2.0 - (18.33 fps), 1835.77 kb/s StaxRip 2.0.2.4 - (22.74 fps), 1737.10 kb/s 3840x2160 - HDR - CRF-23 StaxRip 2.0.2.0 - (1.80 fps), 45412.83 kb/s StaxRip 2.0.2.4 - (1.72 fps), 44538.53 kb/s In both cases the file size is a little smaller. In the second case I don't understand why it is slower when the first case is faster. I don't know if it's because it's 4K or HDR and how come that 1080P SDR is faster. |
2nd July 2019, 02:42 | #598 | Link | |
2nd July 2019, 09:27 | #599 | Link | |
aac, hdr, hevc, nvenc, staxrip, x264, x265 |
